Orgone generator with their hands (The Succor Punch, SP)
Аркадий
Re: Orgone generator with their hands (The Succor Punch, SP)
Post by Аркадий » Thu Feb 13, 2014 19:09
Kozyrev engaged in pure parapsychology with the transfer of thoughts ( inside fit people ). Here the Parallels are just not there. I would like to understand the reason for such strong radiation in this scheme, because when you change the configuration of the power drops
Альтаир
Post by Альтаир » Thu Feb 13, 2014 20:06
To want is not harmful .
Harmful when wishlist wishlist will remain .
Without the device , based on its textile sensations will not get far .
Can leave this thread , because otherwise, all your conclusions are not correct (.
That's got something - now twist this around , find a way to measure it all than that .
But when pick up the device will move on .
In General , in vain you so about Kozyrev .
What did you bring , it's not only what he was doing :)
XUPOH
Been thanked: 10 times
Post by XUPOH » Thu Feb 13, 2014 21:35
Arkady, if it comes to optics pulled, wound Mobius fiber and sapiti blue laser, preferably modulated.
Аркадий
Post by Аркадий » Thu Feb 13, 2014 21:45
XUPOH wrote:Arkady, if it comes to optics pulled, wound Mobius fiber and sapiti blue laser, preferably modulated
Tried. Not impressed. Really done not Mobius (just fiber fractures in complex wound) and was supplied in red
Альтаир
Post by Альтаир » Fri Feb 14, 2014 8:24
I don't know ... this is the direction optikovolokno and the laser does not impress me ...
Saw a similar experience on YouTube ... and that ...
HOW to make this the resulting effect is more powerful ?
Drag babineaux to the fibers and to power the laser ?
Well get a stronger effect , and then what to do with it when you consider the weight of this thing plus power supplies ...
Dead end road :?
Ланцелот
Has thanked: 33 times
Been thanked: 11 times
Post by Ланцелот » Fri Feb 14, 2014 21:29
Аркадий wrote:What do you say????
The photo on the right. Probably live more beautiful?
Альтаир
Post by Альтаир » Sat Feb 15, 2014 13:15
ИгорьС
Has thanked: 5 times
Post by ИгорьС » Sun Feb 16, 2014 18:14
I have a strange somehow wire sbivaetsya places, although everything looks to be primer. First picture is normal and second...
Can someone experienced melisovounos prompt?
Ланцелот
Post by Ланцелот » Sun Feb 16, 2014 19:27
Different wire length and uneven tension. And always at the far end of the drill. This turns out, if Mobius shakes one person. If doing together, then the second person controls the tension of wires. At the end of the two-wire loop, you need to hold in two hands. preferably also the third, He with flannel smoothes wire throughout its length. To sheep and there were no waves. If no help, only experience and patience. I usually wind three wires. First, it is hand stuffed in the trash usually is. and second or third in the case.
PS winding needs to be more dense, to the corner 45грпдусов.
ИгорьС
Post by ИгорьС » Sun Feb 16, 2014 20:21
Hmm. Second person - if only wife to exert. Ie you want to say that this wire in the trash? :shock:
Such bjaka not only get away from drill, and for its entire length. One end of the wire clamped in the drill, and the second around a nail hammered into the Board.
Ланцелот
Post by Ланцелот » Sun Feb 16, 2014 22:52
Wire, before winding, you need to flatten. I use flannel. Two people stretch them, and the third runs along the flannel and iron it all. You will be able to develop the wire and smooth it, to avoid different curls? if not, the wire is no longer suitable for Mobius. In any case, with such a winding.
Two people is definitely better. Or the opposite end is not hard to nail to strengthen and to something podbroshennogo. To preload every two lived were separate.
I had the idea to make the jig. dochechka with 4 holes. As the winding wire of the man with the drill moves away from the conductor. theoretically, the quality of coiling should improve. Almost... I Leche brow to find something to do inside.
PS to Smooth from the nail to the drill until the wire is it is not clamped.
ИгорьС
Post by ИгорьС » Sun Feb 16, 2014 23:40
Okay, thank you. Try to develop accurately if you can. Next time I'll a few pieces of wire to buy. However, not a cheap thing turns out in the end.
Ланцелот
Post by Ланцелот » Sun Feb 16, 2014 23:47
So it is possible to wind a wire in enamel insulation. Better for winding engines, they have the enamel more durable. And buy it easier if there's a suitable factory or workshop. :) The only difficulty, before putting on the crystal, it is necessary to coat plastic (polyethylene) with a gun. If you do not do crystal enamel will peel.
ИгорьС
Post by ИгорьС » Tue Feb 18, 2014 22:27
But if the crystal of the paper reel that the wire is not scratched?
Ланцелот
Post by Ланцелот » Tue Feb 18, 2014 23:31
Probably not. Logan writes that the composition should be homogeneous, without inclusions of air bubbles, in them there are zones of tension.
Glue gun no? Thing like common.
Came up with the silicone. Almost like plastic, just soft.
And what wire Mobius? If as the first with the PVC insulation, then nothing. You need to isolate the Mobius wound from wire in lacquer shell. :)
ИгорьС
Post by ИгорьС » Sat Feb 22, 2014 19:49
I meant a wire of PEL or PEV. I.e. glue gun, then.
And another question a little not in a subject: about tubular orgone generator. I.e. the copper tube shakes the film, then foil, etc. now in the book Veltze both ends of the tube are open, and another source says that one need to solder. So how?
