Brainwave generator
Алексей-тр
Post by Алексей-тр » Thu Oct 30, 2008 17:12
Соловей wrote:Alex-Tr
About audiostrobe - bwgen calm it generates itself, it is only necessary to select "Use external goggles(AudioStrobe)", and it's the easiest and correct way to add light stimulation. In the help never mentions the release of the LPT.
On account of audiostrobe, this is the approach the author of the program was (at least I would do if I wrote the program: to devices to use my app was ready). Because in the hands of users many mind machines with the detectors audiostrobe with compact points, a sin not to take advantage of these ready-made devices.
To use these devices need to be generated in the correct location in Auditron and use ready-made functions MM for light stimulation.
The use of the parallel port, with completion points, with additional circuitry for powering points, it's a lot of quite a narrow circle of users...IMHO
Соловей wrote:[/b]
The mating scheme, the via LPT or USB with bwgen on the BWG website I found. There is a scheme for FutureMind. And scheme audiostrobe decoder for bwgen, where the signal for both eyes General. Somewhere in the forum discussed the possibility of such a connection(via LPT), I think tried to analyze DXSound buffer in the presence of a strobe signal...of course, in this barbaric way on the quality of synchronization of sound and light, however.
It is a pity that the author has ceased to accompany the program, I did not find a newer version than version 3.1.12 from BWG 02/22/2005...
On account of the use of the parallel port for the printer: in the link I posted, just like he is used to two channels, each eye separate. I therefore decided that since there are technical solutions, the program already performed this function, displayed the signals on the parallel port... you just Have to find them in the program and submit to a different port using the "primochki"...
The use of the port for the printer for me it is not acceptable for two reasons:
1. on the mainframe, it is difficult for me everytime you switch the printer connector on the connector points (comp is in recess, and each time to make the switch, it is a heroic act :roll: )
2. on my laptop I just haven't... :cry:
In the worst case you will have to use Auditron detector...
Power it will have, or from the headphones (in parallel) or from the linear output of a sound card.
By the way, maybe someone knows: is it possible for headphones to serve your Auditron, i.e. to separate right and left channels?
Соловей wrote:[/b]
About the glasses from the same site... I want to call somehow nastier, but I am too critical... Here glasses so glasses!
Success!
The score: I was referring to these points, Alexander, I think the original decision. Respect Alexander and of course Andrei Patrushev, as an ideological mastermind az .
NP.<
художник
Post by художник » Thu Oct 30, 2008 18:53
Well, in the same Adobe audizine the EQ to match the power of the strobe up to -36dB.
Andrew, thank you. Probably the simplest solution to reach the worst.
:) I went pretty winding path, but came to a curious result. Opening Bwgen Preset Option in the graphics frequency was moved to NP-2(i.e., BWG used as a cheat sheet) make a great pie. Strobe signal, configured according to one of the frequencies of exposure. Here, however, POPs up here's a question - is it possible to make a pie for Strobe? I.e. make it for each carrier and the frequency of exposure? Not too will it be? :roll:
художник
Post by художник » Thu Oct 30, 2008 19:13
And again. How do you like the idea of doing "Tricks" Monroe( BWG presets in there) on the NP-2 with AudioStrobe? :) :)
ванёкК
Post by ванёкК » Sun Nov 09, 2008 17:45
Hello...
About BWGena wanted a few questions to ask... there can be samples per second to put different to 100000 so how best to put them? is 100000? and the effect of this is what is in pure sound quality?
And rooms and dltu blocks to set by default 4 / 200 is worth everything and leave? or you can
rooms to the maximum length to a minimum?
And the screen flashes as someone wrote black-and-white set , and watch as their eyes open or need to close? 8)
There is still SBAGEN met , with a description of the professional program only che is not clear what brainwave different, to be honest compared to brainwaves full G... :?
Косинус
Post by Косинус » Sat Jun 12, 2010 18:32
In Brainwave generator it is possible to set the frequency of each channel individually.
Does the fundamental importance in a stereo channel to serve a greater frequency, and in what less?
For example, at 200 Hz the right and left 210, or Vice versa?
Волутар
Post by Волутар » Thu Aug 05, 2010 8:46
Personally, I think it has a certain value, but some of the studies on this issue have been published.
It is generally considered that without a difference - a matter of habit and variety.
