CD "Endorphins"
Re: CD "Endorphins"
Post by Андрей Патрушев » Tue Feb 28, 2017 11:16
olgac
Hello.
http://www.mindmachine.ru/photosonix/navigator.htm
- Relaxation: session 6,7 (exactly the same :? )
- Energy: session 4.
"Endorphins" should be on the map Navigator along with a Healing a guide and a Journey through the inner worlds.
Teach materiel. :)
ольгак
Re: CD "Endorphins"
Post by ольгак » Tue Feb 28, 2017 12:14
Exactly!!!!There!!!!! :D
Саир
Has thanked: 17 times
Been thanked: 2 times
Re: CD "Endorphins"
Post by Саир » Wed Apr 12, 2017 17:45
For "Endorphins - 2" branch is not opened?
How do they compare with just "Endorphins"? Is it possible to listen to "a-2" as a separate drive, or better after the course "e-1"?
Re: CD "Endorphins"
Post by Андрей Патрушев » Wed Apr 12, 2017 19:04
Саир wrote:How do they compare with just "Endorphins"? Is it possible to listen to "a-2" as a separate drive, or better after the course "e-1"?
Endorphins, in comparison with Endorphins-2 focuses more on the stimulation of the body.
is it Possible to listen to "a-2" as a separate drive, or better after the course "e-1"?
As you wish.
ГРЛ
Been thanked: 14 times
Re: CD "Endorphins"
Post by ГРЛ » Thu Apr 13, 2017 11:48
E2 yuzayu week, internal enthusiasm, energy, mood, very happy! THANK YOU VERY MUCH ANDREW! Me 15 minutes is enough :)
Re: CD "Endorphins"
Post by Андрей Патрушев » Thu Apr 13, 2017 12:41
Саир wrote:For "Endorphins - 2" branch is not opened?
What's the point? All the same, only the accent of the maximum exposure offset from the body on the mental sphere.
Россомаха
Been thanked: 11 times
Re: CD "Endorphins"
Post by Россомаха » Thu Apr 13, 2017 12:56
Андрей Патрушев wrote:Endorphins compared to Endorphins-2 focuses more on the stimulation of the body.
What should be understood under the stimulation of the body?
Re: CD "Endorphins"
Post by Андрей Патрушев » Thu Apr 13, 2017 15:19
Россомаха wrote:What is meant by the stimulation of the body?
For example, we can distinguish four extreme base state:
- Body asleep, mind asleep (normal sleep);
- Body asleep, mind awake (effective learning);
- The body is awake, mind is awake (normal condition day wakefulness);
- The body awake, mind asleep (combat trance).
In fact, all of us, in the so-called "normal state", are in some intermediate state (of the four).
Thus, the Endorphins, the emphasis shifted to the wakefulness of the body, and the Endorphins-2 - the wakefulness of the mind.
Re: CD "Endorphins"
Post by Андрей Патрушев » Thu Apr 13, 2017 19:40
Did, however: :? viewtopic.php?f=8&t=6448&view=unread#unread
Павел Торнадов
Re: CD "Endorphins"
Post by Павел Торнадов » Sat Mar 03, 2018 23:55
индеец wrote:Image
Anyone listening to this disc?
Something not seen in contrast to "Explorer".
Katushka work? :)
FAQ on disks
Pay and download the ROM
That would have made a CD"SEROTONIN",to me its just not enough, depression....
СофияС
Re: CD "Endorphins"
Post by СофияС » Fri May 04, 2018 1:48
Andrei PatrushevKind time of days) Purchased a set of your rims +the green door. Is there somewhere a short description in the form of "the name of the disk corresponding to the wave/waves, which are activated when listening? Thank you.
митек
Has thanked: 23 times
Been thanked: 15 times
Re: CD "Endorphins"
Post by митек » Sat Jul 14, 2018 14:46
Good day to all!
how you can reduce the listening time for the Navigator to 15 min?
If passed out, then shut down wouldn't work.
thanks for the tips!
Re: CD "Endorphins"
Post by Андрей Патрушев » Sat Jul 14, 2018 15:53
MiTek
In the settings to put the automatic switch-off.
