Bracelets Life
- Дмитрий_999
Michael Hello. Learned how to me possible information on B. J. Really interested me. A lot of reviews according to 2.6, everything seems clear but I need energy, and at the same time working with goals, and the mindset of why it is only 2.7. Based on all the reading, decided to purchase a B. J. 2,7. The next question is for purpose, how well it will work in 2.7 or so, will it replace the 2.6 what will work best. The question may not be quite right but try to understand me torn between the 2.6 and 2.7 you want a 2.7 - inner spirit, but also with the goals I want to complete the program to work.
Oh, how I understand You
Even I have this problem of choice.
2.6 is just so delicious to influence events. 2.7 still works in that sense but not as fast and not as much. But 2.7 harmonizes yourself and growing personal strength, which again allows to improve the order.
Ideally, 2.6 to vilify and to instill a quality of it.
I.e., the ideal - both.
But if internally you want a 2.7 will do so.
quality 2.7 also stepped up with goals, but in a different way, through the increase of energy, not mass.
While it contains slightly from 2.6, because 2.7 harmonious middle.
- Дмитрий_999
Yes, that's right.
Just one of the older versions of this testing and code of conduct including the mental responses to situations, and experience may be new for You. This integration of this experience in your. Ie the one who a few months were 2.6 can already apply appropriate quality ITSELF.
Similarly, 2.5, 2.7, 2.8...but depending on a person's time of "training" are different. In fact, there is a strong extension of behaviors and decisions that unknowingly impact on the outside world. Each person usually has some one propensity and rarely able to switch in a dramatically different state. Some even believe that it is generally not possible or impossible to combine at the same time.
I assure you - you can.
Just need practical experience.
You can be both different even in one and the same time.
Clear physical example. People can be a great (height, weight)and it gives him certain opportunities, for example when transferring or moving around the floor of the cargo.
But at the same time he can be strong.
In addition, it can be savvy
and to spread under the load of something slippery.
and so on.
and so on.
- Дмитрий_999
The pieces of larch is the entire line of older versions -2.5+ (available in the office, you can try a bit), 2.6+, 2.7+ and 2.8+. The cost for the first two and the last two differ as for conventional versions(30 and 45) due to different manufacturing techniques.
the "+" on the end means an extra stage of production to activate the product.
For example, if You wear the bracelet after it was worn by someone stronger than You in power, it will be felt perhaps as a shock. Operation "+" in the manufacture of leaves BJ in the swinging condition, as if with the habit of working more powerful. As You do this as you get used to and catch up, then it becomes natural to You and for this BJ.
The activation process keeps the gain some for a long time (think years, but can not say for sure), but not forever, as just the charger. During this time, due to habituation it is not needed (in the sense of getting no matter of its weakening).
I.e. it's kind of a kick start.
As I said, this 2.5+ is in the office (to make them easier)
other similar versions on the larch, made-to-order (not yet had time to make them for the office "good", very time-consuming operation. From the point of view of elapsed time easier, a dozen normal 2.6 or 2.7, and so on.
The production takes about two weeks (not an absolute time of course process and from).
ACC. back to the question. 2.6 on leaf links(2.6+) will be considerably more powerful than just a 2.6, even if you remove the activation would still be. Including due to size and weight. For this version it is important.
Why normal 2.6 made on the stone? it is in itself enhances version and has a large mass. I.e., for 2.6 it is shown as a good material and type of stone is affected very little, almost insignificant.
2.6 in the tree can be more powerful if you make it heavier, or the amount of damage increase significantly. This will create more problems using. 2.6 ordinary stone is quite compact in the hand and easily slides in somewhere.<
I except 2.6 that was done a long time ago for their own, and some of them just made of more solid wood than the standard wooden bracelets, did another 2.6+ on a standard billet of wood, but with the activation, to increase efficiency with a little less mass compared to stone.
If the person eating it wants, describe the difference.
- Дмитрий_999
Michael_
Thanks for the replies. I about a month ago , You were in the office, Meryl 2,7 immediately felt under the charm bracelet chill and tingling, this time I phoned I spoke for five minutes in the bracelet – so during a conversation I faced a wave of calm, not that I have never experienced such a state was but seldom remembered, because my mobile automatically writes all calls (need to work) I even listened to this conversation, important to me only from the point of view of the experience of the state therefore, I will take a 2.7 necessarily – while the toad smothers for 2,6 – think later a 2.6+ is worth taking because the goal of my "global" to give them can't – tried not work – you lose the meaning of life, but I'm stubborn to go anyway.....
