Give advice
Прохожий
Re: Side effects ABC
Post by Прохожий » Wed Jun 06, 2012 15:44
Thanks for the reply :) Still would love to know your opinion about that:how makes sense to practice NABLYUDATELYA when working with sessions"r".It is POSSIBLE it is certainly possible and even necessary! :ay Can you say trying to be in this state during the session if you say so ON their own INITIATIVE, it is not always derivatise as much as necessary.Alternatively, but only if there is an exact confidence that you are not schem is not identified and you're just an observer not involved in the process.That is, if I understand correctly the technique of elaboration of negative and called it"Gliding"if I'm not mistaken.Thanks in advance for your answer.
Has thanked: 5 times
Been thanked: 8 times
Post by Воффка » Wed Jun 06, 2012 15:53
Preferably before any, depends on how much and what kind of water do You drink during the day. Recommendations with cups of water as I realized this srednestan. citizen means a shortage of water for life is present. If You consume 1.5-2 liters of good clean water a day, in front of the standard sessions in the Navigator separately to pass the Cup is not critical.
I for example regularly and drink a lot of water from BSL, so before the Explorer drink half a Cup or less, because if the glass drink it all in 15 minutes outside asked. Something I went into the jungle, the question about the standard of the session was :)
Post by Андрей Патрушев » Wed Jun 06, 2012 16:06
Passer-by
"Practice observer" for the alpha sessions optimally. It does not have to "worry" how is it You get noticed, being distracted, just gently return to it without anger or any other emotion.
Has thanked: 31 times
Been thanked: 129 times
Post by к-13 » Wed Jun 06, 2012 17:40
A passer-by, read a book, Jose Silva, "You the healer", You will be more clear about the possibilities alpha state. I, for example, alpha can for a week or two the scar to reduce...
Прохожий
Post by Прохожий » Wed Jun 06, 2012 17:58
Good day!An enormous thank you must acquire this book! :)
Прохожий
Post by Прохожий » Wed Jun 06, 2012 18:27
Andrew I have a question for you though not quite in the topic would you say your opinion about my EEG data.Very much alarmed I the doctor's words after I told him that I had 10 days doing the alpha relaxation in MM.And he said this:"You are the alpha doing?Commendable,commendable,well now you know how healthy sprouts,because the overall picture is very gloomy."I like myself understand that I have a severe fabiny neurosis but I would like still to hear your opinion.I will be very grateful to you,here's a brief conclusion:Foci of pathological activity and epileptic foci were identified,revealed changes in the background activity of a regulatory nature in the form of mild disorganization and deformation of the alpha rhythm.Background-there is MUCH disorganized alpha activity in the form of separate waves of low amplitude low index(17%),most pronounced in the left parietal region.The modulation amplitude do not exist.Betta activeness PREDOMINATES in the form of waves height.index(40%)and 1 betta(30%)betta 2,high purity(21Гц),non-localized.Theta activity in the past month(11%)of low amplitude,non-localized.On the background polymorphic activity is dominated by Delta activity in the form of individual waves with frequency of 3 Hz,low amplitude,index(6%),most pronounced in the occipital-parietal-Central and prednisolnoe areas.And I had appointed Glycine.Can it be COMBINED with MM,although here and talking with people I realized that many people do drink IT(for 10pcs)just for prevention in the processing of STRONG negative if POPs up.Well I today after alpha took two tablets(as the doctor prescribed), but I must say don'T lie longing was much less thoughts are clear and sensible,but still would like to know your opinion as I HAVE to drink it.The doctors told me that the preparation included the Samyang acid produced by the body for normal operation.Well, for all said to thank the neurologist who prescribed me Phenotropil this course then how can I DO a single day is impossible,and I drank 6 months in total.Thanks in advance for your answer!!! :)<
Post by Андрей Патрушев » Thu Jun 07, 2012 13:18
Passer-by
I'm not a diagnostician. :? But, as a whole, not so bad (conclusion, some contradictory). 8) Glycine can be combined with the AVS without restrictions. Alpha activity is still well restore drugs Ginkgo Biloba which also go well with AVS. But You about taking GB be sure to consult with your doctor.
Прохожий
Post by Прохожий » Thu Jun 07, 2012 15:03
Good day!Thanks for the reply. :) Though you are not a Clinician, I was interested to know your opinion.Very pleased about glycine directly from the soul stone! :D
Re:
Post by Андрей Патрушев » Thu Jun 07, 2012 18:37
Алекс711 wrote:znachok-to nashel, no otkrivaetsya kakoi-to nabor predlozhenii bessvyaznii ... tam gde zh ssilka dlya teleportpro?
Алекс711
It was a link to subscribe to the news feed, not the teleport. For some reason it also removed...
