Orgone generator with their hands (The Succor Punch, SP)
- Шалтай Балтай
- Has thanked: 125 times
- Been thanked: 263 times
.at.
I am ashamed too, specialist controllers.
old man and identity - like a boy. Here you use it as a rag.
Re: Orgone generator with their hands (The Succor Punch, SP)
why did you decide that old? Not a wrinkle on the face ))) Can you come up with something non-existent?
and who uses it? Open your eyes, help me see I chain skins.
.at. Humpty and look you in the mega-fart recorded))) it is Not necessary to dismiss, it had such a clumsy form of respect, if he understands that before him, someone more experienced than him. Only I'm the old fart-millionaire philanthropist with the "friend in my pants", and you apparently "pioneer-retired", ie already groaning , but still looked devchenok)))
Well what can we wish Humpty)) Not to get lost and enjoy your youth to the full, and then look at all the thoughts around the "pants" and "pussy", so you can casually their labour and masalantie from epoxy overworked hands blindness)) it would be a Pity to lose such a talented combat unit on the front orgone))
александрФ
- Been thanked: 1 time
Humpty BaltayI propose You communicate on your website.
At present, there brings a whiff of trollism. The smell of a mixture of hubris, arrogance, rudeness and a pissing contest.
In any case, do not find it necessary to communicate in such an atmosphere.
Sincerely, Alexander.
- Шалтай Балтай
I apologize, I was interested in this designалександрФ wrote:About that design. For amplification of the radiation used crystal moon quartz. The name of the device - "Weathermaker".Данте wrote:...experimented with some coil "screw" , which, depending on polarity, then gave a huge burst of energy, potency and lack of sleep, depression, apathy, and disease. The coil was installed in the chair seat and its axis "seen" along the axis of the spine. So, no orgonite was not mentioned.
and all questions, including impedance, belonged to her
I just haven't seen all the pictures - can miss, again - sorry
- Шалтай Балтай
cool, breakалександрФ wrote:At present, there brings a whiff of trollism
kogdato of the Russian war we were afraid of?
schaz just all veiled, you should be able to see
in war as in war
but those who go to sleep - restful sleep
александрФ
It is a variant of the Mobius coil made of three-track geometry of a möbius strip. In previous posts, answering questions, and have already given this info. Repeat, if necessary.
1. Alicesme resistance of the red and blue sections, for 52 ohms each.
2. For powering the coil using a unipolar pulsating voltage with a frequency of 120 Hz. Source: buck TRANS with an output voltage of 24 V and maximum current 2 A and the bridge rectifier (type КЦ401). From the output of the bridge - on the two sections of the coil in the opposite direction.
3. Why unipolar pulsing? Because the Mobius coil of this design is a variant pseudomenopause coil, which is a single linear spiral pole facing outwards (on the surface of a donut) and the second inside, around the carrier ring. When washing a single signal outer pole (your choice - North or South) will be drawn in all directions in a spiral, and pulsate at a predetermined frequency.
P. S. Here is how the variant km with moon quartz ("Weathermaker"):
- Шалтай Балтай
alexandrp
rispekt!
this infa.
need to know the impedance. can try on? to suggest how?
ibadans likely high
I'd venture to say that washing need 100 volts somewhere.
rispekt!
52 ohms? I have 2-3 Ohm somewhereалександрФ wrote:1. Alicesme resistance of the red and blue sections, for 52 ohms each.
ibadans likely high
probably increasing. no?александрФ wrote:Source: step-down TRANS with an output voltage of 24 V and maximum current 2 A
- Шалтай Балтай
ALL
let me remind you that the title of the topic:
not:
I'm sure You will help
PS
The post SIM reserves the right not to respond to people with registration less than half/year.
Materials enough. One thing man seeks knowledge, and the other "pagewrite with me", "I want attention" - it's complex.
Good luck
Humpty.
not:
- Let's talk about Humpty
- See how clever I am and even with pathos
- How many buzzwords I can produce per unit of time
- to prove anyone anything
- to catch someone in something
- show everyone something and to work for the audience
PS
Good luck
Humpty.
Very well written, still to himself to apply... page back to go back to read how you write about organic, the first sentence discussing personality )))
and your advice is good for all people, not able to refrain from discussing personalities instead of orgonite:is not particularly interested in manufacturing technology.... more on sale
it's great that you are ashamed of me his complex story, but right...
admins: I would have demolished, but for your mercy................
pathetic verbiage stacherski.........
it sales Manager, it platform needs
well, people too.
again hohlyatsky website which
[youtube][/youtube]I recommend to go to a therapist, to present facts, go ACC. the course of treatment.
