The magic of biochemistry or biochemistry magic
And it's true - the difference is only in the concentrations of several hormones: testosterone there, progesterone, estrogen, oxytocin and other... And electric current and electric current )) the Difference runs which is just different incoming data and their consistency.
Except that in women the shift in intuition and irrationality (perception of the field, parallel), and in men, the offset in the logic and structure (axial perception, sequential)
Re: the Magic of biochemistry or biochemistry magic
In fact, from the point of view of hormones just to transform animal adrenaline in some kind of dopamine or serotonin (hormone of happiness). That is, to learn other chemical reactions, but to afraid to snap and beat with a cudgel and then the other reactions, except for how you go be depressed, offended and complain - there are lots of other cocktail recipes. And from the point of view of electric current - the task is to power the subcortex (subconscious), increasing the currents of the limbic system (limb = boundary, edge) and decreasing the currents of the cortex (thoughts), that they are equal. Or conversely, increase the currents of the cortex by learning to think, if the limb is stronger. That is to learn to control the body though not always, but often. Sounds simple, but the process gives scope to the imagination, especially in terms of interpretations )))
All of this happened to me)))) more understood, impossible to manage even))) of course I had to get a med school, and psychologist and to go into the jungle collectively, esotericism,quantum mechanics)))) basis, the essence is the same, every science is pulling out of context of the piece and is studying to stupor. I think here it is necessary to capture the essence and synthesize knowledge to explain what you actually do. Touched to the depths of your conversations with people who understand your field of expertise, but ultraviolets can't. She tried to explain, but who can not hear, and he will not hear)))))
http://www.popmech.ru/science/351602-mi ... _164075140
The smartest people can't decide)))))
Trying to explain it)))) it is necessary to go on instruments
Physics is an interesting science that explains everything better than psychology or philosophy there, though in a very complicated way. The most interesting approach of modern physics that everything is a set of interferences of fields: gravitational, Higgs, electromagnetic, and other. To see the current view of physics in a simplified form here https://geektimes.ru/post/289699/ reading through the line and not going into details.
If we talk in ordinary language of symbolism and imagery (i.e. the text below), the field in 2D can be represented as a puddle of liquid. Drop to the puddle drop and go waves. If you drop two drops next to each go waves, which will either extinguish each other or to strengthen or to create confusion, storm and chaos - depends on the resonance wavelengths (also frequencies).
The field is everything. The drop is form, and form in 3D and below is again, all animate and inanimate objects ("frozen" field, a very slow current). Waves is the interaction of forms and interactions, and a drop can hit the waves from the side even if she didn't let them ("Rafiq niewinny" or "just a coincidence", although in higher dimensions must also have a reason for the apparent randomness)
Actually, this is about the 8th level of the field, only more complex, as measurement 2 and more, and to cover them figuratively as early as 5-6 measurement difficult.
3D is a conditional sphere of objects nested in each other - the atom-the nucleus of the cell-the man-the planet-star system-galaxy-cluster-cluster and so on... In 4D is the same sphere out of space, for example as one of the fabulous theories without evidence: the stars of the galaxy is the reverse side of the black hole at the center of every galaxy (the black hole draws stars radiate - it is a kind of multidimensional current Thor galaxy trillion the outer sides, but with one internal axis). That is, in 4D space there is, it is formed so that two points of the 3D match. The result is something like a tree realizations of the torus (sphere with axis). Evolution can be represented conditionally as the puddle of water that generates more and more complex fluctuations, turbulence and waves over time - the origin of a tornado or funnel underwater currents.
In 5D there is no time (the sum 4D break) and it turns out that the stars have all rejected and have not yet begun to radiate, they just are like radiation "always", stretched in time in the lower dimensions, and stretched slowly, viscous and inert. That is, the dimension of States, qualities.
To provide an even higher dimension fields can only be in the form of trees, one tree grows from one pole of the sphere, from below, another from above. Connecting, the trees form the shape of the waves and the different implementations. 6D in General can be represented as a bilateral tree, probabilities, possibilities, potentials, and this is again the "sphere" in some way, as the natural geometry in the absence of restrictions. And so on, somewhere out there, the result is a matryoshka sphere in sphere in sphere in sphere, both vertically (between dimensions) and horizontally (in one dimension) on one axis in the form of an unimaginably multidimensional bilateral tree of life. And the difference is only in the radius of the sphere, where they are all self-similar.
