Stabilizer.
Ларин Иван
Re: The Stabilizer.
Post by Ларин Иван » Tue Aug 23, 2011 10:22
Michael_question to you for the manufacture of the stabilizer.
Filled paper stabilizer liquid glass, pre-made bumpers. During solidification a large portion of glue spilled (leaked), and through both zones heterosexualwhile on the "stabilizer base"formed "bald spots"(a very thin layer compared to other regions). So in the end the glue had warped and went with waves from the strong cold snap, because the stabilizer of the ROC on the windowsill.
Actually a question: to use or burn?
Ланцелот
Has thanked: 33 times
Been thanked: 11 times
Re:
Post by Ланцелот » Tue Aug 23, 2011 22:04
Логик wrote:Actually, what they sell, called the violet brush. This is the wreckage of amethyst geodes.
Received the parcel. Really "brush". :?
But big and beautiful. :D
Re: The Stabilizer.
Post by Михаил_ » Wed Aug 24, 2011 2:25
It is quite suitable.
Борис_
Re: The Stabilizer.
Post by Борис_ » Fri Aug 26, 2011 14:56
I want to put an anchor that would in a certain area was not mites.(or even smaller). What area to put.?
If the anchor was like, "ticks "do" territory".
Maybe to where it says "Border of light" ?
Re: The Stabilizer.
Post by Михаил_ » Fri Aug 26, 2011 15:58
well, anchor on "the population of clesea on the territory of so-and-so" to put in a stop (for example)
Алексc3000
Re: The Stabilizer.
Post by Алексc3000 » Thu Sep 01, 2011 11:09
Good day, recently in a famous shop across large trays of bamboo 45cm in diameter, the wall thickness of the order of 1cm, shaped like a wide bowl with a depth of about 5cm , in hands took, like a fine made soundly, the story should not, as you think you are suitable for the stabilizer in the place of a tray made of stainless steel, still the material is natural.
Re: The Stabilizer.
Post by Михаил_ » Thu Sep 01, 2011 20:06
yeah, I think it is fine. Just then his store will be more difficult (fonit will be around much)
Алексc3000
Re: The Stabilizer.
Post by Алексc3000 » Thu Sep 01, 2011 20:21
Fonit? mean that the device needs to be a certain way (by area) in the room to place a relative of the owner (operator)?
Re: The Stabilizer.
Post by Михаил_ » Thu Sep 01, 2011 20:34
metal pallet a few ....hmm... well, not the screens, but closes the areas so that they basically felt on top of the device (where needed). In other variants, most likely, will be felt around. No, a metal version of Shine around not weak, but not sector, and as a whole.
Re: The Stabilizer.
Post by Михаил_ » Thu Sep 01, 2011 20:36
We ourselves may go on the frame option. But there will be taken special measures for puff-pastry.
Алексc3000
Re: The Stabilizer.
Post by Алексc3000 » Thu Sep 01, 2011 20:55
Everything is clear, I have a device in the corner is steer it around the area nytro to my room, here's one program from the stabilizer are stored in the organizer they are the ones who in the building supermarkets are sold under the screws are small there are a lot of recesses on the size just fit, how is the whole farm properly stored, they very felt.
Re: The Stabilizer.
Post by Михаил_ » Thu Sep 01, 2011 21:03
well, felt.... there seems no special threat :)
box is this normal
Алексc3000
Re: The Stabilizer.
Post by Алексc3000 » Mon Sep 05, 2011 18:27
Placed the anchor in NATO area directly above drosou a great experience, the second day of the dig, as if wearing rose-colored glasses here still in this state to work to learn and you do not want :ap
Re: The Stabilizer.
Post by Михаил_ » Tue Sep 06, 2011 0:01
the ideal option is to find a "job" that you perform just like....
Another thing is, it's usually not that simple.
Алексc3000
Re: The Stabilizer.
Post by Алексc3000 » Sat Sep 10, 2011 0:27
Good day, I read on the forum that many in the manufacture of the stabilizer facing the problem of color change or discoloration of the drawing mandalas was printed using a photo printer or special photomachine, tell and before filling the photo Mandal laminate film or still preferably something dry to cover?
Has thanked: 24 times
Been thanked: 142 times
Re: The Stabilizer.
Post by Маг.нет » Sat Sep 10, 2011 10:01
Good!
Probably not necessary, and their appearance after hardening is not very important, the mandala performs most of the work at the time of crystallization of the material by interacting with the material, "shifting" its structure. This interaction may be a color change and discoloration of the mandala, if you still want to preserve "beauty", it is better still to use a "drying" material (varnish for example, it is when crystallization "fix" in itself the structure of the mandala). As for lamination, the mandala is better to give its properties "live interaction" without intermediaries "laminates".
In General, try to "out Stabilizer", fill 2 identical molds (you can do without molds) with 2 identical Mandal (heterosexual often with crystallization "naughty"))), one of which is laminated, the same compound (you can just varnish) with all other same conditions and observe the crystallization process (you can add a third sample - no Mandal) whether the difference.... That will be the answer to Your question.
Often, polyethylene (including laminate) are used for isolation from interference "unstable" (trend) structures of mandalas and artifacts ("stable filters," on the similarity of the structural elements of the Parlor, "filters-reference" cards for Radionics does not count, there is a different principle).
Sincerely, MAG.no
Алексc3000
Re: The Stabilizer.
