Orgone generator with their hands (The Succor Punch, SP)
Good day to all. Long time ago I read your forum, learned a lot and tried, and although the forum is almost over, share their experiences: the Main thing in the device is a crystal, they do live, and with his character, so before it is poured, you need to determine whether he wants to work in the device or not. Feeling will understand the answer..... and others will advise you to tell the crystal what you want, then put in a box and next to put a Cup of wet bread, pastry or piece of meat. Decay, compaction test, is considered as the answer is no, the drying of meat, the rise of dough or a good mould development-the answer is Yes. It is not necessary to force the crystal-is fraught. You can fill in only with wax, the wax better than all the other materials, remembers and accumulates information and is reversible. Many years studying ancient architecture , its energeticheskoi component, as well as minerals and treatment with their help, gathering your experience and your made device in my opinion is very efficient: based on how you on the first page,only filled with wax and the lower base of the pyramid which has its peak for the crystal, then all together wrapped in several layers of copper and aluminum, in layers with insulation between them (common tank-pipe) in the wax filled red and UV diodes and a sealed earpiece to deliver sound. And most importantly, all sizes: pipes, pyramids, the distances calculated by the Golden section! This is a huge plus.
When the device is under the pyramid I put a photo of the sun, moon, cosmic, or mandalas, and on top of the crystal-aim. But if we need someone that is to pump, then a photo of a man under a pyramid. The methods described above (meat,dough) is good to check and work ready instruments, these methods for many years check the geopathic zones in the design of housing.
Re: Orgone generator with their hands (The Succor Punch, SP)
So it is not necessary to fill in the spiral, the energy itself is twisted to the side, depending on the purpose, for example in humans, rotation field counter clockwise leads to the cleansing and release of energy and information in space and time reverse. This is just my experience, but who may be amiss.
Hello!
I have this pyramid, tell me what can be done ?!
Gray that you wrote the matching coil is copper. there is no tension to life-threatening, so it is possible and without insulation. Beautiful (I personally like the color of copper more than all) .and etu 3.5 turns of wire it just to stick it to cake or bridge the contacts to the main coil.
Will throw in my two cents. Coil on 3.5 round goes as an independent stray. It runs by itself. This is symbolic of Kundalini. It is more correct to call it a spiral, not a coil.Дельтус wrote:and etu 3.5 turns of wire it just to stick it to cake or bridge the contacts to the primary coil
- Разгельдяй
Hello everyone, here decided to make another device active
The idea is to balance(harmony) single crystal in the center with the usual möbius, and four at the cardinal points with opposite winding, Attempt to establish two-flow "orgone", which will how-to pulsed-balancing
for this use gathered stereo 3.5 mm Jack Mom, Dad).. stereo will help when you need to equalize the flows(one channel, one frequency, on the other-other)
the filler was going to use steel shavings, different caliber), copper is the problem, used the reserves
Have a question about the use of foil as a screen(medium crystal)?
well shemka:
well shemka:
Lancelot does like aerial acts. and this antenna acts like a normal antenna catches. possible with the help of cake a man tries to lead his reception of the transmitting system in order. likely a person pogruzo n in the Kaku environment where osnovnog role is played by electricity .people are also able to create it. the tension electric fields in the right place.
Razgledaj vector mathematics in the school ?
If the signal from two channels of the array will not be two streams and one total. The orientation and frequency, which prevails.
If phase-shifted with the same frequency then As you will be phasing frequency. Need very strong knowledge in working with audio editors.
Different frequencies if you submit at the same time then what's the point? Again will act dominant.
In the end, is the principle of radio transmission. The modulating frequency and information.
If you apply two different modulating frequencies in the radio and the receiver somehow needs to be told about it...
And this is our case?
Have you thought about this?
Always start with a question. Why is it necessary? what is the ultimate purpose of all this.
Guys don't want to repeat that this is not an area of knowledge where you can experiment with impunity. It is the mental aspect. Chance to hurt yourself and others exactly the same as on luck. And depends on your basic knowledge and luck.
And if you are lucky it is not better to try himself in a casino or a sapper?
- Разгельдяй
Gray, You yourself said that school mathematics in the case of orgonite does not work(well or something similar said)
So my main principle is expansion/contraction, if the vortex to the right is the extension("radiation")
if the left - compression("absorption, the absorption), the Central crystal twist right at the sides - left, if everything works, you get to create organic, which will not be much to suck "Dor"(or whatever it is?
