About the parlor
оуаакун
Post by оуаакун » Sat Aug 15, 2009 12:39
Arthur C.
Here it will lead to normal in a few days. I, by the way, is feeling the heat, even liked, but right now I miss him. Whereas once the cold has started, and I was hot in a t-shirt and even had a desire to bathe in the Yauza river. :)
оуаакун
Post by оуаакун » Sat Aug 15, 2009 13:14
In some branch Going Forward also about the heat from the Chamber wrote.
Артур К.
Post by Артур К. » Sat Aug 15, 2009 15:33
awaken
And what she had then was the result ? On used ?
оуаакун
Post by оуаакун » Sat Aug 15, 2009 15:53
Артур К. wrote:And what she had then was the result ? On used ?
After about 4 weeks of wearing it I no longer feel (the effect on me of the SS). And even thought that maybe she broke down. Or come addictive.
And Going Forward, I think was referring to the energy that comes out of the right hand (and enhanced by the Parlor) on the Anahata chakra.
Try to wear on his chest when the temperature rises - same SS 2 fingers below the navel, if you feel the relief immediately ( within 10 minutes) so that SS raises the temperature. If nothing changes - then it's something else. :?
Ростислав
Post by Ростислав » Sat Aug 15, 2009 19:06
And my temperature does not rise above 36.1 the last time! Carry in his pants pocket.
Post by Guest » Sat Aug 15, 2009 21:20
Rostislav
the temperature and normalization of all processes in the body (that is, when using the super chamber) to rise. If, for example, in the body there is a chronic focus of infection. Temperature - a protective reaction of the organism. Therefore, to eliminate this center the body is necessary to raise the overall temperature. This is a normal process. Among the doctors say: "the Patient felt sick (after treatment) the doctor is happy". It is in the best sense of the word. The patient that's sick, the fever means the body is on the road to recovery, the body's defenses running. :D
Солнышко :-)
Post by Солнышко :-) » Sat Aug 15, 2009 22:52
It was the Sun :-)
Гость 007
Post by Гость 007 » Sun Aug 16, 2009 22:08
Please tell me what is the difference between the Svetlitsa 3 740 R. what is offered on this site and for R. 890, which is available at http://www.svetlitsa.ru. Thank you.
Post by Guest » Sun Aug 16, 2009 22:49
Guest 007
Like the author said. On the website front room of the old model. And here the new and augmented with new ideas. The parlor seems to work only with the space and this time.
Гост'ь
Post by Гост'ь » Mon Aug 17, 2009 13:32
Good day.
Use Your product - there are both pluses and minuses.
Theoretically ....
That is the question : If you take pre unlucky pensioner's financial wealth which is limited to one-room apartment and a pension of 5,000 rubles, and to arm his front Room Good-Brilliant for a month or two (so he didn't know about it), what is the gain of financial wealth through the quarter ? Feel whether the pensioner cash flow ?
Suppose that the mental state of test subjects is very positive, but actually in condition to go to work, he can not, no relatives.
Гостья
Post by Гостья » Mon Aug 17, 2009 13:39
Dear standard"s,
Please tell us about the pros and of course cons.
Гост'ь
Post by Гост'ь » Mon Aug 17, 2009 13:50
Make in the form of a report.
Day 1 (day of purchase).
Condition as usual. Nothing unusual about that.
Day - 2 (after 6 hours of sleep).
Unusual excitement with tranquility. Worked 24 hours, fatigue from working felt somewhere around the 23rd evening, slept great (3 hours), and then slept another day.
Day 3 (sleep 7 hours).
Remains joy, a little vivacity.
Then as a whole unchanged.
The only thing that is marked stable (more or less) is the increased mental activity. Decisions are made faster, his head clear.
I will Express my opinion - I would not recommend meditation without the help (or at least the same Method Silva) the use of this device in persons attending psychiatrist (with panic attacks, depression). It seems to me that this thing can have an impact on the realization of the aspirations, and such persons aim, in view of the disorder, the destruction.
Here.
Гост'ь
Post by Гост'ь » Mon Aug 17, 2009 13:52
Oh, I almost forgot, my neck is hanging "Donor Forces."
Post by Dimas » Mon Aug 17, 2009 14:18
Host s
Try to put in a pocket Svetlitsa Super, in effect it is more powerful than a Chamber donor.
Гостья
Post by Гостья » Mon Aug 17, 2009 14:21
Thanks, GOST"K, but You wear around the clock without breaks? Maybe it's better to take breaks when wearing?
And here is a question for ASD is ripe.
Mr Danovich,
If the chamber increases the energy of desire that occurs in people with unconscious self-destructive motives and autoimmune disorders (which also have self-destruction)? The desire to self-destruct is lost or enhanced?
