Stabilizer.
Алексc3000
Post by Алексc3000 » Wed Aug 10, 2011 13:17
Glue strictly according to the description in the beginning of the topic, there is a graphical scheme is, after potting compound top pictures it is advisable to stick on the bottom because the border in the process of casting move, the boundaries between the areas are blurred and defined about the components of the compound that is certainly my understanding of the process.
Ларин Иван
Post by Ларин Иван » Wed Aug 10, 2011 13:41
Found the answer to your question on the photo http://openmagic.org/ex/stabl_big.jpg
See the decal placement.
АКВО
Post by АКВО » Wed Aug 10, 2011 16:50
Is there any way to strengthen the programs of the stabilizer to carry them in your pocket, in addition to pouring anything?
Ланцелот
Has thanked: 33 times
Been thanked: 11 times
Post by Ланцелот » Thu Aug 11, 2011 21:14
All kind time of day.
Went shopping and decided it was better to make the tray yourself. Stainless steel lorry. However there is a problem with the extrusion of the rim.
Michael_
1. And it is possible the collar will not bend or squeeze, welded to a round plate strip? You once mentioned that you can use the cover of the tank, where mud is the same principle of manufacture?
2. Stainless steel polished, polished inside to do or snaruzhu?
Design should be robust, 3-4 cm backside stand quietly.
Post by Михаил_ » Thu Aug 11, 2011 23:50
1. it is possible it and not to do - the main thing to ensure to be able to fill the part and he is not turned.. and after hardening it is something you can simply remove.
but you can weld it. The lid of the barrel just stamped, but it doesn't matter.
2. no matter which polished, but probably the best out.
3. resin called epoxy... :) (I am famous for boring).
Post by Михаил_ » Fri Aug 12, 2011 0:03
АКВО wrote:is there any way to strengthen the programs of the stabilizer to carry them in your pocket, in addition to pouring anything?
Well, ways to enhance anything there is just a lot, a lot a million.... the question is which ones are quite comfortable and of a reasonable finances. That's probably is the determining factor. For example, you can make a hologram. Will be stronger. Well, more precisely it would be called a lithograph, because the holo is already a consequence of the fact that "printed" the right way processed by the math model. But it's not cheap...
Or you could just increase the number of printouts. Make them a sandwich.
You can, again, laser to burn.
You can for example put a picture of something conductive and cover it with metal, such as copper, by electroplating.
You can handle already made a printout to reinforce the properties of different methods, e.g. amplifier. Well, for a primitive version collect kacher with cold discharge and a conical coil with a ratio of top to bottom more than 1 to 2.
And so on.. you can still kryvobrody to do.
Just many options...cough cough... not the easiest.
Again, metal casting.... melted... a great way. Well who does not like to replace the wax, but there are properties to go.
And the wax, resin...
You can make moooooolto stoppage, and put it in his pocket part of it, as part of the whole associated with great.
Ways million even remember laziness.
What we do these or other products or devices now it is so and not otherwise - is a tribute to the occasion, convenience, efficiency and so on. It would be possible to do everything differently.
So with this particular case - that made the glass in 3D, but it was possible to etch the metal with acid :)
Or even to blow glass.
Or to carve wood.
Use as a reinforcing ingredient dragon's blood I will not advise, since the first is not to find neither her nor dragons in the second - not the fact that he will take a drop thereof, rather, pre-SWAT, and third, I'm a member of the society for the protection of these creatures.<
Has thanked: 2 times
Been thanked: 21 times
Post by Логик » Fri Aug 12, 2011 0:17
Михаил_ wrote:it was possible to etch the metal with acid
I asked several times, should I make the drawings by etching, to enhance the effect...
but you insisted either on the laser or on printouts. Now it turns out that it is worth.
Post by Михаил_ » Fri Aug 12, 2011 0:38
:) I have listed the possible options, but does not say by etching to obtain a SIGNIFICANT gain, compared to, for example, with 5 printouts on a laser color printer. But this does not mean that such method do not, and that it can enhance the individual dances with a tambourine. The question is whether their venture?
Well, for example, 100 years ago, it was not under the hand of the lasers was shitty with the technology of electroforming and no matter with cryogenic technology. Obviously I had to choose from a few different list options.
Etching will not give the quality of fixation on the material and its structure (if you give it too thin layer). Or need to leave in place the results of the chemical. response. Well, for example, to blacken the picture. However, in some cases, because of the weight of the sample and its strength, it can have its advantages. But loses to the casting.
Casting has disadvantages due to the fragility caused by structures in the product. Even technologically correct and not to look fragile sometimes breaks things in an unpredictable place for no apparent reason.
The laser is more effective.
One simple method, which requires a one-time investment. Buy a projector with laser pumping. Video projector I mean. For screens home theater.
