Orgone generator with their hands (The Succor Punch, SP)
александрФ
- Been thanked: 1 time
One more thing, in my opinion, quite significant. In their x's with the three-track coil I had no "classical" quartz crystal and processed in the form of egg (matte).
A possible explanation of the mechanism of the effect here: http://astralab.in/forum/topic.php?forum=3&topic=6&p=2post for August 22.
Re: Orgone generator with their hands (The Succor Punch, SP)
dear friends, have You tried on a cloudless day, warm day to go to the head to the top, so the sunlight was on the sidelines and not blinded, it is better near trees more interesting result,early in the morning is better and the look is simple eyes in the open sky, eyes not to close mind you
get a lot of interesting glitches, it's not like unless collective
once this phenomenon is encountered first things first began to get in touch with more people that I know and explained to me that this is actually what I saw shiny, closer to the snow color small very small pisanki that as winter snowflakes slowly very slowly down to the ground, while another parallel I noticed how a few of these pesenok form small bubbles, which dramatically change their color from light and sheer to darker, do not judge strictly, what is it? guess what is this phenomenon, but is probably not very interesting to finish to the end all at once, I would be grateful if that someone prokomentiruet, thanks in advance, P. s no coincidence in this thread I like this thread the most expensive and favorite on the forum.
))..About three months ago, went one friend of the Armenians, saw the glasses for seeing auras, and was very interested, despite the fact that it is very material and pragmatic man, not that there is aura, actually the word "energy" can not stand. Well -I say - look if you want. He was staring-staring..five minutes, and then broke into a smile and a finger somewhere in the sky shows and speaks: -the SBI!!! fish swim! What fish?-ask.)лексветер wrote:actually I saw a shiny, closer to the snow color small very small pisanki that as winter snowflakes slowly very slowly down to the ground, while another parallel I noticed how a few of these pesenok form small bubbles, which dramatically change their color from light and sheer to darker, do not judge strictly, what is it? guess what is this phenomenon, but is probably not very interesting to finish to the end all at once, I would be grateful if that someone prokomentiruet,
In General it turned out..that it is difficult to find the right words in Russian, but he wanted to say that he sees a small flash which can hold a glow very long, but enough to observe their movement. And.. I must admit I did not pay attention earlier, and then looked up..looked all right. simply look at the sky. But using the filters in the glasses, they are all the magic colors have.. unearthly. And in General began to notice them without my glasses. Kilner think about this effect, wrote in his book, but to explain what it is not tried, just saying..seen this effect.
UFO. if the General classification. In fact, the sight of a UFO at close range is rare. But at high altitudes a lot of them and on clear days and at night. Skeptics are blamed for earth's satellites, packages, plastic, airplanes and anything but earthly and understandable. But nothing of the earth can not withstand simple logic.
With light filters and polarization filters really turns out much more interesting that you can not have to explain nothing earthly.
So don't be afraid of this word. UFO. An unidentified flying object.
Gray
Yeah..) but my friend is a doctor..he says that there is a version.....observation of bacteria on the cornea....
But really, cocovia bacteria are visible..like in the morning is not waking up properly..look at the bright window floating..Yes..but they don't glow..
lexeter
And by the way..) one quite serious master.. not recommended..lots of attention..visual effects...if you do not understand what it is and why.) But that said - they only need it whose anything to get attention..) To the questions: cama need?.. didn't answer and just smiled.)
The doctor says that inherent in the doctor. A plumber will tell what he knows.нева wrote:Gray
If 10 people simultaneously see the same thing in the sky at the same place. All one bacterium or something? And in the sky that constantly moves and is clearly not planes...
Particles of energy moving erratically across the sky, dark or light. If you believe the yogis, it is called prana. Some of the breathing practices associated with the absorption of this energy. I also can watch them in the daytime. Better under a clear sky, worse when cloudiness. To other objects in the sky as it is still not reached.
