Orgone generator with their hands (The Succor Punch, SP)
Re: Orgone generator with their hands (The Succor Punch, SP)
Please tell me on the winding cat. Mobius the link http://www.whale.to/b/mobius_tut.html
(the fifth picture where it is wound three turns)
Do I understand correctly:
1. From my long wire depends on the number of turns ( although the picture three turns is like a start is an example)?
2. Everything should be like in this picture :a new round -by h. the arrow and the front part goes into them is a node , then a new round every time the node gets fat on turn?
3.What if wear down whole wire left on the ends of which a new round is not enough: those who are two to Jack -okay ,and others where to shove it.
4. Gray
wrote:
... To achieve accurate 45 degree angle in the coils. Should be nice and smooth.
I do not understand is what with what, 45* ?
4. Gray
what can be rather relative to what.Михаилл wrote:
4. Gray
Turn to turn to fit at an angle close to 90 degrees, and if the wire is put on a flat surface the relative lengths of wire coils should lie at an angle of 45 gr. That is, the winding is tight enough but not too much!
The thinner and longer the wire the better. But much more complicated. I have a coil length 5000метров.
Which happened only on the third attempt. PALSO 0,01 1920Ом resistance. Motala winter in the yard. Insanity beginner called.
But all these experiments was an attempt to understand the physics of the process. And not helped. And helped ferrocene.
Gray, you six months ago, intrigued by the ferrocene. Maybe it's time to reveal to the world the secret. I should be grateful for your revelations may be some truthСедой wrote: And helped ferrocene.
Questions on honey in orgonite:
1.Dismantled transformer from the Soviet televisora on the subject of copper mining.
Made all dobrotno ... -- on the coils the wires were paraffin in some places
(how could the removed hot water) -will not affect these remnants of wax on the quality of orgonite (after slicing and silicium boxilai)?
2. Whether small(0.5 mm2) wires to remove insulation when grinding and filling
amoxidal (varnish clear-do not remove) ?
3. Old wires should be such as especially to clean before grinding and filling?
- Has thanked: 1 time
- Been thanked: 10 times
1. Will not be affected
2. Lacquer insulation to remove it is not necessary
3. Well, some clean energy method Sanjeevini. Here somewhere the link was on the book.
warlock:
Quote:
Where to find it - I looked in the shops there? Gallop it is necessary for the first layer?
Quote:
What is it ?
Looking for bronze powder -the whole town was ransacked - found Toko 10 g over 46 RUB.
You can place it brass?
The cut will have however.
Thank you.
Quote:
candurin
Quote:
pasta GOI
What is it ?
Thank you.
- чернокнижник
- Has thanked: 14 times
- Been thanked: 24 times
Searching in the network, where pastry chefs hang out. So tamp the resin to the breaking point and thoroughly mix. Then add the previously prepared hardener. It may be more expensive than it seems, five grams cost about a hundred rubles. If you search (Google to help) - will be cheaper.Михаилл wrote:Where to find it - I looked in the shops there? Gallop it is necessary for the first layer?
Speaking of search engines - that's what Wikipedia says about GOI paste: grinding and polishing pastes based on chromium oxide.
PS. In three clicks now you can find almost any information, don't be lazy! I mean, what to look for here is public information, is not comme Il faut))) good Luck!
Dear Gray wrote in this thread about the benefits of a silver bracelet on his left hand
-I wanted to hear more about the useful properties.
Thank you .
Thank you .
It is rather the field of subtle energies or of folk superstition or belief in luck. In men, the flow of energy through your left hand and the outflow through the right. In women the opposite.Михаилл wrote:Dear Gray wrote in this thread about the benefits of a silver bracelet on his left hand
Thank you .
Silver has the property to elevate and purify energy. It is easily programmed to protect or to uphold.
Not to say that I always wear bracelets but sometimes I feel that I need either copper or silver. On which hand. I just feel like I need it. The same thing with my crystals.
Got a couple of tips.
Handle money with my left hand. Right give left take! For this try to give money with your left hand and not hand to hand. So there was no outflow.
And I add a few words about gold.
The gold kills the function. How to understand it.
Each finger is linked energetically with a certain role of the body or destiny. Gold inhibits the function.
For example, a ring on right thumb means that the person thereby knowingly terminates the function of choice of a partner, ceases to send a signal to others...
This can be interpreted that the choice has already been made and it is a sign of the but in fact the thing that stops the search. Logically it is the same energy but not...
Avoid wearing gold jewelry without the knowledge of the energy properties. You thereby kill himself. Gold on the index finger of the right hand will result in the loss of any expression of will and power. And on his left hand to accept the will of others and subordination.
But a refusal will not save you from the evil of the head and will not put you in his place, would be likely to conflict...
In the continued offtopic:
The wearing of watches with metal bracelet on his left hand blocks the flow of energy on the right outflow.
1.Heard that silver bracelet on his left hand lowers the temperature.
I have a son 6 years of age sometimes catch a cold and having fever is it possible for him to try?
Usually, helped put the circles on the palm and fingers, massaging around the nail.
2. Is it possible to wear it to the woman (80 years) to maintain the health and tone?
Любопытный
I wish you all good health. Please tell me if the device works individually, as his on this very individuality to configure?
If you have individual taste, you like a certain type of women, or specifically some sort. Who can tell how to get the woman be yours for the rest of your life.
Individuality is a loose concept.
The device has no handles and regulators.
There's only one link that you can customize. It is you yourself.
How to configure you so that you become a great pianist or aircraft?
So, understand the essence, the very idea of the device and it will be unnecessary for you. And in this way learn something useful.
By the way, inspiring news for all.
