Small offtopic.
Re: Small off-topic.
Post by Михаил_ » Fri Mar 29, 2013 2:14
Here I am in the process of shooting the video right now, at the same time give comments not made in the subject in the video. But first I will add a few words on Andrei raised the topic and move on to the fix on u-tube.
Post by Михаил_ » Fri Mar 29, 2013 5:04
At the request of the moon a short explanation on working with P1 - it's simple.
Post by Михаил_ » Fri Mar 29, 2013 5:13
Yes, I was there in the video "scare" that burned the first pair of devices about the concrete floor, but actually:
- then there was this known and why I received a "warranty repair".
- the problem came after a long time of such malfunction of the device (a watch). Although you consider these things need (to avoid close arrangement of the emitter (cm) solid metal objects, pipes, and other elementov furniture and interior).
And yet in the video not sound. The second "shoulder" of the radiator under the angle 120градусов to the fact that I drive a demo on hand should always be turned "from the body" i.e. the plane between the shoulders of the antenna should be secant at a right angle to the body (seen in the video, but not explained), it is not strict and not harsh, just more efficient.
Moon
Post by Moon » Fri Mar 29, 2013 6:01
Thank you, Michael! I take useful device:)
Post by bofara » Fri Mar 29, 2013 16:36
Михаил_ wrote:see the output of many involved in this system common for all kulturama not a fact - the fall in body temperature.
These people emit noticeable heat into the environment? I mean - in their presence there is a noticeable increase in the temperature of the air in the room without any additional source of heat? "People-stove" or Vice versa - they are often cold?
Directed at another person /for example, to test the feelings/ bioenergy, izhodya of such "low temperature" people felt like the heat from some of the people /of course, others may feel like tingling or a nice cold/? Thank you.
Post by Михаил_ » Fri Mar 29, 2013 18:38
These people feel fine and do not emit anything special, except that in mind the good health they look more holistically and powerfully (personal energy) that can be manifested in different ways, depending on the nature and traits of mental.
Post by Михаил_ » Fri Mar 29, 2013 18:43
my right hand has an interesting habit first endure a flood, and therefore have to read it in flight, it hludova in the basket. And it (the habit) - reflex. It is worth noting that privias on some people then it slowly passes. Business, as they say, master, but then to be demolished starting to go it is not plodovye in General, all messages from such people.
So I highly recommend to write on the merits. I feel sorry for the time of readers who are then forced to perelopatit multi-page thread.
Кимили
Has thanked: 6 times
Post by Кимили » Wed Apr 03, 2013 20:06
Michael, let me ask a question?
Also those who prishel through my anguish to myself pobednik questions.
With BJ for almost a year. The year was intense.
Without emoticons. Much revised, much changed. Changed and transformed until the rejection of some of the trends and patterns of behavior.
(Please forgive me, for this is not a laudatory report on the use of BZ and pan technologies Michael, and the 1st and necessary step to the question. Thank you.)
So, How do you feel about such things(knowledge - practice) as:
Sefirotic( I read your indirect relationship on the pages and I myself have a feeling that something missed ...something... some puzzle in the overall picture lacking.)
Runes and rune work with the same threads.
Reiki.
Let me explain, I am a master teacher of several areas of Reiki and BJ work...this gives me a cleaner or something.
Clearer and head and the response of Consciousness of the Channel Rail.
The same happens with other practices.
After BJ in my life carefully rubbed the so-called personal(which was done personally to me) artifacts. As sensed( and BJ) that there are some not very correct to me, chattering.
Here.
Such is, in a nutshell:-) , the question turned.
Кимили
Post by Кимили » Wed Apr 03, 2013 20:10
In addition, in parallel:
A couple of weeks ago dropped( a year! Do not drop) the key Keys and Doors
Keychain split(% 30-35 split) but the key and most remained on capocaccia and ring.
A. if it Works?
Q. How would it "talk" to the reason for this bold act to reveal?
Thank you.
Кимили
*bold
Sorry.
СтАвР
Post by СтАвР » Thu Apr 04, 2013 2:33
here's a question for I1
here is the vision he can back a man whose rejection of the retina?
he is not a panacea for all ills or pancea? :)
Кимили
Post by Кимили » Thu Apr 04, 2013 2:43
For video: and СК1М could work?
There is a solution, the active cord is.
In a sense, as only 1 point?
For example: what a sore, wart, papiloma. Cold.
Post by Михаил_ » Thu Apr 04, 2013 3:40
аитвюооня wrote:For video: and СК1М could work?
ск1м -no, it can't.
it is a concept for another that follows from the description.
I1 a completely technical thing, without operatorsky software bloat, and to me has no relationship at all, except personal relationships, ск1м is a completely different thing.
Post by Михаил_ » Thu Apr 04, 2013 3:48
СтАвР wrote:here's a question for I1
with retina - Nini...
i.e. not tried and do not recommend-too thin body. It is necessary sujok.
well, see the reasons for rejection (including physical).
water with the correct structures it can fix (there are clinical cases), but it is as if there is no sale. And again it is not clear in some cases how. I do not see this from the words of the author.
