Advice from Andrei Patrushev
Hello, Andrey! Acquired drives Star stranik,Music for hypnosis and self-hypnosis,Conductor,Endorphins,Massage brain,Ultra brain,Healing. Planning to start with a Guide and a Healing. I have a question about alcohol. There is a view of the state of alcoholic intoxication or the presence in the blood, known as blood alcohol to fill up more 10 days. What drinks are acceptable, because the alcohol contained in alcoholic beer and in yogurt. Thanks in advance for your answer.
There is a view of the state of alcohol intoxication.Anonymous wrote:hi Andrea! Acquired drives Star stranik,Music for hypnosis and self-hypnosis,Conductor,Endorphins,Massage brain,Ultra brain,Healing. Planning to start with a Guide and a Healing. I have a question about alcohol. There is a view of the state of alcoholic intoxication or the presence in the blood, known as blood alcohol to fill up more 10 days. What drinks are acceptable, because the alcohol contained in alcoholic beer and in yogurt. Thanks in advance for your answer.
Going - on work with the subconscious, so to speak, an ordinary man...Евгений.М wrote:Hello Andrew.I read your article,I liked it they are very competent and succinct...the Question is not if you write a book?And can expect? Thanks in advance...
Good evening, Andrew and everyone who readsАндрей Патрушев wrote:Hello, Irina
It is very difficult to answer Your questions, for that I need to become You, and it is not possible (but I don't want ). At least you embarked on the path of self-knowledge, so can only wish You good Luck on this journey.
Reiki, in my opinion, is one of the systems of self-improvement.
_________________
Thanks for the replies and wishes
Only I never understand why You're an expert with such experience and expertise can't or don't want to give answers
I just don't understand something
Sorry, maybe I don't understand something... And group (subgroup) of what?:)Иррина wrote:Good evening, Andrew and everyone who readsАндрей Патрушев wrote:Hello, Irina
_________________![]()
Thanks for the replies and wishes![]()
Only I never understand why You're an expert with such experience and expertise can't or don't want to give answers(sorry for the persistence
) And what becomes of me? It is clear that all strictly individually, but still there is the cocoa group, of the subgroup ???
Good day to all-night! Question to Andrew. On the forum there was a mention by You about a possible increase in intracranial pressure when using disk MM. This is only possible when working with this ROM or with something else (specify what). Another question, You said that if you work without mindmachine disk "Endrofin" significantly reduced efficiency. I'm going to use only headphones. In this case, it makes sense to me to work with this ROM or do You recommend to replace it with something else with similar effect. The mild depression is sometimes manifested. The other disks, as I understand it can be used successfully and without cars? Thanks in advance!
1. Perhaps, only with MM.Кисуля wrote:good day to All-night! Question to Andrew. On the forum there was a mention by You about a possible increase in intracranial pressure when using disk MM. This is only possible when working with this ROM or with something else (specify what). Another question, You said that if you work without mindmachine disk "Endrofin" significantly reduced efficiency. I'm going to use only headphones. In this case, it makes sense to me to work with this ROM or do You recommend to replace it with something else with similar effect. The mild depression is sometimes manifested. The other disks, as I understand it can be used successfully and without cars? Thanks in advance!
2. Well, replace the Endorphins Fenotropil...
3. Can.
Sorry, I probably incorrectly expressed. About "Endorphins" - is there a noticeable effect? Maybe just the result will be less pronounced and a longer time have to work with the disk (more courses to do so). Just, as I understand it, this disc is somewhat apart, not like the others, the direction of its own. Or maybe in my case it is better to take another drive, for example, "Healing."
Елена премудрая
Hi Andrew! I'm 48 years old!Long been interested in the work of the subconscious. Recently decided to buy Your CDs healing and conductor(M cars and other accessoires I don't have). At my age, a lot sluggish health problems.Read reviews of guys on the forum and think I have their problems(in the best sense of the word,remembering his youth).There are problems in the family.I listened to 3 times the disc healing,but since a lot of problems and I can't choose to install,perhaps in the morning listening to the conductor and in the evening healing? And You still tell me in my situation?
Yes, the result may be less pronounced (or maybe notКисуля wrote:I'm Sorry, I probably incorrectly expressed. About "Endorphins" - is there a noticeable effect? Maybe just the result will be less pronounced and a longer time have to work with the disk (more courses to do so). Just, as I understand it, this disc is somewhat apart, not like the others, the direction of its own. Or maybe in my case it is better to take another drive, for example, "Healing."
Here is quite interesting and useful http://www.koob.ru/xannaford/Иррина wrote:- experienceАндрей Патрушев wrote:And group (subgroup) of what?i.e. I would like to say that the results of the studies analyzed, klassificeret, etc., etc.
And maybe my case is possible to analyze and understand the cause of this asymmetry?
Please advise what can be read on this topic.
Thank you
Елена премудрая
Andrew!Thank you for your answer. 23. August, my birthday. I hope that doing your wheels,I have the chance to be transformed to this day.Buying Your CDs, I could not get them to listen. And then came the day when she had two very unpleasant events. I was literally in shock and didn't know where to start next,I'm shaking,confused thoughts. And then the thought-wheels.Frankly to say ,I didn't believe it,but got exactly what you need-I calmed down and realized that I do it right.And so it happened.And now session with a disc healing me constantly like my heart stops and I sigh very hard and so the whole session. Is this normal?
Yes, it is quite normal (gradually to be). And You also learn to let go of heavy thoughts http://www.koob.ru/dwoskin/or(and) master the state of inner laughter http://www.koob.ru/kurlov/Елена премудрая wrote:Andrew!Thank you for your answer. 23. August, my birthday. I hope that doing your wheels,I have the chance to be transformed to this day.Buying Your CDs, I could not get them to listen. And then came the day when she had two very unpleasant events. I was literally in shock and didn't know where to start next,I'm shaking,confused thoughts. And then the thought-wheels.Frankly to say ,I didn't believe it,but got exactly what you need-I calmed down and realized that I do it right.And so it happened.And now session with a disc healing me constantly like my heart stops and I sigh very hard and so the whole session. Is this normal?
Вадим1
Вадим1
Hello!Вадим1 wrote:Good day! Question to Andrew.
Constantly are driving cars. Somewhere slipped the idea that there is a drive to prevent fatigue and prealablement. Listen to and sleep driving are gone. Sorry if asked wrong. Thank you
At night - Healing in the morning of the 2nd track Star Wanderer.
