I still do not understand, "So You want to go, or checkers"?
CD "Ultramesh"
East
Re: Disc "Ultramesh"
Rostislav
On the way out.
On the way out.
- Княжна Инстасса
- Has thanked: 1 time
- Been thanked: 9 times
How critical listening is not on the lowest volume?
I would actually love to, but the headphones (bought on the recommendation of Andrey Patrushev here), apparently, too good - the sound on the player at zero, but can hear perfectly well and quite loudly at that.
On the lowest volume to include just does not work.
Princess of Instance
At least it should be for You comfortable.
Tell me, and if do is mp3 to FLAC, it can be no real CD to listen to? but I have no CD player, only CDROM in the laptop
Kuzma
Only WAV.
Only WAV.
Максимус Алексович
- Has thanked: 7 times
Hello. Download "Ultramesh", copied the Navigator folder gate. If you use any questions. The LEDs flicker only in the second (permanently, as in the other sessions), fourth (at intervals of 5-10 seconds and the same twinkle not twinkle) and the first programs in the third program of light activity there. In the beginning I thought that the glasses weren't working, all tested, working. It may be the case in the files themselves, or is it OK, please clarify?
Maximus Alexovich
In Ultramote nowhere audiostrobe. There are a lot high, so glasses sometimes blink erratically.
Максимус Алексович
That is Ultramesh to listen to without glasses? And is it possible to combine (does it make sense) with sutorito? For example:
1st PR-mA + BM: CMP, MM: Attention, session: 2 or 7
2 teach read without Svetlitsa
3rd + BM: alpha-theta, MM: deconcentration or giprotrans, session: 1, 5, 7
Etc.
Etc.
Maximus Alexovich
Maybe first, it's manual say?
Just listening to him is useless (except the last track).
Максимус Алексович
Read the instructions. Use it. It is interesting to experiment.
I apologize for being too aggressive. Thank you.
Максимус Алексович
Hello! Please tell me if the program ultramega listen on a tablet asus nexus 7, don't will cut the effect?
Maximus Alexovich
No idea - I'm not an expert on tablets.
Good time of day.
Andreiplease 2 track, you can listen to from any point (if the training information for 20 -30 min)?
3 tracks to listen to immediately after training or later hours 3-4-5-6?
Aastha
Hello.
Hello.
There's, like, no cuts - whole 45 minutes (the optimal time for engagement).ЯестьЯ wrote:Andrew,please tell me, 2 track, you can listen to from any point (if the training information for 20 -30 min)?
Immediately after all this day of training, otherwise it can replace a normal night sleep.ЯестьЯ wrote:3 tracks you need to listen to immediately after training or later hours 3-4-5-6?
if training time is 20-30 minutes-Pererov - then 20-30 minutes =2 track, you can put it where it ended the first time or learning to put firstАндрей Патрушев wrote:There's, like, no cuts - whole 45 minutes (the optimal time for engagement).
Aasta wrote(a):
And, Yes, of course - it is uniform.ЯестьЯ wrote:if training time is 20-30 minutes-Pererov - then 20-30 minutes =2 track, you can put it where it ended the first time or learning to put first
Hello, Andrey!
Please tell me a 15 day break between listening. You can listen to the session with a mind machine or not?
Wademan
Can.
Can.
Wademan
Recall that Ultramask makes no sense just listen to (except the last track), respectively, and it makes no sense to take a break (except for the last track).
CD "Ultramesh"
Good night!
What if the moods Sytina to impose a "super training". Whether the effect is interesting.
But if one were to study combat under iskustva trek super training? But it's just a question.
If all this is not fatal, then I will try it. That is, try Sytin + super training.