My student won the car, which was played in a supermarket. I just admonished advice. So in all fairness. Got what you wanted and much that was worthy.
Focus on the desired object.
6 years of our work together that she did and finally realized its ability was crowned with a small gift for her.
Her next mission is to win the lottery the required amount.
When she to cope with the task, I will unsubscribe.
And all this is just pure concentration. Absolutely nothing of witchcraft and magic.
So there is only one universal device, which can be set in all. Are our brains.
Good luck to all.
Good luck to all.
[youtube][/youtube]Седой wrote: The device has no handles and regulators.
If possible, the frequency of the current to be measured,it would be OK if the instrument is likened to the "ammeter" apply for measurements of forces orgone.))This is a rather rough definition (without a doubt,would be useful) such a device.
PS watched the cartoon,where butterfly shook reality so that it has impact on many processes...think about what a powerful force one live butterfly!
PP.With.And an important point in my opinion,who does and for what purpose SP.
Good day to all!I've been reading this forum and thought to create something similar got it about two years ago.He SP already exists I have a year made for the design of Humpty Baltay. The fact that it works is a fact,feel myself,now we had free time and I decided to experiment.I made a very accurate generator of rectangular pulses with a resolution of 0.01 Hz.That is, can specify any frequency from frequency table for Radionics with almost perfect accuracy.Now going to conduct experiments on themselves,even as it is scary.http://itmag.es/1i2xk
Better yet, come up with schalamar or lubimets. Skalholtsgatan for children and disabletime for adults.
That's for all the years of hard work I had developed a need to measure the power of orgone. Although instruments exist, written here repeatedly about it. Only here on what page it is
Again let me remind you that any schemes, electronics and electrical circuits with indicators, as in the photo to measure orgone impossible.
But the meter is easy to make.
Take a piece of copper wire and a little long quartz crystal. Wrap the wire coil around the crystal and with the tip of the crystal
output wire per centimeter. Hung is a miracle for the thread in the middle, balanced. All this miracle stuff in a glass jar and fasten the lid.
the second option is to put a piece of Styrofoam in a bowl of water.
The device reacts on the field quite sensitive. It remains to come up with a scale. As units orgone does not exist and the devices to do the same just does not work, as no two identical crystal on earth.
On one of these sites all experimenters have produced for the same things and consistently have calibrated them and used his health.
ДмитрийВосемь
Good day to all! Interesting topic, I read a few days. You want to make your device, but first want to hear the views of experienced members of the forum about such thoughts. What is the price? The law of conservation of energy, and just life, nothing is free in this world happens. If you get something, something must give. Well, if you have the opportunity to choose what you want to give. Worse, when there is no choice, and gets what you're not going to give. What about generators?
- чернокнижник
Knowledge in this area are paid the multiple (sometimes costly in terms of money) experiments, personal time and stress thoughts. As with almost any esoteric artifact, the SP is only visible reference to the subject. With the same success can be used at all in anything - a piece of brick will fit perfectly))) But SP is still better, as successful instances sometimes create sizeable effects, it works on the confidence of the operator. Effects vary from mild tingling or heating of the skin to the spontaneous emission of consciousness is not clear where... Haven't heard that anyone is seriously suffered from it. Another thing, if Your SP is assembled with significant deviation from the classic design, here no one will tell you and any possible surprises. To understand what was happening, get a crystal of black quartz (Morion, Smolyak, "Gypsy", and so on - it has many names), read all about it and practice for a while. Required skill matured quickly, from a couple of weeks to a month. SP is somewhat similar to the Morion, with the difference that the Morion is relatively independent, and SP "locked up" for a more comfortable interaction with the operator.ДмитрийВосемь wrote:Good afternoon, everyone. Interesting topic, I read a few days. You want to make your device, but first want to hear the views of experienced members of the forum about such thoughts. What is the price? The law of conservation of energy, and just life, nothing is free in this world happens. If you get something, something must give. Well, if you have the opportunity to choose what you want to give. Worse, when there is no choice, and gets what you're not going to give. What about generators?
PS. We are guests in this world, and all that I possess, given to us rent. What could we possibly give? To give only his own, and his we....
ДмитрийВосемь
Thank you for your opinion. Read about Morion - as something very different opinions. Some write for ordinary people virtually useless, the other is afraid that can be with him and to play in the drawer for quick. As scary
- чернокнижник
for samples you can make a simplified version of the SP - just coil on the crystal. And cheaper, and there remain opportunities for experiments to rewind the coil, if you have any doubts in the direction to move it over the crystal, wind the coil of a different type, and you never know what thoughts come to mind? If the result is satisfied, it is possible to roll all this splendor in organic, the device needs to become stronger. In any case, the experiments can not be avoided. Instructions instructions and your own common sense - itself)))ДмитрийВосемь wrote:think to try the "classic design"
PS. Morion not really simple, but does everything that he can SP! The process of domestication of this black pebble is largely similar to the development of SP. Besides pugalki and horror stories about him are actually very useful - are forced to treat the issue as a whole. This area sucks yet studied, and each stomping on it at your own risk, your way. Each shaman his drum!))))
warlock Morion in the hands of a novice in this area?
To be honest I did not yet ready for it.
Dmitrievichem
What you said, 177 pages do not really described how to assemble the device puzzled me. I times 4 quite detailed and thoroughly described assembled and tested device.
And, as a beginner myself I would advise to find a pure transparent quartz weighing from 100 to 300g. and a couple of meters of thick copper rod and to try to establish contact with metal and crystal. To assemble the pendulum and experiment with it.
All you need to do step by step.
I wish you success.
Dmitrievichem
I wish you success.