митек
Re: CD "Endorphins"
Post by митек » Sat Jul 14, 2018 16:43
Андрей Патрушев wrote:MiTek
Apparently I'm blunt. Can't find where to set this time in the Navigator settings (Settings)
I have the Navigator 2.
In the sessions you can change the time of the session, and AUD. The gate, where are the endorphins, not fails.
:roll: Help!!
Re: CD "Endorphins"
Post by Андрей Патрушев » Sat Jul 14, 2018 16:54
MiTek
Settings (the wrench with a hammer)/waiting time (from 5 minutes).
митек
Re: CD "Endorphins"
Post by митек » Sat Jul 14, 2018 18:04
No, this timeout idle, while the Navigator itself is not switched off.
I tried in any case (actually 5min. this is the default setting), the screen went blank, but the program goes on and GPS turned off.
Works as designed.
Re: CD "Endorphins"
Post by Андрей Патрушев » Sat Jul 14, 2018 19:13
MiTek
I understand that the problem You have with falling asleep, and therefore advised. But if You are afraid to prestimulate, you have some third-party timer enable (or Pathfinder, if You have this machine), or phone alarm (hours).
митек
Re: CD "Endorphins"
Post by митек » Sat Jul 14, 2018 19:20
I understand that the problem You have with falling asleep, and therefore advised. But if You are afraid to prestimulate, you need some third party to enable the timer or the alarm on the phone (hours).
Well, Yes, falling asleep, just the opposite.. :)
Has thanked: 478 times
Been thanked: 264 times
Re: CD "Endorphins"
Post by ЛИЛИЯ-Р » Wed Jul 25, 2018 16:22
митек wrote:good Day to all!
MiTek, what to listen to in Pathfinder? In the section of the Session in the Navigator, the time can be changed. Under Strobe.record-this drives the gate, the same Conductor in the gate it is not possible to change the time played to the end, avtomaticheski disabling the program. In combined sessions Explorer , you can change the playback time, played, clicked off.
Andrei Patrushev Explorer in combined..if you change the playing time is lost if part of the text, if the time is reduced? Something like tried to listen. Sometimes long sound Conductor in the Gate, sometimes you want shorter, but not lost part of the text at the same time? Or sound faster)) the speed of the text, or what?
Re: CD "Endorphins"
Post by Андрей Патрушев » Wed Jul 25, 2018 16:30
ЛИЛИЯ-Р wrote:Explorer in combined..if you change the playing time is lost if part of the text, if the time is reduced?
To be honest, not tested. The logic needs to change only the accompanying session, but we need Alexei to ask.
ЛИЛИЯ-Р wrote:long Sometimes sound Conductor in the Gate, sometimes you want shorter, but not lost part of the text at the same time? Or sound faster)) the speed of the text, or what?
Here on what cannot be influenced.
Лева
Has thanked: 9 times
Re: CD "Endorphins"
Post by Лева » Thu Sep 06, 2018 18:18
Listen to the endorphins already 5-6 days in a row, everything seems normal, no headache, but resumed trouble falling asleep which only started to disappear after a course of healing + guide. Increases the tension in the trapezes and neck. During the session, so can normally pull. This is a beta session, right? If I have 15 days I will work endorphins + endorphins evening (session Navigator) can I assume that the beta worked and can do theta?
Actually, I think that lack of beta waves I have, for example in the morning is never heavy sleepy heads can Wake up earlier than I would like and not sleep.
Maybe I do then beta is better not to do and from theta to try and if her to fall asleep will not the rules?
Re: CD "Endorphins"
Post by Андрей Патрушев » Thu Sep 06, 2018 19:38
Loew
You can "PEEN" its rhythms, just have trouble falling asleep. - In the morning engaged with the Endorphins (about 15 minutes), and in the evening - with any alpha session.
Лева
Re: CD "Endorphins"
Post by Лева » Thu Sep 06, 2018 20:28
Андрей Патрушев wrote:Loew
Please advise your Combe sessions or discs. In addition to healing and conductor. Or some standard from R series to use?
Re: CD "Endorphins"
Post by Андрей Патрушев » Thu Sep 06, 2018 21:20
Loew
Yes, the easiest to use r1.
