Radionic devices Karl Welz.
Generators of bio-energy (orgone)
Post by Михаил_ » Tue May 04, 2010 14:48
By the way for those who have read Karl, it should be understood that one of the biggest magical machines we use constantly.....
Вадим Перелыгин
Been thanked: 7 times
Post by Вадим Перелыгин » Tue May 04, 2010 21:44
Michael Thanks for the reply.
Interestingly, in the encyclopedia Entropy (from the Greek transformation) is a measure of the probability of stay of system in a given state (Boltzmann principle). Nonequilibrium processes in an isolated system are accompanied by increased ad that brings the system to equilibrium, where E. maximum.
If we consider the energy of "Yin" and "Yang" in the living system as nonequilibrium processes, the entropy must strive to the maximum of ie to harmony. What does the new concept of "negative entropy" – not clear!
If you take in another way, entropy is the increase of chaos and negentropy – the increase of structure, of order... some confusion in the terminology and why "High Potential will draw from the Low Potential" High potential will "pull" from low?... :roll:
Maybe "a More harmonious system would harmonize less harmonised?". I.e. the system with higher entropy(harmony) God, Life, Nature to seek to harmonize the system with low potential for harmony – human, plant, animal...
Михаил_ wrote:I just recently, will post a description to your device, which is considered biofeedback
And where will you publish? I have been interested in barefoot. Will there be something like a Mirror of the Intellect(Z)
Maxwell Cade and Geoffrey Blundell for measuring brain waves? :ay
Post by Михаил_ » Tue May 04, 2010 22:38
Here I will publish(in the sense of forum) and the device will be in stock.....
With entropy the situation is.
I have mentioned many times in different situations, that's a great idea to buy the two-volume world of tenacula Pak Jae Woo and read at leisure, drawing Parallels. There are very talented with the examples in the macro and micro world of particles and atoms to galaxies and social processes. All very technical and physical... in the sense of scientific, not esoteric :)
It is easy to be recognized and incarnation is reflected in the same Chronicles of amber, and THREE.
hmm...
In the above-mentioned Carl the Tree of Life (severoceska model) there are three pillars (vertical columns) corresponding to the same three principles, although there are significant differences of interpretation, but this is not so important.
Ie in a harmonious as a conservative force, conventionally, the power of order and the power of chaos - balanced, but the third, driving. It just seems like called Chi, ether, life energy, energy of fire...
well, or correlated with them, in General, to give a completely accurate description of the different models is difficult because of model and patterns that sometimes describe different facets of the same process.
As for the retraction of energy, or negative entropy, then Yes, any such phenomenon there is, and I do not presume to speak about them accurately. When talking about objects endowed with reason, the system does not seeking maximum entropy, it is misleading simplistic utopian science. And corrected by science in modern "updates" :)
But there are more interesting aspects, such as a valid manifestation of the Yin principle in relation to energy (the contraction itself), which is one of the existing principles and sometimes is not something negative, namely certain life process.
Did the view of Karl him or something else - I don't know.
As I understand it, he was looking for an explanation where firewood, and his explanation is correct from the point of view of one of the models :) the same processes can be described from different models from different angles.In my opinion there was a view that we see in the form of balls of mercury in a broken thermometer, they are secured in a uniform manner the surface tension forces, pulling together all of the blobs in the BLOB, so an oasis in the desert forms a rapid manifestation of life, instead of evenly scattered on her piece of trees. Oasis turns on the water source, but he might be it and produces (for example roots), which is the root cause? Why?
And the manifestation of increased life energy will begin to manifest around the resonance. To a certain extent, the contraction drops. And all around these fall into the stream (i.e. the source). In General, all processes in nature are so multifaceted that they are difficult to describe unambiguously.<
Вадим Перелыгин
Post by Вадим Перелыгин » Wed May 05, 2010 12:31
Before you dive into "the World of tenacula" Park, Jae Woo read the discussion on the Topic: "Ideas Pak Jae Woo" on the Eastern portal http://oriental.ru about their scientific and rather inclined to believe those people who challenge it. Here is one of them Egor L.