Post by Логик » Fri Aug 12, 2011 0:44
The cheapest Chinese engraver cost about $ 800. But there is a big but... it's a tracing of your drawings. A very non-trivial if at all real.
Post by Михаил_ » Fri Aug 12, 2011 0:56
WELL I wouldn't say that I Trossero not trivial :)
Ланцелот
Post by Ланцелот » Sat Aug 13, 2011 11:26
Druses of amethyst can be purchased here http://uralsuvenir.storeland.ru.
Ordered, waiting for the parcel. The first impression from the contact with the site, not bad.
Post by Логик » Sat Aug 13, 2011 13:35
Actually, what they sell, called the violet brush. This is the wreckage of amethyst geodes.
Алексc3000
Post by Алексc3000 » Sat Aug 13, 2011 17:28
This stuff VVC is full, there is a pavilion with stones trades in the owner before buying to hold and twist, but it certainly is for Muscovites, and and another place there twice a month show sales are 8) on the Crimean Shaft if I'm not mistaken.
Ланцелот
Post by Ланцелот » Sat Aug 13, 2011 21:14
I don't know. I photo impressed, I ordered. In any case, to go to the Crimean Shaft, for me, is ten times more. :)
Has thanked: 5 times
Been thanked: 8 times
Re:
Post by Воффка » Mon Aug 15, 2011 14:36
Логик wrote:Actually, what they sell, called the violet brush. This is the wreckage of amethyst geodes.
Ie lying that sell druzu? Actually it's not a Druze?
Has thanked: 24 times
Been thanked: 142 times
Re: The Stabilizer.
Post by Маг.нет » Mon Aug 15, 2011 15:41
Amethyst crusts is a microcrystalline aggregates of amethyst on the breed and size of individuals 5-10 mm.
Ie "nudecrystal" (unripe) because of its small size.
Sincerely, MAG.no
Re: The Stabilizer.
Post by Воффка » Tue Aug 16, 2011 19:07
MAG.no
Don't know what online shop can be a normal Druse amethyst to take?
Re: The Stabilizer.
Post by Маг.нет » Tue Aug 16, 2011 21:05
We have some shops available there
the normal range in the "affordable" prices
so through the Internet never bought.
If the Stabilizer on my brush....
Sincerely, MAG.no
Ланцелот
Re: The Stabilizer.
Post by Ланцелот » Wed Aug 17, 2011 10:25
Before the production I want to clarify some points.
1. Druze, clay, wax and oil charging technology BJ 1.0 , do I need to charge epoxy resin and the tray.
2. If not recharged, it is possible to put the first track cleanup on the epoxy and tray to clear the information.
3. Thickness compaud will be about inch, the height of the Druze about 2 inches. Druse is placed on the first layer and almost half filled with compucom? Somewhere I came across a Board Mihailathat Druze not necessary, or not necessarily immersed in compoud.
4. Can or should carry out the work in a clean or just a beautiful place? I plan to do everything in Mageweave relict forest.
5. SP left a mental programmer. In this part of the forum was not very favor, but still, you can use it, to submit to him any frequency or tracks from records in breia curing resin? Or is it another story?
Re: The Stabilizer.
Post by Михаил_ » Wed Aug 17, 2011 15:08
1. charge Druze.
2. without peeling it, cleaning will produce stickers
3. inch is a lot - maybe to a full boil, akkuratno.
4. Druze can be loaded in the last queue but it is better to do it. Do not immerse if there is a danger to screw up, to get
5. A good place is a good thing.
6. No additional signals do not need to file, you need to stickers worked for the establishment of a zone of the stabilizer in the process of hardening of the composition and all.
Ланцелот
Re: The Stabilizer.
Post by Ланцелот » Wed Aug 17, 2011 16:15
Thank you.
Алексc3000
Re: The Stabilizer.
Post by Алексc3000 » Thu Aug 18, 2011 0:44
When the stabilizer was doing, too, thought like druzey to be shorter just glued it to a stick a long a little more than the diameter of the tray gluer, centrolock made and then filled, and the device really works, be careful with the anchors :)
Ланцелот
Re: The Stabilizer.
Post by Ланцелот » Thu Aug 18, 2011 10:32
View. My stabilizer will be any different from all. 8)
I originally want it was only with right hand twist. And from the center should go cold. :D
Will he then stabilizer - :?
Хаст
Has thanked: 13 times
Re: The Stabilizer.
Post by Хаст » Thu Aug 18, 2011 11:01
Confirm once you have done (with no fill and the Druze on a small plastic tray), accidentally put the anchor itself in all aspects in chaos, confused heterosexual with Neutro (like creativity). In General, slightly shook, and health and situations, started to cough in the morning pressure, despite the fact that even in winter I rarely get sick. Through day 3 noticed I had the wrong area, moved the anchor in natro.
Re: The Stabilizer.
Post by Михаил_ » Thu Aug 18, 2011 20:19
Well don't joke like that with an anchor :)