...I wonder if orgone is called prana?. if you can..then you can then go to the countryside on a clear day. positioning the product against the clear sky..and see ..if it works))
Good day!
Read slowly section and related sources, but some answers not yet found. In particular, with regard to the electronics (knowledge of which at the level of the first chapters of the Soviet leadership for ham radio).
1.Regarding orgonite. Optimal how long should I use wire crystal with a diameter of 1-1.5 cm, and with how much resistance to put a resistor to connect mp3 player?
2.About Radionics. Can't find a clear diagram radionic machine. In what sequence to connect the generator of rectangular pulses, potentiometers (what resistance?), metal disks and organic?
Logically tried to rethink the single scheme, there were such variants:
3.Is it possible to use radionic machine as a generator of rectangular pulses, the device NS047 http://www.chipdip.ru/product/ns047/ (with replacement connectors, potentiometers and switch for more comfortable), and do this for some electro parts? What kind of power source it is better to use, and whether in this case the resistor to the Mobius coil?
If not the right section, please do not kick your feet, the census in Radionics.
You need to watch how accurately it produces these frequencies as a rectangle. Frequency should not swim, the form must be as perfect.Обсидиан wrote:3.Is it possible to use radionic machine as a generator of rectangular pulses, the device NS047 http://www.chipdip.ru/product/ns047/ (with replacement connectors, potentiometers and switch for more comfortable), and do this for some electro parts? What kind of power source it is better to use, and whether in this case the resistor to the Mobius coil?
The length of the wire any, the main thing you wind the coil exactly. The longer it is, the harder it is to shake. The resistor is put sequentially the coil. to the total resistance was as earphones for the player.1.Regarding orgonite. Optimal how long should I use wire crystal with a diameter of 1-1.5 cm, and with how much resistance to put a resistor to connect mp3 player?
Lancelotthank you for the reply.
Frequency range NS047 seems to be not a small 250-16000 Hz frequency and amplitude are adjustable. A bit simplified scheme is used and sold radionica.
I'm only interested in the generator you can simply connect to the beginning chain radionic machines, or need any additional parts?
I.e. the resistor goes before the coil +, or after - ? It would be nice just to present a scheme.
At the beginning of branches echoed in the resistance, 10 Ohms, with the resistance of the coil, length and thickness of the wire, too, because affect.Ланцелот wrote:the Resistor is put sequentially the coil. to the total resistance was as earphones for the player.
radionic because will affect You? probably, because this is his doing. So there are 4 different effects. Two depend on how worn the coil on the crystal, and two from where comes the signal, + or-.
How to put on a reel written by Logan in OPGI. And with a signal experiment. That is, in the final product You only have two ways to get the "effect" is the signal to + or -.
Impact for me to say Operator, but the coil will be connected to El.circuit, the components of which do not want to burn the first time around. Especially if it's not the mp3 player for 150 rubles, and the device 1000.
Thus the Mobius coil has two ends, one wire connects to the positive audio output Jack of the player and second, respectively, to the negative. The question is, which connection to put the resistor at the input or the output? Question to the participants involved in this.
Logan on this account a lot of information, but it all depends on the knowledge of electronics. I guess to connect to radionic-generator NS047 will be much more difficult to calculate the required resistance at the entrance to the Radionics.
PS: Actually, sleepless night over variable resistors, in the end, the third diagram in your court.
For player or amplifier anyway. For the operator there. These are two different effects of 4 possible. What are Logan, it is the decision of Logan.Обсидиан wrote:T. O. Mobius coil has two ends, one wire connects to the positive audio output Jack of the player and second, respectively, to the negative. The question is, which connection to put the resistor at the input or the output?
Never bother with this, the output of SP 2 colored wires, the output from player 2 colored wires. include, did perekool wire. Do not want to be confused, compressed wire color thermochemical. Once again, it is individual for everyone.
You have missed the point. If charge dilution organit scheme of Logan, there is still present the effect of Chladni. Why Logan mentions this in passing, without explaining this - I don't know. Maybe just not fully figure this out, but only intuitively?
