the question drives to Andrei Patrushev
Hello!
Does it matter what time of day to use MM?
How many days in a row you need to use mm to get the therapeutic effect?
And about the CD, "breakthrough to creativity" which consists of 10 parts, I would like to know how to use it? Separately what that melody throughout the day, week or month? Tell me, please!
Re: question on wheels to Andrei Patrushev
Erika
With the disc Massage the Brain to work better in the first half of the day (at least, not later than 4 hours before bedtime), because otherwise there may be difficulty in falling asleep (but not necessarily).
you'd have to ask Dmitry.Алиночка wrote:about the CD, "breakthrough to creativity"
Hi Andrew! Could you give some information about how your drives? It's just sounds or affirmations or some kind of talk or what?
Iomic
Basically, it's "just the sounds" and the Conductor is something like a "little talk".
I do not know because they do not represent the principles of the flac format.Жомик wrote:And can be converted to flac. format?
Thank you.
[quote="Andrei Patrushev"]Iomic
This is exactly what I always say about the Guide: "It's not abormot and not moods, namely the Talk." The body responds to the needs of not only their own , but also the soul. The soul responds(consciousness , the subconscious and all that is there is not fizicheskogo in the body) the words that maybe no you never say. But in Explorer affected , I think , all possible situations in life in which we, for some reason ,but didn't react properly, clogged these problems and complexes themselves. The body captures it ,forming a figure, way of thinking, a pattern of behavior. The guide helps to remove blocks, clamps, work out all things not needed in the body and in consciousness.
And only you and no one else runs with your conscious , subconscious, body
. Speaking from the heart, with the Soul, about the Soul .......revealing hidden your possibilities , Your true desires and intentions ..... Only you yourself . I have him ,sorry,
went mad , bastard and will probably baldet long
Because developing , moving forward, you still make mistakes in deysvtie, judgments, the truth is less, but still. Explorer how to crack from all the problems. Once suffered netuda, so I got under it and see what the body and mind react? Yeah, that's where we have to work. Never ceases to amaze
how wisely chosen phrase in the Explorer , so everything worked okay.
LILY-P
thanks for the reply
Andrew, if you listen to all of your courses (CDs), listen to all right,listen for instructions, and no harm I hope not?
Sorry for the trouble
Another question. Is it possible to combine your CDs with the methods of EFT, BSFF?
Thank you!
Thank you!
viewtopic.php?f=22&t=2181Жомик wrote:Andrew, if you listen to all of your courses (CDs), listen to all right,listen for instructions, and no harm I hope not?
Can.Жомик wrote:Another question. Is it possible to combine your CDs with the methods of EFT, BSFF?
Jomic, well, you give)))))))))))What is the harm??????????I write to you personally that comes from using a disc. Changes of use to , and you're talking about harm - complete nonsense for sure. And read about the wheels in each subject
Guide, reviews , tips , experience, Healing.......Well, the forum is for what? For simple questions and to read ? After all, while you read the forum on the topic , you simultaneously read not only by the fact that Andrew has written or said, but other users and form their opinion about everything. And not that if I drink a bucket of water , I will die? .Of course , it could well be , and it surely will , if its all at once)))))). And discs-everything in moderation!!!!!!!!Instructions)))
what is session:
FUN.SES
MINDHEAL.SES
FUN.SES
MINDHEAL.SES
Irena
FUN.SES - for a good mood (alpha-band)
MINDHEAL.SES - Mind Healing - to get rid of obsessive thoughts.
Andrew, tell me! Before employees show up for duty with the weapons, what session they will be preferable from Your point of view?
In our system use NOVA PRO AND Navigator
Irena
So what?
So what?
Before going to use the service, and You do not recommend(((
Well, maybe something has changed since then... or You been there recently. And so, the situation is standard: any emergency - and You're washing the main culprits. Another thing, after - prevention, etc., but to our own peril...Ирэна wrote:Before taking over the service used, and You do not recommend(((
