Panacea or product "P"
Масяня
Re: .Panacea or product "P"
Post by Масяня » Thu Dec 06, 2012 21:27
Михаил_ wrote:read the module description and copier questions.
:o
Post by bofara » Sun Dec 09, 2012 11:49
Андрей С. wrote:about the program for stabilizer. I have no stabilizer, and I did not use any programs for it, except Stop Magic, so their work is me not understood, that is, there is no understanding on a conscious level or intuitively - this at least we must try. Therefore, as long as they are in the generator no.
Probably :) it is possible to make very large stabilizer /how many want/ overlay 'pictures' for the manufacture of stabilizer on top of a photo of a piece of land.. of Course it is good to consider different factors.. :?
Post by Михаил_ » Sun Dec 09, 2012 11:53
I would advise with these quite well, so carefully, and it will be it is interesting how such a "Big stabiliser" to destroy if something goes wrong :) yet the relationship is mutual....
Post by Михаил_ » Fri Dec 14, 2012 1:48
a little bonus symbols :) for lovers of photo processing.
please use with great caution, especially when projected on a photo of the territories (although in this sense may be).
However basic protection from the fool and just not a neat action has not been canceled (and it is impossible to abolish it in principle, and it is one of the basic principles of cells).
The top is a trace mineral at the cellular technology used in the "wheel" and "artifact clock", it is possible to integrate in TO your existing 2.0 creates an opportunity to restore structural integrity of the structures in time and to attune with different points of time and space
http://openmagic.org/g2atsrc/volchok.jpg
or
http://openmagic.org/g2atsrc/volchok001.pdf
Post by Михаил_ » Fri Dec 14, 2012 1:58
At light, can be used to overlay computer facilities and systems processing and transmission of information (communication)
http://openmagic.org/g2atsrc/G20_at006.pdf
http://openmagic.org/g2atsrc/G20_at008.pdf
Post by Михаил_ » Fri Dec 14, 2012 1:59
these are some of the long-promised surprises and gifts since the New year on a nose, there will be more.
Андрей С.
Been thanked: 4 times
Post by Андрей С. » Fri Dec 14, 2012 2:10
Wow :) Thank you!
Post by Михаил_ » Fri Dec 14, 2012 2:17
I think at-layt smart people will come up with photos which use, as for example in the case of the wheel it's already sort of been discussed. The truth might be that the principle of "a Holy place is never empty" has a lot of things because of at has a tendency to tamaraparani.
Petr99
Has thanked: 3 times
Been thanked: 15 times
Post by Petr99 » Fri Dec 14, 2012 8:13
Михаил_ wrote:at light, can be used to overlay computer facilities and systems processing and transmission of information (communication)
Michael, thank you for the gifts. I already have the at, but where to apply if u know. Tell me, which one is in and out. After all, there are different programs, and, as far as I understand, you can individually use? Maybe it's in 006, and 008 - out? Thank you.
And another question: if the connection and washing to put on the source, and the program on IC, it may make sense to do the pair and labelled them as a transfer?
Друид
Been thanked: 3 times
Post by Друид » Fri Dec 14, 2012 9:00
the one with the dot in the middle - inside (in) (in side of phone)
the one without the dots - side cap (out) (not on the lid).
Petr99
Post by Petr99 » Fri Dec 14, 2012 9:15
Druid. Thank you, checked, and is correctly set on the second phone.
Друид
Post by Друид » Fri Dec 14, 2012 9:15
It is one program in two parts, and she was just on the operator and it needs work, plus something else.
Petr99 wrote:...may make sense to do the pair and labelled them as a transfer?
Transfer this last century, very limited compared to this
димыч
Has thanked: 7 times
Been thanked: 16 times
Post by димыч » Fri Dec 14, 2012 9:34
as always - a bit of clarifying questions
At light print on two papers - one under the battery - the second battery?
the print size matter? (under cover got)
glue to the phone necessary?
about the top - except for the pictures of the placements are the same as in the case of the wheel?