Прохожий
Re: Main mistake beginners.
Post by Прохожий » Fri Jun 08, 2012 20:02
Good day Andrew!I conducted an interesting experiment.Remembering that you have written to me about STRENGTHENING emotions,I decided to go to session letting her mind be informed in the negative as he wishes.The effect was stunning, from simple trivial ABSOLUTELY stupid fears I nearly went nuts waiting until three hours to REPROGRAMMED itself BACK.I just hollowed the images that I was allowed to rise during the session,and it was FAR from the worst thoughts so EASY middling.But what is most interesting NOT help me even a WELL mastered the technique of stopping VD.Yes, there was no thought but everything inside was RAGING and raging it is in the area of the three lower chakras,failing to get to Anahata.That is my EMOTIONAL-astral world JUST ignored all my mental calls for calm.Did not help and glycine.Three hours later I was session in which I described how all THESE fears just disappeared,and not with the mind but rather my gut adsutil it and lo and behold at the end of the session I barely even remembered that I was tormented for three hours.The first question:If there is a strengthening emotion BECAUSE it is primarily the impact on one area of the brain which is directly connected with the ASTRAL body,because obosralsja ALL emotional.I correctly think?The second question:why in both experiments, ALL three lower chakras as if burned and filled them from the inside,although specifically I couldn't focus?And so my questions had to do with this topic, I will say this maybe you need to give more information on this issue,because I knew that I put the experiment and people will be INCLUDED in the session will allow negative in my head without giving it VALUE,because the machine is pozitsioniruetsya like crazy!And get this effect.What thinking time for the mind then he is now with the help of the mind and get rid of bad thoughts stuck for the session.And it was not there.No course can be more sophisticated than I am a man and able to subdue the astral but it JUST will not allow it.I would be very grateful for answering my questions!
Post by Андрей Патрушев » Fri Jun 08, 2012 20:35
Passer-by
You just did not read carefully what I have written. :? During the session, all the fears pop up recycled due to, first of all, good relaxation and the optimal alpha state. You really tried to pull all that came to mind. In principle, after this experiment becomes pretty obvious that You can do with your mind all You want without there devices, so You shouldn't have waited those three hours. It was enough to raise his hand up, then abruptly lowered her palm down, to say the magic Russian word "husym" and do more worthy things... :wink:
Прохожий
Re: Give advice
Post by Прохожий » Fri Jun 08, 2012 21:58
Thanks for the reply. :) Believe me, BITTER experience I like to repeat,and then I didn't intentionally escalate IT popped into my head and I just identified myself with these thoughts.But you still have not answered my question.I would really like to know your opinion about that: does the device on the ASTRAL body?I have no doubt that the device REALLY works!It works :ay But I just want to know about it a little more.Recently stumbled in the Internet on a very interesting article about the interaction between the subtle bodies with the physical.And so it begins:"NOW when nobody somnevaetsya in what was known 5,000 years ago we asked the question how the interaction between the subtle bodies of man and his physical body!Of course it is no secret through the GENERAL control center of the brain."Generally not to bore you I will say this the main idea of the author:EACH subtle body may use any wave.More precisely the one that EIU needed at this moment.But every body has its basic driving frequency,that is where it is more frequently sends signals through the brain to the physical body.Another thing is that we don't know all the subtle relationships in these areas.So I wanted to know your opinion about that all the same contact with the astral body that occurs.Another thing that I do not advise anyone to repeat my experience.But the fact that it does not change.What do you all think on this issue there is INTERACTION?
Re: Give advice
Post by Андрей Патрушев » Fri Jun 08, 2012 22:30
Passer-by
I don't know what is the astral body... :?
Прохожий
Re: Give advice
Post by Прохожий » Fri Jun 08, 2012 23:24
:ay Thanks for the reply!By the way he writes about the fact that MM is primarily a device for training the astral and mental bodies,indeed, any brain activity is somehow connected with thoughts and costume.Well, Yes it is I myself UNDERSTOOD :D But he's sights on this as I was not to myself!Writes the following:with proper mastery of the alpha and then tettau,which according to him is the door to karmic causal level of CONSCIOUSNESS,it is possible not only from fears and phobias forever to get rid of but almost identity(Ahamkara)another new!I was just wondering your opinion:is joking or ACTUALLY using the device to reach such a level?I'm now very CAREFUL for IF I is from alpha on the astral hits on his perception of the world WHAT is POSSIBLE on the causal terms of attitude to reach where so to speak feet and rising.But in General, do you think this is in PRINCIPLE possible to achieve? :)
Re: Give advice
Post by Андрей Патрушев » Sat Jun 09, 2012 2:01
Прохожий wrote:But how do you think this is in PRINCIPLE possible to achieve?
I have no idea. :?
