Try to posobiyami post.And plenty of vitamin C<АлексВлад wrote:Hello!
Sorry for the duplicate emails, but in another thread, apparently, living there
Friends, please tell me or give a link where and how to learn to work with ORGANICA? Made 3 pies in plastic cups for the microwave to 0.5 liters. On quartz crystals, the longest about 5...7cm, wrapped Mobius wire PEV-0,15, 18 metres long, folded in four, twisted, folded four times more, tied up, turned out beautifully. Wrapped around the crystal, in parallel with the coil, at the bottom of the crystal glued a piece of three color led strips, got 6 LEDs and also led wires for an external controller. Thought possible to work quartz with frequency in parallel to enable working with color. It looks also beautiful, especially when the bottom quartz glued aluminum foil as a reflector. Sliced finely washcloths, because they are not cut badly compressed and trebuutsya and the fill factor of the glass obtained is low. Filled it with epoxy. Coil resistance 9 Ohms, a series resistor was not soldered. The first glass of almost boiling, saved a bucket of water, cooled. Everyone froze, from glasses to get and looks so good and more aesthetically pleasing. Included in a couple of weeks the player that recorded a whole bunch of frequencies for all and from all , someone here or elsewhere posted. Day passes - or anything! Nor any sensations. However, the fruit cake is on the table on the first floor, and sleeping on the third. Some days nothing, put on top of the cake the hair, or what, put the nails again, that does not feel, spit on him(literally - spat) , i.e., left biomass in the form of his own saliva - what did not hack and any where. Checked the signal in the coil - is. Connected parallel to the second Kulichik, player powerful, pulls without problems, but don't feel anything.
Please suggest how to determine if my appliances? I can send a photo somewhere of the devices.
Thank you!!!
Orgone generator with their hands (The Succor Punch, SP)
Re: Orgone generator with their hands (The Succor Punch, SP)
With what purpose was created the device? What is the ratio of the volumes of polymer and metal. And the ratio of the volume of the crystal and orgonite in General?
The device does not zelinkova on you then spitting it will not be. But even the most insensitive people feel the unit is switched on. Ringing in the ears, etc. should be observed when they first met. Frequency to drive any should not be. You can run into. Beginners should start with a recording of the prayers and not with frequencies.
A set of words Love and Gratitude and it is noticeably better than the all sorts of frequencies.
On account of fasting and vitamin C also could not agree more.
And most important thing to determine why you need this beautiful thing.
And again the same problem. Iron. Not a beginner the iron, just can't. We must learn turns copper(bronze)-silver(gold) is iron.
For many years I have mastered the copper, tamed a variety of metals and stones. And only recently started to learn iron. Changed his profession for the sake of it. Started to learn blacksmithing and processing of steel opened his workshop for processing steel. Energy used to the bit.
Copper is easy to learn, it is close to the people. Iron and requires special treatment. But the cake with the iron I'll be ready to do a year or two. I did not react until your first cakes with iron shavings. Although everything started in this thread with advice Logan and Humpty. But then I realized that that something was wrong. Maybe it's the person.
But probably not only.
So good luck.
So good luck.
not found in the thread info for the properties of water energy Yin and Yang before and after exposure to SP, ORGANICA, according to my observations after exposure to water it becomes more Lanskoy, Yin wanes, Yang increases, the water becomes like easier
The device was created as, possibly temporary alternative to the orgone box, haven't decided the place of installation. And, of course, that would imagine to validate experience and capabilities, and my device in terms of improvement themselves and their families, as well as for spiritual growth. While still at the level of the experiment, starting with the fact that at least, say, organic neutralize the negative field and change negative energy to positive, and in my bedroom window on the second floor just "Shine" from the two towers cellular/3G/2G/WiFi and still do not know what the distance of 100 meters. With the advice of Humpty and the other companions, began the quest for it is actually and You. The ratio of the volumes? And somebody is measuring or just doing so, as it turns out the descriptions of other pioneers? Half-liter glass is approximately 350 ml of epoxy + 100 grams of small crystals of quartz + 7 iron sponges(weight do not know tomorrow to buy a kitchen scale - weigh) + crystal quartz long 7cm, diameter 2 cm Crystal processed, cut and polished in our city not only sell polished Druze, but he is right its not split. Just want to look at local factories swarf of different metals, although the operating plants we have almost no. There is still a desire to get the polyester resin instead of epoxy, cheaper and more volume.Седой wrote:for what purpose was created the device? What is the ratio of the volumes of polymer and metal. And the ratio of the volume of the crystal and orgonite in General?
