The effect of theta Sisi and disc
Идущая вперед
- Been thanked: 6 times
Идущая вперед
we are talking about the same disk IN the DIRECTORY of the WEBSITE-SECTION AUDIOSTROBE-13 TOP DRIVE-ELECTRONIC SCAN of the BRAIN well tryndets what a super disk for it, I scored the Explorer and the solar wind and use it every day (alpha on the basis of the waves of the ocean) theta finally the tale can not describe....
and escho drive Compassion where whales and dolphins identity is awesome... theta disk scan of the brain is the most powerful for me out of all the other drives programs and sessions
Mercy, understood. And here's a slightly provocative question arose: in Germany, this disc is in the retail 18 Euro, and in Moscow - 200 rubles, that is, four times less. I'm not against illegal copying, but I understood that when you copy audiostrobe disc lost essential information. I understand that I then hardly anyone will openly say that, well, Yes, of unlicensed copies. But how do you know exactly what you are buying is not a copy and the original - don't know...
All perfectly legal - ROMs are manufactured under license from Andrzej. Just the level of income in different countries are different, and therefore prices too.Триалект wrote:mercy, understood. And here's a slightly provocative question arose: in Germany, this disc is in the retail 18 Euro, and in Moscow - 200 rubles, that is, four times less. I'm not against illegal copying, but I understood that when you copy audiostrobe disc lost essential information. I understand that I then hardly anyone will openly say that, well, Yes, of unlicensed copies. But how do you know exactly what you are buying is not a copy and the original - don't know...
the disks are - check for yourself... you can safely order the Albus - not a fake.... and if about theta it is better to buy the entire series theta meditation (concentration, deconcentration, etc.) well then to not be excruciatingly painful....
and then I have 2 pieces from the series - initially not acted theta finally did... but after 2-3 weeks of everyday use soooo flooded
going forward
going forward
Came drive "Brain-Scan Programs" which "Electronic scan" is called in Russian, I listened to the second track (alpha) - like. During relaxation periodically had a very short heartbeat, one to three blows to his chest from the inside, then again silence. Not understood just as it is with alpha and theta, EVE how many days is recommended to drive the alpha before you start the Board with this drive? Or they can be one day to listen to?
It can be anything, but whatever it is, it always leads to improvement.Anonymous wrote:Good Day Everyone. When listening to the Theta sessions to MM. Heat up the Palm and even more why it heated the knees, and the feeling that now to get the burn. After all, the idea is to warm up the feet, not the knees. Tell me, it is a muscle clamp or something else?
it is the energy - prana - the life force starts to go to the body and punches... and you don't have arthrosis or arthritis? when you climb the ladder you have to strain and hurt your knees?Гость wrote:Good Afternoon, Everyone. When listening to the Theta sessions to MM. Heat up the Palm and even more why it heated the knees, and the feeling that now to get the burn. After all, the idea is to warm up the feet, not the knees. Tell me, it is a muscle clamp or something else?
just an altered state of consciousness increase the amount of energy in the body... cleaned the channels, respectively, and long-standing adhesions.... cleaned the chakras...
in the feet tingling is? in the middle of the foot and the middle of the palm are very important points of the body.. using feet is energy from the earth.... let heat up my knees and palms... etozh harashi...
just ask about joint disease (arteret, osteoarthritis, rheumatoid arthritis) just in case...
the process has begun and the energy of prana-life force heals all diseases...
the current is not all know how to use this...
Comrades, I try all Theta-improv to love more and more.
More than a session of meditation and relaxation.
After a 15 minute session of 100% pulls to sleep. 100% I sleep from 1-2.5 hours. In the morning, afternoon and evening, no matter the time of day.
After 6 minutes already somewhere scared of what... that can't remember. But it is very nice and warm. Come to mind only when you can't hear in headphones and can't understand how I'm lying, 15 minutes or an hour.
No nightmares repeat, no overdose, and headaches, the opposite is true. I'm starting to think appears to Theta improve dependence
I know I can also do without the rest.
