IMHO . I think if it is like yours or like yours, when the rings are horizontal. I wrote that ring like a trumpet. the direction of her energy goes into both sides of the ring , as it is not put vertically or horizontally. And then imagine the picture. Your all ring horizontally so? so see the direction of energy from them, it turns out that each ring directs the flow to another and back and forth. And there is already a thread and it turns to the right and to the left , reverse the vortex. seed-kuvak his direction. But you still have the lower trim for kuvake, and harmonizer in General, no horizontal end of at the office all harmonizer. This dual parallel thread with a different spin. Don't you think? And those kalayder double with two contra flows.Код wrote:it Turns out that the lower edge of the Harmonizer pulls/cleans the space from the lower edge of itself, its Foundation, not shutiva that below. And I thought that Harmonizer captures all space, regardless of its location.
Now Humpty , there are rings in different directions , flows also , and there is horizontal banding , frame for all the threads, kuvak it sews on the measure and these are also one of the options. which works everywhere and on the floor and on ie on the ceiling. )))but he has no common framing of the entire harmonizer in General, and the flows are sent to the ring.
