Седой wrote:Candle, fire, flame, prayers of the faithful over the hot candles. Here's the source orgone. All under 8 carbon pyramid, the Golden section. Directing the energy, the energy flows straight to God
Not so - ALL this gives the Chronal charge , or Bio energy .
Orgon you can get from the sun and from Outer space .
The people of Orgon is not isolated .
BUT there is a trick Orgon is isolated from the air , concentrate it and send the same pyramid . pyramid in General is a tricky thing .
She can work with orgonomy and chromonema , it all depends on WHAT it falls at this time .
Here is a clever twofold action items include the stones (crystals) , needles .
If you take a clean needle , they radiate the orgone charge .
If they slander or hold by the open fire - hramony .
The same with crystals .
Take the pure zircon from the store , not previously worn a man - has a charge of orgone .
Diarrhea is a ring or earrings has the chronal charge.
And of course - ORGANITY .
Themselves secrete and accumulate the orgone charge , BUT if you put them under the irradiation Chromonema , they with the same success will accumulate and then give - Chronal charge .
Tree . The same as organite .
The mirror and the lens themselves have a double meaning , only the mirror even when irradiated Chromonema , change the SIGN of hromonov .
Originally taken times hroney draw the indicator , it will be a plus
Orgon, pushes the indicator will be negative .
So , irradiating from the side mirror Chromonema , ie . plus , the mirror comes out a little which PUSHES the indicator , ie - minus .
I.e. it changes the sign .
BUT more interesting is , remaining after the exposure, the mirror emits, PLUS
This kind of shit .<
