Read. Thank you!Андрей Патрушев wrote:Go read the topic FAQ.
Classes start
увлечённая
Re: water
Water plays an important role in conducting nerve impulses. If water alone in such a heavy load as audio-visual training, the possible headaches. Water simple clean.гост wrote:On the forum many times upominanie about the use of water. What is it and why? Thirst is presented or using special water (soda, etc.) ?
The question may seem ridiculous, but it's meeting very often...
- Агент Смит
- Been thanked: 1 time
Hello everybody!
Tomorrow I meet my kit MM discs (I ordered a "Guide", "Healing on the Magic river", "Ultramesh" and "Massage of the brain"). As I understand it, we must begin with alpha sessions and listen to them for 21 days and then go to "Explorer" and other drives. Turns out like this chart:
From 1 to 21 days of alpha session MM (45 minutes total).
From 22 to 42 day - "Explorer" using MM (it is possible and without, but MM that is).
Here immediately the question session to stop these days? or have others connect? Particularly interested in the session on study in. languages and memorizing words.
43 to 64 day - "Healing" through the MM (again, what session you can listen to in this period?) Or is there needed a break in disk for 21 days? And machine no way, too?
65 to 86 day (if here again on day 21 all moves) - "Massage of the brain." Again the question: since he audiostrobe, it is necessary to listen without cars, and how to deal with sessions? To ignore or rather to reinforce them (not simultaneously of course)?
"Ultramesh" generally a separate issue, they need to listen during lessons, and when you can start listening to the tracks of this disc - after 21 days of training with the alpha sesijami or you can use it on demand? To listen better with headphones or through speakers? And when you can begin listening to the program "Star Flight" with this ROM? She's with the rest of the tracks are not connected.
I bought a set of 6 best audiostrobe discs. As I understand it, they are mostly for relaxation and contemplation. As their use is combined with the above schedule? Of course, they constantly listen to just not enough time (for the session plus drive time to find and that is hard), but sometimes you want not only loaded, but also unloaded. The rule "break three hours" I've learned, and that they work together on the contents discs and sessions? Not in the sense of "someone like", it's a matter of taste, but in terms of when we should or should not listen to them, not to reduce the effectiveness of training with sessions/discs?<
Идущая вперед
- Been thanked: 6 times
- Агент Смит
Read again (essno read before this) but never found the answer to the main question: how it is recommended to combine session and discs? The fact that every man will feel a "wave" - of course, but there is also some common experience? Well, I'll own something to improvise, besides, in the book on machine I read that you need to do only an hour a day, about this and will fit your schedule. Just don't want mangled wood, because you want all at once. Today included the alpha session and disconnected after 2 minutes, and woke up after an hour (I from lack of sleep so). Tried audiostrobe - like, very beautiful. And my wife loved it, after the session, she got up 10 minutes later and said that slept like 2 hours, although she always needs an hour and a half at least.Гость wrote:please refer to the FAQ topic. In many ways it applies to mindmachine.
Thanks for the tip, gonna give it a try at least a week or two on alpha to sit if the curiosity will not overpower. Although my issue is that I'm driving all day, and there is no way of relaxation.Идущая вперед wrote:if I wait start over I didn't bother with session alpha-improv 21 days and all sessions on relaxation and immediately started with the Explorer
Идущая вперед
the fact that to buy a mind machine I already had extensive experience in using different prog with binaural beats (in the Internet a lot of them) but mind machine compared to these prog as the elephant and the pug...
all individually feel.... feel the overdose - stop... listen and look inside yourself...
it is possible for example in the morning session evening drive (massage of the brain better not tonight... don't know who I like and then half the night I can not sleep)... and finally ceased to listen to him patamu sausage
- Агент Смит
Going forward
Yes, I too any Bwgen's Yes s MindController'dug at the time, I even Kiske is a generator of binaural beats, but most importantly, in my opinion - it's the system. Actually, hence the questions in the system to deal easier.
While "Massage brain" is far from me, so I hope to get used to that time.
