About the parlor
АСД
Post by АСД » Sun Aug 02, 2009 17:03
Ростислав wrote:of ASD and how do you check them for resistance? There is some device?
Interaction with people on GDV.
слон
Post by слон » Mon Aug 03, 2009 20:51
Good afternoon. Acquired the room and did not find the operating conditions of the instrument. Specifically interested in the following:
Is it possible to wet the window (let's say lower it into the bath for a few hours)?
Can I use Svetlitsa for pregnant women and infants?
Артур К.
Post by Артур К. » Mon Aug 03, 2009 22:01
Will not break if the parlor if to put the carafe sodoy ?
Post by Dimas » Tue Aug 04, 2009 11:50
Arthur C.
Will not break! :)
elephant
To use all you can, water too can be omitted,it is tight. But why???
АСД
Post by АСД » Tue Aug 04, 2009 15:42
слон wrote:Good afternoon. Acquired the room and did not find the operating conditions of the instrument. Specifically interested in the following:
You can soak it. The housing is sealed. You can put in the tub, but it will float.
Contraindications our uzdeli no, because the main effect of normalization, i.e., the movement to normal. There are cases of successful application of the Parlor before the birth of the child, which contributed to a healthy pregnancy. Although the application of the Parlor were several unsuccessful attempts to have a baby.
Солнышко :-)
Post by Солнышко :-) » Mon Aug 10, 2009 17:10
ASD
good afternoon. And were there cases improve vision in nearsighted when using a chamber . And that really want to have unity. :)
Post by Guest » Mon Aug 10, 2009 21:30
Sun :-)
it is innate :) improve the breed or make Lasik ... az
Солнышко :-)
Post by Солнышко :-) » Mon Aug 10, 2009 22:35
this is why it is congenital, I have a vision in adolescence deteriorated. While this unit was!!! :D
Post by Guest » Mon Aug 10, 2009 22:52
Солнышко :-) wrote:Guest
that's it ... puberty ... the body tries to Mature and is wrong with vision ... the failure of the genome ... looking for a healthy husband ... and the children will be with the unit until retirement az
Солнышко :-)
Post by Солнышко :-) » Mon Aug 10, 2009 22:56
Thanks for the advice. Not a course I would like to do surgery. :(
Солнышко :-)
Post by Солнышко :-) » Mon Aug 10, 2009 23:12
ASD What do you think about this? They can improve eyesight with myopia without resorting to surgery. :oops:
Post by Guest » Mon Aug 10, 2009 23:28
Sun :-)
while ASD has no say ... no you can not ... well, if homeostasis floating possible small improvements or as if by themselves improve while calming the nervous system , light sport ... changing loads on vision and nutrition full ... but does not fundamentally improve the gene ... it's a violation of the device the ocular system ...
incidentally to calm the nervous system and relieve stress and maybe you can help Svetlitsa as a placebo when strong in her faith ... try to see if it helps az
Солнышко :-)
Post by Солнышко :-) » Mon Aug 10, 2009 23:30
Guest And you yourself used it? Write, if not a mystery.
Post by Guest » Mon Aug 10, 2009 23:42
Солнышко :-) wrote:Guest And you yourself used it? Write, if not a mystery.
I have not used personally ... so tortured here users and sellers and yet they have not convinced me ... and so I'd love to buy this great tool ...
buy and you then write to us :) buy ... I think its information jewelry ... buy and won't be guessing and doubt ... and I do all right, and there is no urgent need to buy ...
it suffering health or luck when it backed enough for a straw ....
Post by Dimas » Mon Aug 10, 2009 23:44
But then why do You need "and I gladly would have bought this excellent tool ..." if You have it right?
Post by Guest » Mon Aug 10, 2009 23:45
Sun :-)
generally good health and eyesight are very rare ... in nature for as following natural selection and we have every bot leaves the offspring ... and then his grandchildren rushing to hospitals and shops of miracle ... but the essence of it in many ways, but not luck at a crossroads ..
