Аура wrote:Yes, should have clarified... the concentration in this case is better to use not so much visual, as a mental-shaped. You can not even look at the symbol itself in the process. Mental concentration must be sufficiently severe and prolonged to cause "fatigue" of the mind, its subsequent disconnection and as a consequence opening the intuitive channel.
Bioresonance modulators
- операторпси
- Been thanked: 3 times
Re: Bioresonance modulators.
hi, I know the posts, messages is intended for experienced, knowledgeable people so maybe the text is not verbose, but if you can explain what Your understanding of "Mental concentration", thanks in advanceАура wrote: Mental concentration must be sufficiently severe and prolonged to cause "fatigue" of the mind, its subsequent disconnection and as a consequence opening the intuitive channel.
in any case, the concentration associate most with the work of consciousness.and then suddenly we learn that there is a second option concentration unconsciously.
lexeter Mental concentration , it is also mental. Any character, candle. pendulum, anything that distracts your Mind from logical reasoning about goals , getting directly to the Subconscious. The subconscious is an interesting thing to get there , we have to trick the Mind, to lead him away. Consciousness as caretaker of the Subconscious. I wonder why there should be such "deceptive"(roundabout) way to go? Apparently all of the Subconscious is truly faithful. Any goal-intention put in bypass Consciousness is implemented quickly and accurately , as a matter of course, in principle, as everything works on auto-reflexes. On what to concentrate to achieve the goal? Yes on anything, and I think this is not so important, although it may be different symbols and stuff and give certain moods and even provide some vibration depending on which we concentrate. But in essence it uvlekalsya. These otvlekli can be frequency, verbal , gipnoticheskom, concentration on the characters......and so on.
Perhaps someone from the childhood said , that all you get is wanted , then this will work throughout life. Especially if it is to lay in your crib, when the baby is asleep, Rlpsee such programming , Abcsee)))))) in the Subconscious. Just remembered the gray Volchek))))
So this means it's working. If I did not pay attention to the small things, then kirdyk (and when the change or the change in a big way considered, it is all good, you should strike). Better things like long-term goals to set, well a year at least, week is kindergarten, honestly, if no trade lead. Cash flow is the real flow, i.e., they pass through You should work to do (this is how I would allude to charity, without it in any way). You people give money just like that, well, You just like them too then give. I think understand the idea flow.операторпси wrote:had Ceased to understand what is: I created the intention to "cash flow" - for a week no response and nothing happens. Intention was created a month ago, I found a coin from 10 kopeks to 2 rubles, nothing more
Rich relatives for example, or betting with the lottery. I even once the tote has tried to compensate for the shortfall against money held me money at work, even with it successfully. And reading these posts I remembered I once upon a time was really a good expert in some area, and actually received the most money in this specialty market. But this is still not enough, I came up with this hint to shake the team with whom I work. And indeed, if the goal to switch to environment, first they are all normal, and then dad in chocolate. Ie, the crowd was simple for us to a new step to climb than the one I kochevryazhitsya (and then ponavydumyvali different turbidity decent). The environment in this process plays a decisive role, Vose do not have to go to work in GAI. But the business card is still a trump.<Андрей Кабанков wrote:when money is not wait.
They will, if you high-class specialist in anything, the businessman or the official.
In other cases, little idea of the sources of funds, in addition to the suitcase full of money falling from the sky.
Джейсон wrote: If I did not pay attention to the small things, then kirdyk
Golden words!
One friend was the banker on the cents condition did, he sees a lot of money in cents..and in the store when buying something else, says how much you need to sell or buy currency in order to of cents was established the amount which he is willing to pay for toilet cleaner..)
Separately, this paragraph read and proreal from their labels. Have in mind that a small thing to pick up is not necessary, and the more cashiers to cheat. This factor on the dynamics of the process indicates, the process you should strike, not small things. Still laughing, really Golden words.нева wrote:Jason wrote(a):
Golden words!
Yes . This is the response..when the process started, and say that process is important and not the result..Джейсон wrote:This factor on the dynamics of the process indicates, the process you should strike, not small things
in the sense of focusing on the process allows in the process, but the desire result is just a wish without a process.)