But it's all very technical and confusing - and to be closer to reality, it is of course psychology and physiology (endocrinology, neurobiology, etc). But if even closer and easier - "live and don't hinder others" (where interfere is including to cheat, or to apply adrenaline to a club, or just in mind want to hurt someone, or think poorly of yourself - all this creates "waves" that prevents even not involved)<
If you're lucky...
1. If you're lucky, you'll be alone. All alone, when no one was around and will have to look for support on the ground and on yourself.
2. If you are lucky and it will be at the right time, life will hit you to split like a nut to get the kernel.
3 .If you're lucky would be the right time, you will be hurt. So painful, that the pain will almost be forced to die, and then will help to be reborn from the inside out.
4. If you are lucky, you will cry. And these tears nothing will be impossible to keep. And through them comes the release, and then real life.
5. If you are lucky, you will be vulnerable to other people. And no way to hide it. And then understand who is with you and who is not.
6. If you're lucky, you won't know the answers to the questions. And then you have to invent something yourself.
7. If you are lucky, you will be disappointed in people, ideas, and teachers and good wizards. And, having survived that, you can look at the real world.
8. If you are lucky and the time was right, you do not have anyone to ask for advice. Not one. And will have to find an inner compass.
9. If you're lucky would be the right time, you will be unbearable, so that will have to do something with it or just relax and let the world anything to do with you.
10. If you are lucky, you will lose, be deceived, be betrayed and devastated. The "almost" are imprinted on the face with wrinkles of wisdom. And the experience will stay with you for life.
11. If you're lucky, you'll have no money. And will have to enter into real relationship with people before you can just pay.
12. If you are lucky, you will have a lot of money , you will comprehend the depth of despair, when it shatters the illusion that happiness is in them.
13. If you are lucky, you not everyone will love. And you will need to set up an internal system of values. But the desire to be liked by everyone let go of your throat.
14. If you're lucky, someone will turn away from you. And you will know the price points of happiness.
15. If you are lucky, you will face with your favorite face to face. And will two truths. Their and your. And you will feel jangling space between the individual universes that are barely touching.
16. If you are lucky, you will be able to withstand all this. And find a way of transforming yourself. Experience the inner alchemy, which makes the pain of beauty. Out of anger humility. Fear of accomplishment. And joy inspiring example. Guilt and shame, clears from the soul as the janitor sweeps old garbage. And the scars turns in the door.
If you are lucky and the time was right...
Quest performed when physical life )))))
Consciousness and subconsciousness are identified as one entity. Just all just. But soooo hard about-with-to know. The sequel promises to be exciting)))))))<
And nothing more is needed ))) the Main thing that the internal paradoxes left and it became clear to all. Not at all - it is impossible, and all that is in the field of their interests, attention - all inside. And if something is not clear, if there is an insoluble paradox, a contradiction there, especially causing emotions enough these contradictions articulate themselves (to realize, to bring into consciousness, to acknowledge their presence) and a solution as quickly as possible - the right decision is always simple and comes by itself, without voltage.Consciousness and subconsciousness are identified as one entity
Just make it often impossible. After all, if was an internal paradox - it's already included in the current wiring configuration of the neural network. And she can't admit they were wrong, at least quickly. After all, to deny himself, no one can, until you understand what the neural network has in it not one, but two, and the polar opposition. And that their inconsistency is the paradox, to resolve which can only physiologically, the reconnection of the transaction. To resolve any paradoxes easily if it turned out to form an "outside observer" that watches over them - and most importantly to trust him and do not obey the physiological emotional reactions. We can say that "observer" is associated with about occipital lobes and the presence of attention to her, as if watching from behind, although this is not entirely true.
