BJ 2.1 / 2.2 / 2.4
Re: БЖ2.1 reinforced "hard" version 2.0
Post by Михаил_ » Tue Jul 09, 2013 3:08
well you can, and 3.0.... I would still recommend the PC or AMB...
Кимили
Has thanked: 6 times
Post by Кимили » Tue Jul 09, 2013 5:22
MM, the first - the inner silence.
to remove the importance of "what(who) need(need)", with "the right kick"...
to live. thank your heart, thank your state for what you already have.
Has thanked: 478 times
Been thanked: 264 times
Post by ЛИЛИЯ-Р » Tue Jul 09, 2013 14:15
ММ wrote:you Need to materialize your mate that ordered the Universe. Working with this problem for 2 years, but no result. :cry: The materialization of people, objects, things, own more than good. But it works how-to for details. Want to buy 3.0 or 2.6 or bracelet panacea ( wide ). Exactly what to take? Or wiser to buy all three types of BJ?
Don't forget to say :"the best and safe way".... and don't forget to speak or to think " ....this which suits me in all respects and I told him.....not zabudte to clarify the nation .)))))))An incident happens in this))
Post by ЛИЛИЯ-Р » Tue Jul 09, 2013 14:20
димыч wrote: I would advise you not to wait a single appointments, and chat with many people and then choose to taste :)
or do it the other way, do not put the purpose to find a man, and to turn into a goal :)
Not at all subtle taste, yet to taste....can and aging or to......So the above option I personally prefer. Because advised. And turn into the goal .., I don't know there probably is a target. And maniac maybe the signal to fly))))Filter then everything will have. Do I need to? The time and effort. To set the parameters and forget it. Works.
Андрей С.
Been thanked: 4 times
Post by Андрей С. » Tue Jul 09, 2013 15:10
Only, tend to forget the most difficult :)
Has thanked: 24 times
Been thanked: 142 times
Post by Маг.нет » Tue Jul 09, 2013 15:25
:) It can be easy to learn (or rather to learn how to use already available) - after "design" and launch trends (activation of the process of desire or intention) to integrate "active construct" from "operational" to "long-term" memory (not really forget, but rather to push for "background" in the "storage area" of active processes) and recall only upon receipt of feedback "feedback" from the world (through signs, circumstances, sensations of resonance events are designed with "form", etc.) then re-integrate in the "new version" (as amended - "stuck" for the time and feedback of the world that displays the focus). Yes, desires (funnel thrust) can sometimes slightly adjusted in the permitted framework with awareness of the "mechanism of implementation", but the intention....... like, took aim, pulled back the bow string, the arrow flew to the Target and then start progress Target where the arrows hit?
Sincerely, MAG.no 〠
Post by ЛИЛИЯ-Р » Tue Jul 09, 2013 15:45
No adjustment in-flight arrows, and targets if, instead of the Princess in the frog by hit. Then the adjustment. And during the flight to adjust that to slow down.....a change of trajectory , the energy loss and the important thing here is the power of intention. I was on tour at the time.....flight is a brake on progress. But in terms of it is possible and to adjust and once more, after adjusted .....And right in desyatochku)))). Something like this))
С. Альбатрос
Post by С. Альбатрос » Tue Jul 09, 2013 21:21
Not always clearly defined goal is a good, not always we know what we need, unfortunately. The result is not what I want, and what they ordered, and then do not know what these frogs do :). And then there was a precedent: an order to "lived happily together to the end of life" was realized very quickly, within 2 months, including flowers, offers of marriage, and also the last point, about the end of life, so that to adjust the aim I had in emergency mode. So be careful with the wording, especially with 3.0., even more so now. Better "most beneficial for everyone, including me (which is important) in both long and short term." :) And 2 years is not that much, maybe this is the time required for the best scenario for You. Good luck! :)
Post by Маг.нет » Tue Jul 09, 2013 22:05
So the desire (the"order" in Your interpretation of the senses) is fundamentally different from the intentions of the polarity of the supplied Power and if you take that into consideration and re-reading my post, where exactly and indicated that the presence of the understanding of the formulation of desire (of the order of the funnel thrust) can be more flexible and, if necessary, adjusted (in the permitted framework) to the process of implementation, but the intention is the aim and "shot", here focusing on the goal in forming the "intent form" can be important necessary and fundamental (to get it formulated the result, and as in the song about the magician: "I wanted the goat, and received the storm").