Of course, questions remain. Why all the takes time to sleep? Why cut down on the time of the session? Why it is difficult to keep a clear mind (such as mind awake, body asleep)?
Идущая вперед
I've also long suffered...
in the solar wind was knocked out after the manipura or anahata in sleep (5-6 tracks) to the end of the disc.... I could not understand well is....
after testing on chakra turned out that 2 of the upper chakras ajna and Sahasrara opened to 60-70% and lower by 20-30% and lower... not enough energy.... and they take it from the top...
in General, my subconscious blocks the further development of the upper chakras trying to tighten the lower to the upper level.... that's the parsley... very subconscious eliminates the imbalance...
with theta first identity is there.... also in the dream was cut - but most likely I had a lack of sleep...
Hello. Typically, theta listened to lying down. Preliminary relaxation, with postanovkoj any purpose. Noticed that to keep a clear mind in this situation is problematic, or a complete failure to sleep or catignani dives. In the sitting position the mind control more real. The effect is curious. If you do not silence you can hear the environment that to some extent(last time my knees ran kitten) and at the same time to see the brightest images with some specifics and sometimes not. Didn't pay attention, but feeling a very strong heat the same as it is received. From the heart throughout the body. All fears about the theta state, it seems to me far-fetched
but it codecname opinion
Мак-Сим
On account of the alpha range waves in the mind machines I agree with Dimasom, give personal preference to disc Healing (I want to boast that I am the happy owner of Christmas prize series Audiostrobe CDs, many thanks to the organizers of rozygrysha!!!) - guys, trust me that drive is very strong and useful, but not everyone can effectively use the alpha, be patient, and negativity will fly right before your eyes )))) to you without any harm. Once the brain is ready to Theta waves, so once himself and immersed.
I've been training for almost 2 years, during listening sessions trying to stop all thought, to achieve the effect luchshe all fixed in a tabular report session dip, the results are very satisfied.
Игорь Астана Казахстан
Hi all mindmachines!!
Acquired Luma 10. Taking the first steps. Experienced advise what music to connect for effective results.May be there is some article for dummies where to start,how to develop,something to strive for.
Which is a good result?
How is it manifested?
The ability,in life,how?
Thanks in advance.
Thanks in advance.
Yuzal 3 days Lucid dreaming,at first it seems to be nothing,now again the day the mood is not very good,reluctant to do anything...tonight I slept badly..damn not given me these theta-the program does...Can listen in the morning, alpha,day beta,and the evening-night theta?hmm..I wonder what will be the result...
Igor Astana Kazakhstan
I think it is better without music to work out (IMHO),as it is distracting...a Good result is total relaxation,good mood,positive thinking and purposeful action
Appears everywhere!(I'm serious).
Then, too, this morning - bet, day - alpha and Nocera theta...Dimas wrote:Yuzal 3 days Lucid dreaming,at first it seems to be nothing,now again the day the mood is not very good,reluctant to do anything...tonight I slept badly..damn not given me these theta-the program does...Can listen in the morning, alpha,day beta,and the evening-night theta?hmm..I wonder what will be the result...
I think it is better without music to work out (IMHO),as it is distracting...a Good result is total relaxation,good mood,positive thinking and purposeful actionAppears everywhere!(I'm serious).
Recent work on Theta iprov.
in the morning (before 12) 23 min distance,
sometimes a day 30 min.
well, before going to sleep so about 15 minutes.
Sleep comes after the wiretapping. The end of the session immediately vovraschaetsya consciousness. But within 10 minutes and immediately to sleep.
After the session, the easy sleep, with dreams, mostly good, but usually don't remember.
I feel the warmth is not a specific place of the body and in consciousness. Like you remember a good moment reminiscent of sunbathing by the sea. In the mind a pleasant feeling of detachment and warmth.
Before work is better not to put! The head becomes heavy. In a good way, but it's the middle of the day can interfere with concentration. Although if you follow and sleep for an hour, the negativity disappears.
Noticed cravings Theta session! Good or bad don't know?
