Test products technology SEM.
Corwin, congrats! This gorgeous state. Through music, dance to get out of it the easiest way, and in sex, just need a partner for this, too, was prepared, and that "normal" people might not understand. Once having felt, You will be able to learn to enter yourself and "tune in" to anything, for a dance of the forest, the wind, the ...space. I practice this almost daily. Objects settings are different, mainly just for space. With the arrival of spring began to do it more often, study what you can get out of this state.
Just this morning I wrote in my diary about what thought processes as if "lifted" above the ordinary that, on the one hand, allows to do everything more efficiently, and not getting involved, not involved in the process, I think that Ouspensky wrote about such as, calling him rabotodatelyam. And it becomes possible only after it will be possible attunement, this, about which You write. Don't know how, but these processes are interrelated. I am now trying to figure this out. I have suggested that the brain begins to work volume. It is a word that often uses Aura, very suitable.
Re: testing the products of technology SEM.
About the brain I would say that it ceases to disturb it like chatterbox opielka turned off which says that tree and you see you know what this tree is but not speak and the report is not saying that I see a tree.About the brain and the volume would say that the whole feel in another volume of t e as if another space , another quality plus the feeling of freedom.This condition is less energy, just a resort
Ordered the necklace "horn of Plenty",could not resist
wanted to wait for the response Aura on it ,well, nothing, and so you can see the thing standing
Then I will unsubscribe about my experience with it.
"Not Firemen We, Not Carpenters...".
In anticipation of the appearance of furtive announced "Neocolonies I":), I decided to share a photo previously ordered neocolonial. The first (left) ordered in November-December was "hardening" cold plunge pools, baths and so on. The second is almost from the time of activation has passed the process cycle. The irony is that on the second and drop of water spilled. The paradox
I feel I have a base to work on the 4 th mode level II, and going at him, at the moment are at a fork of the possibilities of verifying the optimal path. Let's wait and see.
The whole point of a chain, on which hang the pendants ))) Metals contacting each other creating a weak current and the oxidized metal with a more negative electrochemical potential. If pendants would be gold plated - oxidized the chain, or silver on the body would be blackened. I think that's the case
passing alas. At first gold had hung up after three months. The meaning of the replacement between the height of the pendants. The second factory was also dark. By the way, the chain with the first one now as a spare. In the precipitate the main thing is not to leave before replacement)
The difference most likely in batches . In the first serial begins at 2, and the second serial starts with 5, tinted.
Aura
- Has thanked: 22 times
- Been thanked: 1124 times
The product is designed for experienced users. Or extremists) In recent years is clearly felt and there is a group of users who have advanced in the management of variant lines far...this ”energy special forces”Лаймпроф wrote:Can be more special the product as possible I understand correctly, that it is on the principle of Coulomb's II, where you can connect any combination of pendants I? It can completely replace the wearing of pendants I? When about to wait for this miracle product? In what price range to expect the cost of the product ? It is planned to test this product? If so, I'll gladly take part!
Firmware is fundamentally different than from pendants and I and II level. The carrier will also be in the form of a pendant...but it's still a secret
Received today the necklace of the application system of the 1st level of"cornucopia"-wear for an hour and already there is activity in different areas of the brain.Frontal lobe,temporal,occipital,parietal,at the third eye in the thyroid gland. Worked out all the chakra system,clearly there is activity with the 3rd chakra and higher.
Interesting energy,even its taste is felt,but not in the normal tactile sense.Interesting modes of consciousness.Went for some relaxation throughout the body.
I like
I like
Aura in personal Cabinet in the development of a map of the Alchemist. I will assume that for magic-operators?:)
Looked at the magical branch of neocolonial replenishment. Pleased with the Master of magical Sciences - show psychics resting
The program control elements and weather. Now think of was how to curb the Gulf stream)))
СтаниФилмТВ
- Has thanked: 24 times
- Been thanked: 63 times
Gulfstream curb is not difficult. First have become by the Gulf stream, that is when you can afford to say that.. You are the essence of the Gulf stream. Then..you can start objectivenew. ) Just will not work..better stages..) In such cases, there's no rush.)Фаренгейт wrote:Now think of was how to curb the Gulf stream)))
Aura, Hello!
A small question:
Pendants "integral" and "energy" series can be matched in the same group? Is it possible as the primary ( the one from the group will be worn) to choose the pendant of the "energy" series, such as "Dream"?
Thanks for the reply!
A small question:
For better absorption of presistemnomu, as already mentioned, it is important for us as the volume of consciousness, therefore, can be recommended from level I Mental and/or Body (depending through which field, mental or bodily, the operator used to work)
And if the operator is accustomed to working through the mental,but wants to develop the ability to recognize bodily responses,what programs fit? (I have 2 pendant)
Aura
It is the direct appointment Program-Sens. As a healer You probably understand the relationship between mental and bodily aspects: the development of one brings the other. This is a question with some “end of the stick” to take...Арт Мак wrote:And if the operator is accustomed to working through the mental,but wants to develop the ability to recognize bodily responses,what programs fit? (I have 2 pendant)
Interestingly,in the thread someone was talking about some kind of mystical connection with the pendants. I will share my case. still a few days for your pendant premise,in the dream a woman appeared and said: "Only desire is not make - will not be true". The dream was clear,under the category of so-called "prophetic". I mentally suggested that the lady have to the team or Club members. But the first was the idea - "Fairy pendant"...
