About the parlor
Logik
I meant that kostnost thinking is that you have an opinion already before met the subject.
It would be wiser sformirovat my opinion after Dating.
While this is just a postulation that you want to cheat.
And that can't work what you don't understand - the greater your delusion.
The world is much more complicated and mnogogrannaya than models that describe it.And you immediately reject what does not fit into your model of miaopinie. Unfortunately, this is inherent in most.
Do not attribute to me what I wrote.Андрей Кабанков wrote:And what can't work what you don't understand - the greater your delusion.
This feeling rests on the complete absence of information about the parlor.Андрей Кабанков wrote:While this is just a postulation that you want to cheat.
The naukopodobny crap. what is contained on the official website and in the booklet does not stand any criticism. Well, and sales method. This is of particular mistrust. Just remember Herbalife, Ceptor, and other "subpresentation"
Okay good to argue. I'll save your energiyu for ASD. I have a lot of questions for him...
And here is the report (written at the time for ASD. Without additions and cuts) on the effects of the chamber on the water:
http://www.mindmachine.ru/infokonstruktor/report.htm
When the first day wore the parlor in my pocket I wasn't expecting anything. I just can't imagine normalization of data fields.Надежда Владимировна wrote:This effect is called "samoupravleniye prophecy"Dimas wrote:I actually can't understand HOW this thing works...!!!damn,but it works somehow,less tired he became,the calmer the soul...I'm in shock,how can you believe in all this nonsense about a chamber!?
Do not use here do not write.Логик wrote:Where now these cylinders? Panacea did not work. DemAs wrote that they did not use them. Other modestly silent. By the way, my feelings from the cylinders are the same as the demos - cylinders do not use.
For a long time stood in the corner. Not used because no special chips except the heating of the whole body did not notice. The joints I have not yet sick therefore the check was not on anything. And I really don't like the dryness of the hands after the fit. Another point strongly through the veins on his hands, too, is not a healthy thing.
For some time I began to practice working with energy. So now I have the feeling that the fits increase the number of sensations (in the early days of highly amplified). However the last two days, the amplification began to decline. Apparently your body gets used to the effects much faster than the promised 21 days.
Probably still the body gets used to the action chamber. I have never observed any greater friendliness, nor the feeling of "sweetness."
If the effect decreases, but the dreams Svetlitsa influences of capital. I already wrote about the fact that I dream of her every night lots of dreams. In the few days that I wrote nothing has changed, the dreams continue to dream. Black and white unfortunately... once again, to the parlor under my pillow the dreams I never dreamed of for months...
The principle of operation is not clear and really looks like a divorce is for suckers. Some plastic card, some bio-chips, everything works without batteries, and even some informational fields, which in the eye no one saw Svetlitsa normalizes... bullshit in General.Логик wrote:Immediately reminded of Herbalife, Ceptor, and other "subpresentation".
But it works, and the first two days actually the front room freaking out.
As an experiment, can I get a medallion or an ellipse 900 p., not too expensive. Even if noticeable the effect will be only two days as I have, it's worth it. Why? Yes, for example to personal experience to understand that there are things beyond our understanding.
Let's try to accept the fact that the chamber act on the information, field or God knows what, but in General not at the physiological level. Svetlitsa making - normalizes the information field. You can just not think of anything bad to maintain always a level condition and will probably be the same effect. However this is not easy.Андрей Патрушев wrote:From the point of view of physiology, 21 days to a permanent factor should still be an adaptation - that is, the effectiveness should be reduced to almost zero.If, for some tricky reasons, this factor does not cause adaptation, it turns out, is even worse - so this factor needs to be addictive.
At the moment I don't use the front room is already two weeks - dependence is not observed (in the worst way, nothing moved - neither health, nor the mood).
It turns out that always carry it with me just useless...
Now thinking about the physiology and 21 days. How about the following analogy. To wear the window is the same as to bathe twice a day. To clean the body cannot be used and it cannot cause dependence. But unwashed body just might cause problems. If my thinking is correct, then the Board manufacturer to wear the parlor is constantly logical.
Clearly I had problems on the information level. These problems took some energy. Svetlitsa two days I have everything put in order. Released a bunch of "extra" energy went into the production of endorphins. Two days later, the body simply slowed down energy production to the necessary minimum. Endorphins in this minimum is unfortunately not included.
I felt so good two days, I'd helped other people, I'm not being rude, I was not angry and did not feel negative emotions, I was happy (not in words, but literally) just to live... eh...
Carilo, can You work and not Perd this(sorry for renorm.Lex.) - Svetlitsa? Chet, I dragged entu room and the guys after her, I had not noticed... But then again the admins of the forum are preparing to trade these miracle normalizers can tell properly that thing... wait for the boom... and we can't stands and Mara? Huh? Somehow razvodnogo it all...
Logik
Maybe You have an extra toe still wrote?
searched around the Internet-did not find,give a reference please! 85800 is coolI Especially like the Svetlitsa-Blaga gold-or Rather, not the front room, and the price for it! 85800 RUB! Shocked For a plastic card! Not otherwise she biochip from bisalta done!