As for 3.0, there is generally "another song" has little to do with the wording of words, meanings, even now, even late, "there" is more important.......
Sincerely, MAG.no 〠
С. Альбатрос
Post by С. Альбатрос » Tue Jul 09, 2013 23:22
In my understanding the desire to have a primary impulse (thrust funnel?), and intention is the vector of its application, the way of implementation. The polarity of impulse/desire characterizes either the washing or grazing purpose, you can adjust its strength and direction (from/to target). Therefore, the stronger impulse and a more narrow vector, the less probability and heavier adjustments. And in a situation "like a goat, and received the storm" - error in the misalignment of the impulse/the desire and goal (I wanted one, and took over goal more). Maybe I'm wrong or oversimplifying, could You explain where? It is interesting to understand. About operational and long-term memory is clear.
Post by Маг.нет » Wed Jul 10, 2013 0:00
The emitting impulse and the pull of different directions. As the difference between the desire (attraction desired) from intentions (adherence to the target).
We can say (and sometimes to feel) with the intention of You move to the result event (goal), optionally formulated event (desired) is moving to You. You can wish, for example apples and no matter how You have them appear, and you can implement the intention is to go for apples in the store. With regard to feed and grazing (as well as redistribution) the probabilities (of events), then you need to have certain skills (or appropriate tool) otherwise, such manipulation of future events is often nothing more than fantasy, sometimes accidentally (although sometimes not accidentally) coincides with the end results.
Sincerely, MAG.no 〠
С. Альбатрос
Post by С. Альбатрос » Wed Jul 10, 2013 0:10
So more clearly. It turns out, desire and intention are two ways to achieve the goal, and not two sides of the same process? In this case, whether one wishes the person who has special skills and abilities? Or part of the work can be done unconsciously?
PS Where you can learn more about the mechanisms of feeding/grazing and other work with probabilities?
Post by Маг.нет » Wed Jul 10, 2013 0:25
I think the goal when to reach her (come to her, for example sbiraetsya on the mountain), but the desire to move is not necessarily the world (through its elements, such as other people, events, circumstances, etc.) or implement it or not yet, i.e. it is enough to wish and wait here can be useful - the more flexible wording, the more options ways of implementation, which can speed up getting the end result. Desire and intent are different processes using the opposing Forces. Often in life we are like desires and intentions, something more, something less. Work with the probabilities of other action than the formation of desires or objectives (goal-setting).
Sincerely, MAG.no 〠
ММ
Has thanked: 185 times
Been thanked: 40 times
Post by ММ » Wed Jul 10, 2013 0:43
Thank you all for the tips! :o I'll try and remember everything said. In any case, inform the following info. So actively working on your desire to attract your soul mate 2 years. On 2.1 I BJ, at, ISS-1. In 2012, on the advice of the psychologist I found on the Internet photos are very beautiful and stylish men, printed the photo and hung it in the kitchen. Such beautiful men I've ever met. And it is this type of men after my own heart. I am terrible monogamous. And what do you think?! After 1-2 months in our house drove a new family. When I saw the face of my new neighbor, I almost got a heart attack. :shock: The man is 80% similar to my boyfriend with pictures!!! It is clear that this cannot be a coincidence or accident. But my roommate's already married and has 4 children. The question is, roughly speaking, to fuck me a married man?! The Universe with the head all right? Now I can't bear to look at his neighbor. :cry: What did I do wrong? Where did I go wrong? But on the other hand it can be a powerful sign of support of my intentions with the Universe. In Simoron is Still called. They should immediately write to not forget. I myself skorosice with the experience. In General, I got confused with all of this.