александрФ
The impedance of the coil depends on the frequency. To measure the impedance of my coil at a frequency of 120 Hz I can not afford. In any case, it does not below the specified active (michelago) resistance.Шалтай Балтай wrote:need to know the impedance. can try on? to suggest how?
ibadans likely high
Two sections of the coil can be connected in four ways:Шалтай Балтай wrote:probably increase. no?
1. Serial codirectional.
2. Serial counter.
3. Parallel collinear.
4. Parallel counter.
I include (commuter) section of the fourth way - in parallel-counter. In this case, the resistance of the sections will be equal to 26 ohms. At reduced voltage to 24V (and TRANS in amplitude produces up to 30V), the current powering to get within 1A. During operation, the coil is heated to 70 deg. Increase current - will increase heat. And it is not Gud.
- Шалтай Балтай
it is not difficult.александрФ wrote:Measure impedance of my coil at a frequency of 120 Hz I can not afford.
- There are multimeters with built-in measurement impedance
- If you are using a laboratory power supply - it presents the current. The difference act-pass = load
- Walter/Ammeter on load
Ettochna. On the order and the account may two aboveалександрФ wrote:In any case, it does not below the specified active (michelago) resistance.
He is the Mobius so heated? Hmm, strange...александрФ wrote:During operation, the coil is heated to 70 °
even if we assume that impedance of 120 times in 3 above michelago, then
24*24/56/3 = 3.5 W - no b a helluva lot of grezzo, however the photo does not show scale, what are the dimensions of the coil?
александрФ
Given that the coil is powered by the rectified pulsating current of more than 1A, and the total resistance is equal alicesme 26ом, the power dissipation is obtained no less than 26 watts. But the main heating gives steel frame (eddy currents).Шалтай Балтай wrote:Is itself Mobius so heated? Hmm, strange...
I sculpted the coil more than 5 years ago out of scrap materials. And iron, in this case, is not the best option. Therefore, skeletal elements recommend of fiberglass or PTFE. The most "comfortable" option - 3D printing. Dial skeleton hand from frame - to-e-e-e-SIMA time consuming.
Dear, Humpty. If there was any experiences to pump up the energy with SP... well I have some idea of taking Kombucha Kalinkovichi (how to do it?) the SP and feeding programs (again, what?) for Kombucha, most to use, respectively, the brew and to earn any profit (which I don't know yet). Understand that the idea of raw to impossible, but seems highly promising because it is recognised that the impact of SP on the body is very strong, and there is a kind of bioenergy hookah (that's my Association
). Please do not throw stones at me
- Шалтай Балтай
Good zdraveska, Andy
In the General case, this idea is called "charge the water". This one (from a fairly extensive variety of ways) use SP. If you obstreperous from the water, I would have used the term "liquid crystals", in which falls the whole organic at all. Including Kombucha
For example, Karl Welz, there is a special stand for the waters which zelinkova on radionic. I mean what Humpty says nothing new
here, for example: http://www.radionics.org/301_water.html
By the way, in Your case You can put Kombucha (liquid crystal) right in the knot of the Mobius. I can't tell you how acceptable it is for You structurally, but conceptually is completely normal.
But one thing I will say unequivocally, You are thinking in the right direction.
I don't know, please You or disappoint, but this idea is not new.Энди wrote:I Understand that the idea of raw to be
jacket here: viewtopic.php?p=45463#p45463Энди wrote:Kalinkovichi (how to do it?) the SP
it's up to You to decide. You don't want Your Kombucha went someone not Your programsЭнди wrote:a program (again, what?)
Fake. The body takes from the devices as much as you want, no device force energy not vpihnesh. If there was a temporary overdose, due to the fact that the "energy norm" for most people now is to crawl from home to work and from home to the store, that is the primary task of the device just shake and temporarily exit rules, well, put down the device, relax and dose. No harm but good
good luck in studiesДжеймс wrote:Fake. The body takes from the devices as much as you want, no device force energy will not cram
and You that ahead of time chose to leave this world? vkoem cases, I do not advise! a maximum of 4 hemispheres, the link as that just above a few posts at the source, REMEMBER! all at Your own riskФинансист wrote:I'm sorry, not in the subject. And what is it? You can at least briefly?
Thank you! They are there to stock and it is possible in principle to start using one hemisphere and then gradually increase.милениум wrote:and You that ahead of time chose to leave this world? vkoem cases, I do not advise! a maximum of 4 hemispheres, the link as that just above a few posts at the source, REMEMBER! all at Your own riskФинансист wrote:I'm sorry, not in the subject. And what is it? You can at least briefly?good luck, the thing is very strong but simply just thermogenerator and no more powerful really, the location of the fields has a value of dish up the radiation plate down getting
There is evidence the tree made of? As well as the size. Diameter, wall thickness? Or all randomly and the thicker the better?
good luck in studiesФинансист wrote:There is evidence the tree made of? As well as the size. Diameter, wall thickness? Or all randomly and the thicker the better?