"I too can write a book "unified theory of everything. I" - quite a way with words, and to disguise her stupidity under scientific phrases, hoping that professionals from any field - 1% (and usually a lot less) of potential readers who will understand my ramblings and throw my book. But the other 99% (or even more), I earn good money".
I'm afraid that the ideas and the book of Karl Welz's "Magic of the future. A practical guide" of the same order. :?
Another question: do You Have anything to VipForex and Timecode?
Post by Dimas » Wed May 05, 2010 12:53
Vadym Perelygin
I'm Afraid that the ideas and the book of Karl Welz's "Magic of the future. A practical guide" of the same order.
About the book do not say anything, but that's about ideas not agree. Here he conveys just not very clear and shallow, but the ideas themselves deserve the most attention and study.
следующий
Post by следующий » Wed May 05, 2010 13:10
Vadym Perelygin
Since then, the same thoughts go.
Although the device works, maybe not with the efficiency with which need - related knowledge is not.
Post by Михаил_ » Wed May 05, 2010 13:12
1.Vadim, you know... Pak Jae Woo not a theorist. My practitioner reflexologist, trained personally by Puck, many years(to go ), practicing trenchline scheme with a simply stunning performance, the review You read, refers to the opinion of the person, sorry, not understand the subject, I'd rather be subjected to very serious doubt on the adequacy of the commentators-the"experts" of this kind.
Tringale Puck, is a completely practical work.
The specified two-volume popular book, but there are two practical. Popular need to build the model in the mind of the readers.
In addition, the Worlds of Tenacula, this is not the Eastern concept, and the independent fundamental.
If by the time you read this, You'll be familiar with a number of other modeling concepts, you will see a number of direct Parallels.
In particular, it is not Eastern severoceska model, and the I Ching, the principle of "work" which is decoded in the Worlds of Tenacula.
It is also worth noting that this is the only two-volume popular content written by pack, everything else - practice medicine and is very effective used by a huge number of specialists. Many of these experts are inclined to think that tronically approach to health and impact on the problems with it is the most efficient of all we have this pack for many years.
So You mentioned a commentator can write a book, but this is just nonsense, judging by his level of competence, and puck never made empty and unclaimed. It was a completely unique person.
Believe me... I've seen different.
2. The book of Charles surface and slightly (or not slightly) advertising, but gives some idea about the topic, examples are all correct in it. In the "summary" referred to real and, as I understand it, reputable schools, that does not mean of course that he really studied, and the more does not determine what they have learned, but it is not an indicator. Radionics make a profit that is seen on a number elementov. The book is made for the Western reader (IMHO), difficult to read cut :) Other than that I absolutely (and almost confirmed) I agree with what Carl wrote about the confusion of the terrain and the map itself.
You need to understand that many like the keepers of the tradition, you know very little tradition and even less know how, the result is that they keep losing practical meaning and value, containing the shell elements have no real meaning, rather iconic framing, and in modern interpretations, not understanding physics, it is the artistic part starts to give a sense of the sacred, and what comes out the nonsense.
The point is that Karl practices and no matter how he explains, he explains that people that works.
Pak practices and saved a huge number of people's lives and health, and many changed lives, giving a different perception of reality.
This is undeniable, plenty of those other people is huge. Theorists lubimie to chat for his life in the interest of their topic does not interest me.
3. direct.<
следующий
Post by следующий » Wed May 05, 2010 13:14
Dimas wrote:but the ideas themselves deserve the most careful attention and study
It's kind of hard to learn on rumor and sucking of the thumb.
And from my own experience not one life will be gone. How many cones will be stuffed!
Post by Guest » Wed May 05, 2010 13:19
следующий wrote:camera works, maybe not with the efficiency with which
needs? Rather can! Maybe Your expectations have convinced You of this?
следующий
Post by следующий » Wed May 05, 2010 13:25
Михаил_ wrote:the Book is made for the Western reader (IMHO), difficult to read cut
Michael,
You could not, would if You have the time to translate this manual into our native language
can I ask Carl what would that he were cut, he was sent back home. I mean - to us.
