Orgone generator with their hands (The Succor Punch, SP)
ИгорьС
Has thanked: 5 times
Re: Orgone generator with their hands (The Succor Punch, SP)
Post by ИгорьС » Tue Jun 09, 2015 10:29
The two of us-me and the wife. And this is 4th attempt to wind Mobius. Of the winding wire is slightly better, but still has nodes/ (however, even with such a wound toroid without a crystal well spin the pendulum counterclockwise)
Sitting watching the video, as the Americans shakes Moebius: hooked wire over a nail the other end in a drill and counter-clockwise. A couple of minutes and you're done. :roll: .
Look for more then.
Ланцелот
Has thanked: 33 times
Been thanked: 11 times
Post by Ланцелот » Wed Jun 10, 2015 0:43
ИгорьС wrote:but still there are nodes
The knots are due to the fact that the cable is badly stretched. On the opposite side of the drill on the two wire loop. If each loop to make the interference, the nodes will not. They appear when these two loops to hook onto one hook. And yet, before winding, you need to flatten the wire. I use a soft flannel. To smooth from the drill to the eyelets. Therefore, the desired preload on each, the distance between the eyes and a drill for a few millimeters different.
ИгорьС
Post by ИгорьС » Wed Jun 10, 2015 9:29
Ie if you catch the 2 hooks should be better? I tried 2 springs to cling to, but probably should be more tight. These have started to curl.
Свами Доупаду
Post by Свами Доупаду » Thu Jun 11, 2015 0:38
Ланцелот wrote:Igors
Plastic insulation rigid, not solko extra turns in different places. The insulation should be soft but durable. Therefore, the better the Polish.
-About insulation strength totally agree with You. Winding short circuit is not Gud...
Came at the time (paraporti a bunch of wires :D ) to the fact that you can use varnishing copper wire in additional silk insulation were PALSO cross-section was 1 mm. the flagellum diameter. 3.2 mm.:
and that's what Coyle did (Mota the size of the crystal, EXT.dia.50mm, 88mm external.) :
on the lower photo, the coil is still "raw", unaltered...from behind her crystal :)
( I'm so, in terms of exchange of experience :) )
ИгорьС
Post by ИгорьС » Thu Jun 11, 2015 9:30
Krasoten!
Tried again to twist the wire. Drove 2 nails side by side, each hooked over the loop and began to twist. Ares ultra, it is very important that the tension of both parts were the same. Look for 2 springs tighter and try to catch them.
By the way, there is interesting info on scalar waves: http://milogy.net/content/1_98.html
Ланцелот
Post by Ланцелот » Sat Jun 13, 2015 12:48
Swami Dopado Looks beautiful Moebius. But... it is Desirable that the twist angle was close to 45 degrees in the photo, to the eye 60. The circumference should be three turns on a photo or 2, or a little more, but certainly not three. At Mobius, if you twist 45 degrees, then the windings have to look almost in the center of the ring. In the photo they do not look into the center, and to mine the diameter at 1/3 and 2/3.
Judging by Logan's not quite right.
Igors
Therefore, we need a third. it provides a preload instead of springs. Although you can try to throw a loop on the springs, smooth wire flannel, to remove loops in the springs manually to ensure tightness. But in this case, the 45 degree angle is difficult to obtain. I have never worked. Here you need to find the wire.
Свами Доупаду
Post by Свами Доупаду » Sun Jun 14, 2015 15:38
Ланцелот wrote:Swami Dopado Looks beautiful Moebius. But... it is Desirable that the twist angle was close to 45 degrees in the photo, to the eye 60. The circumference should be three turns on a photo or 2, or a little more, but certainly not three. At Mobius, if you twist 45 degrees, then the windings have to look almost in the center of the ring. In the photo they do not look into the center, and to mine the diameter at 1/3 and 2/3.
-I know :) The coil was made 3 years ago,but for various reasons was never filled. Photo I brought purely for demonstration leads to silk Of PALSO. In fact, then the same, and came to the idea of refusal from the Mobius coil,of the more efficient operation of such devices is not "Mobius coil" and the coil birthplace of Marco - Rodin Coil.. :wiz
Ланцелот
Post by Ланцелот » Sun Jun 14, 2015 23:37
Свами Доупаду wrote:and coil the birthplace of Marco - Rodin Coil
Flat or convex? And how it is combined with the crystal, if possible a photo. :?
XUPOH
Been thanked: 10 times
Post by XUPOH » Mon Jun 15, 2015 22:29
Logan argued that the coolest coil - Cesco Little Secret Coil.
