2. can and modules to activate, but it is not the first month
3. for reviews BJ first (free) version is enough to Shay peeled home used to sit on it. However the same effect often occurs such as from regular drive Patrushev, and many other techniques, although the nature of the effect will be several from different sides called.
BJ will cut unnecessary activity relations and will fill the shortage of energy, which causes some lethargy (reluctance to go to the targets).
you need to wear on the hand. the appearance is different. if the appearance bothers You then the problem is not yet very worried