Королевский Тигр
Post by Королевский Тигр » Sat Mar 12, 2011 5:52
Князевский wrote:I am new to this business and did something stupid. Worked with the program for debt, he wrote the installation is now incredibly bad. Dizzy, nauseous, and sleep when the hearing becomes aggravated by, so much so that sleep is impossible if that'll make noise.
In short, stick to the recommendations that are on the site(is) in the first two week at 15 minutes. With relaxation, preferably in a single setup. In General the brain needs to get used to, and only then to increase the impact.
Use the subject for about a week. I downloaded and installed a bunch of presets with the purchased disk set "Smart music". There are 4 record was a collection of programs. From there I took the presets. Until last night, I only listened to Schumann''s of 7.83. A few times even slept under it. As for effects - after him, or rather, after listening for more than 20 minutes (lying down with closed eyes) comes the incredible drowsiness. I caught myself even at that asleep, stretching out a hand to turn off the computer. But the next day pretty fresh. Hosted daytime sleepiness, there was some interest in the work. Yesterday I set the visual effects and upload additional presets, are now trying to determine what is responsible for what. Color visual effects put black and white (someone here recommended). More unfortunately, settings are not provided. First impressions - very different effect. Sat 40 cm from the monitor. Head is instantly turned off. After that, listen to strobe-drive (only the music) and going out again. Woke up 40 minutes later - the music was still playing. Incredible effort he forced himself to get up off the couch and went to sleep. Today as usual cheerful and contented life. Today plan to continue the experiments. Put any preset (I want to increase creativity) and watch the screen. Yesterday I after some experiments with visually a few seconds and never could in shock, did not understand where they are.
Generally, on YouTube, quite a lot of binaural file filled with simultaneous playback of a visual track, even with a lot of colors. Someone even created a channel. There are Schumann, and many other presets. However, I did not download them and watch at home, because all files there you can download either format .flv, or MP4, and I converted the formats don't trust yet, because are not expert in this area. If experts certify that the translation from one format to another does not affect the quality of the effects, then try to download some files from YouTube. About their experiments, I will write further, if the comrades don't mind.
Косинус
Post by Косинус » Fri May 06, 2011 9:35
I use BrainWave Generator to quickly relax and recover, most of it did not like very rough impact.
Made for myself here are it:
Preset 1 SOUND: Dive into a dream from wakefulness (paperback)
Very soft and smooth dive into a dream from wakefulness.
Preset you can also use a day to recover quickly.
The Sound Of A
Binaural alpha waves: 18-8.0 Hz Carrier frequency: 600-247 Hz 10 minutes
The Sound In
Voice 1 Binaural waves Theta: 8.0-3.0 Hz Carrier frequency: 247-185 Hz to 20 minutes
Voice 2 Binaural Delta waves: 4.0-1.0 Hz Carrier frequency: 110-90 Hz 10 minutes
(Active influence Binaural Delta waves: 3.0-1.0 Hz)
Preset 2 SOUND: falling asleep (deep sleep)
Slow - Delta sleep in addition to Prieto 1 "Dive into a dream from wakefulness."
Used for a deeper dive into the phase of slow sleep.
Binaural Delta waves: 3.0-1.0 Hz Carrier frequency: 90 Hz to 10 minutes
Noise 93-95 %
Sound and noise modulation, the phase is not used.
To enhance the impact of preset 2 using multiple cycles of repetition,
after preset 1 (1-2-2-2...)
It: https://yadi.sk/d/smkNJjXRfkRA5
To convert the audio file and listen on the lowest volume before going to sleep and bad sleep. Too lazy to understand ready:
mp3 files: Sleep1 and Sleep2
Терапевт
Post by Терапевт » Mon Jun 27, 2011 18:36
Does anyone know how to solve the problem on your computer is stick, to endure do not want because like. After playing preset prog kicks. Who-thread knows as it is treated?
рубен
Post by рубен » Sat Jul 02, 2011 0:41
Путешественник wrote:BWG in my opinion, very good... I'm her machine and now I often use. By the way, writing the session a pleasure and very easy, and very effective session. Don't forget that in this area, too, the rules of musical harmony (she even letter notes understand!!! :))
Please tell me so I have mindmachine glasses.
and is it necessary BWG to add and how to do? and plus what do I get ?