I1 good - viruses, injury (acceleration splice, healing, etc.), a parasitic disease, damaged organs (they first experienced at tirrenico written off to die, etc.). There are anomalous cases like Alzheimer's, which drastically improved sweat I1 for literally one session (this was in Europe, details of further treatment is not known to me), but due to a number of factors I think eyes in General, such devices directly is impossible, and on the course - (General warming of the body) it seems possible, but it is not clear what will be the result.
However, what I heard was from one person that the detachment tagabinet parasitic nature and were such cases.
And so - no, not a panacea. But sometimes I think are some of the simple things, a vet, ASD, I1 - and the majority of cases the relatives and friends served them.And what is not - sujok (of course when needed and when possible, even personal effects of the victim or someone in the inner circle are described - the heavy artillery, and even mobile.
I1 is good because with a high probability of extremely important help the body including in cases of previously unknown diseases. As ASD however.
Post by Михаил_ » Thu Apr 04, 2013 3:49
аитвюооня wrote:And in load, in parallel:
A. if it Works?
Thank you.
apparently this is an attempt to enter into some kind of "door" - ie, a hard change of course. It is highly likely that the reason for the questions themselves here.
work is work - it nedenetsya. But the efficiency is slightly decreased and it is better certainly to replace.
Post by Михаил_ » Thu Apr 04, 2013 3:55
аитвюооня wrote:Michael, let me ask a question?
Reiki.
Here.
all of these practices are considered not very good.
Ie will take it all to the hard methods of withdrawal method the world of levers (with the exception of Reiki, there are other problems, I once wrote about them several times).
Yes, BJ will help with any data practices.
But they are not natural.
sefirotic and runes - it means "impact breakage" with the outer points, and support zones.
Serve for the purposes of those who so strongly does not resonate with the actual world and its order that for their purposes, they need an external lever and the external pivot point.
True, they got so ingrained that trying to prove that this structure is something internal.
But not quite all the way....
And Reiki well, in principle, in a soft way nothing particularly wrong with that.
And there is simply no such thing channel Reiki :) it is a natural thing, but on them hung the add-ons and often have to let flow by the method of mmm, a pyramid. In General messed up.
It is sufficient to take the desired bypassing of the system of Reiki, information and the given frequency range directly accessible including through the BZ (as the setting) any statement directly from the world. The dedication levels and the master and other attributes are not needed here. This jewelry overgrown slightly parasitic way around more or less sound ideas.<
Кимили
Post by Кимили » Thu Apr 04, 2013 3:57
Hmm, I wonder how.
Dropped In the 1st day of the workshop ASD.
So...match.
Кимили
Post by Кимили » Thu Apr 04, 2013 3:59
Read.
Thank you.
Then...choose your words...
That you can use as a Skeleton(base) of the Natural Things?
Post by Михаил_ » Thu Apr 04, 2013 4:00
well, actually a partial fracture = overload = linked to current events where a direct target-practiced program a keychain.
аитвюооня wrote:Read.
Thank you.
Flower Kamalanga read?
I didn't realize until the end of the question about the basis.
Кимили
Post by Кимили » Thu Apr 04, 2013 4:13
No, not had a chance to read it.
Even, I admit, never heard of neither the author nor work.
And the skeleton...
Let me explain: someone has a clear vector, and internal structure, and it also happens that looking for people looking for rushes that jam builds Knowledge(as he thinks. Or how it feels).
And later, coming to some new( internally only measurable level) looking back, realizes (and it is encouraging these things, and hurt) that All he was doing was looking for... some fake!
Well, some.... still sounds nice:-) but when Another fake - a hundred times harder.
Something like that.
And the skeleton= the internal structure. Structure and Values, and knowledge.
You know, books can be in the trunk or suitcase to put:-) and can be on shelves or bookcases, clearly-comfortable-strictly organized.
Кимили
Post by Кимили » Thu Apr 04, 2013 4:17
Found Olga Gromyko and its flower:-)
Try to download now or buy the day.
СтАвР
Post by СтАвР » Thu Apr 04, 2013 11:47
Михаил_ wrote:i.e. not tried and do not recommend-too thin body. It is necessary sujok.
so it is possible to try to T. V. to send?
the effect must be from this :)
and yet, what about the restoration of dental tissue?
Post by Михаил_ » Thu Apr 04, 2013 13:39
the effect is not "must be" a will, but in some cases, when vision is a secondary factor - the effect can be not fast (in General, a sick body) and need to pull not only the vision, so the effect was sustainable.
teeth incidentally I1 warming is good in the sense to remove inflammation if is = new has not yet grown, although long nobody checked. With dental tissue is necessary to work closer to the techniques of Stolbova. Ie first it is good to cleanse the body....
Moon
Post by Moon » Thu Apr 04, 2013 15:21
Michael, please enlighten:
What kind of equipment Stolbova?( poplinas, did not help)
It?
http://www.li.ru/interface/pda/?jid=342 ... 122757013/
Michael Posts - As I have grown new teeth (continued)
http://mikhail-stolbov.narod.ru/theend.htm
