What is this power manifested?Искатель-2 wrote:tried to activate the contactless vegetable juice (tone)
powerful effect
Structured water
Re: Structured water
I found this online:
Dear friends, You know? Who thinks about this?<216 digit name of God
A method of obtaining answers to their questions, when there is not enough information for analysis.
A method of determining the information based on entropy, it is entropy sensor.
1) Write a question starting with the words: - "How to change the order of (those actions)?", it's already happened or conceived of to the accomplishment.
2) Throw 3 dice 21 times and record the combination of numbers.
3) Then stamped (+) next to the harmonic combinations, for example: 1,2,3 (harmonic number n); 1,2,4 (harmonic series 2n); 1,2,6 (harmonic number n); 1,2,1 (the harmonic series Gauss); 2,4,6 (harmonic series 2n); 1,3,5 (harmonic series 1+2n).
And affix (-) in front of the non-harmonic combinations, for example:
1,2,5; 2,4,5; 2,1,2 etc.
Against combinations of 1,1,1; 2,2,2; ....6,6,6 have uncertainty, because they can be represented as a harmonious close to n0, and not harmonious, for example: 10,20,50; 20,40,50; 20,10,20.
4) writing Order of a cube is not important, for example: 1,3,2; 2,1,3 1,2,3 or all United as 1,2,3 (harmonic number n).
5) Take the difference between the number of + and – and see the order from the plan of action in the range from 0 through -21 to +21.
6) All possible combinations is 216, of which 210 are a certainty, and 6 are uncertainty. If a response is received to have the uncertainty should delay receiving a response to this question until the next day. The same question can be answered only once a day.
(1) 1 2 3 4 5 6 (4) 1 2 3 4 5 6
1 1,1,1 1,1,2 1,1,3 1,1,4 1,1,5 1,1,6 1 4,1,1 4,1,2 4,1,3 4,1,4 4,1,5 4,1,6
2 1,2,1 1,2,2 1,2,3 1,2,4 1,2,5 1,2,6 2 4,2,1 4,2,2 4,2,3 4,2,4 4,2,5 4,2,6
3 1,3,1 1,3,2 1,3,3 1,3,4 1,3,5 1,3,6 3 4,3,1 4,3,2 4,3,3 4,3,4 4,3,5 4,3,6
4 1,4,1 1,4,2 1,4,3 1,4,4 1,4,5 1,4,6 4 4,4,1 4,4,2 4,4,3 4,4,4 4,4,5 4,4,6
5 1,5,1 1,5,2 1,5,3 1,5,4 1,5,5 1,5,6 5 4,5,1 4,5,2 4,5,3 4,5,4 4,5,5 4,5,6
6 1,6,1 1,6,2 1,6,3 1,6,4 1,6,5 1,6,6 6 4,6,1 4,6,2 4,6,3 4,6,4 4,6,5 4,6,6
(2) 1 2 3 4 5 6 (5) 1 2 3 4 5 6
1 2,1,1 2,1,2 2,1,3 2,1,4 2,1,5 2,1,6 1 5,1,1 5,1,2 5,1,3 5,1,4 5,1,5 5,1,6
2 2,2,1 2,2,2 2,2,3 2,2,4 2,2,5 2,2,6 2 5,2,1 5,2,2 5,2,3 5,2,4 5,2,5 5,2,6
3 2,3,1 2,3,2 2,3,3 2,3,4 2,3,5 2,3,6 3 5,3,1 5,3,2 5,3,3 5,3,4 5,3,5 5,3,6
4 2,4,1 2,4,2 2,4,3 2,4,4 2,4,5 2,4,6 4 5,4,1 5,4,2 5,4,3 5,4,4 5,4,5 5,4,6
5 2,5,1 2,5,2 2,5,3 2,5,4 2,5,5 2,5,6 5 5,5,1 5,5,2 5,5,3 5,5,4 5,5,5 5,5,6
6 2,6,1 2,6,2 2,6,3 2,6,4 2,6,5 2,6,6 6 5,6,1 5,6,2 5,6,3 5,6,4 5,6,5 5,6,6
(3) 1 2 3 4 5 6 (6) 1 2 3 4 5 6
1 3,1,1 3,1,2 3,1,3 3,1,4 3,1,5 3,1,6 1 6,1,1 6,1,2 6,1,3 6,1,4 6,1,5 6,1,6
2 3,2,1 3,2,2 3,2,3 3,2,4 3,2,5 3,2,6 2 6,2,1 6,2,2 6,2,3 6,2,4 6,2,5 6,2,6
3 3,3,1 3,3,2 3,3,3 3,3,4 3,3,5 3,3,6 3 6,3,1 6,3,2 6,3,3 6,3,4 6,3,5 6,3,6
4 3,4,1 3,4,2 3,4,3 3,4,4 3,4,5 3,4,6 4 6,4,1 6,4,2 6,4,3 6,4,4 6,4,5 6,4,6
5 3,5,1 3,5,2 3,5,3 3,5,4 3,5,5 3,5,6 5 6,5,1 6,5,2 6,5,3 6,5,4 6,5,5 6,5,6
6 3,6,1 3,6,2 3,6,3 3,6,4 3,6,5 3,6,6 6 6,6,1 6,6,2 6,6,3 6,6,4 6,6,5 6,6,6
Speak this language mind and nature. The structure of water process the information.
