My impression of the parlor
Good night.Question by ASD.Question regarding water and parlor.Does it matter what material is made, the container in which the water (glass,plastic,porcelain,metal,cast iron . . .) "charging" the front room?And what is the volume of water at a time and does it on time "charging"?Or is it irrelevant?
According to our observations, special effects material is not noticed. More affected by the thickness of the wall, i.e. the mass of the vessel.Раф wrote:Good night.Question by ASD.Question regarding water and parlor.Does it matter what material is made, the container in which the water (glass,plastic,porcelain,metal,cast iron . . .) "charging" the front room?And what is the volume of water at a time and does it on time "charging"?Or is it irrelevant?
The volume of water that matters and affects the restore process structure. 1-2 liters - 30-40 minutes, 5 liters for about an hour, 20 liters - a couple of hours. If the vessel is not emptied completely, then the next portion of water is converted much faster due to mixing with the previous portion of water that is already transformed.
ASD
... and why was she sealed in plastic and not just pasted on the surface ...
nepoymu what is the connection with your statement that the parlor is affected by the structuring of space and not penetrating through the physical body ... people enjoy coming to them good luck and repaired equipment and computersAccording to our observations, special effects material is not noticed. More affected by the thickness of the wall, i.e. the mass of the vessel.
you also laugh at those who repairs computers the parlor ?Димитрий wrote:lol!!!!!Гость wrote:I am glad that to him is good luck and repaired appliances and computers ... and why was she sealed in plastic and not just pasted on the surface ...
or not ... I will answer with a quote -
I'll add some more (this will confirm any competent psychologist):
The use of this lol!!!!! in the debate on the second level of understanding predlagaet author lol not only the fact of the narrowness of the point of view of the person, against whom this was said, but the fact of the intellectual superiority of a man who was able, by comparing the level with their own, to determine the fact of the narrowness.
That is, such a statement does not have any rational content, but is a way to Express the idea of his superiority and say the fool .
Me personally it's not catchy. But I regard such statements as proof of lack of arguments and unwillingness to look for them , just to play on the emotions of their sense of rightness at the expense of real right .
All kind time of day!
So, in the number of voluntary testers mystical artifact arrived-help!
Svetlitsa-super is safely moved for permanent residence in my pocket yesterday morning, ie 14.08.2009. As he listened to own sensations, but no changes in time have not found, and went home. I will only add that eve was made of the aura without the aforementioned artifact, and yesterday he after 40 minutes of wearing in the left pocket of my jeans. Pictures will post in the appropriate thread.
At night, as expected, put the Svetlitsa in the pillowcase of the pillow and, as usual before going to sleep, lay down with a book in hand, occasionally glancing at the clock. I must say that I usually start to go to sleep after 23 hours and 23:30, usually asleep, but looking at a clock that shows 20 minutes of the first understand that do not want to sleep!((( Then, not waiting for the appropriate symptoms, just set aside a book and trying to sleep that, in General, and it works. Enough sleep is restless throughout the night finally left me about 6 o'clock in the morning and had to get up to head out relaxation with Innerpulse mode r04 20 min. then got up had coffee and started the usual morning chores, listening to their own state, which, in my opinion, after such a night should not be so hot. However, feeling normal, cheerful-maybe the machine helped?-plan after normal complexes qigong and other to go to the gym and give a good exercise.
While such observations, no conclusions do not-view.
СравнивалиВы
Hi,
And tried anyone compare blankets Datchenko, and a Chamber? Understand that this is not the same thing. This refers to the increase of the life force, or call it what you want. Blanket Datchenko, the principle of operation is the same as the Orgone accumulator of Reich. Is a variant of the Kozyrev mirrors.
Жека3000,
You can believe whatever you want. On the acquisition front room is super, I have no regrets. At the time, when I had the enthusiasm to write this topic thoroughly flood. Here is how you now leave all the topics your posts are one of semantic contents, despite the title. If the inspiration to write. And now - lazy.
"The first discovery". Here and the parlor. Immediately she "discovered" I have two General problems: the presence of fear and lack of faith. Both problems stated about himself: mismatch external design of a Chamber with the one presented on the website just thrilled and even made to write a letter. Sent answer helped to understand the main thing - inside. "Works" the contents of the chamber. The fear is gone. And with it, the doubt that sent a fake. I have to admit that such a fear was. The departed fear and anxiety "opened" the way to knowledge. Wanted to get information about what's on the inside that it "works". On the website read that the inside of the chamber has a porous cellular structure with pyramids, spheres, etc. They just interact with the person with his mental body and others. That was enough to really stop wasting energy on doubt in it.
Here's a post to confirm my words about that topic sapluuna. The topic name does not read, write wherever you want.Anonymous wrote:"open First". Here and the parlor. Immediately she "discovered" I have two General problems: the presence of fear and lack of faith. Both problems stated about himself: mismatch external design of a Chamber with the one presented on the website just thrilled and even made to write a letter. Sent answer helped to understand the main thing - inside. "Works" the contents of the chamber. The fear is gone. And with it, the doubt that sent a fake. I have to admit that such a fear was. The departed fear and anxiety "opened" the way to knowledge. Wanted to get information about what's on the inside that it "works". On the website read that the inside of the chamber has a porous cellular structure with pyramids, spheres, etc. They just interact with the person with his mental body and others. That was enough to really stop wasting energy on doubt in it.
In General, flood, brothers, flood.
The impression that the effect of the Room was a temporary one, week two, and then something happened that in medicine is called "withdrawal syndrome", but not to this extent. Some time ago I made another snapshot of the aura and noticed that it became more similar to the one that was before the Chamber.
In principle, to any measure of the impact of the body it becomes addictive and I'm not surprised that this happened in the case of the Parlor from me. But continue to wear because I want to capture a larger time interval.