донна Лилия
- Has thanked: 7 times
- Been thanked: 21 times
I had similar with neocolonial II and BRM, also during sleep. My BRM bridge hasn't come in yet, but I dreamt last night in the bright dream. Showed a film consisting of shots from my life. When you look at actions, evaluate quite differently. Sleep helped define the intention for the bridge. With neocolonial II was something like costarica. Round iridescent monster devoured my free time (new path?..). It was not so much afraid of being, as the fact that as soon as there is free time, and it's gone. Maybe it's the result of the adjustment. Maybe there is a subtle connection is the same connection between people, feel and read each other's minds at a distance.
the Art of Makand there are "Fairy pendant" when we used the pendant?
Good all the time! In the month of February conducted a regression session with my friend. I practice regression. Sitestyle pendants, this issue was on the agenda of the session. Girl operator (submerged) sufficiently advanced psychic. Received quite interesting information. On the question to see neocolony, and how they work - she spoke in an unknown language. What I don't even know what language group it can be attributed. Further, requested a transfer, gave the translation : "be honest and truthful, one who will relate to the realities of outer space with the same purity and wisdom and periodic energy inside himself a process of inner alchemy, reviving the Planet and all the hypostasis of the human Soul, generated not only here but in all times and spaces." On the question that the language in which she spoke this text, the operator replied he did not know, but the language is very ancient. She was carried outside of the Earth, described the enormous light Beings. Then again I went to the information, the girl was spoken of as dictated, without stopping or hesitation, and what she says : "We bring harmony and peace in the density of the Planet for long-term transition, those who are ready, will make its vibrations to support this process. All consciousness, Wake up, your age-old slave contract is over. You can go to blissful development in the desired direction, according to the laws of the universe in this creation. You, gradually awakened, recognized, and go down the steps to your development above. On the way to you are our consciousness, we are the ones who help you with their knowledge, skills, and energies. All the way open, and you're ready to start your self-development and to enter into a world where everything breathes of love and creation."
Looks like channeling. Well, it's a experience. Now it is interesting to test the operation of the card Chronos Delta. I worked with spatial and temporal lines in the sessions. Also, changing the past, removed the root of the negativity that has taken root in the present. Generally, the Subconscious, the human Psyche is a mystery. It's bottomless.<
Neva, in trance, or is it still possible to call on the subtle plane, there is neither time nor distance. On request. There is a request - past life - travel there. Or even further. Only need a cause - what it's about.
нева wrote:travel Far.? Mean time parameters..
Yes. You only need the desire to see, to accept and to deal with their problems in the past, and where and how deep))) as request. I managed in the beginning. But there is not interesting)))))No awareness)).ЛанаМайнд wrote:thin plan, no time nor distance
It is important not that there will see everyone, and then what to do with it will be? Well, revealed the problem, and????
Not having worked for not realizing and not letting go , and will hang , waiting for elaboration. If you define a volume, if I may say so, volunteered for a recapitulation, by analogy computer-the most intriguing moment of the brain))).
Incidentally, I then "went to GEEP", not just unsubscribed. Found Energy Matrix Model, the letter W is not yet decrypted
But, based on the logic that the technology associated with codes, then W, perhaps from the word CIPHER encryption, encryption, encrypt, etc.
Yes, it's generally a good method to grab the attention ofИспытатель wrote:it's Funny, isn't it? We manufacture products for a super-duper technology, and what it means think for yourself.
New year's eve, it is useful to take stock of the past and set goals for the future. Now that I have the technology SAM today?
The first level - almost a year and a half, with the second - slightly more than a year. Recycled enormous layers of information, new understandings, feelings and insights obtained in such a degree of concentration that seem to have lived during those six years than one life. Thinking changed radically if there is a question or any problem, they have no chance to remain unresolved. Empathy increased significantly. Relations with many people have changed. Became clear level (degree of understanding) other people. Just a "gut feeling" capable of development and those who can put a cross. My goal last year was to reach the level of conscious self-programming,the task is large and complex, what can I say, I'm in the process, the process can be improved and improve on what and work. The feelings, managed to step a little further self-programming, a lot of things... a lot... to describe all stack, study, and coordinate... to manage reality much was clear, but not all. But as I "paint reality" already keep track of and even send.Neocolony gave me a powerful impetus to the movement spiralling upwards. To relate all the changes only to their personal qualities, definitely, can't. I don't pull without support.
What's next? To continue... to Learn ... and to share what I learned... People reached out to me with questions. How do they feel? I don't advertise work with neocolony. I wondered why the developers share such important information. Now I know why.
All members of the forum and developers happy New year! All difficult and interesting tasks !!!