С. Альбатрос
Post by С. Альбатрос » Wed Jul 10, 2013 0:52
MAG. nothanks for the explanation. Ask you a few questions :)
Why in this case depends on the degree of fulfillment of desires? The extent to which the response request World of man? Why in this case is implemented are word desire (to which no one comes, events are lining up on their own), not a true human desire? So let's say here affects the purity of the conductor? I mean psychological troubles, stereotypes, negative expectations, etc.?
And I repeat the question: is it possible somewhere to read about working with probabilities, at least as a trial?
MMthat's what the question actually: how to avoid similar incidents and to do what you want, not the neighbor :oops: :lol: In fact, given what is sent a specific request, and it sometimes really looks like a mockery. I'd love to understand WHAT are they DOING THAT??? :wiz And after a few such experiments are beginning to think: well, it nafig? Me which one is bad? Want eat candy, I want the accordion to play :)
димыч
Has thanked: 7 times
Been thanked: 16 times
Post by димыч » Wed Jul 10, 2013 1:02
apparently there was a request to a guy and about the fact that he was single - wasn't the deal :)),
I would advise to remove these restrictions in the form of a certain type of growth and so on. Not that that would be too little I guess, but dreams are inspired by fashion, movies, and fantasies, and do not meet the reality of the inner query...
can connect a channel of your kind to find the most suitable for you.
ММ
Post by ММ » Wed Jul 10, 2013 1:20
What is the channel of your race? Read more pliz.
АКВО
Post by АКВО » Wed Jul 10, 2013 2:03
MAG.no, once again notice that for some reason I find it difficult to understand Your posts... ie all generally easy and clear writtenbut for understanding, you have to read. :)
and interesting topic raised.
димыч
Post by димыч » Wed Jul 10, 2013 4:46
http://www.tstraza.com/index.php?option ... Itemid=472
well, at least it is for submission to read your kind interested in continuing, so let's moving:)
you can use a Spectrum light for this..
Post by Маг.нет » Wed Jul 10, 2013 7:05
S. AlbatrossYes including is affected by the degree of conformity desired world, or rather its abilities ("fine tuning" private event) and interests, you can still differently, the presence of events resonant with the desired or the capacity to organize such events. Thus in the presence of subtle perception, and you can test your desire to sbybot - the presence/absence of resonances in the world and their background (including emotional - for intuition). While the execution can influence also other factors ranging from time and onwards, places, circumstances, environment, matching the desired Peace, and Operator (configuration of cocoon), etc. you can also explore the other parameters of the Operator and of the World and to match/mismatch of the desired effect. What is the "true desire" is not quite understood, the Truth is generally not so simple. The purity of the conductor, as I perceived attached to this proposal, the meaning is extended (as compared to lower purity) channel Operator interaction with the World, accordingly processes in the body happen faster, including the realization of desires. With regard to "psychological problems, stereotypes, negative expectations," there are problems more serious, is "treated" (psychology - get from memory/cocoon and correct; stereotypes are created and used by people in order to save mental energy - to fill the building and not to save; negative expectations - the work of the "talk", the internal dialogue, focusing enough attention on something else, on the "washing", because where attention is, there the energy of this "talk" is not and she falls silent, until a new power-up). Something narrowly specialized in working with the probability to recommend yet can not, because in most of the materials are free flow, but if through the reflection of meanings, it is recommended here in the forum literature, it is necessary to include research attitude and "clear" meaning from the shell, something like this.