Photos can be added here?
Enlighten is not correct, please what is the LINK? Perhaps that's the case, head circling, perhaps where the rang, but so would some write "hits", this was not. Again, the instruments were in other rooms on a different floor of the house, i.e. away from my permanent residence and for a long time, about two...three weeks began to make attempts to turn the device on, not for long. Then longer. If You don't mind, please give a reference how to work with It, how, from whose point of view do devices and why? To read all the forums on this topic I guess you can't, your eyes will meltСедой wrote:the Device is not zelinkova on you then spitting it will not be. But even the most insensitive people feel the unit is switched on. Ringing in the ears, etc. should be observed when they first met. Frequency to drive any should not be. You can run into. Beginners should start with a recording of the prayers and not with frequencies.
Thank you!<Седой wrote:a collection of words Love and Gratitude and it is noticeably better than the all sorts of frequencies.
So good luck.
There has been written so that it is easier to write new than to look for anything.
So. Purely on the theory of Logan. The devices are passive, based on iron wool or shavings are used to absorb negative energy radio transmission antennas.
Different psychos and (or) philanthropists or other people with difficult diagnoses around the world have made many many different balls, pyramids and other amenities and is buried nearby radio towers. In my opinion it would be better to abandon the same cellular and plant a tree somewhere. Sense more. However, this subtle energy, we will not condemn.
I nawaafil many different pyramids of hexagons of parallelepipedal and parallelepipedal, (well you get my point) for iron, with different stones. But I cannot feel them. 0.
Then, as I'm a big fan of copper began to do simple washer with a diameter of 10 15 cm and a height of 1-3 cm. the volume ratio 1:1 organic metal. that is volume and not weight! Planed any copper wire. Added crumbled stones, amethyst, shungite hematite lapis amazonite citrine. what I saw, and was not sorry. And always in the basis set of the spiral of Archimedes.
And such devices, I feel they bring peace, good sleep and good luck in business. Yes, and look beautiful and not afraid to put their homes, as part of the interior.
Put them always closer to himself either on the window sill.
There is even a ingot dimensions of 40 cm by 25 cm with a thickness of 3 cm Weighty thing. There's a huge spiral for the entire size. the frame is bronze rod of different thicknesses and crushed amethyst. Quartz can be said. This thing weighs kilograms 8-9. Standing on the windowsill in the bedroom. Under the pot of flower. Flower money as it is there is popularly called.
Always try to keep near the vessel, a vase filled with plain water. Water does not rot and is not covered in green muck and gradually evaporates.
Between the tile and the pot is always keep a stash. Rather than stash and earned or found by the money. Profit income. Of course spending money, but try to make sure that the place was not empty. Given, then, of necessity, took, thanked.
The method of working. Brings fruit. Energy in the house is excellent, money can't complain. I have to earn it through hard work. But they come to me... And this is important.
I always have exactly as much money as I need. Just needs people have different... the Main thing is to be content with what you have and you have clearly defined goals. What do you want to have. The money to pay for it themselves.
Why do we need money ? in order to buy something you really need. So you need to imagine a thing, a phenomenon or something connected with it but not the money. Looking for a house, imagine it, draw and be creative. All will come true in itself. The money is only a means to the goal and not the goal itself.
This is a slip up when working with the device.
On account linking. And what is the link. The link is the link in human language. But since we all love America and perfectly fluent in English, we call words in the original. Link! here it is.
So. there is an active energy device and energy-a confusing man.
The device can emit certain frequencies by themselves or can modulate these frequencies by the thought forms of man. That is, your thoughts and wishes to transfer there where it is necessary. To the appropriate authorities. And you have to sit and wait for you to knock on the door what are you so fiercely desire.
