Experimental product Svetlitsa - the Constructor Body.
Re: Experimental product Svetlitsa - the Constructor Body.
Post by ЛИЛИЯ-Р » Thu Jun 18, 2015 19:28
passing Svetlitsa Constructor bodies are not a panacea and is not pill. The body is constructed by consciousness , consciousness is to understand how to construct the body on their own. The consciousness of many as a computer hard disk-all yuzali and advertising" tasty" products and programs on correct nutrition and what is there not inherent in the consciousness. To achieve the desired result, it takes time for awareness . While this consciousness through a Chamber CT ,as the disk of the computer will clean out all the viruses , installation of unnecessary programs on the "right" food, in blocks of childhood established by parents like that who eats well , and that works well. etc.
The restructuring of consciousness some occur quickly, it all depends on the" stuffing" of each , and some more time spent on it to rebuild the consciousness that will start to hear your body, and give him what he really need. But this may need effort, time and most importantly the desire to change something in his life , in the body ......For this Svetlitsa CT and created , it doesn't force you not to eat, it helps the mind to hear your body. To understand whether Fizicheskaya problem in the body associated with weight or is it psihosomaticheskoy?
In some diseases, increases weight , so before you complain about the Room , again it is better to consult a specialist there may be a disease(physical or psi...)
But in any case, the restructuring of consciousness will help you to understand your body and its needs. And weight if it's (remove,add) or lifestyle change ...everyone has their own way.
Try to simulate ..and listen to your body.
Акела
Post by Акела » Thu Jun 18, 2015 21:52
Interestingly, the same parlor CT 108-I series went?
ММ
Post by ММ » Thu Jun 18, 2015 22:05
The way you write here about some pathetic 3880 rubles. How about 100,000 rubles, or about $ 3,000 which I laid out for 4 AMB and after 16 months nothing have? But in advertising it has been said that AMB supposedly work online. Type only covet and one day will receive.Shish is getting! :(
мимоходом
Post by мимоходом » Thu Jun 18, 2015 22:08
MM I understand you very well. 100 thousand is not the limit, there are goods and over 700 thousand
Post by ЛИЛИЯ-Р » Fri Jun 19, 2015 16:17
Акела wrote:I Wonder Svetlitsa CT the same 108-I series went?
Yet CT 108's. :?
Новенький
Post by Новенький » Fri Jun 19, 2015 20:20
ММ wrote:how about 100,000 rubles, or about $ 3,000 which I laid out for 4 AMB and after 16 months nothing have?
Good investment!!! :ay Try it in a Chamber to invest...))) in a year or three, I will describe the results....
ММ
Post by ММ » Sat Jun 20, 2015 1:32
But the parlor the situation is somewhat different. Apparently they are stronger. There is already a good response from SB 108. I will unsubscribe in a couple months. Do watch.
мимоходом
Post by мимоходом » Sun Jul 19, 2015 22:39
Gave birth to several ideas for the development of new versions of the Constructor Body:
- increase bust by two sizes (will take both women and men, the latter not only heterosexual orientation to their friends, but you can negotiate with Thailand to establish there sales for transvestites)
- change the color of hair and eyes
- sex change
- plastic non-surgical resorption moles, spots, warts, scars
- growing a lost limb (the disabled - a large social group)
- transformation of the body in preparation for ascension
Астероид
Post by Астероид » Mon Jul 20, 2015 2:06
Rejuvenation.
Muscles for men
Why breast size by 2? Need more. 5 - the most it.
Laughter.
For example increasing the level of hemoglobin in the blood.
A stronger heart.
Strong lungs.
And a special program with which you design your body.
Post by АндрейКо » Mon Jul 20, 2015 2:18
мимоходом wrote:plastic surgery resorption moles, spots, warts, scars
About papillomas have already been cases that really took place (SS).
Иван Славов
Post by Иван Славов » Mon Jul 20, 2015 20:38
Астероид wrote:..level of hemoglobin in the blood.
And You probably didn't listen my opinion about Svetlichnaya products.. Well, I do not understand.. :?
Астероид wrote:Rejuvenation.