Apparently it works as written.
Aktiviziruyutsya due to the energy of the biofield. Further, the phase grid included in the bio-resonance and restore the information when the life-support systems between themselves and the whole organism with the external environment.
However, it is not clear that such a phase grating. But if you think I have a lot not clear. Yes, almost all I do not understand.
For example what is the magnetic field? It's a magnet right? Which hanging on the refrigerator And it works how? Batteries he incidentally either. However, clearly he is attracted to iron.
What is electricity? Socket at 220 volts? Or maybe the battery? Well, let the electric field rips electrons from their orbits, and drives them in an electric circuit. Then why not the magnetic field rips the electrons? Why such batteries are not magnetic or no gravity?
Or here. In school I learned about atoms and electrons. What is it? Charged particles right? Particles they are probably from something broke? And it looks like a whole if the particles in the bunch to collect and glue? And who are these particles charged? And again - what? They themselves are charged Yes. Well. And what is the charge? Why there are positive and negative particles, but there is still some neutral or even as something charged. Well, for example why not omnitele charged particles or separating? Funny huh?
Or maybe these particles have? That's just have not discovered them yet.
And gravity is that? This phenomenon is on everyone's mind, but still failed to make anti-gravity engines and use petroleum, poisoning your same air.
Another joke. Physics says that the vacuum contains an enormous amount of energy. Like as if to extract energy from a cubic centimeter of vacuum, we can boil all the oceans of the earth... However, to get the energy can not and wars for oil and resources. I can't wrap my head how in the void can be energy. What kind of nonsense... However, I believe it is quite.
And so on and so on... We by and large know nothing about what do not see or feel.
I want to add about bio-energy.
There are courses where train contactless battle. Also divorce is for suckers? That is a healthy pumped up commandos play tag huh? It seems to me the technique of non-contact fight is quite valid and it can be learned.
And my experience with sprouting grains. Why nobody is talking about why nobody is trying to tell you? Really existing fact of bio-information influence. Can one jar add with the parlor downstairs. I am sure the effect will be. I think as with the second cover. That is, together protostat whole grains and at length they will be half as two more of the control cover with the beans.<
In the booklet, which I laid out look.Dimas wrote:Logiksearched around the Internet-did not find,give a reference please! 85800 is coolI Especially like the Svetlitsa-Blaga gold-or Rather, not the front room, and the price for it! 85800 RUB! Shocked For a plastic card! Not otherwise she biochip from bisalta done!Maybe You have an extra toe still wrote?
Carilo
Carilo, duck I wrote somewhere about his miracle lemon,who started fucking to grow and turn green when I put it under the card-ellipse Svetlitsa...non-contact fight is generally a phenomenon that excites me to the core...the Way the book Trehlebova "Comuni Fenesta clear Falcon Russia" there is a very interesting description of the connection of the Cossacks and soldiers of the Japanese samurai to the power of family and what it all causes...in particular described the battle at Tsushima,if I'm not mistaken.So izuchaem all
- Владимир Никонов 2
Here are the opinions of famous people about the Parlor
http://www.mindmachine.ru/infokonstruktor/star.htm
Will soon add more.
And here are the reports
http://www.mindmachine.ru/infokonstruktor/lik.htm
Will soon add more.
Евгений Кош
And here , as they say laugh and cryЛогик wrote:Somewhere I such already read... But... remember:АСД wrote:people who start to use the products of the FACE become less predictable (calculable). They begin to control your own destiny beyond any of the prophecies
One boy rewrote the letter 10 times and had a GREAT Happiness!
In my experience tried that rewriting many times my (fully decorated intentions) very well perceived by the subconscious.
I first got OS.
Stuffed in a text file phrase for "rainbow", which was set up on the OS.
I have it on the same day happened.
Intention is a powerful thing
Eugene Kosh
You perepisali HIS intention, and in this case it's about the fact that someone feeds promises : - buy and you will have happiness
- buy just dobeshsya.
Like Stanislavsky, to shout - NEVERS!
Explained to how it works. Show me how to do this notorious "biochip". Etc etc. In General, I want specifics, not sweet promises the user a chamber increases the aura and open the third eye.
The paperwork proves nothing and is worth nothing. I wonder, do the celebrities know about his "opinion"?Никонов Владимир wrote:Here are the opinions of famous people about the Parlor
Will soon add more.
Yes...the same thing convincing. In the same furnace as the "opinions of celebrities"
Евгений Кош
In your case, you wrote about the boy and the letter, which he copied 10 timesЛогик wrote:Eugene Kosh
Everything is as it was in the price, and wrote. Svetlitsa – Blaga gold - 85800р.Dimas wrote:searched around the Internet-did not find,give a reference please! 85800 is cool Maybe You have an extra toe still wrote?
But that's not the limit. There are card Svetlitsa – Blaga brilliant. Not the prices are not specified. Apparently another zero Doris!