AKVOI already several times wrote about the reasons of such my messages are not hot air fabrications, and engage through words with resonant meanings for real Information, we can say (or rather - perceive) "conducting channel" in the resonating unit of the Information field, and to interact with the Information in this range requires very high-frequency Yin-potential (renewable usually during sleep), the amount of which in the great majority of cases is extremely limited capacity, so we have to approach the question of re-reading a few times and every time revealing new facets of one and the same. By the way this is sometimes partly the reason my correction immediately after the publication of the message - fine-tuning channel, a narrower focus on the faces.
Sincerely, MAG.no 〠<
инженер
Post by инженер » Wed Jul 10, 2013 14:36
the day before yesterday, being in the way, ill.
I do not remember such effects at all. almost could not speak. plus other typical cold stuff.
after submitting commands to the set of energy and healing, my 2.1. sharply (within an hour and a half) became light brown (on the outside, the inner side remains black).
now bracelet black again, feel much better.
use 2.1. since the beginning of February.
Post by Михаил_ » Wed Jul 10, 2013 18:53
I think all BJ will expand its capacity and similar effects (including visual changes)will be clearly manifested
this is not by BJ, but is associated with changes in the world, which the BZ-like things that resonate with the world and not artificially created consoles it will be more manifested in all its effects
Post by Михаил_ » Wed Jul 10, 2013 19:52
С. Альбатрос wrote:So more clearly. It turns out, desire and intention are two ways to achieve the goal, and not two sides of the same process? In this case, whether one wishes the person who has special skills and abilities?
quite
large
no need (generally it is inherent in man and the stimulus to Recalling laid in BJ).
MAG.gone about correctly explains, but not quite correctly understand the working mechanisms as much embroiled in the paradigm of a well-known school and sees the process of reaching broader and in other structural planes, so despite the extraordinary value of his comments, technically competent, in many cases, they need to reasonably filter.
There are many mechanisms of interaction with reality - said "tipitaka and grazing" - only a narrow range in a particular case.
In the most General case, if it does not limit the operator, the process goes in many planes.
If we are working with the regime of the BZ 2.x (in the world), we are talking about a complex manipulation of the Assembly of the puzzle, and it is impossible in fact to speak about something specific, rather it is a kind of switchings (switching) using a multiplicity of methods between the parts of the puzzle that changes the mechanisms and routes build new parts of reality on the basis already generated.
If primitivized process, the simplified and simultaneous application modules "spiders-move" and "passage of air", gives rise to a quantum switch to other variants of the Assembly of reality and the consolidation there of the option "quality" to stabilize the effect. From the point of view of "magic physics" is known for many historical paradigms it is generally not possible in some cases (there are no prerequisites, energy, skills of the operator etc., no need route and many others not), but it really works. Works more effectively than the operator it is tied to technical perception of the process. Imagine a surfer on the wave who THINKS as he NOW is to act the muscles :)<
Post by Михаил_ » Wed Jul 10, 2013 19:58
димыч wrote:http://www.tstraza.com/index.php?option ... Itemid=472
1. I do not recommend this read, there are primitive notions, not very closely reflects a small part of the picture (not more than 10%).
2. moreover, and in any case not to use for this range, so such mangled wood.
3. and never recommend to look for a pair based on these ideas.
do not recommend to bother - real resonance will be felt. And does not depend on any egregors, moreover, in some cases, roughly proignorit them and it will be correct.
4. generally look for a pair based on the ideas task type is quite primitive, is still something to give of himself to plant slavery on the collector conveyor. The tasks of women and men in creative and create a world much wider, and when their children, if any, will be harmonious processes would be desirable, it will be a lot more than just doing kind of reflection.
5. in addition you should not assume that an option is only one.
Post by Маг.нет » Wed Jul 10, 2013 20:00
I broadly see the working mechanisms, but narrow foci of attention to certain aspects so as not to pile up in the presentation, but in General I agree that the conjunction occurs multilevel process. As for: whether one wishes to achieve the goal, I think - not always. Test principle is easy - their own experience, to want anything and to take the results.
Sincerely, MAG.no 〠