This technique is a product of the collective mind of three people: (by) Eremin Dmitry Ivanovich, (opponents) a Nut Yuri erikovich Zalogin Vladislav Stanislavovich.
Literature: Marc Silberman "the fire bird of luck" Technique of Youth 5-1991 p. 20. The Movie "PI" Darren Aronofsky. A. S. Pushkin "Queen of spades". The Film "Great Secret Of Water".
A bit reminiscent of the Book of changes - I Ching. But then dear Master of the TaoIgor wrote:... Method of getting answers to their questions when there is not enough information for analysis.
2) Throw 3 dice 21 times and record the combination of numbers....
Igorthank You - that's interesting! Will You have problems if you specify iztochnik this information on the Internet? Of course, I see the mentioned literature. Thanks in advance.
I just saw the accident on forum one of the participants is attached to the message file.bofara wrote: A bit reminiscent of the Book of changes - I Ching. But then dear Master of the Taothere are specialist.
Saw it and was interested.
Igor interesting system, apparently Michael_ promised in the programme for СКМ1 uses something similar, only instead of a cube psyleron.
Искатель-2
well, once the charge in the head, hands and feet felt the Hizdakchut of the juice by energy-feelingsКарил wrote:What is this power manifested?Искатель-2 wrote:tried to activate the contactless vegetable juice (tone)
powerful effect
another felt that it works.
if you drink activated water, the effect is similar.
(EC-but pre-net)
and then I look at the people from the tap pours, activates deshovye akomodasi, chlorine was timetal puff puff, and people think that's cool
For sure we do not know it, but you can use anything, a coin (binary data), the cube (six data), etc.Хаст wrote:Igor interesting system, apparently Michael_ promised in the programme for СКМ1 uses something similar, only instead of a cube psyleron.
My IMHO is not worth it to drink juice restored, i.e. any juice in the package.Искатель-2 wrote:well, just a shot in the head, hands and feet felt the Hizdakchut of the juice by energy-feelings
(EC-but pre-net)
He's plastic and not porous as possible?the activated liquid through a thin layer (layer a glass for example) gets into the juice itself
sort of, he's pretty caustic, stomach ulcers are not afraid?Карил wrote:I Advise you to try beet juice to activate
the main thing that the Cup (and indeed any utensils in contact with activated liquids) was not plastic; disposable cups suitable for this purpose.Карил wrote:He's plastic and not porous as possible?
(rumor has it) the trick is that the electrons and protons seeping through the plastic
I am not afraid. Another question have you ever beet juice drank?ЗОМБИ wrote:sort, and so it is quite pungent, stomach ulcers are not afraid?Карил wrote:He's plastic and not porous as possible?
Carilo drank once, maybe a couple, but can not drink, can not remember
his ulcer is not recommended...
but when I tried to get drunk raw beets, Yopt, pancreatic toli toli still that... well it's not nice
Well, raw beets a little rough for the pampered human stomach, the unaccustomed and could be hurt.ЗОМБИ wrote:but when I tried to get drunk raw beets, Yopt, pancreatic toli toli still that... well it's not nice
Искатель-2
My IMHO shouldn't drink juice restored, i.e. any juice in the package.
It's certainly not tap water, but he seems to be "neutered" compared to fresh. Too sweet, too sour and empty. For example, after tomato juice a metallic taste on the tongue.