Rost&slav wrote:I still would have understood the manufacturers of mud pies if they strukturyzowane the location of the metal particles by the method of Chladni figures. Type creating some vibration field, as I had already created a vibration vortices of particles graphite on the surface of the water.Just need to create the volume. After that, the resin sagonet, and particles of metal will remain in it in the form of strict pattern.
But did not mention the inventors of organito. But what is done in the mass is dohodnoe anywhere.
Perhaps you are lucky with the resistance of the coil. Otherwise, such methods can be all the electronics to burn. In this issue of the necessary technical approach, as I said. But, to me, the issue has been resolved.Ланцелот wrote:the Fact that given Logan, the decision of Logan.
I remember someone in the thread have already described a similar experience. Curiously the influence of such figures for further use of Orgonite. If he would like one installed, to prevent the use of another, or the same figure will work like a structuring crystal lattice?Ланцелот wrote:You have missed the point. If charge dilution organit scheme of Logan, there is still present the effect of Chladni. Why Logan mentions this in passing, without explaining this - I don't know. Maybe just not fully figure this out, but only intuitively?
However, if fine metal powder under electromagnetic action of the coil and is able to form the figure, major elements, BB balls, nails, pieces of wire and chips hardly ever budge. There's a metal dust with quartz sand the best option.
No. Wire length is about 50 meters, wound more, but the room does not allow, therefore it is always consistently soldered resistance.Обсидиан wrote:perhaps you are lucky with the resistance of the coil.
падмасамбхава
Share your recipe organicos. resin+metal powder+chips+quartz sand+a little dolomite.Обсидиан wrote:metal dust with quartz sand the best option.
Metals: copper,brass, bronze, tin, aluminum, zinc, titanium, chromium oxide, steel.
As a form of using silicone bakeware.
Two speakers from big Nosikov, in sealed boxes (which would not fill speakers) orgalitovoj pour the mixture and let harden.
For the form use silicone bakeware.
During the solidification of organito use CFS (correctors Koltsov) lilac series.
Connect to computer, and the sounds of the BrainWave Generator with different presets.
Did orgonite with artificial and natural quartz crystals. Crystals embedded in organic or fastened with wax at the top. From my point of view, the quartz crystals give a directional beam, which is not always true.
Dear Gray! Sorry in advance if You already answered this question.I was looking for the answer in Your post (in the personal section) by 6 p. I boiled brains
Question-Can you make passive the cake entirely of aluminum powder(high frequency) crystal of course.With Respect.
Offered friends and relatives to assess the "blind" three castings: aluminum powder, copper powder and titanium. Most chose Titan as the most attractive sensations.
Maybe better than the piezo from the lighter instead of the crystal?
Better not instead of, but together.
One time my friends (and especially girlfriends) was a very popular pendant, I called this option "Golem": in the centre of dvuhgolosyj quartz, near two sides of the "hands" of the barium titanate from the kitchen piezosurgical, at the top of the "head" of phenakite. All bathed in meteorolgy organic on a broad base of blue kyanite.
Somewhere in warriormatrix posted a photo: http://www.warriormatrix.com/about12634.html.
Good afternoon. This is my personal opinion, many may not agree. But passive devices for RF work is not effective. Yes, and our everyday tasks are often associated with a low range where orgonite are bulky and expensive and spirals and large, the crystals themselves more effective.Ангел wrote:Dear Gray! Sorry in advance if You already answered this question.I was looking for the answer in Your post (in the personal section) by 6 p. I boiled brainsQuestion-Can you make passive the cake entirely of aluminum powder(high frequency) crystal of course.With Respect.
a lot of small organito the size of an acorn with tiny crystals and fine powder. And with different kind of shamanism navel lizard or dried tongue of a Nightingale. It is a matter of faith and feelings. And faith was not discussed.
And the more expensive person pays for garbage, so it is better and cooler and try to convince her otherwise.