It is not necessary to remind, probably, that desires need to be very careful. Can you wish that you will have to disentangle the result of a very long time. THIS IS ESPECIALLY TRUE OF MONEY. Money for money ...
In where to start.
This is the first post. Preferably 40 days. There are monotonous food, meditation, and the most important and long-forgotten in this case. to maintain spiritual purity.
This process on my recommendation should be accompanied overdose in vitamin C. Preferably obtained from lemons or other fruits and vegetables with a high content of vitamin C. the Dose of vitamin should be at the level of 1000mg per day. What does this have to do.
For the emergence of new neural connections in the brain necessary vitamins B and C. And the frequent and deep sleep. Peace of mind, lack of stress and anxieties. And the Idea, a new idea which is to make contact with something unknown to the village. That is our cake.
You can accompany this case work with the plates. But you have a single-coil device and there is nothing to be done. In this period of time you should often be around. To carry it with them should not be. Need two or three hours in the evening alone, before bed to sit quietly and peacefully to communicate with the device. To be in his field, meditate, drink tea or read a book doesn't matter. Importantly, the presence of radiation.
Most people just fall asleep next to happy and calm like an elephant, or a boa constrictor.
Do not move to reposition the device. Need to find him a place in the house and leave it there for permanent residence. And so it was easy to be around. And so that it does not interfere with the rest to live. Especially women do not like all that to catch the dust.
There's a lot said about linking with saliva blood and other fluids. But it is better to get used to the device than to tie yourself to him. It's a Voodoo doll please...
It's your mimicry. This should treat it as proper to him personally.
If the goal is to create just such hard bound thing that is done with the sperm. Not the blood or other fluids.
Maybe this idea to the liking of the young drochery for Hee and the rest. But the essence of the man in his seed. And there is a very deep meaning.
But again, this is for General information and you have not the case.
The device first, and most importantly to understand what it can do without a hard connection.
So you need to rebuild yourself.
what is the expected result. According to the experience.
First you will begin to feel the instrument, to find it even if you hid it. To feel his presence. In the storm of feelings will grow! Charged air contributes to the fact.
Second
You need to study and apply the correct syntax of communication with a device through a device with the logo, a single and how would you called.
What is it. We use only the words and through them Express their emotions and desires.
The universe does not understand the word NO in any form of denial.
I am for peace or I am against the war for the ordinary man the same. But for the universe there. Peace is peace and war is war. No matter how many different words next.
To start the contact with sensations, with deep feelings of love. This is the key to everything. And end with gratitude.
You need to keep the laws of the universe. Need to know what all you need to pay yourself.
It is impossible to violate the will of others.
You need to fulfill the promise.
To accept the result with gratitude.
The result might be delayed... But not necessarily condemned. You need to believe it as you believe that 2+2=4
When you are in contact by means of an apparatus possible body shiver, attack, crying and even having an erection. Not worth it to be ashamed of or be afraid of it or accept everything as something strange. People under the influence of a strong field can do and such. All need to be taken for granted.
And in the conclusion. After contact you should always lie down and try to sleep. To take a NAP. Most often the answers come like flashes, a certain number of photos.
Suppose you want an answer to some question. You asked it through the device.
The answer you will receive in the form of plots of imaging. This is better in such moments to lie down and close your eyes.
Another very important consideration.
Learn how to keep inner silence. It is very difficult, just harder than with a person faces in their life. It may take years and it can all happen the first time. But this need to learn. If you have embarked on this path.
For only in a state of inner silence when your inner voice is completely stopped contact can be clean.
And practice visualization.
It's already easier. Close my eyes and try to imagine any object known to you. Suppose the ship.
Close your eyes and imagine the ship. Begin to draw the details, twisting it to look out on all sides to notice details. To observe from different angles.
It fascinates and captivates. And contributes to the development of imaging techniques.
The result of successful practice with the device I believe the test for the effects of the weather.
If you like the result, then you are ready.
