Orgone generator with their hands (The Succor Punch, SP)
Виктор Тейваз
Good time of day! Dear friends, please give step by step instructions on how to make SP. I would be very grateful!
- Шалтай Балтай
- Has thanked: 125 times
- Been thanked: 263 times
- Александр Н.
- Has thanked: 30 times
- Been thanked: 50 times
Re: Orgone generator with their hands (The Succor Punch, SP)
The enameled wire of 0.1. I wound the coil on the mandrel, the resistance of 39 Ohms. I filled the cake with epoxy, also 39 Ohms. The cake is not boiled, only heated up slightly. After drying of 25 Ohms. Who can tell, is that a problem? Will not work? Is there a solution to this problem? Or is it easier to leave a passive this cake and make another?
- Александр Н.
Thanks for the reply.Логик wrote:Alexander N. there is no problem. 25 Ohms - enough
Of 39 was 25. Perhaps it means that somewhere there was a shorted winding, disrupted the integrity of the coil. This is not a problem?
- Шалтай Балтай
Good day, Alexander N.
As 25 Ohms you still there, I'd recommend to work.
it's weirdАлександр Н. wrote:Of 39 was 25
possibleАлександр Н. wrote:Perhaps it means that somewhere there was a shorted winding, disrupted the integrity of the coil
thinАлександр Н. wrote:The enameled wire of 0.1
um... this is a problem, of course. The question is how this serious problem. The answer can only give flight testsАлександр Н. wrote:This is not a problem?
- Александр Н.
Humpty BaltayI understood, thank you.
The wire is fine, just be close at hand. I thought for a small crystal(5-6 cm) is normal. And what is the optimum thickness and length of wires? So, get comfortable and work as it should?
- Шалтай Балтай
I take it 10 meters under F1 or F1.5 In impedance it will give a 25 Ohm somewhere, Besh will need another resistor Ohm 50 under the player. Or Ohm 10-15 if welcom.Александр Н. wrote:And what is the optimum thickness and length of wires?
- Александр Н.
The table value for a 1m copper wire diameter 1mm - 0,023 Ohm. Is 10m the impedance it will give a 25 Ohm somewhere? And cheap Chinese tester it will show?Шалтай Балтай wrote:
10m in half and twist the braid under 45 gr.? Ie for winding coils will be slightly less than 5 meters pigtails?
Wire enamels or in plastic?
Hello! Have decided to build such a device, but I doubt in the choice of stones.
Is it worth buying from the Chinese, for example?
https://ru.aliexpress.com/item/70-80mm- ... 269.PzhCjo
https://ru.aliexpress.com/item/100g-Nat ... =200042146
Or Ali is generally better to bypass the party for such needs?
- чернокнижник
- Has thanked: 14 times
- Been thanked: 24 times
The second link - looks quite good. Referring first too equal sides, from which it was carved is unclear. Better simple, wonky, but REAL. Quartz is widespread, it makes sense to ccontact with local geologists, we can tell where found. Trailer and to learn from them a lot of additional information about the crystals, about the varieties of quartz, and so on. This subject is vast and interesting))) the network also has good information, don't be lazy, read. Here's some:
http://www.ethanlazzerini.com/crystal-f ... -meanings/
Polished, smooth like a pencil not worth buying, may not even be crystal, and carved from a monolith or even artificial.Каспиан wrote:Should I buy from the Chinese, for example?
Small that weight sold look real.
Good day to all!
Going to do the SP to execute 1 desire (not money).
I read all 190 pages of the forum, but have questions.
1) How many layers of orgonite to do? 3 layers would be enough?
1A) do I understand Correctly that the lower the density, the thicker the layer?
2) whether as a filler for high density orgonite to use copper grease for calipers of the car? There are composed of fine copper and binders. Do I need these components to corrode/to evaporate?
3) So after all do I need to add the product of the spiral type SBB Coil? And if needed, in what layer?
4) I Want to make the first compact obelisk dimensions 150х50 mm, the distribution of layers the easiest way to do the horizontal in the region where the crystal, pour XHD, then the following layers organic with lower density. Get the gradient in one direction - from top to bottom and from left to right - a constant density. So will work or still need to make the gradient in all directions?
6) the Bottom layer want to make shungite dust. Criticize.
7) And most importantly - why people stopped to discuss this topic? Sharply StuH in all forums, there is no happy life with SP users or those for whom this appliance is not helped.
Thank you in advance for your answers.
manone of the reasons - for fulfillment of wishes easier to make a primitive radionic with one to three resistors. The diagrams and descriptions in the network is more than enough, the cost compared to the SP is negligible.
XUPOH wrote:manone of the reasons - for fulfillment of wishes easier to make a primitive radionic with one to three resistors. The diagrams and descriptions in the network is more than enough, the cost compared to the SP is negligible.
I collected the passive the cake - he works. But in the Assembly process made mistakes - had to destroy it.
I understand Radionics is the same sp only krutilki. That is the meaning of these krutilek not clear to me.
For the price I have is 2.5 Tr with a small crystal. I think krutilki today will cost more
IMHO. two reasons.мэн wrote:7) And most importantly - why people stopped to discuss this topic? Sharply StuH in all forums, there is no happy life with SP users or those for whom this appliance is not helped.
1. Comes the understanding that it is not working exactly as described in the manual.
2. All men are brothers is not a fact. What is done there, works. But it is not always correct when using the those who live here.
On the second point, a lot of information on YouTube from Anatoly Klyosov. Not directly, but he that heareth, let him hear.
And could you explain in your own words these two points?Ланцелот wrote:1. Comes the understanding that it is not working exactly as described in the manual.
I understand that 1 point is the person wants to ride a black jeep, sends this desire to the universe, he grabbed on the street thugs in the black jeep driven outside the city to knock the headstock?
And 2 item means that the mentality of the inventor is different from ours, so we have it works at random? Maybe it is because they have better epoxy, and we have poured Glue EPD?
The product is decorated with crystal, its correct preparation (cleaning and programming), not all succeed, hence a lot of frustration.мэн wrote: is not working very well, as described in the manual
I've read WarriorMatrix - where people do not bother. Mobius harassed in any direction, break apart, solder two coils in one. Put the aluminium - and all of it works.
We have neither read - "do not get - kill!"
Where is the truth then?
- Шалтай Балтай
in the 101 times I sayмэн wrote:no matter how we read - "do not get - kill!"
will allow you to give yourself advice:do not read Soviet Newspapers
understand what You want, SP or talk about it
there is a practice, there are conversations.
make a selection
everything worksмэн wrote:I've read WarriorMatrix - where people do not bother. Mobius harassed in any direction, break apart, solder two coils in one. Put the aluminium - and all of it works.
read here, for example: viewtopic.php?t=6151
I have MEbius and with right and with left spin and so and so works.
The only course, if the pigtail legaspina, and the bagel - letopisny
if the pigtail propina, and the bagel - pravopisnye
think why
good luck
- Шалтай Балтай
the truth is not say, it is minedмэн wrote:Where the truth lies then?
what they say is the crowd control.
But winding a Mobius strip through the centre out or from the outside to the center has a value or just spin?Шалтай Балтай wrote: The only course, if the pigtail legaspina, and the bagel - letopisny
think why
good luck
- Шалтай Балтай
man
think with your head, please.
Tell me - can't find the answer.Шалтай Балтай wrote:man
Logan shakes through the center to the outside, warriormatrix harassed outside to the center.
- Шалтай Балтай
in the East there is a saying, why to go, when the donkey is........
Шалтай Балтай wrote:your head, please.
