CD "brain Massage"
Post by Андрей Патрушев » Sun Feb 08, 2009 16:48
Натуся wrote:"You Probably long did not draw attention to myself"
Will have this phrase to adopt :)
Works 100% - as well as "YOU HAVE DAMAGE!!" :shock:
I do something to offend you?
Post by Андрей Патрушев » Sun Feb 08, 2009 16:57
Anonymous wrote:
Андрей Патрушев wrote:
Anonymous wrote:Listen to the CD "brain Massage", but I can not allocate at least some changes. Nothing happens. The head does not hurt. Sleep perfectly.
The disc is played in different modes: morning, afternoon, evening, with water or without.
Can a disk do not give me any effect?
Comment, please
A healthy head even analginum does not help... :)
Did You have issues for which you bought the disc? What do You expect to receive as a result? What tests are use to verify?
I think like most, I can focus only on subjective feelings. And trust it to them first and foremost. Tests were not.
More interestingly, even feelings of any effects not.
Negative or positive is not important, no feel
Well, it is clear that the test was not... :) In the entire history of this forum only one woman (vaasche no one else :cry: ) seriously went to his brain and ran tests on memorization of foreign words...
But about the rest-how? - Did You have issues for which you bought the disc? What do You expect to receive as a result? Have You ever had a life experience when You felt what the impact is, :roll: You now targeting? Do You drive a car, or, perhaps, doing something that requires dexterity, fine motor skills? How many times and in what mode You've already listened to this CD?
Натуся
Post by Натуся » Sun Feb 08, 2009 23:47
"I do something to offend?"
Yes You are! When wrote, thought about the fact that I do not have specifics :o
Post by Андрей Патрушев » Mon Feb 09, 2009 17:21
Натуся wrote:"did I do something to offend you?"
:o :?
Post by Dimas » Fri Feb 13, 2009 12:45
Andrei Patrushev
here's what we've noticed together with my wife: doing the Massage of the brain in the morning,after sleep.The room is warm,under a blanket in the sleeping heat,she and I got through 3 minutes after the start of the program starts the chills and want to wrap yourself in a blanket.Andrew,this is normal and why this happens? :ap :roll:
оуаакун
Post by оуаакун » Wed Feb 18, 2009 18:47
Dimas wrote:here's what we've noticed together with my wife: doing the Massage of the brain in the morning,after sleep.The room is warm,under a blanket in the sleeping heat,she and I got through 3 minutes after the start of the program starts the chills and want to wrap yourself in a blanket.Andrew,this is normal and why this happens?
I become cold even under the blanket. But only from the Explorer. :)
And no wife... :?
Post by Андрей Патрушев » Wed Feb 18, 2009 19:07
Dimas wrote:Andrei Patrushev
During deep relaxation (like during sleep) reduced body temperature.
Счастливчик
Post by Счастливчик » Thu Feb 19, 2009 18:12
Àíäðåé ñêàæèòå ïîæàëóéñòà, à ìîæíî ëè äàâàòü ïðîñëóøèâàòü Ìàññàæ ìîçãà, 7-ìè ëåòíåìó ìàëü÷èêó? (âìåñòå ñ ìàéíä ìàøèíêîé èëè áåç)
Îí ïëîõî ðàçâèâàåòñÿ, òàê êàê â èìååò ïîâðåæäåíèÿ øåéíûõ õðåáöàõ è êðîâü ïëîõî ïîñòóïàëà äåòñòâå... â È â ó òåïåðü íåãî 7 ëåò ðàçâèòèå 3-4 ãîäîâîãî ðåáíêà... =(
Èëè ìîæåò ïîñîâåòóåòå äðóãîé äèñê...
Post by Андрей Патрушев » Thu Feb 19, 2009 21:52
Счастливчик wrote:Andrew, please tell me whether it is possible to give a listen to the Massage of the brain, 7-year-old boy? (along with a mind machine or not)
It is poorly developed, as it has a damage in the cervical hrabcak and blood badly as a child... And now he is 7 years development 3-4 annual child... =(
Or can you advise another disk...
Better 2nd track Star Wanderer, but first find a good vertebrologist and tidy up the guy's spine.
Алив
Cerebral palsy and massage of the brain
Post by Алив » Sun Feb 22, 2009 15:24
Hi all, I want to share the experience. Attended the course mm, I was able to finally abandon the pill clonazepam, who drank 5 years. I have the effects of cerebral palsy. I am 32 years old. Maasi brain is a very powerful and efficient drive. I want to ask, has anyone else used this disk (or other disks) with cerebral palsy. Maybe there are some features.