Солнышко :-)
Post by Солнышко :-) » Mon Aug 10, 2009 23:48
Guest Mmm... I see. And have you used any products from this website? the mind-machine, audiostrobe...
Post by Guest » Mon Aug 10, 2009 23:51
Dimas wrote:Guest
well, I've always relied on common sense and he carried me all the troubles ... and common sense tells me to make sure the reality of drawing rooms and use ... explore all the wonders I am not able ... easier to learn from others mistakes or guru ... you know, set of information for analysis and insights ...
well, for example your seminars deserted ... te Svetlitsa does not act to radically ... adequate examples, I saw ... bought silent as clams ... the old site of the parlor is dead ...and so forth .................
Post by Guest » Mon Aug 10, 2009 23:58
Солнышко :-) wrote:Guest Mmm... I see. And have you used any products from this website? the mind-machine, audiostrobe...
I like a scanner ... impersonal robot scanning the entire old and looking for a what of just posted it the real thing ...
I like this website ... it is the presence of what I took at the time, the vanity of the world :) there was no time and as you can see thank God ... but as a business maybe it's someone good
you will be advised to do the surgery and enjoy the precious time of fellowship with friends and family and the search for Nirvana, and so forth, leave stalkers az
Солнышко :-)
Post by Солнышко :-) » Tue Aug 11, 2009 0:02
Гость wrote:I like the scanner ... impersonal robot scanning the entire old and looking for a what of just posted it the real thing ...
real thing why, because you wrote that you have everything in order. Well, you're looking for something not just for the sake of curiosity. Or am I mistaken? :wink:
Post by Guest » Tue Aug 11, 2009 0:08
that is why there is a demand for such amulets ... what am I looking for ? I , like you, always looking for something ... as there Tsigan ... that is not what a pity , his heart rushes into the distance :wiz
we all know from childhood and waiting for Santa Claus ... and a miracle tickles emotions and I became a cynic and instead of waiting for a miracle began to look for what's the point ...
and you seem carefree seeker of wonder and happiness ... you probably all in the pink fog ...
Солнышко :-)
Post by Солнышко :-) » Tue Aug 11, 2009 0:20
Гость wrote:and you look like a carefree seeker of wonder and happiness ... you probably all in the pink fog ...
You've got me smiling.
By the way ,at my expense, it's much easier to be cynical, to give up and move somewhere in an unknown direction.
I don't consider myself a gullible person, on the contrary consider myself a fairly pragmatic person who knows what they want, reaching to his goal.
And I can't talk about some things if I tried, or studied, I can't say with confidence that this is not and can not be. Be sure to study only try and if I like it will suggest another.
Гость wrote:will buy you and then write to us Smile buy ... I think its information jewelry ... buy and won't speculate and to doubt.
You I suggest that do not try. By the way, I just ordered some...
Post by Guest » Tue Aug 11, 2009 0:29
Sun :-)
in this case, you should not believe of geography and use maps .... you yourself were not there and did not see ...
I tried everything but not on the level of feelings and the level of evidence of cause and effect, I do not have a strychnine that would understand that would inappropriately to drink out of the swamp that would not do this anymore and inappropriately believe that to understand what we're trying watching the world ... but the feeling we do not understand but the meaning is obvious to us and the result az
can I suggest something that is not tried. By the way, I just ordered some...
well, as you say ... like rats ... smart animals ... make their weak cousins to try unfamiliar food or bait and if the kinsmen did not die, they drive away and eat themselves :? what type of I also try and learn but as they say only the Karoo learn on their examples :) like why are we given the info and knowledge that would all pull in the mouth in order to understand what is , look for drugima and understand what is good and what is not ... 8)
Солнышко :-)
Post by Солнышко :-) » Tue Aug 11, 2009 0:32
"All is not gold that glitters." (sorry for short)!
Post by Guest » Tue Aug 11, 2009 0:39
that's it !!!!!!!!!!!
for you now that it is shiny ... but the gold is it ?
so I see ... please leave feedback when you receive ... what and how ... interesting ... and good luck to you az