For you personally I can recommend as guardian for the house following construction of orgonite.
Take a small clay pot with a volume of approximately a liter. Put on the bottom of shungit in any form. can the cups the ball can be crushed though.
I usually used crushed stone and not only shungite. Hematite at this place are also good but are very expensive.
Then voete this spiral.
http://www.loohan.com/flat2003coil.jpg
Preferably from wire thicker and the whole size of the pot.
The spiral above the shungite on the bottom of the pot.
Next.
take the honeycomb pure honey. That is, the honeycomb with wax. This is not a gimmick to get you anywhere. cut the cell size of the pot and put on a spiral.
Put this concoction in direct sunlight for a day or two. After 6 PM get home. And pass at dawn. That is, he must see the sunrise and Sunny day, but not the sunset and not moon.
Honeycomb to melt and cover the spiral and shungite.
Next.
Take an ordinary household al. foil. Not BU. Cut the leaves at 10x10. put in atpco, so it was convenient to continue to cut with scissors. And cut some strips from mm 5 up to. as the hand lies.
Then the strips into cubes. Get confeti of small foil of different shapes.
Have to worry about for a long time. Do not tamp the foil, it should be loose and fluffy.
volume the next layer of aluminum must be three times thicker than the layer of honey-copper compote. But not ramming it!
Next. Buy beeswax. Natural honey and high quality.
And do the following.
Pour in our pot of honey, shavings of aluminium to the throat and a natural wax suspended above it on a string and put everything under sunlight. The wax melts and is drained gradually into the pot and fills the rest of the volume. Don't forget tonight to bring home and in the morning under the sun. Everything must happen slowly, slowly.
You can apply the fat of a sacrificial animal. But let it go.
You can cauterize branches of wormwood and magical herbs and cast spells. But again, too harsh.
When everything is ready and the wax has cooled and is characterized by the sun's energy, which usually all are not enough, you can put your crystal ball in the center of the pot.
This can be a crystal ball small. The fluorite. Can Schorl tourmaline black crystal.
Fluorite is beautiful.
You can still 6 different crystals to decompose the edge to the center of the perimeter of a large Central crystal. But these small crystals to symbolize something. Or it may be charmed objects with power.
All this will gradually sink into the wax.
I love the amazonite. The guardian of the hearth. Jasper. Falcon eye or tiger's eye. You have to love every stone of every detail in the design. every element needs to please you.
Seal amulets like salt. Not from the store. Take rock salt, chop it. Well, at least the major salt in packs. Whitewashing the iodized will not work.
Salt remembers once any given information. And for all.
(By this I do not consume salt in food)
Reinforce talisman with salt and in the process do you program a talisman for the solution of the task that you need.
All that is to salt a source of energy. Crystals for communication with logo. Spiral and shungite attract the energy from the outside and clean. Aluminium specifies the direction of energy.
Tourmaline, if you apply it. It's like a black hole. It is able to absorb as much energy as her put.
For this it is used in only one cases. If you want to save the place from spoiling. To clear the heavy history of the place. But in this case, touching the crystal could be deadly.
Never touch another crystal of Tourmaline.
He also can absorb all the good, if it is programmed...
So for tourmaline taken either know-nothings or know-it-alls.
Fluorite to solve more spiritual problems than the mundane.
Good in the event that you are looking for enlightenment, knowledge, knowledge of hidden secrets.
Quartz is a versatile and serve as a direct dialogue of the person with the logo.
In short, the choice of stone in the center needs to be very thoughtful.
But if you don't want all these magical jungle to climb that take everyone's favorite quartz.
Missed that.
Salt is programmed for a single task and for all and this task should not be global and all-embraced. type world peace and money to the Armenians. Or a wish list of 150 points.
Take care of this house and the people living in it. Something.
A list of what to protect is not needed. The salt is characterized by one and always.
Guardian must be at the door. Preferably under the threshold of the house.
Good luck.<
