Magic Attention
in China in the theater...staged a contest of actors.who will replay without falling into duality.these things aerobatics game)))))and in the bulk of its people perform the role of...which dictate cockroaches.artists little...and the audience is even less
Re: Magic Attention
which information is not carried and this topic....whether it's something useful...and its emotionally charged....this perturbation of the environment gives the opportunity to behold in itself.....(who to play)well and on a course to learn to play myself.watching playing.here attention will fit.
Re: Magic Attention
environmental disturbance allows...with attention ...to nablyusti a "the strings of the puppeteer"and she pick them.and not to play their games.and there is no difference...who describes this as...in the context of magic...psychology...or religion.or even what the current...trends or schools.all boils down to inspection and elaboration of the inner world of man...to whom he is not the master.the darkness there... with a complete lack of light consciousness...awareness.that, and it turns out that the world is moving..dancing psychokosmos person..and not Vice versa.
Re: Magic Attention
and the only suitable tool is the opposition to this outrage at first... it's the attention and the will.besides, the further into the woods.the more and Strength.and accordingly, more and attacks(disturbances of the environment) so his taste for lice and ustoichivosti.that and Force a lot of jelaousy away.piece still tasty))))by the way C. Castaneda last years of his life went into the service to the very evil and obnoxious people.but this path as a monk tied to the amputation of his will.the river of consciousness is cleaned from destructive elements... but at the same time it did not leak.for example, the plant develops mutates ...if it is subjected to different attacks lasusa.if all type-top...what a move.happy with everything.rather destructive Force....spur creative.evolutionary.)))and the man as the center...as mirgard as the center still Forces should not go on about it...or go for one of the Forces.and using both to vidiohot of this kórnik like a cork from a bottle of champagne
Re: Magic Attention
Destroyers, stimulating movement, not just enough, but they are about 80% of time awake ))) And endless patience has long been... So... nice thread just a pleasure to talk with nice people, so long... Without finishing to 100% )))
Re: Magic Attention
thought so for a long time. And then I realized a simple thing - no need to lift too heavy and to embrace the boundless. If you can communicate with those who understand and who understands. Let them from all over the world there are just a even a couple dozen... the Coincidence of harmonics increases, the wave, gives a stronger total harmonic. Dissonance puts out, spend, take. Here again can be seen "they say, a subjective issue, not giving all to be in harmony." But do not forget that the world is objective and with his free will in the form of many individual units. What I want, and I do, on all harmonics.
Re: Magic Attention
eternity had plenty of time.she is in no hurry.people will still be human.it's worth it.besides, I do not call to change the world to fit their concepts.and is internal.....subjective world is nepomnyu and incomprehensible?
Re: Magic Attention
If to describe more or less clear in the electromagnetic analogy, that is, the waveform is sinusoidal. It is a flattened circle, the perfect form, the two-dimensional sphere, extended in time, the Wave maximum softness. This is what is called "high vibration", confusing the wave form and frequency (any frequency is harmonic if it is sinusoidal, it is especially nice when a sine wave of high frequency sounds at the same time with the sine wave of low frequency, giving a kind of orchestra). Is the waveform a sawtooth, serrated, these teeth scratch and tear, regardless of the subjective (call it "low vibration", again confusing the wave form and frequency).
What form to generate every man chooses is his personal right and freedom of choice and ability. Trying to change someone else's form of the signal is violence, trampling on the will. But its will is as is and it is free to choose any options. If the other generator produces a "saw," and you were a sine wave then there's no need to interact with "saw", because sine waves abound, and eternity is infinite and contains many options.
Re: Magic Attention
Take two of the wave generator. On one we put a sine wave on the second saw. Serve their total output on the oscilloscope and see total chaos.
Now on the ground, put a sine wave on the second sine wave in antiphase. Served on the oscilloscope the amount of - we get zero.
Now on the ground, put a sine wave, the second a sine wave in phase. Served on the oscilloscope the amount of - we get double the gain.
It's physics, subjective nothing to do with it. If you mean that you have to adjust your generator under each - the first, it is impossible to do quickly (by changing the frequency and form required for a few years and you quickly only to adjust the phase), and secondly why degrade the signal...
It is possible that the amplitude of your sine wave, and the amplitude of the saw is small - then the modulated signal will be almost a sinusoid with small teeth on top... It's a wave carries the wave. It's possible, but it needs a large amplitude.
Re: Magic Attention
It contains the man and expresses. He can't Express what it is not. Can't write that he does not. Can't say about what is not inside. Therefore, the fact that man contains something and radiates, it carries.
Re: Magic Attention
I want to propose to speak for themselves and about themselves...as part of this space.. and not to borrow a whole hour menyusui observations of various observers in the sinusoids.many plants and animals are also very privlekatelnee....externally.but basically have a stinger.we can circle more informative to watch...rather than rely on surveying the curious state. account.
Re: Magic Attention
not a high vibration, and high-quality form. Quality. Frequency does not matter here, can be low frequency quality and can be high. And they are together, if in phase, can give very beautiful and qualitative picture. When such frequencies are not two, but thousands, and all in phase... normal (on free will), the rest is deviation, a grotesque mockery and broken heterodynes.the fact that you are nice to communicate with nice people.alleged sluzewski high vibration.
To communicate with a broken radio, which seeks to pereorat the music of Mozart... Why?
Re: Magic Attention
a person can check for lice...or how good it is.by placing in a certain environment.and immediately all the lasciviousness of the beautiful slogans and trample.you should look for these rooting. and snatch..anyhow there won't be anything hooked for further manipulation by the emotional world of the person.the world of subjects.
Re: Magic Attention
subjective...objectively it's just a symbol of the two halves of the whole.they flow from one to the other and back.subjectivly the world of objective forms.and that, in turn, amends subjective.
Re: Magic Attention
No matter how much change the subjective world and the objective will not be able to change that in the world there's no war or that all began to March in formation and so on... It is very heavy and vast. Trying to lift, reach and subjugate the world - and you can straining... He's bigger and includes the human, not Vice versa.
Re: Magic Attention
so I love it!99% patience ))))вотан wrote:subjective objective...it's just the symbol of two halves of a whole.they flow from one to the other and back.subjectivly the world of objective forms.and that, in turn, amends subjective.
the aerobatics!
cool visual aid Wotan
Re: Magic Attention
You think perhaps, that we are here with vatanam (Odin) grappled as he is here for you and all that... It's just a game, and with it we drank beer more than once, and he understands what I write, moreover, knows it all by myself ))
It is for you personally - that "behind the scenes". You are now playing back the program to "stray into the flock to find friends together and overwhelm the enemy in a fit of revenge." Boring... Seen this program a hundred times, at this stage, it's definitely time to wrap up, not let go... Sorry, topic not all potential exhausted.