It already aerobatics. He is a Guru and just full of such examples. On the bread save on Grand cheroke etc, etc. Just so meticulously and no complexes about money not inherent in all, and it very often leads to good results.нева wrote:, One friend was the banker on the cents condition did, he sees a lot of money in cents..and in the store when buying something else, says how much you need to sell or buy currency in order to of cents was established the amount which he is willing to pay for toilet cleaner..)
Jason
Another master said, -That's why you need a million? you already know what to do with it will be? called one.. he says tell me how you use unexpected money. In General, we laughed for a long time. And the master said, you see not just in the head of a clear structure, where a million can fit, but the unconscious desire of a million present.)
Yes, any descent will settle down and the structure will appear to enter it, just give. This is the indirect flow is relevant. People requested the stream, not a certain amount. Conditions, he is not told, but if no conditions, then someone gave it to him, the 2.5 per week, so in 10 month and 12 000 in the age. If you will care, then expand it. All is fair. Whether only such a flow is not clear.нева wrote:Jason
- операторпси
нева wrote:Jason
- операторпси
And cleverly so to change the stream on a specified amount it can be? They say the more you ask the better - all the same many will need, but you can exponentially increase supply. The only question is where this progression will flow?Джейсон wrote: Yes, any descent will settle down and the structure will appear to enter it, just give. This is the indirect flow is relevant. People requested the stream, not a certain amount. Conditions, he is not told, but if no conditions, then someone gave it to him, the 2.5 per week, so in 10 month and 12 000 in the age. If you will care, then expand it. All is fair. Whether only such a flow is not clear.
1. What a strange question. You're not the Genie of the lamp for three wishes spin. You do work, you want to concentrate the stream, looking at the amount, it is not clear just why not both?операторпси wrote:And cleverly so to change the stream on a specified amount it can be? They say the more you ask the better - all the same many will need, but you can exponentially increase supply. The only question is where this progression will flow?Джейсон wrote: Yes, any descent will settle down and the structure will appear to enter it, just give. This is the indirect flow is relevant. People requested the stream, not a certain amount. Conditions, he is not told, but if no conditions, then someone gave it to him, the 2.5 per week, so in 10 month and 12 000 in the age. If you will care, then expand it. All is fair. Whether only such a flow is not clear.
2. Here you can see how You put a question. Although I clearly described earlier, and You don't get it. Vague where it will flow, if in the right place, then swing the optimal entry point, then it is possible to adjust already. Tell me what is the flow of money, if you money for the goods will change? You are in the mind understand, what You want, maybe another job just come up, and then throw the unfamiliar words, like cash flow or is there a magnet for the channel which writes some invented creature. The world is in fact random, and to choose in this chaos the best route, that's all.
- операторпси
Yes, just two is optimum, three is a lot - spraying some starts, it turns out neither one thing nor I think, why not 5 then?
Aura
- Has thanked: 22 times
- Been thanked: 1124 times
In this case, exactly what was described in the art is a representation of the symbol in the volume and movement..not in the sense that the picture that will start to move. The symbol is a static two-dimensional display of a certain stage of movement of energy. What - in detail described. Static picture is "dead" character, and "alive" it is in motion. The task is to imagine. Of course, to represent the infinite axis around which the movement is potentially possible, it is necessary first to imagine and understand what the Infinite has already been the task for a graphic representation. Imagination forms a picture of the symbol and calls the necessary experience, fills the senses impressions. Impressions, in turn, form the sensations in the sense organs. At this stage of the work with the character may experience unusual bodily sensations, including vibration and humming (should be familiar with the astral travelers). Bodily stage starts the process of reverse actions, that is the collection, accumulation and compaction of the energy in the senses, then in the view through impression, and finally comes back to the imagination. This is similar to the search for solutions to logical problems. The mind "gets tired" quickly and begins to shut down, at this point, person a flash of inspiration - a "micro-enlightenment." Everyone knows that most great discoveries have been made in sleep, a warm bath and other periods of relaxation after severe mental koncentracii. The same mechanism. The Zen master also loved to load the students with tasks that are just unsolvable for the mind to shut off at all and the student received full enlightenment. Technique one, the ways are different. The information obtained during the period of illumination is qualitatively different from information read or heard from someone. Deductible will never be experienced - there is no stage of receiving the impressions and filling their senses. Inspiration can be interpreted in knowledge, but you can not interpret, and to remain in the intuitive channel.<лексветер wrote:hi, I know the posts, messages is intended for experienced, knowledgeable people so maybe the text is not verbose, but if you can explain what Your understanding of "Mental concentration", thanks in advance
Aura
Targeted experiments on the interaction of BRM with radionica was conducted. Theoretically, they should be a good idea to reinforce each other as a source and hub.ВИТАЛИЙ ГИНЗБУРГ wrote:does anyone have experience tracking and analyzing collaboration of BRM and any model Radionics? I would be grateful for any information)
sorry for the repetition)
Aura, there are recommendations on the type of collaboration the two devices?