Some even with the help of the water "boiled":http://u2.lege.net/whale.to/b/orgonite_boiling.html
Свами Доупаду
Post by Свами Доупаду » Mon Jun 15, 2015 22:45
- A classic "donut hole" . photos can not bring ,alas.. :?
and that the curved coil home ?
АлексЦБР
Post by АлексЦБР » Mon Jun 15, 2015 23:03
Good time of day.
Please tell me, in terms of efficiency (power) is a big difference between a quartz crystal and a simple piece of quartz? If the same size, approximately. Fill in a simple organit, without coil.
Ланцелот
Post by Ланцелот » Mon Jun 15, 2015 23:05
Свами Доупаду wrote:and that the curved coil home ?
After removal from the prototyping Board, I have all the coils of Logan become in the form of 12 petal Lotus. :)
The photo in the Internet they are flat, why do I have these - I don't know. I'm at the beginning, they were straightened by hand. But then they stopped. The sensations, the curved better. The latter made arched-surround (with the fixation of the wire intersections of the glue gun on top). Feels - most of my.
PS Now looked on Yandex photo, I have it without the bagel. Like
The initial diameter of 20 inches.
Свами Доупаду
Post by Свами Доупаду » Mon Jun 15, 2015 23:28
АлексЦБР wrote:Good day.
-The difference in the passive device will not feel.Read the brochure of Logan, he's generally crushed quartz makes the surrogates :)
АлексЦБР
Post by АлексЦБР » Mon Jun 15, 2015 23:35
Thank you.
ИгорьС
Post by ИгорьС » Sat Jun 20, 2015 16:27
Today the market was down, was asked about politiki. The seller said there, but it boils if a thick layer, than put me in a stupor. Like wrote that boils the epoxy and PE no. Has anyone filled in PE?
ИгорьС
Post by ИгорьС » Wed Jun 24, 2015 0:54
Thank you for reading.
Read. Somehow not impressed. It is better to epoxy, although more expensive.
Unless there are different types of PE resin and what I saw normally dries in the air.
АлексЦБР
Post by АлексЦБР » Wed Jun 24, 2015 10:33
Polipol 3401TA I such took, yet not flooded.
пилот а
Post by пилот а » Sat Jul 04, 2015 4:10
if anyone is interested in a very powerful device -- fill it with mercury.
Эдуард
Has thanked: 4 times
Post by Эдуард » Tue Jul 07, 2015 11:28
who's on the bottom when you create a sp put out paper sign of life? and what?
what is the effect if there is?
is it worth doing or no?
what sign would you recommend?
Post by Мастер 108 » Tue Jul 07, 2015 14:04
Эдуард wrote:is it worth doing or no?
Edward, you make m this way and that, experiment and tell us... okay?
Владимирвввв
Post by Владимирвввв » Tue Jul 14, 2015 1:38
Looked for fun videos on YouTube on the topic of orgone, orgonite - this word search was introduced.and here's a video I found interesting - orgone music generator in which the generator are realized, the LEDs and an input for a feed signal.shown that it works and the clouds disperse as cloudbuster.Understand that powerful enough.Details of how to do not clear because it says the author of the video in Spanish or some such language.
Maybe someone knows this language? And method.Like, such a device significantly more powerful than conventional organic similar size (if not mistaken)
Седой
Has thanked: 13 times
Been thanked: 36 times
Post by Седой » Tue Jul 14, 2015 5:20
8) I think it is because of Bob Marley. While I watched the movie, we turned off the water. :?
To give to every intent in the form of the experiment it is necessary to observe at least a few primitive conditions.
The result should be repeatable regardless of where the actions of participants and other circumstances not included in necessary for the experiment conditions. In the video, only it is not visible.
Second. I am sure that the real experimenters, if they were on the site will agree with me that the POWER of the device does not plays absolutely no role at least in the devices based on organito. If the purpose of the device is obviously clear and understandable, that is, the device amplifies the intention of the operator in the implementation of the operator with the logo.
By this I do not understand how can coloured LEDs to the music of Bob Marley to influence the weather, despite the fact that the operator is stoned Brazilian teen hardly fingering in English. So the whole thing in Chinese magnetic balls in orgonite bizarre without the quartz crystal. az :?
As the saying goes. In a miracle is to believe, it turns out that it's true.
Владимирвввв
Post by Владимирвввв » Tue Jul 14, 2015 13:31
There is information about what the LEDs have the same bioenergy SV-VA http://www.second-physics.ru/work/zhigalov_effects.pdf page 11.
Well true or not the effectiveness of the product is not clear of course.
чернокнижник
Has thanked: 14 times
Been thanked: 24 times
Post by чернокнижник » Wed Jul 29, 2015 22:19
As you are such a perversion? )))) By the way, I think it works!
Desi warm lamp orgone!