Post by Guest » Wed May 05, 2010 13:25
Dimas wrote:conveys he is not very clear and superficially
that would not reveal some of the contradictions of understanding - flexibility. I think the main thing is "translator" gave us the "mysteries". The literary translation of "the coloring" is to Novels it would require a "conversational" translation (literal) with the advice of the Magician by interpretation. Then everything will fall into place.
следующий
Post by следующий » Wed May 05, 2010 13:27
Гость wrote:Can Your expectations led You to this?
I mean, expectations?
следующий
Post by следующий » Wed May 05, 2010 13:28
Гость wrote:this requires a "conversational" translation (literal) with the advice of the Magician by interpretation. Then everything will fall into place.
I agree.
Post by Guest » Wed May 05, 2010 13:36
следующий wrote:Your expectations
...the reason - the "translation"...
Empowering expectations - potentiation "miracle". Let me explain, removing the frame restrictions, we are expanding our capabilities, and as a consequence the capabilities of the tools used in these processes.
After reviewing the materials on Radionica I put my frame, and got the real capabilities of the device. So far EVERYTHING MEETS EXPECTATIONS!
P. S. This is the approach I APPLY to ALL GOODS Psychotronics...
следующий
Post by следующий » Wed May 05, 2010 13:39
Гость wrote:after Reviewing the materials on Radionica I put my frame, and got the real capabilities of the device. So far EVERYTHING MEETS EXPECTATIONS!
Share your experience?
Post by Guest » Wed May 05, 2010 13:49
следующий wrote:experience?
it's not experience - is the use of "models" and frameworks based on experience in other fields of knowledge.
следующий
Post by следующий » Wed May 05, 2010 13:53
Share the use of "models" and frameworks.
Post by Guest » Wed May 05, 2010 13:59
следующий wrote:Share the use of "models" and frameworks.
what is it like?
... model used only those where they have a fairly complete understanding of the scope formed according to the same principles.
Model - "as it happens" frame "as there is no" main argument "because..."
следующий
Post by следующий » Wed May 05, 2010 14:03
Гость wrote:model is used, only those where you have a fairly complete understanding of the scope formed according to the same principles.
And You give an example - like You had.
You can?
Post by Guest » Wed May 05, 2010 14:19
1. Example:
- it can't be because...
usually, because...
2. Being able to "decorate" (the strategy of literary creativity), get to share the essence and the "excitement of understanding", i.e. to separate the wheat from the chaff.
3. After analyzing all the texts of the description of the devices Psychotronics Department of General (present in all texts), I got the DRY RESIDUE - from which to form expectations...
следующий
Post by следующий » Wed May 05, 2010 14:23
Thanks, everything is clear
олигарх
Has thanked: 10 times
Been thanked: 4 times
Post by олигарх » Fri May 07, 2010 1:31
I wanted to offer this idea,if we assume people have mastered the Rad 2400 wanted later buy a more powerful Rad,because of the uselessness of the first,it can be sold at a reasonable price to those who really wants to,but doesn't have that option(or lease office+surcharge for the next purchase and the office will have to offer in the assortment of goods as the b/u) will be more sales in your most powerful range of devices Rad+a kind of publicity in product promotion and expansion of the merged common interest of people.In my opinion with the help of instruments Rad society will begin to develop a more progressive(hopefully most for the better,although everyone has their own way of trial and error,no need to intervene,but you should always be ready to help when necessary if your wish).
I'm not trying to be clever,just an idea,I think why not ask for your opinion.
Post by Михаил_ » Fri May 07, 2010 2:02
I would not recommend due to the specific binding of the device to the host ( I already wrote - it is better not to show your happy anyone! keep them out of sight). b.from. the unit will easily tune the previous owner, including inadvertently...
рыжая
Has thanked: 34 times
Been thanked: 46 times
Post by рыжая » Fri May 07, 2010 12:52
Guys, those who have Rad 2400, tell me, please what kind of power supply need exactly?
ГОРОДСКОЙ СУМАСШЕДШИЙ
Has thanked: 115 times
Post by ГОРОДСКОЙ СУМАСШЕДШИЙ » Fri May 07, 2010 13:03
рыжая wrote:have a Rad 2400
I have included with Psychotronics came. Very good!
