Radionic devices Karl Welz.
- Шалтай Балтай
- Has thanked: 125 times
- Been thanked: 263 times
As the Romans said, "spit into the root"Dimas wrote:Humpty Baltay
Damn, so it's not just the spring, as I first thought, so that all ... extremely..
http://en.wikipedia.org/wiki/Orgone
PSBeginning with a materialist concept of the Freudian libido, Reich ultimately came to see orgone as a massless, omnipresent substance, similar to luminiferous aether, but more closely associated with vital, living energy than inert matter.
I do not recommend to drive the device at the beginning of the day.
Sometimes - switch it off.
- Шалтай Балтай
- Шалтай Балтай
- Шалтай Балтай
- Владимир Никонов 2
- Has thanked: 20 times
- Been thanked: 28 times
New materials on radionica:
- Frequency for Radionics and programs implementation intentions
- the Causes of failures when working with radionic device
- Radionics weight loss
- the Transfer of energy on other people and multiple operations
- Successful business, wealth, leadership, skills working with people
- Шалтай Балтай
Volodya did.
What you need
Especially advise to pay attention to this thread:
PS
Volodya, if you can throw links right here:
http://www.mindmachine.ru/viewtopic.php?t=3164
Those I suffered.
Saved
What you need
In principle, this is a common statement of objectives, nevertheless very good. especially important when working with radionicallyНиконов Владимир wrote: - the Causes of failures when working with radionic device
PS
Those I suffered.
Saved
- ГОРОДСКОЙ СУМАСШЕДШИЙ
- Has thanked: 115 times
- Been thanked: 1 time
Сергей11
Checked RAD2400 HD in a simple blind taste test on water
the bottom line: in two identical clean glass is poured drinking water from a bottle southcrete one glass half an hour delivered to the tube of the device
testers - two women - wife and mother - in-law negatively related to the device(large adherents of the Russian Orthodox Church).
In fact, with great difficulty was forced to try, for fear of dangerous forces and other nonsense
Both noted the difference in the taste of water, not knowing which is which, noted the sweetness and pleasantness of the water after the appliance
http://www.koob.ru/mag/
http://www.koob.ru/cart/
http://www.koob.ru/astrology/
There is always something to read...
- Просто_идущий
- Просто_идущий
Came just now!Dimas wrote:Humpty Baltay
Sorry for the indelicate question. You once bought radionic, nothing weird don't feel ...um..cough...in a sexual way?
On may 2, made of copper tube battery. Almost the entire day holding it in his hands, aiming at different parts of the body, on chakras, on your photo, etc.
On may 3, Nakata is (forgive me, wife!).
4th may (ie today) have: a sense of guilt and remorse, toad strangling for the money spent on a paid love and a complete misunderstanding of what happened.
Until I read post Dimasa.
system f-tsiya, you need to have some useful application of energy in their lives and sexually will become harmonious, even at the same intensity.
Most people think that the motivation of the actions and evaluations of the world themselves, even though they are more part of the biosphere and motivation via the network. Biosfera saw, pardon the comparison, to you gentlemen, "breeding bulls", due to the fact that healthy people bear it, and in the city where to take the healthy men? In physical and energy terms healthy. Here you gruzanuli such a motivational signal to the piece number of people to correct the bias obtained by a shortage of million
hihi.
You can:
1. to be able to move the energy.
2. to be able to spend it on different levels so that excess particularly, there is a healthy abundance.
3. to be able to filter intelligently the external signal. On the principle of "siren heard, but I'm not a crowd, I have other tasks."
4. to have to the outside world and in some cases, the cost of which outweighs the role of the successor of the tribe.
by the way, over estimate the world of human potential successor kind often leads (if there are no other strong factors) to the natural rejuvenation of the body, at least the signal is going.
You can:
a simple pipe connection is a simple home spring, not a machine. For purposes not adapted, the instrument of Karl - complex device, not only electron, i.e. it must not be seen by eye seem to be constructive.Просто_идущий wrote:Hello, Michael!
Made orgone accumulator of the copper pipe (according to the book Welz).
Feel weak cold stream in the direction of the hand, the wife the opposite - heat. Anyway works!
Tell me the use cases with goals.
To use any source of energy with the goals, you need to know how to work with these objectives without a source, including locking the work into something paper or electronic, allowing, with this commit, connect external source to recharge implementation.