Друид
Post by Друид » Fri Dec 14, 2012 10:31
димыч wrote:at the light print on two papers - one under the battery - the second battery?
Can print on one, then cut.
The size is not particularly important.
Glue on the communication device, if they have a battery on it.
Друид
Post by Друид » Fri Dec 14, 2012 11:06
dimych Carefully read the description of Michael, and all questions will disappear.
Post by Михаил_ » Fri Dec 14, 2012 12:20
actually I mostly posted pictures to use with your favorite people technology overlay on the photo.
use the spinner if you know what it is and how to continue to work with it. If not, then there's a wheel and what for You need top.
With at-Lite should be all clear... it can be used where no battery and the device is not one.
Петрос
Has thanked: 45 times
Been thanked: 9 times
Post by Петрос » Sun Dec 16, 2012 0:48
stuck on phone and laptop, the next day (day off) all outstanding among weeks things suddenly resolved by phone and Skype :)
Владимирович
Post by Владимирович » Sun Dec 16, 2012 2:21
Друид wrote:the one with the dot in the middle - inside (in) (in side of phone)
And how to stick on all sorts of routers, switches and computers?
Has thanked: 13 times
Been thanked: 49 times
Post by ФилиНН » Sun Dec 16, 2012 6:40
Михаил_ wrote:and system of processing and transmission of information (communication)
Such systems include the output stages of devices(if their "giblets" with a camera to get)?
Well, there is the cell antenna SOT, "needle", [sensored], Ostankino :wink:
Distribution of copies at, at all, whether in this way, â and the essential boxes and whether they are there for the latter?
It is reasonable and not too it? Talk about recycling at the parasitic radiation and which part is there is "parasitic" - is unclear... :)
And then maybe this crap only under the wheel to let you...
Post by Михаил_ » Sun Dec 16, 2012 17:53
it is spreading everywhere, that there is a signal (including Internet telephony, i.e. routers and network equipment in many places for a long time already and mobile equipment operators, too).
So... note.
Post by bofara » Tue Dec 18, 2012 13:07
IMHO, you can stream the track tablet /ozone, etc./ in a large room /and not only of course, depends on personal power/ - there is an option to associate a photo with an audio file in the program ACDsee about. I did so, there is an effect.. :)
It would be useful for the prevention of influenza /not only - many options / - IMHO it would be great to be around you smiling people /track endorphins/ .. If you have the opportunity and enough power, you can raise the mood of the whole city through AT2 light + panacea + of endorphins..
You can make mandalas with defined properties and as a basis to take the same photo a Panacea, Spectrum 2.1,Etalon, etc.
I thought out loud.. :)
PS Michael, please will sense if someone suddenly want to impose a 'wheel' or 'spinning top' and a photo of the asteroid /the great mass, etc./ - will work only ask because that's the outer world to the Earth ... Thank you.
Petr99
Post by Petr99 » Tue Dec 18, 2012 13:28
bofarawell done)) By often thinking out loud - very inetersno thoughts. Thank you.
Something I completely forget how to write)) :? Interesting
Petr99
Post by Petr99 » Tue Dec 18, 2012 14:09
bofara wrote:Michael, please will sense if someone suddenly want to impose a 'wheel' or 'spinning top' and a photo of the asteroid /the great mass, etc./ - will work only ask because that's the outer world to the Earth ... Thank you.
Michael does not recommend to do it from space because of misconceptions about the nature of the latter. the link does not deliver - do not want to look)) :oops:
Post by Михаил_ » Tue Dec 18, 2012 14:25
not recommended. fact. not necessary in any case.
Has thanked: 5 times
Been thanked: 8 times
Post by Воффка » Tue Dec 18, 2012 19:19
Михаил_ wrote:this is some of the long-promised surprises and gifts since the New year on a nose, there will be more.
Thank you very much! :o I have long wanted a at on phone, but here such a gift!