Post by Guest » Mon Aug 17, 2009 14:26
Артур К. wrote:Dimas
Based on the fact that when I rented it on my next day off temperature. Once again trying to vilify appears again. While I don't want her to wear. Will try in about 5 days to vilify, if will pop up again the temperature, I think that will cease to wear it.
Arthur , you are likely very impressionable and hypochondriac people ? that's basically the mechanism of action of svetlitsy PLACEBO and carousing !
it's easy to check ... ask relatives to quietly put you in a neck pouch that the parlor the simulator on the weight and size ... that's when it will be able to know that it affects you ... and as rightly said demAs : Arthur C.
Arthur, explain in detail please on what basis You conclude that wearing a Chamber You have a fever?
after all, you did not eliminate the placebo effect !!! it is a pity that this effect could be explained by other effects , though positive ... but in these cases no one doubts that they are from svetlice :roll:
the paradox :?
Гост'ь
Post by Гост'ь » Mon Aug 17, 2009 14:44
Dimas, I will try, a little later =)
First, existing information tchotchke we need to understand and then "bigger and Stronger".
We'll see what else next week will be.
Гост'ь
Post by Гост'ь » Mon Aug 17, 2009 14:45
Guest, no measurable change regardless of the periodic wearing =)
Post by Guest » Mon Aug 17, 2009 14:46
Arthur C. Yes , and most clearly placebo manifested on the body , that it inculcated the brain and the psyche is exposed to the homeostasis and functions of the body ...
still under the influence of gravity falls in the placebo effect for subjective assessments of feelings and insights striving to replace real experience as a real ... success , luck and etc ...
Post by Dimas » Mon Aug 17, 2009 15:00
And You, I understand, a specialist in the placebo effect? :)
Post by Guest » Mon Aug 17, 2009 15:11
Dimas wrote:Guest
well I irony ... and if it's not ironic that prokomentirujte what's wrong ? I did and your statement used and made the same assertions but in the opposite direction ...
I'm not a placebo but a logical chain to perform can ... that is, to trace the causes and consequences of deriving one from the other ... osporte insights and not sneer against the person az
ASD it says : 2. In the body there is a hidden foci of chronic infection with which the body itself can not cope. As a result of interaction with Svetla appears the reserve energy that the body wants to fight this infection. As a result, worsening with increasing temperature. So try to be patient, let the body cope with the hearth. I recommend to go see physicians.
he's a doctor ? other doctors agree with him ? and speaking your own words but according to the ASD ... explain in detail please on what basis You conclude that wearing a Chamber You have, you receive a reserve for energy that the body wants to fight this infection. As a result, worsening with increasing temperature.?
:roll:
Post by Dimas » Mon Aug 17, 2009 15:16
Why do You always suspect me in some kind of catch? I can't just ask a question?
To argue with You and challenge something I'm not going, I already wrote to You about this someday. ASD is not a doctor, but tightly associate with them (on the topic of the Parlor), so I think he has a reason to talk about the reserves of energy and other things from the point of view of medicine.
And about the temperature there are already like someone said, I think even ASD, and if he did not, and ASD is not commented, so apparently he agrees with this point of view.
Post by Guest » Mon Aug 17, 2009 15:21
And you probably have a hidden inside desire to buy the parlor :wink: So you attempt all questions . Better buy and try for yourself :)
Post by Guest » Mon Aug 17, 2009 15:39
Anonymous wrote:Guest
Yes, of course I don't mind positive things but only if they are justified ...
you buy me a chicken foot if I give the is and say it cures all diseases ? buy to test ? and then a lot of amulets from Internet and Newspapers ? go to the top ten witches and Sens extra ?
why you are reluctant to respond for example to a sensible offer on Arthur : it's easy to check ... ask relatives to quietly put you in a neck pouch that the parlor the simulator on the weight and size ... that's when it will be able to know that it affects you ...
why he does anything anyone asks, and even stakeholders and being the kind of intelligent and educated can't distinguish the real reasons from self-imposed simple process of elimination ?
Гостья
Post by Гостья » Mon Aug 17, 2009 15:46
Гость wrote:why you are reluctant to respond for example to a sensible offer on Arthur : it's easy to check ... ask relatives to quietly put you in a neck pouch that the parlor the simulator on the weight and size ... that's when it will be able to know that it affects you ...
Dear Guest, how do you imagine such an experiment ? To make a circle of the same material, same size and same weight (with a groove around the circumference) ? For example, I could not imagine how to do it at home a regular user of the drawing rooms.
Despite the fact that I still have all sorts of questions about the front Room, I can tell You - it works - improves performance, relieves pain.