) and much to give(beat by brain)
And podsalivaya and giving at the same time , create a balanced region of space(harmonious)
in which, in an urban environment can develop.. something like that
can someone from experience say how to do "mind warping" device? in my experience(small, 4 pieces made with crystals more than 1.5 kg ) the most powerful when in parallel to the coil connected to the winding of the 12 layers of foil wrapped around orgonite through the paper ( as in the condenser)one wire to the inner circle, the second external. If you are afraid it will be too ready to feel ( nothing to lose). or can tell me what amplifier?
Even as the second coil tried to reel in the crystal normal wound( as on the speakers).... my feeling is working harder....
Not quite to the point, but let it lie here.
the Lemon of deliverance from serious illness. Several reasons to drink in the morning on an empty stomach water with lemon
http://oko-planet.su/ekstrim/ekstrimsov ... monom.html
yeah
still to this ginger and honey instead of sugar and water is not just cold and not boiled, lukewarm, activated, the drink of the gods
drink in the morning and the afternoon and evening with great pleasure do not remember when was the last time a simple zavarnoy drinking tea. only bad thing is that in Ukraine, prices for all lemons in particular are growing by leaps and bounds,
try to eat at least one lemon per day in any form.
Although I eat them like apples. We have a kilo of lemons worth 2-3 dollars. As much as bananas. What is Ukraine worth ?
Pilot
And who the roof in place back pathologist?
This website is not for sado-masochists.
- Разгельдяй
Hi, I understand what Gray Gutara..
The solution was found immediately, made a recording of "mantra" his voice, alternately, the signal on the left, on the first channel for 5 seconds...
If the top hand to keep the jitteriness a little pressure, nice)
Freezes yet..
Freezes yet..
Идущий Маг
Hey all,decided to collect the device but instead of epoxy wax in General, and charge it in the hardening of his thought.
Still read the forum and found that fluoride is harmful to the development of abilities. Already abandoned sodas and I think to abandon the passes of the tooth. It is better to brush your teeth with salt in General)
Decided to try the lemon diet)
Running MAG
Dubious pleasure to charge the wax with your own thought forms. If you have the ability to focus on one thought for at least 10 minutes you do not need the device. You need to put a monument.
Prayers are the best possible. Prayer coming from the heart and with knowledge.
Идущий Маг
Седой wrote:Running MAG
I have several years learned at least to keep the image and stopping the internal dialogue.
Устройство
Good day!Профан-к wrote:About an entity in SP in fact, she misses it there born )
I'm sorry, I want to clarify, is tower buster and other passive too?
Thank you very much.
Good afternoon everyone. I'm just starting the study of the topic, although the gender theme, I even so was able to read. I have a question to knowledgeable people, what if in the generator to use the "mirror Kozyrev"? He also creates not sickly flow of torsion fields and spin in particular is used in a counterclockwise direction. Here is a link to a resource where we can see the subject, do not pretend that there is all but it is enough to begin. http://facultymagic4.narod.ru/mirror.htm
Why do we need SP?He also creates not sickly flow of the torsion field
You and the rest of the development site read?
I need the same topic to study. If a working TV to pour sea water, it will evaporate. Long, not long does not matter, but it turns out that the TV, you can desalinate sea water.5.4 the Bottle for Hottabycha
I'm certainly not as in these cases, but it seems to me that the flow of orgone in any case will interact with the torsion field.Ланцелот wrote:Quote:
Why do we need SP?
As for the rest, no read. I just gave one of the sites. I don't think its particularly interesting but nevertheless it tells the essence of Kozyrev's mirrors. The same people are doing and Miass and in Response to people being treated for psychosomatic diseases. I think that such things in any case should attract orgone.
I'm also not the authority on this topic, but still high for what I could use SP, cakes of orgonite, etc almost is to create a powerful stream of negative ions, is that in fact I was able to measure devices that are used to test ion generators air conditioners and other appliances for the skeptics who didn't learn to feel subtle energy, and even in this case, use is very very, about the benefits of negative ions Gallente will find many wonderful and interesting things for themselves, unfortunately in a strong magnetic field, the city, the bad air, the quality of water, etc. is a very useful device, stumbles anywhere near electronic devices.
the passive version of the cakes collects the positive ions thus reducing surrounded by their concentration, generates active negative ions, and almost all data Divisi can rather much more more than, just not as they appeared long ago and dealt with,