Post by Алексc3000 » Sat Sep 10, 2011 23:56
Now use a large stabilizer 50 cm in diameter, it lives in the far corner of the room but too attracts the attention of the constant questions what is it? why? etc., etc. and type of anchors one of which is for non trained person, so I think to post it somewhere with the top on the Cabinet and another stabilizer to do less 40 centimeters in diameter it is easier to store and visually, I don't know why, he's twice less big it seems, so the question arose when I was doing the first Druze loaded on 1.0 technology, in the second I would like to try all the same 2.0 charge, Druze acquired on the occasion of the three hundred grams weight of large crystals beautiful, do you think with the bracelet 2.6 get such a heavy Druse charge or have the old 1.0 to do?
АКВО
Re: The Stabilizer.
Post by АКВО » Sun Sep 11, 2011 0:22
using 2.5 you can make a weak 2.0, you can also try an Amplifier to amplify 2.0
Intresno, matrix, panacea can be charged?
Re: The Stabilizer.
Post by Маг.нет » Sun Sep 11, 2011 0:35
Panacea probably not necessary... there is your settings TO. Amp 2.0 is not amplified.
Charge 1.0 (for cleaning), and FOR formed and "adjusted" mandalas of the Stabilizer.
To "work" to make the removal easier paper Stabilizer. As the mandala of the programs can be manufactured in a presentable form, such as the Gulf of compound checkers or just wkleic inside them.
Sincerely, MAG.no
АКВО
Re: The Stabilizer.
Post by АКВО » Sun Sep 11, 2011 0:40
MAG.no Your question:
May enhance and BJ 2.x - 3.0? How to produce this increase? Is it possible to strengthen the BZ remotely (on a link for a certain BJ)? What are the expected effects from gain (which literally means POWER GAIN) IIM, HF-top box, Stabilizer? Off the Amplifier provides only the flow of energy or also continue to carry out programmed tasks?
Answer:
2. Enhancing items is due to the fact that they have a "buildup" increase energy flow missed for some time. There are two ways to concentrate the whole power on the object remotely and use it at the same time, or long (a week) to keep the amp on top (live stream). However, artifacts third party, especially purely informational, I would not put, erase nafig more (wash just).
And the BJ and everything else - possible.
Алексc3000
Re: The Stabilizer.
Post by Алексc3000 » Sun Sep 11, 2011 0:52
Clearly, the paper is not I want, I want normal with drosou will again druso 1.0 system charge, so I think if after charging Druze along with a bracelet in a foil wrap and a few days in this state to write out something worthwhile, or not worth it to spend time?
Re: The Stabilizer.
Post by Маг.нет » Sun Sep 11, 2011 1:00
So it's about different gain, what do You mean by "enhance 2.0"?
Weaker 2.0 made the "weak charge", meaning not clearly spelled out the structure of BJ (KO) on the product, and even as it enhances the "boundaries and rules" better not identified clearly will not, but you can add an external thread to the Operator BJ 2.0 Amplifier or "pump" (increase bandwidth) poorly drawn structures, but in this case it's not, then it is better ready Stabilizer to the Amplifier...
2.6 you can try to charge Druze 2.0, but after she enters the Stabilizer, if it is full and big enough TO be bigger and "more drawn structural" than in the "weak charge", so it is possible, but... try.
Sincerely, MAG.no
Алексc3000
Re: The Stabilizer.
Post by Алексc3000 » Sun Sep 11, 2011 1:09
Thank you MAG.nounderstood everything, did not find the description of the stabilizer on TO it is something different from CO 2.0.
Re: The Stabilizer.
Post by Маг.нет » Sun Sep 11, 2011 1:15
The stabilizer uses TO version 2.0 generated by the charging system with the help of mandalas.
Sincerely, MAG.no
Re: The Stabilizer.
Post by Михаил_ » Sun Sep 11, 2011 14:00
no, not so.
Have TO is not as such version, it is for BJ model programs are called similar with version numbers.
When you use a charged stabilizer preprogrammed Druze TO Druze, according to their tasks.
Without charged Druze and if You have no other sources TO 2.0 - probably it will not contain KO (options), without using charged Druze, but if you have other sources TO 2.0 it can hook up TO the operator and to use it, but it is not obvious and will not happen at the start of production (where desirable).
At the time of creating charging systems stabilizer I had a well-functioning system of locks with which it was possible without fear of not Karetnyj of Boldesti for the world to give the charging system, initiating the creation of a copy of the cell.
Generally there are only three ways the occurrence of a copy of the cells with subsequent growth it in TO:
- mental command of one of the operators with the authority "administrator" (it was never distributed and not sold and can not - the powers controlling the planet are complicit in the creation of technology)
- mental command of one of the operators that have received wide powers of programming close to the administrator
- execution of the cell program in which is described the conditions for creating a copy of the object created by the call action in the world ( the use of the mandala identical to the button "create copy here")
- execution FOR a program, which describes the terms of the backup without operator intervention in the presence of certain key conditions
the first two items are almost identical, with the exception of the origin of the branches, at PP1 - independent trunks without mutual influence almost.
Incorrect programming can cause the reset "hole" - i.e. a set of cellular organisms can collapse as dangerous or disharmonious to the world.
For this reason, version 2.0 and its podorsek I was extremely careful with it, then the more advanced versions of the algorithms smolokurov had accumulated a bunch of reviews and barely managed to pripustit nuts.