For all of you who have used my methods, and receive help and advice from me, the test was gone, and without exception it took place. Although some small degree of doubt and self-criticism. But the self-confidence comes with age.
There will be more questions no doubt. Write. I will be glad to help whenever possible.
Good luck.<
In where to start.
Second
Good luck.<
Just - STUNNED!!! THANKS Buddy!!!
Now there is something, and something to work with!!!
THANKS again!!!
PS America is not loved, not love, but maybe even learn to love it!
THANKS again!!!
Let the issues. Somewhere I read that someone tried to make organic based wax. Is there any prospect for such direction? People doubted that the wax can melt from room temperature, that hardly. The second issue is related to a method of winding a Mobius strip. Noted that you need to correctly twist the wire that is the main problem for the correct operation of the device, and the winding doesn't matter. That is, wind does not necessarily every round to complete transverse ring around the already wound coils, you can just as winding, turn to turn, and everything works the same. Of experience in radio and a soldering iron, I supposethat counter-parallel arrangement of the conductors in pairs, it is necessary to compensate for the electromagnetic inductive component, and a tight twist to compensate for the capacitive component. All that would leave from the signal only the information, without electric components. Accordingly, to wind such a coil, not something that would be easier, and less chance of damage on the faces of the crystal.
Another question. Box of Reich's analogue Argenta, in one form or another, or all the same other thing? Experience in comparison to someone that is?
Thank you!
Thank you!
The problem is that these fools see what is happening in the place where left by these crafts. And You think you know how this works. Agree that it is different.Седой wrote:Different psychos and (or) philanthropists or other people with difficult diagnoses around the world have made many many different balls, pyramids and other amenities and is buried nearby radio towers.
I'm just saying that the rejection of the use of mobile phones and planting trees will bring more tangible benefits.Ланцелот wrote:The problem is that these fools see what is happening in the place where left by these crafts. And You think you know how this works. Agree that it is different.Седой wrote:Different psychos and (or) philanthropists or other people with difficult diagnoses around the world have made many many different balls, pyramids and other amenities and is buried nearby radio towers.
But, as we say who is not crazy the one PI...
In light of the foregoing advantageous to be crazy
This is of course a joke.
Nothing pollutes the environment as bad thoughts, especially when it is in the masses. Rallies, riots war. Litter over the whole cellular communication in the world combined. Any person who constantly complains about life fonit worse radio tower. And hurting themselves and others. So positive and a little bit of craziness better secret bookmarks under the radio tower. All the radio tower is not the enemy bridge from the novel "For whom the bell tolls"
Alexcold
On account of the wax. Preferably processed independently from honeycomb. With the addition of natural propolis, if you get me.
It is impossible to overheat! Better to thaw in the sun. Energy uzhzhzhasno high.
Remembers information easily, can be easily cleaned. Ideal as a replacement for epoxy.
But so much fuss and shamanism... in short for everybody and certainly not for the inhabitants of megacities.
On account of winding. I always make the frame forms the letters C and make three coils on the axle. Not one, as reglamentary Logan and three.
the length of the arc frame needs to be equal to the arc length of the crystal. Wound on the coil frame is then moved to the crystal. Coils always make very thin and very long wire. Everyone has his own insanity.
Which way to turn does not matter. You can change the polarity of the signal but if just use a drill as the screw is twisted or Svetlitsa drill. That is, the rotation from left to right. And in the cartridge to fix the ends of the wires of the winding is correct. Then there will be from right to left
Any terminology from the theory of circuits-type the magnetic field and the more compensation capacity zamordovali. There is some capacity at frequencies of 5Hz?
Here is another physics. Gay.
The only clue is a scalar field. We are dealing with scalar fields! And about the physics of scalar EM fields, science is silent for a long time and hopelessly.
It is impossible to study the physics of scalar fields. This scientific taboo. That we are here and break.
Cabin Reich first. The analogy is undeniable. Any transition metal dielectric has a property to accumulate orgone.
It is in the surface of the transition. This any porous materials, meshes, etc energetically very active.
The only measures that are useful in this case, the ratio of volumes of polymer-conductor and the total surface. The smaller the metal particles the more as a result of its surface to the specified volume. That's all it is.