Матвей
Post by Матвей » Sat Feb 28, 2009 23:33
I am glad that your blog is constantly evolving. Such posts only added popularity.
Счастливчик
Post by Счастливчик » Sun Mar 01, 2009 0:36
Ëó÷øå 2-é òðåê Çâåçäíîãî Ñòðàííèêà, ñíà íî÷àëà íàéäèòå õîðîøåãî âåðòåáðîëîãà è ïðèâåäèòå â ïîðÿäîê ïàðíþ ïîçâîíî÷íèê.[/quote]
Îê, íó à ïî-ïîîäó Ìàéíä ìàøèíêè... Å ìîæíî ïðèìåíÿòü äëÿ ðåáíêà?
Ñïàñèáî
Post by Андрей Патрушев » Sun Mar 01, 2009 10:58
Счастливчик wrote:Better the 2nd track Star Wanderer, but first find a good vertebrologist and tidy up the guy's spine.
OK, well, in poodoo Mind machines... It can be used for a child?
Thanks[/quote]
Start with the 2nd track Star Wanderer. In the General case (without any problems) with mashinoy better to start with 14 years. In Your case you can try, but be careful at low brightness and volume and not more than 15 minutes.
Post by Guest » Sun Mar 01, 2009 13:37
Thank you!
Post by Гость » Sun Mar 01, 2009 20:37
You sell something that they themselves did, and rightly so. But do Your products have certifications? Is there any statistics based on the results of the research? Don't think I'm being nosy or questioning aktivnosti Your products, I'm just not used to trust blindly.
Best regards
Post by Гость » Sun Mar 01, 2009 20:43
Sorry. The previous post about certificates and statistics addressed to Andrei Patrushev.
САМОЛЕТ
Post by САМОЛЕТ » Fri Mar 06, 2009 6:24
The question is....
What to do while listening to disc "MM".For example while listening to "disk Imaging" we need to try to visualize...When listening to the CD"Focus" should be on something to concentrate, etc., etc.
I'm listening "MM" was trying to relax.After all, it alalfa-ROM so you should give relaxation.But somehow still not very good for him to relax.Maybe under the "MM" does not need to relax even though he was an alpha drive? Maybe this is my fault?
PS.Tried to learn to draw but I wasn't very good.On the fourth day of listening "MM" I tried to go back to this lesson.And the miracle happened! I was able to draw a very good drawing!Of course,the object that I was pererisovyvali on paper in terms of a good artist is very simple,but before I even could draw.So for me it's quite a decent achievement :)
Post by Андрей Патрушев » Fri Mar 06, 2009 12:42
САМОЛЕТ wrote:the Question is....
Of course, as with any massage, it is best to relax, but it is a passive practice, so no need to try or try... :) Just try to listen carefully to all the sound material (recall that the volume is comfortable and closer to the quiet).
Post by Guest » Fri Mar 06, 2009 17:33
And about my discovered abilities of the artist :) what do you say? Could only four-time listening "MM"to have such an impact?
САМОЛЕТ
Post by САМОЛЕТ » Fri Mar 06, 2009 17:34
"And about my discovered abilities of the artist say what? Could only four-time listening "MM"to have such an impact?"
That was my message.
оуаакун
Post by оуаакун » Fri Mar 06, 2009 17:42
САМОЛЕТ wrote:"AND about my discovered abilities of the artist say what? Could only four-time listening "MM"to have such an impact?"
Out with the drawings. Check it out. 8)
САМОЛЕТ
Post by САМОЛЕТ » Fri Mar 06, 2009 17:52
What about "the ability of the artist" I am of course speaking figuratively.... :oops:
САМОЛЕТ
Post by САМОЛЕТ » Fri Mar 06, 2009 18:45
And yet I noticed that the drive is "MM" as that is not right.I listen to this disc early in the morning between 6:00 and 7:00.And the result is evident after about 16:00.By this time there is some clarity,vigor,"otdohnuli" :)
лиза
Post by лиза » Mon Mar 09, 2009 15:23
But I immediately after a Massage clarity and vivacity :) appears. Listen too at 6-7 am,really asleep and under the disk, and another hour after :)
САМОЛЕТ
Post by САМОЛЕТ » Mon Mar 09, 2009 16:02
Now I, too, once and satranala for a whole day :D .But at first why-that was not immediately.....