I advise you to try beet juice to activate. Not tried it myself (yet there is nothing to activate), but I think it will be abruptly.
totally agree, at that time just the other was not. And so the juicer is.
penetrates fluid and IONS through a thin layer of latex condom
i.e. through the thin layer of transferred CHARGE
learn the theory http://ikar.udm.ru/c_n_aw.htm
He's plastic and not porous as possible?[/quote]the activated liquid through a thin layer (layer a glass for example) gets into the juice itself
ahem... and it (the condom) should be washed thoroughly with soap and water before use, on both sides???? there is in fact a lubricant, the silicone to be kind of... eww.Искатель-2 wrote:does not penetrate fluid and IONS through a thin layer of latex condom
Искатель-2
condoms for ultrasound go without lubrication (because they like anal and smeared directly on the ultrasound vaseline or whatever)ЗОМБИ wrote:ahem... and it (the condom) should be washed thoroughly with soap and water before use, on both sides???? there is in fact a lubricant, the silicone to be kind of... eww.Искатель-2 wrote:does not penetrate fluid and IONS through a thin layer of latex condom
well, you can just plastic Cup put in a vessel-a jar by the promoters - it's easier than to pull the condom and it may break even
the essence just is to have a thin film through which the IONS passed
Искатель-2
the Seeker-2
Yes, very interesting technology. Only, it seems, for two days this water can not drink, because it ativirus all the chemicals dissolved in it and significantly increases the permeability of cell membranes... But then (when all impurities are "burned") it turns really water activated, can activate when you are adding small doses of other water in large volumes. At least so I understood from all the research reports.
As the activator changes the ORP if you do not consume electricity. So any other activation takes place. What is this activation which increases the permeability, but does not change the ORP (or change)? And as the impurities burn, they're in the water? Precipitate?Андрей Патрушев wrote:the Seeker-2
ORP and pH change. All chemical substances dissolved in water, activated (probably via free radical mechanism), and "furiously" come together in a chemical reaction, "burn." Activation is the ultrasound, which appears apparently in the water flow - know-how.Карил wrote:As the activator changes the ORP if you do not consume electricity. So any other activation takes place. What is this activation which increases the permeability, but does not change the ORP (or change)? And as the impurities burn, they're in the water? Precipitate? Can a small educational program for the teapot to arrange?
Andrei Patrushev Thanks for the reply.
Actually... I Read and felt like a Pithecanthropus. Live so think smart, well excited
at least not the most stupid and here you. Ultrasound, radicals even theoretically can't imagine that with water occurs.
Искатель-2
so Shironosov once said - before electrolysis to indulge it is necessary to first PHYSICALLY the water to clear. Along with otherwise useful, will electrolysis and salts of heavy metals.Андрей Патрушев wrote:Iskatel-2
Искатель-2
so I wonder how it without. What is there for technology. Prices on the website do not have. But I have this activator vidil from Icarus, they did the test. Bullshit and they will not take.Карил wrote:As the activator changes the ORP if you do not consume electricity. So any other activation takes place. What is this activation which increases the permeability, but does not change the ORP (or change)? And as the impurities burn, they're in the water? Precipitate? Can a small educational program for the teapot to arrange?
Can technology Shandera, or as the Germans call it when the water passes the structure - XS
Even as - is I'm still in the 90s he tried it, when an expert chemist he worked, and the most dangerous thing in "live" water is going...Искатель-2 wrote:along with Otherwise useful, will electrolysis and salts of heavy metals.
Electrolysis-electrolysis strife. In short chopped high-voltage pulses, the picture is completely different from classical chemistry. No wonder the same kierowcy say words like "plasma". There are lots including scientific and our Patriotic works, showing the facts of transmutation and other weird things. A good man recently told me that based on the high-voltage discharge in water, they have developed a method of deactivating a radioactive suspension in water (Ukraine - there is a place to apply in the form of local issues, and money does not, as always).At the output of different composition.
So much depends on what is served on the electrodes. There is an opinion that the process is manageable.
Well, except for the odious some Bolotov, who recently reissued his work about isostere (which I think is not even close to adequate to reality, but confirmation at the experimental level that is), it is possible for example to tell the Yandex energeia-2, there are a lot of interesting, except for energenie (http://www.rulev-igor.narod.ru/theme_172.html)
cannot find the page created by the sponsors of the project, there were references to similar studies are not data-bound project - a whole page. Where it was in one of my posts, but I do not remember what thread, here or in the debate with the author of "New physics".