In the future try to make two coils instead of one. Two identical coils, one exactly in the middle of the crystal and the second in the Golden section. Closer to the tail.
Would be more useful in the future and the device will be more versatile.
To optical irradiation of the crystal, I am skeptical. Did not recommend.
Introduce a third unknown into so strange a dubious pleasure.
Better to know in advance the volume of the crystal and the volume of the metal. The Method Of Archimedes. Polymer is easier to measure.
The volume of orgonite at least 3 times to surpass the volume of the crystal. And best of all 12.
The volume ratio of the polymer and metal one-to-one.
And only copper copper and more copper. The other side did not even look.
And for the passive radiating only aluminum.
Copper accumulates orgone and crystal directs in the desired direction under the influence of modulii scalar field around the crystal.
Aluminum also emits orgone itself. According to this handy passive.
And if you want bull to say dirty energy, say to clear the room from the gardens, it is a passive copper organic. Then it should be thrown away. or is it better to bury in the woods.
See table of electrochemical metals will become clear.
To combine these two metals in orgonite just a gross error and any two different metals, that is, from the opposite electrochemical camps. Such devices are just useless scrap metal.
Now.<
Hello! trying to find music tracks so to speak for the charge of SP, for the subsequent SP radiation into space by the strong positive, prompt what better to select, who have tried with good result, thank you all in advance, with UV.
that is my pendulum dowsing has temporarily stopped working, whether it is time to clean, whether to change, whether he I this wine, actually left the instrument, and my subconscious is on temporary leave
I would recommend Jean Michel Heat, but do not have SP.лексветер wrote:tracks to say so charging SP
There is a desire pozitivnenko to scare the Russian tanks on the border?лексветер wrote:trying to find music tracks so to speak for the charge of SP, for the subsequent SP radiation into space by the strong positive, prompt what better to select, who have tried with good result, thank you all in advance
Just a friendly advice, to start with, to understand what is covered, for example temporarily, the ability to work with a pendulum. It is not very good bell.that is my pendulum dowsing has temporarily stopped working, whether it is time to clean, whether to change, whether he I this wine, actually left the instrument, and my subconscious is on temporary leave
PS Although if you believe that You are doing everything right, you just need to clean the pendulum from negativity and charge it.
no for personal use only to disperse the surrounding negativityЛанцелот wrote: There is a desire pozitivnenko to scare the Russian tanks on the border?
around because of this policy, which does not look solid film, in the bus, tram, at work and even at home, that probably work with the pendulum suffers because like it or not as easily impressed a lot of people miss everything
What is it like? - and the second in the Golden section closer to the tail - to the base? A skeleton can? but do not insist. SorryСедой wrote:In the future, try to make two coils instead of one. Two identical coils, one exactly in the middle of the crystal and the second in the Golden section. Closer to the tail.
Two coils are the same. One is wound exactly in the middle of the crystal and the second closer to the tail of the crystal somewhere in the 40% of its length. Displayed on two separate plug. Coil gotta heap, not flatten around the stone if the stone is not tiny. Crystals of less than 300 grams of weight very inefficient.Хеди wrote:What is it like? - and the second in the Golden section closer to the tail - to the base? A skeleton can? but do not insist. SorryСедой wrote:In the future, try to make two coils instead of one. Two identical coils, one exactly in the middle of the crystal and the second in the Golden section. Closer to the tail.
the Golden section is a ratio of 1 to 1,618 where it turns out that 40% of the total length.
Good afternoon, almost the entire forum read a lot of interesting things to learn have long been interested in this topic.Have a question bought 2 products I have very big request in particular to the ETS know you can determine how much energy comes from these amulets .They are made by technology of organito .I'm interested in what energy emanates from them ,positive or not ,as they in strength ,and do they give what is written below. Charges the body with vital energy, Restores and strengthens the bio-field,Reveals the creative potential and intuition,Adjusts to the perception of subtle vibrations,Calms and promotes spiritual work,Neutralizes the negative effects of techno and geopathic zones,Protects against electromagnetic and torsion radiation.