Michael
Good evening. Michael. I flew for 2.7 protection of engraving on one link(on reserve shelf) if you can glue on the glue? I wear it for more than two months, I read somewhere(on the forum), that for some time the texture goes to myself BJ( it's about БЖ2.5 was written) and even with the erased engraving characteristics do not deteriorate. Does this apply to 2.7? I read that you can change to another bracelet, but I would like to write this.The best thing to do in this situation?
Thank you.
Thank you.
1. can be glued.
2. you can do nothing.
but probably better option 1.
Quality goes for all versions, not just for 2.5
usually things don't happen by accident, and due to some stress event. Sometimes it and the links break.
Under the warranty replacement came the first version of 2.7, where the composition was not stable, we have them all replaced but a new one.
While it is certainly possible flaking on some production issues, but unlikely. They are usually specially to clean the impossible.
But you can replace one link, not sorry. Only the color tell me they come in three different shades.
By the way your bracelet gradually "sways" and increases capacity.
- Дмитрий_999
All kind time of day. I decided to describe first impressions after the purchase of 2.6+ wood EBEN. I wanted a 2.7 but when I realized what I can do 2.6 with activation, there was no doubt. Feels like wearing a bracelet in less than two days. Just as taken put the right arm above the elbow because the size originally planned for leg – riding the subway smiled ,went energy the likeness as after doing qigong after 40 minutes in the tree (not engaged about half a year) then felt on his head like a "cap" in the middle of the forehead "movement" the same familiar feelings, then at times such a weak vibration to the body, such as in the VTP, but in "the Bud" by the evening all was quiet, I merged with him, slept in it now especially it and not notice unless you move it, then Yes - you feel the warmth, the tingling, the "chill" of such a kind. Although now such as direct burning, a very strong heat. In the event anything yet – the only certainty appeared.
And over time, wearing it corrected by amplification, with the feedback of personal experience and committed "as a permanent property", the truth have different versions of BJ 2.x for different amounts of time worked. Adding other versions of the 2 bracelets.x further enhances confidence, fuelling further demonstrate the quality of adjustment possibilities. And "burning" and "tingling" means works, are active processes, at this time, the bracelet is better not to remove, recharge not to interrupt. Over time, and the bracelets don't always wear, but always use them when I need them, as I do not know, here so often and wear...Метхуселах wrote:confidence came.
Sincerely, MAG.no
- Дмитрий_999
dry-heaving like I had been drinking, and is likely to talk about the active oxidative processes in the body...Метхуселах wrote:to Remove the bracelet and do not want - people here wrote about some of the worsening "fractures to the body" so I got up this morning and I was so "thirsty" as if I was drinking, only the mind clear, though not drank somewhere in the new year. What would it mean?
...while "burning" and "tingling" under the bracelet could depend on the house or on the hand bracelet.Маг.нет wrote: and the bracelets don't always wear, but always use them when you need
Sincerely, MAG.no
Thirsty is that this instance is slightly more powerful ones(well in fact a Magician.not accurately described, but it is a consequence), for You are not accustomed to managing such potential, and the cocoon is still a bit in shock, and the reason that 10 times You told me that you wanted the powerful version, and I could not resist and succumbed to this campaign, was credited there as 2.6 arms (this is what is seen on the reverse side
) so it works more firmly than usual.The type of "stubborn" as such in the 2.6.... Usually 2.6+ have mass twice more and the same effect is obtained by the mass, but not the physical pressure, in this work the bracelet more than gently regulated by more-less. And this specific has no topkran. So be careful with him. Especially in relationships with others. New emphases in the behavior can be unexpected or inconspicuous. Perhaps it should be removed, and give yourself a rest sometimes.
- Дмитрий_999
Michael do You regret that he made such a "hard" instance and in my opinion, my cocoon in any not in a state of shock, probably even "not enough", quality is 2.6 I need , there are no coincidences. At the expense of accuracy I totally follow your thoughts. Rest of the bracelet have no desire at all I really need it.
Very interesting quality, and the changes are not only felt by You, but they seem to be "noticeable" to many in the area of direct contact, there can also be accidents of all sorts... You begin to "expect" that You yourself still don't expect it, but if you try, usually works. Expectations are appropriate.Метхуселах wrote:even probably "not enough", quality is 2.6 I need , there are no coincidences.
Sincerely, MAG.no
