The idea of drinking the dirtiest adult in a head will not come? :P I 27.Сергей Михайлов wrote:Interesting experience. And tell me how old are you?
About vitamins strange question. Who just would not advise starting with doctors and ending with his parents. Well, in the different places I ran across that the use of vitamins is especially important in winter. I drink the alphabet in which the vitamins are divided into three groups who each other vzaimodopolnjajut. And Vice versa the vitamins that oxidize each other separated. The dosage does not exceed, so nothing to fear.Сергей Михайлов wrote:How decided to take vitamins? can be advised by whom? Do not I fear that when you stop drinking then fall into a lethargic hibernation
I also eat pollen and bee bread, bee products. These are the same vitamins plus a bunch of amino acids including essential and minerals. But also in a reasonable dose, 2 teaspoons per day. Think of hypervitaminosis I won't have from what you drink and vitamins and pollen at the same time. Doses of vitamins can be quite increase, the excess is simply excreted from the body.
About Noben nootropics and Piracetam is not a stimulant, kind of the same coffee (which I don't drink) or ginseng. I'm not sure until the end that is their action, but in General, they "clarified" perception. For example, often notice for yourself listen to someone else, for a notice, that after a while "float" and think about something else. But the last two days on another. "Float", but the threads of conversation are lost, and it feels like the alpha session, the mind-machine. More see more hear including the nature around, can better perceive the person can less. You can even fully concentrate, and if you start to answer then turns on a different state, as I understand it beta activity. But it is in fact a perception of significantly weakening.
In addition Noben and Piracetam improves blood flow (if I understand correctly). For the manifestation of the effect requires about two to three weeks. But I am sure the effect will not disappear the day after the end of the course. A few months to stay exactly needs. In the manual write that the rate of nootropics you need to carry out a couple of times a year. Respectively in the intervals need no drugs.
About Q10, succinic acid, glycine, glutamic acid concerns either.
COQ-10 is essentially energy: it stimulates energy production at the cellular level. Inside each cell are tiny energy generators - the mitochondria, which produce 95% of energy needed by our body.
Again as I understand after discontinuation of the Q10, nothing bad will happen. This is the same as to stop eating salmon, sardines, beef, peanuts and spinach in which contains this substance. It is one thing to drink 10 drops of Q10, and the other to eat a kilo of peanut or meat))) the rest of succinic and glutamic acids and glycine in approximately the same situation.
Ginkgo Biloba – it is generally something with something. The extract from its leaves has a bunch of useful properties. Well, I think that after the cessation of the effects will gradually subside, but again, not immediately and not drastically.
"Ginkgo biloba significantly improves blood circulation and lymph fluids in capilano... This means that Ginkgo biloba is perhaps one of the most effective drugs currently known for the treatment of "side effects" of the aging process of the human body, such as worsening short-term memory, slow thinking and deterioration of logical thinking". - Ross Pelton, R. Ph., Ph.D. Mind Food and Smart Pills
The only thing that confuses me ginseng is a definitely a stimulant.<
