Aura and drawing rooms
Александр79
Идущая вперед
Гостья
Yes like normal all...I think the excess on the aura began to redistribute,hence the imbalance...It's just in 40 min..Will take a couple weeks to make one more picture,then we can draw conclusionsИдущая вперед wrote:that's it.... it turns out that the parlor you are doing breakdowns... and the chakras are shifted from the main axis... what the crap is not a normal happening.... and how status and feelings? they have improved???
At the request and with the permission Going forward spread the results of its diagnostics BEFORE and AFTER the 30 minute holding Chamber-Super.
On the left AFTER, right BEFORE the Chamber.
Filled circles and stripes on the chart AFTER this testimony, stripes and circles with stroke, respectively, TO.
Идущая вперед
oooooooooh blaaaaaaaaa and this thing is working.... and I do not believe.....
and the energy rushing from it so I go nuts
now all the same normal human language
Svetlitsa-super is really working... if you impose on the projection of the chakras on the body - then this is the place heats up... dreams are dreams vivid and I can very well remember and recall literally poswietne dreams...
the photo shows that anahata has gone beyond the norm... didn't think of it then realized that I communicated with a very powerful energy vampire and in the morning was a stressful situation...
diagnostics allows you to determine at a particular point what happens to the body... the photo shows the breakdowns down on the foot... so... new shoes too tight
corn
- Кирилл Коротков
answering questions about the work of the GDV programs:
we shoot black and white pictures (video is also possible, but this is a separate issue), then uploaded in the GDV programs, where processing the image data, a program written by people...
the program can be found here: http://kirlian.ru/grv-soft.html
thus all that we see is mathematical model position and size of the chakras, aura, etc
right-left in the chakras, it is primarily the distribution of energy image representation
ideally, the size of the chakras should be medium to large and they should stand strictly on the Central axis, but such a living person, You will not see, because it is a state of rest or stagnation, and stagnation is death
for 15 years, we had 1 case of alignment of chakras in the Ticker - this is the man who meditates and does yoga at least 8 hours a day, in California...
- Кирилл Коротков
Идущая вперед
Kirill Korotkov
how to determine the size of the GDV chakra.... the color of the aura.... a chakra is open or closed and on how many percent of it is open? why is there in the diagram chakra go with the - and +???
and there is where the thread exploded decoding graphs? well, for example you can take the figure of demAs, for example, and decode it so it was clear th TSE tak and that all these graphs indicate
i.e. I like to wear the Svetlitsa-super is likely a half-day... then the head starts to crack from too much energy...
- Кирилл Коротков
it is necessary to define the conceptual sphere...Идущая вперед wrote:Kirill Korotkov
we work with mathematical models, so the "size" - we see and can count in pixels and percent
"openness-closedness" chakras you can watch on involvement of organs and systems of the body in a process for which this chakra is responsible, but you need to know and understand what is chakra and have a medical degree to understand what is happening in the body processes
- Анна-Виктория
These effect was observed by one person and can be noted the fact that Svetlitsa With reduced illumination where there may be serious violations still in development ie not explicit on which to work!!! (I personally Svetlitsa-already the fifth month)Идущая вперед wrote:Alexei Semenov
- Кирилл Коротков
displacement, breakdowns, and other "defects" is the reduction function, and all...Анна-Виктория wrote:These results were observed even one chelovea and Mona noted the fact that Svetlitsa With umenshaetsya glow where there may be serious violations still in development i.e. not explicitly pronounced on which to work!!! (I personally Svetlitsa-already the fifth month)Идущая вперед wrote:Alexei Semenov
it's not bad!
we look at the function and, respectively: Hyper - and hypofunction, i.e. if after the drawing rooms (or something else) area of the illumination is decreased and/or human energy redistributed, then:
1 chamber works - not bad
2 People respond, that's fine too
3 Person reacts badly - he can sell anything.
3.1. Be sure to watch out for those bodies and systems that react
4 etc., the conclusions are specific specialist, and their scope and competence depends on his education (s), so the main conclusion:
to learn more, better, more, faster
Of course, if make sure after=dueГлан wrote:And that is this possible? There have been cases? Dimas, what then? A refund?Кирилл Коротков wrote:most importantly, for such a thing as Svetlitsa - determine with the help of GDV camera as it acts in each case
ie and the fourth can't be near
- Кирилл Коротков
In this case, such a (negative wsdata), do can not happen, but this rule...Dimas wrote:Of course, if make sure after=dueГлан wrote:And that is this possible? There have been cases? Dimas, what then? A refund?Кирилл Коротков wrote:most importantly, for such a thing as Svetlitsa - determine with the help of GDV camera as it acts in each case
ie and the fourth can't be nearbut such cases were not,and frankly I think it is unlikely they can be, as based on the philosophy and concept of napravlenia,and the normalization of S. Avdeeva, this can not happen.
About you can not come close disagree. Hurt products the face of the impossible. Possible negative feelings often are not associated with negative effects of products, and with increasing sensitivity of the individual by restoring connectivity. If the growth of sensitivity ahead of the process of removing the distortion, the person starts these distortions to notice, although previously they were not taken. As an example of a possible initial short-term increased pain, and then begins to decrease.Кирилл Коротков wrote:most importantly, for such a thing as Svetlitsa - determine with the help of GDV camera as it acts in each case
ie for one person is enough for 10-15 minutes a day after work, the second must carry it with you constantly, and to the third 5 pieces in his pocket, and the fourth can't be near
However, almost everyone notices a reduction of conflict and the reduction of hassles after applying the FACE products.
And GDV method (as a wonderful research tool) of course allows you to visualize the positive effect of the products LIK. In the hands of a professional GDV allows to do real opened...