thank you in advance)
IgorsI have also the outer circle began to move, though almost immediately. This effect is difficult to get rid of) Remembering that you need in amount to see, begin to ustraivat volume in this moving design. The feeling is similar to viewing 3дэ pictures. For a long time did not, and then - BAM! - there was a picture (in the imagination) and the circle into a spiral, is also moving. Moreover, little effort (as in optical illusions with a woman who can spin right and left), the spiral can move me or from me. Status as expected the alpha rhythms. And now a day on whatever you see and whatever you can think of, everything starts to spin around infinity...an infinite spiral..the unity and multiplicity))
And if you really start to paint - what, how and where - not so all simply turns out. From "large" - well, flat, the car...but it's a one-time purchase, no need of 10 apartments and 10 cars behind them still need to keep an eye on and there is no real need. And the rest of it turns out that not need large sums very difficult to spend, there is no real need or...a habit. Or is it just me, all so shy?Джейсон wrote:Yes, any descent will settle down and the structure will appear to enter it, just give.
Finally collected homemade BRM from rock crystal. Found an old device that was collected 25 years ago. However, there is less than 30kV, but I have been working on crystal for about 40 minutes. From the crystal, sack something powerful. He seemed so big and hot ball. Once gathered BRM, more pomonella:). Put under the pillow at night - let him get used to me, and I to him. Then glue 2-sided tape to the phone.
But still, I will buy BRM with rauha and amethyst. Yourself Rauch, amethyst wife.
don't know would approve of a repost, or rather the census on the share, but still dare to post in my opinion is an interesting opinion, info from the forum colleagues real unreality
To make the causative agent of a crystal at a given frequency.And not necessarily such Exotica with a smartphone.
This part can be done quite simply.
I had such a thought, I have the transceiver 100 watts of power + 3 ГУ13 1500 W,
and dipole 0t 1.8 to 28 MHz, and stramit in their point power crystal
Do you think the brains did not boil?
Hello, I had a similar idea idea, to use the transmitter with AM modulation, in place of the equivalent antenna in the form of coils wound on the frame so that the inside could be different types of crystals,minerals, to put it to modulate the voice through the microphone reciting different mantras, prayers, etc. and the second option all the same only with NCH to try on gercovich frequencies
you can learn what frequency, i.e., the voltage which has a frequency which forces the current method of influence on the crystalИгорьС wrote:there is less than 30kV, but I have been working on crystal for about 40 minutes.
Beryl: Really manifest itself in any marked not previously seen in the description mentioned. It is a pity that the crack in the crystal passes to the middle, apparently the mount is inserted from the right with force, this is evident by soldering, it is slightly to the side and crooked. It remains to hope that the internal voltage will not udlinenie of cleavage in the crystal.
Unfortunately, now the frequency can not remember and yet measure up nothing. But, like a few kHz. Did then spark ignition in the oven in Zaporozhetsлексветер wrote:you can learn what frequency, i.e., the voltage which has a frequency which forces the current method of influence on the crystalИгорьС wrote:there is less than 30kV, but I have been working on crystal for about 40 minutes.
I.e. external-flop on logic and a few transistors. The current is not large. The output is КТ812, which pulls the output of the ignition coil B 115 to ground. The high-voltage terminal and the common patpal to two sheets of foil-clad fiberglass plastic. Between them in the open matchbook crystal. This box had to put on another one, for it is pierced by the spark. Held about 40 minutes.
It would be interesting with a frequency generator to play upward.