[img][IMG]http://s006.radikal.ru/i214/1403/22/b5042edd39d6.jpg[/img]
[/img]
[img][IMG]http://s020.radikal.ru/i711/1403/5a/aa64ae328982.jpg[/img][/img]
[/img]
Sorry I guess I was wrong on the pictures sent (the first time pictures are placed in such a way)
here are the links
here are the links
Hello, left unattended post in the topic, Gray and other forum users asking procument on the question of the correctness of the winding including two coils mibis on the crystal in phase and antiphase thanks in advance to allлексветер wrote:who thinks what about it gentlemen?????????
"Experiment Scalar coil
March 27, 2011 | Author: Sorynzar
I have always had great success with the Scalar toroidal coil style, for example, as developed by John Logan . These exciting coils radiate energy, which was called a scalar. In popular physics they are associated with zero spin particles such as the boson. Theoretically, you can create a scalar field on the opposite two identical waves that are in phase with each other. The black projects community term scalar generators as split phase coil. It was something that eluded me directly, and my physics tutor who match has done her PhD Scalar waves. Time has a strange way to combine all the pieces of the puzzle.
Coils such as those developed by Logan, work on the principle that a small scalar field is made when two identical waves create magnetic zero point of the node on which they become unsynchronized. Genius using chetyrehkantnyj wire provides a greater degree nodes should be merged in one small package. One thing I found creepy chetyrehkantnyj wire, which uses Logan is a reference to a template Node Chi, a design which was widely used by Celtic tribes and the Saxons in their artwork.
While impressed with the ability of the regular coils of the toroidal scalar, I have had an idea niggling in the back of my head that I need to experiment with. This was after reading several of the physical works to open Russian research into torsion fields, also called spin fields, I came up with the idea on the basis of entropy. I still do not fully understand how these two relate to my idea, but I just wanted fantasy. I briefly cover the theory of torsion fields.
The positive entropy, that is (evaporation of Accetone) = SR (right-handed torsion: Time Emission)
Negative entropy, i.e. (the freezing point of water) = SL (Left Handed torsion: Time of absorption)
SR is a repulsive force, and SL is the attractive force, together they create a torsion.
The idea of two opposing forces led me to use two counter flows of electrons combined with a regular installation of the toroid. To do this, I had to wind the coil is a little different from the way Logan taught. Instead of using single strands of wire, had to use two in parallel. Two 60 'lengths, it becomes quite difficult to manage, let me tell you!
I persisted, and record the two lengths together at each end, folded them, as by the method of Logan and started to wind them. Once the coil was completed, after some considerable time, I was able to implement the theory.
Positive from one generator is switched from the negative of the other. They are accurate as can be achieved with analog electronics, but there may be some drift. I managed to get the fields to read equal to 15 Hz for each timer, but there is always a small intolerance.
The positive and negative stream flow parallel to each other inside the coil. If positive and negative flows cancel at the nodes with the applied frequency. It is possible that parallel to the flow of electrons in opposite directions, also has a small effect, a scalar that gives performance improvements to the coil.
Use a Gauss meter on a traditional coil of the same ohmic value as the base reading. I then set out and measured reading of a new round. Gauss has significantly decreased, which led me to believe that in a greater degree of electromotive force scalar of steel and not magnetic. The experiment seems to have been a success. However, it will require additional testing.
Edit:
One thing I would like to change this generator and amplifier circuit. The generator itself does not give enough power for scalar coils. In fact, most of the voltage is lost. When adding a power amplifier, the output increased significantly. I aim to replace the amplifier IC with a power transistor to adjust the coil so that the reverse voltage is put back into the loop and not lost. It will take some testing, but it's what I started to work.
the source of the article http://www.berkanapath.com/radionics/17 ... xperiment/
lexeter
Sorry, but it's just a bunch of words devoid of any scientific meaning. Like tried the Google translator.
Yeah the way it is. he clicked on the link.
Frankly I do not understand absolutely nothing and not because of English but because of the primitive and inherent zamorochinsky English stiffs Charodey.
Now, about two coils, which I recommend to shake.