The ideal solution to you can do for a couple of minutes, clicking in the border (twilight) state in "limbo" - where quick thinking is 100 thousand times faster, the main thing is to cover the entire huge volume of used insight, and not to forget, plus unzip to a known nervous system terms and concepts in the months/weeks/days/hours. But it order to do is difficult, often spontaneously, and very little at work. Well, if you go in this state constantly and never lose is the so - called continuity of awareness, the desired state.<
Have olalo you some practice using, like meditation or qigong?
I don't think I use any opredelennie practices. Let me just say that since childhood I was not like everyone else,I wanted to develop the brain)))) I felt that everything is not so as everyone can see, that's not so))) I sooo wanted to know. Reached the ridiculous, the alternative Board spoke to the so-called healers(which happens), but those probably that "blacker" bounced off me, those that are "whiter" say - you're a card)))) you can do it yourself. Don't know how but had the most. Different sensations,feelings, long story)))) so the circumstances "sakalelis" my brain, a feeling and a concrete pole would have broken brains))))))))))
There is speculation that it is infinite, because the extent and quality of mastering the body can be different. Mozart mastered the auditory area and small motor skills. Aivazovsky - visual area and small motor skills. Bruce Lee - large motor skills and tactile area, Strugatsky - speech area. And so on... they All managed to convert the unconscious in one or another quality. That is, the better developed man - that he is a genius in the literal sense, he does because in fact there is nothing to do. (this takes your creations from the "limb", otherwise they are dull and empty, just "inflammation" of the brain). In fact the word "genius" and means "spirit", if you Wade through the difficult etymology.the Quest is completed when the physical life )))))
So... Seeing who does (and does whether or just there) - we can understand the degree of development. But it is more for men and for women criterion of the development of love, care, nurturing, preservation and protection. The combination together is already level 9, two perfectly mastered the pole, but again with different radius of the sphere, where the radius of any sphere is determined by the least-developed quality. That is why you need to develop what can not do, want, avoid, resist and development necessarily occurs through effort, and "don't want", or how to learn to stop being afraid of this quality and stop to avoid it.
Have olalo, then does that quest over what you're already coated?
Guys,honestly I don't know a woman or man I'm inside))) prosvetlenny or dark, happy or not)))) everything is relative, but where everything is broken I'm still alive))) what are the fears? Any fear can be removed))) all branch events are only two options: 1 - something bad, really bad(as it might seem) 2-physical death. All. From 1 option there's always a way, depends on the power of intention. No power - 2nd. When you realize this - just Wake up.I call it lead to zero(variant purgatory))))))) and then the person decides for himself where to go. I had to experiment on people and a))) no fear,just given the choice of where to go, you know what will happen, and the choice is yours. Yes, of course 2 paths lead to physical death sooner or later. But when you accept it as inevitable,then it is possible))) Such a power,ingenuity and imagination appear on the 1st path))) Thank you for your fine banter over a blonde, I appreciate it)))))
Have Oslo thank you for the answers you need .at. thank you very much for such a topic, when they started to Wake up the energy, I had to read tons of literature, your theme proved very useful.
Maybe so))))
СтаниФилмТВ
- Has thanked: 24 times
- Been thanked: 63 times
...Interesting.ОлялО wrote:If you're lucky...
comes to mind a quote from domestic alchemy, the mystical Russian millennial worldview Hesychasm.If you're lucky...
Imagine a piece of iron, a forgotten blacksmith and the years lying in the corner of the forge. In the end, the iron will begin to ask the blacksmith to take him to work. Then Smith quickly pick it up, thrown into the fire and when it is hot, put on the anvil.
Will the hardware be happy?
And your illness to joy, not sorrow. Because you prayed for the Lord has made you better. And He is the blacksmith of iron, took you to work and began to temper and forge. Brother, the Lord took you to work! Hail, rusty iron, but the blacksmith!
as a result, unless of course you're lucky, you get "spear of destiny" - the axis of the inner world, the basis of his universe. Or, if easier - the inner core of indomitable will.
СтаниФилмТВ
)) Yes, and indomitable will(spear) -- it is not necessary Dubove the shaft, can be lightweight, elastic and flexible..like a bamboo pole.) But natoyaschego times..the best of spear of destiny..this is Aspen.)