Ланцелот
Post by Ланцелот » Sat Feb 22, 2014 20:17
Veltze not read. Is there a link?
About the sealing of one end of the tube the first time I hear it.
Do as Logan in OPHI (OPGI). http://yadi.sk/d/_HBQnq_FJMXGE
Description in district 18 page
ИгорьС
Post by ИгорьС » Sat Feb 22, 2014 23:19
http://www.mindmachine.ru/radionics/magic-future.doc
this is the link to the book.
Logan now read. Thank you.
Read. It's not about that, though, what it seems.
In the book Welz page 11
Still here http://blacmagia.narod.ru/learn/kurs/st ... /thema02t/
about the orgone accumulator
николайй
Post by николайй » Mon Feb 24, 2014 15:03
on a flying platform.
schizoid is a username defrauded, he wrote on one of the forums: warning - Scam. he writes that he paid for all that he demanded from the platform. the result of illogical letters and excuses, but does not give money back.
николайй
Post by николайй » Mon Feb 24, 2014 21:55
go fishing I recklessly left for a long time his lonely car on the shore unattended. when I came back to four wheels was not. it's been a few days. my sister-in-law offered to read the prayer "for the return of stolen". initially, I myself have called her a fool, but then decided to record her prayer on voice recorder and to drive her to the field winding of the generator. of course I was aware that crooks will not come to me with wheels. a few days passed, I went to his garage and saw on the lawn of the post 4 studded tires. there were no porches and no garages. after standing for 15 minutes / suddenly comes the owner of the tires/ I brought it to your garage. what happened then defies logic. the next day I again went to his garage about the same time and almost in the same place again were 4 studded tires. the protector in both cases was great. just in case this time I stood at the wheel half an hour, but nobody came.
лексветер
Post by лексветер » Tue Feb 25, 2014 22:56
николайй wrote:go fishing I recklessly left for a long time his lonely car on the shore unattended. when I came back to four wheels was not. it's been a few days. my sister-in-law offered to read the prayer "for the return of stolen". initially, I myself have called her a fool, but then decided to record her prayer on voice recorder and to drive her to the field winding of the generator. of course I was aware that crooks will not come to me with wheels. a few days passed, I went to his garage and saw on the lawn of the post 4 studded tires. there were no porches and no garages. after standing for 15 minutes / suddenly comes the owner of the tires/ I brought it to your garage. what happened then defies logic. the next day I again went to his garage about the same time and almost in the same place again were 4 studded tires. the protector in both cases was great. just in case this time I stood at the wheel half an hour, but nobody came.
Nicholas excuse me, but you can find out when it was done the device ie the generator I realized spak, IT was done from the heart with soul, creatively or as on the Assembly line without any cost inner intentions, it is very interesting, if YOU this was done so to speak with the soul sincerely seriously the result is understandable and predictable but twice, this is one of those topics of loan repayment, with interest there certainly harder why twice :?
ИгорьС
Post by ИгорьС » Sun Mar 02, 2014 19:44
But no one tried, as hinted Michael, - granite aggregate as a filler orgonite?
And maybe the gypsum as a binder.
николайй
Post by николайй » Mon Mar 03, 2014 12:53
the device was made during the year, sometimes in the screwed state.
that happened twice-it is a fact that in Your comment.
ИгорьС
Post by ИгорьС » Wed Mar 05, 2014 9:15
It is interesting that the pendulum rotates counterclockwise as on the individual crystal and the 3-node is not very good Mobius and over the crystal placed in the middle of the "Bob" of magnets from speakers. In the latter case the palm is a very weak breeze.
АлексВлад
Post by АлексВлад » Sun Mar 23, 2014 23:46
Hello!
Sorry for the duplicate emails, but in another thread, apparently, living there ;)
Friends, please tell me or give a link where and how to learn to work with ORGANICA? Made 3 pies in plastic cups for the microwave to 0.5 liters. On quartz crystals, the longest about 5...7cm, wrapped Mobius wire PEV-0,15, 18 metres long, folded in four, twisted, folded four times more, tied up, turned out beautifully. Wrapped around the crystal, in parallel with the coil, at the bottom of the crystal glued a piece of three color led strips, got 6 LEDs and also led wires for an external controller. Thought possible to work quartz with frequency in parallel to enable working with color. It looks also beautiful, especially when the bottom quartz glued aluminum foil as a reflector. Sliced finely washcloths, because they are not cut badly compressed and trebuutsya and the fill factor of the glass obtained is low. Filled it with epoxy. Coil resistance 9 Ohms, a series resistor was not soldered. The first glass of almost boiling, saved a bucket of water, cooled. Everyone froze, from glasses to get and looks so good and more aesthetically pleasing. Included in a couple of weeks the player that recorded a whole bunch of frequencies for all and from all ;) someone here or elsewhere posted. Day passes - or anything! Nor any sensations. However, the fruit cake is on the table on the first floor, and sleeping on the third. Some days nothing, put on top of the cake the hair, or what, put the nails again, that does not feel, spit on him(literally - spat) , i.e., left biomass in the form of his own saliva - what did not hack and any where. Checked the signal in the coil - is. Connected parallel to the second Kulichik, player powerful, pulls without problems, but don't feel anything.
Please suggest how to determine if my appliances? I can send a photo somewhere of the devices.
Thank you!!!