According to my idea. (On the authorship of the idea to do two or three or how much you want the coils to pretend I won't)
one coil is fed the modulating signal. White noise! and the second connected two plates of different metals. Copper and aluminium. On platinum put the palm of your hand.
Thus generated by the galvanic current modulated by our thoughts. The brain activity cause a change in the electrical conductivity of human tissue. And different metals cause the electroplated process, as in the battery. And the coil current flows with its consequences.
The method was tested and works quite effectively. With the polarity of the coils and the sequence of inclusion is to experiment. There's no good No good! the main result that satisfies.
lakras
http://s006.radikal.ru/i214/1403/22/b5042edd39d6.jpg better. I do not know whether full compliance with the stated advertising but...
Make sure that the polymer material is not toxic or at least covered are harmless to humans varnish.
lakras
Very interesting. Here the perfect analogy with the cylinders of the pharaohs. There are not only connected through the SP-design. And the metallic pair I similar. A cylinder or plate, I think it does not matter.Седой wrote:one coil is fed the modulating signal. White noise! and the second connected two plates of different metals. Copper and aluminium. On platinum put the palm of your hand.
now think about a fully collapsible design. because all of the cries against the crystal roll up organic (for me crystal live and crystal fully bathed in organic are exactly what in the sarcophagus)
Thank You, Gray!
Thus generated by the galvanic current modulated by our thoughts. The brain activity cause a change in the electrical conductivity of human tissue. And different metals cause the electroplated process, as in the battery. And the coil current flows with its consequences. The method was tested and works quite effectively. With the polarity of the coils and the sequence of inclusion is to experiment. There's no good No good! the main result that satisfies.
PS. introduced the construct of the instrument, see like right-handed right-handed host copper under the left hand aluminium, but as well almost experimentem
this is slightly off topic, but let me share, I own not yet learned how to evaluate the result of the operation of the instrument, but helps me a lot with my little brothers family cat and of the surrounding circumstances
do not believe for a week I three times crossed the road black cats, once, you know I was very surprised the sidewalk, a lot of passers-by, the cat was sitting hesitated no where to go as soon as I walked up to Matt close to his location, the cat is neither from that nor from this began to cross me, a coincidence is unlikely, it seems, but what I mean is that working with equipment and in General should pay attention to the surrounding circumstances and signs, attention to the world around them helps a lot, this is one of the components of any magic attention to the surrounding area, etc. for instance did device, ask thought want to know to see to understand, to feel the result and see the result is good, bad, neutral, not say a word to sleep, Wake up, this is especially difficult in big cities when all the vending machines in the subway enter the subway take out, etc. sorry for not in topic not found other places to share.
PS personally I am very surprised that today the cat and the cat alternately lay down next to Rin. doors such a long time or rather never was, I was very alarmed, and began to dig. to ask, ask, info, is only one outwardly powerful negative impact from the outside, have the benefit of my dear cat's little brothers, I'm sorry that hardly anyone will be interested but if any one who is useful to have a post not be written in vain.
So, we need to create. Here, everyone will be typed one and a half to two dozen such stories. But I don't know
I hope admin., moder. us, You support something like gazebos, Smoking room, Temko, branch to OTL. theme not connected with the themes of the forum and policy will create the problem to create a theme no problem just press a few buttons, the problem is whether it will be supported and approved by, the topic of multiple messages, too, as it seems not why, just that quantity. PS. previous post before you can place long thought to have not found anything better how here, too
p. s thread humor for a serious text, too, as it seems not an option, there are initially people for humor will take serious
section talk about everything as much as 15 pages of branches with only a branch not mnogochislennye messages, you may want to combine them for easy search and useful as it is called, respectively,
THANK YOU FOR THE OPPORTUNITY TO EDIT AND COMPLETE THE MESSAGE AT A LATER TIME! that would not create a new message.X,Zyy, mi attentive assumption is justified, the firm where I work were checked as many as three control orgone and me including the Prosecutor's office, organized crime. and wait for another fin validation region, the coincidence is hardly likely regularity. so the external signs are very important especially if it is birds and animals.