Терапевт
Post by Терапевт » Wed Jul 06, 2011 0:45
Me about a club who-thread answers? Whoever does not understand - I'm talking about Win7
kiawint
Re:
Post by kiawint » Wed Aug 31, 2011 20:09
Терапевт wrote:tell Me about a club who-thread answers? Whoever does not understand - I'm talking about Win7
I also had all sorts of problems with compatibility BWG and Win 7, the program kicked, then the BWG would not start and so on, but I decided this problem by install the package "Microsoft Windows XP Mode" for Windows 7 (tipo emulator Windows Xp), now I have Windows Xp in a separate window, where you can install any programs as well as launch them from the comfort of Windows 7. Running in the emulator BWG no problems at all no...
Экко
Has thanked: 2 times
Been thanked: 4 times
Re: Brainwave generator
Post by Экко » Fri Sep 09, 2011 9:26
tried this stuff, it really is not an XP emulator and virtual machine with XP installed. by functional I don't like the Virtual Box is much better, it start
ягуар
Post by ягуар » Sat Jan 07, 2012 19:26
to listen through the speakers you can?
Косинус
Re: Re:
Post by Косинус » Thu Oct 18, 2012 21:25
ягуар wrote:listen through the speakers you can?
It is possible, but more effective with headphones.
BrainWave Generator 3.1.12 Portable Rus-3.1.9 Win7 Win8
http://narod.ru/disk/51967400001.3c2975 ... 9.zip.html
нувориш
Post by нувориш » Sun Mar 10, 2013 1:21
Hello everyone. Where to throw a WAV file (which is for the background), the corresponding BWG the preset file that the program saw it?
Could you tell me the presets for the development of imagination? if there are any
Аэрофлот
Post by Аэрофлот » Sun Apr 28, 2013 12:50
Created preset "Harmonic of the Schumann resonance". Used the first 5 of the 7 harmonics.
1. Binaural wave of 7.83 Hz Carrier frequency 125,28 Hz Volume 100%
2. Wave binaural of 14.1 Hz Carrier frequency of 225.6 Hz Volume 80%
3. Binaural wave 20,3 Hz Carrier frequency 324,8 Hz Volume 60%
4. Binaural wave 26,4 Hz Carrier frequency 422,4 Hz Volume 40%
5. Binaural wave 32,4 Hz Carrier frequency 518,4 Hz Volume 20%
I used to wonder why when I go to bed, I hear the sounds of then decrease, then increase. Now I know what is that I hear the harmonics of the Schumann resonance.
This preset time is achieved the same effect.
крошкин
Post by крошкин » Thu Oct 03, 2013 20:47
Hello - after reading the topic very interested in the possibility bwg + points. I have long use the success variable with the glasses may be cooler. So I do not understand whether it is possible to collect and use these http://www.mindmachine.ru/articles/glasses.htm or should like to gather that on the website bwg
if you can then where in the laptop stick
Has thanked: 31 times
Been thanked: 129 times
Post by к-13 » Thu Oct 03, 2013 21:30
крошкин wrote:Hello - after reading the topic very interested in the possibility bwg + points. I have long use the success variable with the glasses may be cooler.
Look at neuro-programmerhe possibilities of stimulation and the efficiency higher.
крошкин wrote: So I do not understand whether it is possible to collect and use these http://www.mindmachine.ru/articles/glasses.htm or should like to gather that on the website
No, these points for MM firms photosonics (Nova, innerpulse and luma, plus some other simple work).
if you where into the laptop stick
If you have LPT or COM ports, you need to make a version for them, otherwise you'll have to collect audiostrobe decoder for LM-ke to connect to the sound card.
крошкин
Post by крошкин » Thu Oct 03, 2013 22:29
I've read that bwg need glasses with the AudioStrobe interface. Can you give a link where in you can buy online. I live in Bulgaria here to order easier. I just don't know where to look.
Post by к-13 » Thu Oct 03, 2013 22:45
You can Google "Mind Explorer AudioStrobe decoder" is almost the only coherent decoder on the market in Russia, but it seems to me easier to pay a little extra and buy innerpulse - it itself is very personal, and the decoder no prog or discs useless...
Экко
Post by Экко » Mon Jun 01, 2015 7:52
It does not work on Windows 7 and 8, and compatibility mode doesn't help
