In order for something to be installed it is necessary to read carefully, choose only what You specifically need to save it in a separate file and then install.Анна_Н wrote:I have a few questions about the use. I can not understand the 3 files with the phrase-units, in what order to install themfirst phrase of the Sedona Method, or affirmatsii for Rainbow or just affirmations
The Program Of Andrey Patrushev Raduga
Идущая вперед
- Been thanked: 6 times
There is a medical fact YOU ANDREI PATRUSHEV on the website your yoga laid out prog - style rainbow -arc current there is a stick instead of colored stars ссылкаhttp://youryoga.org/med/affirmations.htm
so what you have there is a notable followers....
and stick raznocvetnye current in one direction fly.... but the principle taken your....
The essence they caught...Идущая вперед wrote:there is a medical fact YOU ANDREI PATRUSHEV on the website your yoga laid out prog - style rainbow -arc current there is a stick instead of colored stars ссылкаhttp://youryoga.org/med/affirmations.htm
It is necessary to look absently through the screen, completely indulging in this lesson.Anonymous wrote:I Have a few questions:do I need to pay attention to the session, or you can look at the monitor but at the same time distracted by thoughts, visualize?
Frequency have to do with anything? If you put more affirmatsii metabolized faster?
Frequency is optimal (6,6 Hz)
Идущая вперед
Combined there is a rainbow arc visually and in the headphones on the MM session from the training L forgot the name of 51 minutes to absorb affirmations in the next 12 minutes... need to work with memory...
actually happened a little over an hour...I really like the new built-in affirmations Cab with them and work mainly
Идущая вперед
drives Sviyash with affirmations built on the theta waves....
ie, the most active capture brain affirmations occurs when theta meditation... so include a rainbow and theta waves at the same time.... those who have researched alpha first, alpha should work on me... at first from the sausage theta specifically (any physical sensations unpleasant WASPS and negative in real life first)... wait OK
Is it possible to learn the Sedona method to use in the rainbow-the arc of such installations:
- I am well aware of your true feelings and emotions
- I am able to focus on their true feelings and emotions
I can surrender to his true feelings and emotions when necessary
- I accept your feelings and emotions for what they are
I atsihwiu your feelings and emotions to the roots when necessary
- I know how to release their feelings and emotions when necessary
or something like that, but I can't figure out what I really feel? And when you imagine/remember to any situation, at first, like something is there, but just trying to watch everything at once disappears and becomes totally unclear.
It is possible to try. But I'm not really concentrating - was caught and immediately released.Anonymous wrote:is it possible to learn the Sedona method to use in the rainbow-the arc of such installations:
Good evening!
Tell me, why does the "Rainbow" use of affirmatsii, not affirmations? it happens the phrase "I Butterscotch Why do I ..." It will not distort the meaning?
For me, in General, the concept of affirmatsii discovery was!!! Read Your article and realized why affirmations never worked with me, and only internal protest caused or some iskustvenii attitude. But affirmatsii is power! I just tried all of your questions that do not give to live in peace, to remake it in the positive, so I have already the mood has risen!!!
Only from a sense of frustration was internal, and then from somewhere in the head, the answers slowly began to come (respectively positive)
And is it possible to work first with the "Rainbow" and then right after that listen to "Conductor"?
1. You can, if you uncheck the prefix and names, it will only affirmatsii.Ириска wrote:Good evening!
For me, in General, the concept of affirmatsii discovery was!!! Read Your article and realized why affirmations never worked with me, and only internal protest caused or some iskustvenii attitude. But affirmatsii is power! I just tried all of your questions that do not give to live in peace, to remake it in the positive, so I have already the mood has risen!!!Only from a sense of frustration was internal, and then from somewhere in the head, the answers slowly began to come (respectively positive)
2. You can, but live-when then?:)
Devices and programs
Then help to formulate, really want to quit Smoking , perhaps you will have a lot of ideas on this subject . Thanks In Advance!!"Quit Smoking" is not a well-formulated result...
I can't find the strength to beat and break people. Type sorry... of course it sounds Stupid.
What afirmatsii and adformatie in yourself to stick to not receive the effect of a maniac killer.
Type "the type of training I'm always happy to turn partner's neck and stomp on the nose"
What image need to wet people to think, not to become embittered???
Евгений Кош
- Has thanked: 2 times
- Been thanked: 2 times