1 - according to the post, digging a lot, but decent sessions dug out and write any, not learned... but in vain.Агент Смит wrote:Yes, I too any Bwgen's Yes s MindController'dug at the time, I even Kiske is a generator of binaural beats, but most importantly, in my opinion - it's the system. Actually, hence the questions in the system to deal easier.
2 - what it means to "massage brain"? it with one hand without audiostrobe (i.e., on your PDA to portray, if you can), and on the other hand is a very decent session. According to reliable rumors, there's at least one person (not me), stating that "massage brain" only-working (for him) solution (used - quote - "when my batteries are completely discharged").
In General, here, of course, need a system. And the 2nd stage (if you are serious and want more) - writing session.
It is strange that the last on the site dedicated to almost nothing (except separate posts).
- Агент Смит
Again, to grasp at writing sessions, without setting himself in the rhythm of the classroom - makes no sense, and this is the system, which I interpret from your first post in this thread. IMHO, the system, even if built on standard sessions and the finished discs can give a newbie like me support for training to become something like a coach saying to a beginner that he is doing everything right. But we'll see whether you want to do research with the sessions, or the internal mechanism has already started. After the session - not an end in itself but only a tool to achieve the goal. Besides, often the best is the enemy of the good. I know for myself that perfectionism is more of a disadvantage than advantage.
So my MM is only in the hands of the fifth day. Then, as they say, "the autopsy will tell."Гость wrote:to write any, not learned... but in vain.
This means that I would like the first "Explorer" go, then, "Healing," and then to "Massage brain" to get to. And display it on the PDA it makes no sense, the disc you already bought.Гость wrote:what does far from the "massage brain"?
So, it is the right situation -- for the next few months... And even a lot more - there is still theta... ie I think that when you have disks and machines so or approximately so be it.Агент Смит wrote:This means I would like the first "Explorer" go, then, "Healing," and then to "Massage brain" to get to. And display it on the PDA it makes no sense, the disc you already bought.
Ie, not Agent Smith, and all the guru - well, I would share experiences on "how pishitsya good session."
In a separate topic. It would be cool (fear, though, imagine how much waste there will write - well the garbage thing - removed and not...). Ie, for my taste it's really interesnee than, for example, "audiostrobe decoder your hands."
On the website there is a book that is written quite a lot...Anonymous wrote:So, it is the right situation -- for the next few months... And even a lot more - there is still theta... ie I think that when you have disks and machines so or approximately so be it.Агент Смит wrote:This means I would like the first "Explorer" go, then, "Healing," and then to "Massage brain" to get to. And display it on the PDA it makes no sense, the disc you already bought.
Well, at least there is no word about holopenichsky autofocus.Андрей Патрушев wrote:On the website there is a book that is written quite a lot...
Maybe I read bad, but also about the construction of the "Z-waves" there is also no Tae.
And about the sync of the beat with the light, just awful, see BW-gen...
But our little thing - the theme to offer. No - well, no.
Holophonics Avtopostavka on mindmachine to play impossible...Anonymous wrote:Well, at least there is no word about holopenichsky autofocus.Андрей Патрушев wrote:On the website there is a book that is written quite a lot...
Z-rhythms are reproduced with difficulty (look how long my session).
In all prog, where instead of glasses the computer screen, the overlay flashes on the scanning frequency of the image - the result is a mess.
On konkretnye questions on the sessions I try to reply...
I have no doubt. The website is of course dedicated to Majd-machines, well, and the way Your disks. Ie it would be wonderful if You ever this technology painted...Андрей Патрушев wrote:Holophonics Avtopostavka on mindmachine to play impossible...
Yeah, I learned something. Thank you!Андрей Патрушев wrote:Z-rhythms are reproduced with difficulty (look how long my session).
I agree 200% - well, not about the frequency sweep (though including) - there, and without it a lot of things that make this "technology" at best useless and even boring to list.Андрей Патрушев wrote:In all prog, where instead of glasses the computer screen, the overlay flashes on the scanning frequency of the image - the result is a mess.
Yes, I'd still naschet publish the "secrets of technology." Yes, I am, to put it mildly, aware that this ... well, at least the author nothing but a headache will not bring.
But no - there is no trial.
