Noopendant II. The library programs. Reviews. Discussion.
Александр Высокий
Hello. Please tell me whether Neocolor II in solving the problems with society, specifically with the sociopath. Uncomfortable to be around people (especially transport), in conversation there is a wild fear when our eyes meet, every day itself overcome but these States occur spontaneously. Helps alcohol (glass of champagne) and you become a different person, but it is no panacea))) in short, social suffering. Will it help if I Neocolor II? Thank you.
донна Лилия
- Has thanked: 7 times
- Been thanked: 21 times
Re: Neocolor II. The library programs. Reviews. Discussion.
Alexander HighI will share my experience. Just got nookular level II without level I. Connected Titan, Atlas, Experience the unconscious, the Centrality, Meditation Learning. Became more brave and relaxed to communicate, new acquaintances, in large companies began to feel more confident. Still use the club card so not sure which worked, apparently, all in the complex.
Hello, can someone tell me. I do not understand what is happening. in the post above wrote about their feelings as a result of work of neocolonial level 1 Mental and Master. And as the saying goes, can not boast. Decided to see what kind of bounce happens to other users when you put the power. Translated , this chatter felt through the day when out in society. The emergence of the state of causeless anxiety, fear before anything is unclear. Transferred to the mode of medium ago. It was a pendant Mental. I would not say that the mind began to work better, but there are new opportunities. Why the me is getting worse and worse it gets picked up known as angina. It hurts, the fear inside is not going away. You are asking yourself what it is that is happening and can not understand. Like some sort of veil hid me from the light of the world and pulls in the world of dark. Started to show aggression. At work some messy went. Maybe someone can explain and what should I take in the future. Thank you.
RESEDA turn on auto. For translation mode power, in my humble opinion, at least, need to put the end goal. That is, what You translate in this mode. In fact, You felt the bounce that You own and sprayed, figuratively, for a short time.
донна Лилия
Crosbyif understand correctly the explanations in the forum, you can use the pendant to level II without I, if the I level is worked. Not to brag, everything is perfect, but level II and started to work immediately. While the sense of gaps there. You may have to master the pendants I. can't decide which one to start with.
that checked outРезеда wrote:Decided to see what kind of bounce happens to other users when you put the power.
I have like 4 mode neocolony was impatience and anxiety
turn on auto it settles or you take the bar you have set
- Иван Славов
- Has thanked: 650 times
- Been thanked: 150 times
RESEDA, it is, in my humble opinion, the work in the first phase with the energy body. And there is not a day or two, even a month or two. And, believe me, none /unless, of course, wants to be correct/ not be able to tell You exactly what You need in this moment. Good luck.
Experts
What happened to Neocolonial II?
I tired to wear it, because from him skin green!
After half a year, I thought about it and then spot it inside =))
It still fit? =))
Nookular: no cracks, drops, water and temperature treatment.
YS,
S!
It still fit? =))
YS,
S!
Александр Высокий
Hello. I have a question for the creators of Neocolony II. Neocolor II refers to high-frequency products (software that enables the operator to carry vysokochastotnom) or neocolor II working out of these concepts? Thank you.
Your case with sociopathy is the Armor when everything is back to normal,buy another that will manifest the intention.If you have fear, then you're not lost.))Fears,panic in rare cases,this infoverse,mostly infrared radiation,burden poison,like mercury,arsenic,silver nitrate(carrying the fear),do not necessarily think that you were poisoned by the closest people,these substances can be and vaccinations to weaken the main components(shit) vaccine,etc. combination,and therefore, we need a parallel approach for neutralization on the physical level, normalize organic.Neocolony have no microwave radiation,they are neutral,this type of antenni-chip)) which will configure itself in the right direction for you.Fears have already passed my stage.Fear is a universal condition that is able to enter into an altered state of consciousness for astral separation from the body double, etc...,the main thing is to take it to dissolve it become the most fear,but it's a psycho way of the warrior,not to everyone under force,for the elite.Александр Высокий wrote:Hello. I have a question for the creators of Neocolony II. Neocolor II refers to high-frequency products (software that enables the operator to carry vysokochastotnom) or neocolor II working out of these concepts? Thank you.
Aura
- Has thanked: 22 times
- Been thanked: 1124 times
It is not mechanical effects, or rather, the reasons why physical changes are taking place in the artifacts differ from regular jewelry. Artifacts are broken, lost, etc. more than the usual pendant, and it's not the quality of the materials, rather, as an Artifact which has great communication with the operator than the ordinary jewelry. Most likely, the first “tired of carrying”, and then it is manifested in neocolony.дюраселл wrote:what happened to Neocolonial II?
That photo is not a stain, and the detachment of the top coat layer, such meet a second time. On the working properties of the product are not affected in any way. You can, of course, change is not a problem, if you want to start working with zero...дюраселл wrote:It still fit?
Aura
Nookular works by a wide range of frequencies of the natural electromagnetic background.Александр Высокий wrote:I Have a question for the creators of Neocolony II. Neocolor II refers to high-frequency products (software that enables the operator to carry vysokochastotnom) or neocolor II working out of these concepts? Thank you.
Aura, what do you mean "tired of wearing"? Why it appears in neocolony? Ask a question, too, because there was an insuperable desire to remove nookular, to get rid of it away. Until removed... all the levels... Which means a rejection? Directly physically felt... How it applies to me and how to neocolony? What are the processes it describes?Аура wrote:most Likely, the first “tired of carrying”, and then it is manifested in neocolony.
Aura
One thing the novice, and another thing to the experienced user. Tells the body – try, watch what happens. There is a certain period when the subject of consciousness resulting laws becomes part of the SP operator, or in other words, the skills, experience, knowledge are fixed and remain with the user permanently. Maybe integral field stood on its feet, somewhere clean, somewhere stronger, became self-sufficient in a certain area, and thus is trying to say: “I can, without helpers, let me try.”
Yes , this is a talked about how those who engage in something regularly and use different artifacts))) had it more than once.Аура wrote: Can be of integral field stood on its feet, somewhere clean, somewhere stronger, became self-sufficient in a certain area, and thus is trying to say: “I can, without helpers, let me try.”
Yes, it seems You, as alwaysАура wrote:One thing the novice, and another thing to the experienced user. Tells the body – try, watch what happens. There is a certain period when the subject of consciousness resulting laws becomes part of the SP operator, or in other words, the skills, experience, knowledge are fixed and remain with the user permanently. Maybe integral field stood on its feet, somewhere clean, somewhere stronger, became self-sufficient in a certain area, and thus is trying to say: “I can, without helpers, let me try.”
Re: CAMPAIGN for Neocolor II + Full library programs
Good afternoon. My question is, connection of library programs unlimited or 3 months?
Of course indefinite.But still very expensive.It would be nice to be able to before buying a week of free testing as neocolony and selected programs.And then reviews the small number is clearly insufficient.
Has anyone tried it with the connected program "arcsine Law" affect Psyleron? What are the results?
The power needed to achieve the ultimate goal and not only set goals you can alternately change until you find the right target-variant line, I feel that the selection is correct ,then everything will calm down soon,your world will be included as stated in the right topic for you.it hurts, the fear inside is not going away. You are asking yourself what it is that is happening and can not understand