Ie is the task of consciousness.
- Вадим Перелыгин
- Been thanked: 7 times
Yes... that is the best in the short term may be worse in the long term!Михаил_ wrote:Purpose it is necessary to correctly formulate! Radionic and other technologies (you can in fact with mindmachine work, etc.) are taught how to formulate goals. The more flexible the better, but with the "insurance" from the left options. Therefore, "the best way for me in the short and long term
How to pass a razor between momentary pleasure and long-term use?
The famous expression "Afraid of their desires! They can come true!" calls very carefully consider your goals and trends.
Thank you Michael for the detailed, competent and clear answers!
Could You clarify the issue of negentropy? In the book "Magic of the future" on 10стр describes the Negative entropy in systems of vitality. I do not understand the expression "will draw High Potential from Low Potential".
and you can explain what is meant by a hook, and incoming port more specifically, that did not work, I give advice don't understand the question?Anonymous wrote:if the goal is to create a "hook" (incoming port)?Михаил_ wrote:if the goal is to create a simple transfer pair for energy
if we are talking about the transfer of pure energy from source, we don't need the second item, make the first and only item correlated with the MOST energy.
This way one of several know-how of Carl
Here is an example with the same germinated seeds - in nature, in the moment of delivery, the man or plant, he is given a lot of energy on this process. If we talk about person, talk to different modern maternity centres not adhering to health relation to the process, they will tell you that the start of delivery, is associated literally with the "enable" channel of energy. Then, often immediately after birth (tens of minutes), sometimes the next day, parous is "fever", a strong chill - channel is turned off, and the body is already used... There is very much more powerful Radionics.
In plants it is almost the same, only the scale is different. The biosphere takes care of the support of the species, feeding him from their sources. When dry the germinated seed begins to, he's literally given input channel, a special outlet.
This is a consequence of certain life processes in the complex scale of the biosphere, there is no "mind" in human understanding, it's just a resonance in some way.
What am I? the channel feeding the new life exists objectively (remember I recommended about Jiang read - it is the signal of rejuvenation takes from the same germinated seeds, which by the way is not always correct).
If this channel is shown somewhere (a plate of seeds germinated) and we fix it in the nearest neighborhood (froze us there is something), it turns out the subject of very long aligned with the signal, it will be the socket itself. Yet not change its structure.
The structure will be very slow to change itself or due to excessive consumption of energy. Ie if it otherit very much, he will die as the source. If you take in the normal range - will give energy for many years.<
But in order to fix something it is necessary to create a thread to signal "demolished" in our object to be processed. In Radionics it is the tube output. But there is pure quality + set modulation (centredistance). In other cases, use of shapes (geometry) or shape (mentally) or both + materials, screens, etc.
I can explain in detail in your own words. But it's long.....Вадим Перелыгин wrote: Could You clarify the issue of negentropy? In the book "Magic of the future" on 10стр describes the Negative entropy in systems of vitality. I do not understand the expression "will draw High Potential from Low Potential".
Very briefly is the principle of harmonization. Just balancing on the blade, the balance of forces leads to the fact that energy is stored and not emitted, and the result is emitted and as it gets bigger.
We can say that the object gains an experience that enables him to obtain another status in the world that gives him energy, i.e. here, in terms of the "law of conservation" to find other principles. The energy produced by the information. So You have 10 copies of a computer file with a photo or warez version of MS-office 10 times to copy with the media, any USB flash drive, where we copy.
In the case of the worlds media the whole world. And the program - our experience.
Creating a balance between chaos and order we generate the energy of life.
I'm afraid that my explanation is not very clear.
It's too fundamental a question will come back to it later.
I a few days will post a description to your device, which is considered biofeedback, but in fact is also a kind of emitter, there will be a lot of harmony in the goals and between the subject (man) and the world. I.e. what leads to the solution of our tasks or a pleasant "accident" from a physical point of view (understanding of the processes that was). So let's try to describe why there is an increase in energy. But I do not believe that she contracted from everywhere, its manifestation at a given point increases, but in fact it is a dimensionless object as a fractal structure. The change of energy somewhere is changing the biosphere as a whole, but the scale Radionics, even in mass production, this does not influence... ie the planet so nobody can change, especially in the technical human activity there is an imbalance in the other direction.