Muscles for men
you can see my photo before my use of Svetlichny products /joy, СС108, СБ108/, BRM-s and test nookular SAM-Korsar /I then used the nickname bofara/ now /Achim/.. :) About the muscle /I have intentionally wanted to lose additional muscle - it's not good for the energy flow/ - I hope it will be already too much, so I took on some short clothes or no.. :) I hardly do.. :)
ЕваРу
ASD
Post by ЕваРу » Tue Dec 15, 2015 10:38
Good day, dear ASD!
I have a question...if you lost the bracelet, it is possible to use the second overlay as a bracelet? well, for example, to get out of there element and fasten to some bracelet? whether the same effect? or is it only designed for water? Sorry if duplicate question :oops:
Ростислав
Post by Ростислав » Tue Dec 15, 2015 10:47
you can structure the same
АСД
Post by АСД » Wed Dec 16, 2015 0:04
ЕваРу wrote:I Have a question...if you lost the bracelet, it is possible to use the second overlay as a bracelet? well, for example, to get out of there element and fasten to some bracelet? whether the same effect?
Ростислав wrote:can structure the same
Indeed, the structure on the bracelet and the second element are the same.
ЕваРу
Post by ЕваРу » Sun Dec 20, 2015 12:35
Thank you for the feedback =) :o
Гуфест
Post by Гуфест » Fri Dec 15, 2017 21:20
Today I stepped on the scale +3.8 kg!!!! UZHOS! Did not expect, I thought well, at least at the same level will be. And like eat little, mostly vegetables were taken, although the pastries... and grill.... and seafood.... m-m-m.... But, surprisingly for myself, the rest was in several in sport mode in the morning and water aerobics in the evening - belly dancing, in between gymnastics, etc.
Exclude from the diet of sunflower oil, pork fat,chicken,sausage.It is recommended to eat mutton ,beef and their fat.It is impossible to lose weight dramatically,with a sharp weight loss occurs caused by toxins which the body has no time to withdraw,during the year, 2-3 kg weight loss ,a normal result without any damage to the body,eliminate the above and to gain weight don't Wake provided that other products will not get palm oil.And ask always prescription supply Khudyakov,not wild boars are thin,lean'd know better than to be slim.
Post by ЛИЛИЯ-Р » Mon Dec 18, 2017 14:14
Гуфест wrote:ask always prescription supply Khudyakov,not wild boars are thin,lean'd know better than to be slim.
Do not confuse the design of the body(generateresponse) slim and lean from Woe from wit)) . From thin - eat all you want , when you want . The only time when you can add 10 kg is lying position and trichrome food with tea ))). Restriction of movements. In the normal transition to your diet when you want and how much ...all vertan ago))
Because lean are different. If there is ( and often overeat people ) 3 times a day as prescribed by science type))), three times Yes, three times first and other....it does not have time to shred the organism that is eaten during the day. the remains of the warehouse. Always a bit malnourished, there is always one thing and not mixed with vinaigrette)) . The salad vegetables. But if it's not a hard stomach and a lot of different enzymes need for processing of...
Because neither thin nor thick each other do not understand.
Malvina
Сотрудник mindmachine.ru
Post by Malvina » Mon Dec 18, 2017 14:25
And, in my opinion, on the contrary, to ask the thin useless. They're thin, often eat everything and not worried. So their advice to full-bodied worthless. Organisms somehow work differently.
Цигун
Post by Цигун » Mon Dec 18, 2017 20:03
Heh. 2-3 kg I can during the week to go here, it's about nothing at all, for some people, and 10 of anything. Lamb and beef is the meat yanskoe for girls will not really a diet, like meat in principle, but if the street minus 20 is not an option without it, but it is important to see that this is not a tortured animal, and from clear sources. And the Council on the exclusion of fats is not ice. Sugar should be excluded, and it is very difficult, because it is in all prepared foods and cook everything inside and to himself. And if for good to understand that there is a certain genotype in humans, karma if you want, he seems to have little training, and the body still lays in reserve. And if it is an option and starts quick weight loss, then there is some kind of injury or situation something unpleasant, which returns him back his pounds.
Гуфест
Post by Гуфест » Mon Dec 18, 2017 23:23
The food is not safe as cancelled GOSTs and standards,it means that the manufacturer can produce anything not caring about the health of the consumer and for him it will be nothing.
I got the idea that the basis of the product needs to be a mechanism for encouraging and giving priority to the preferences of some products to replace other products,the reduction of consumption in most cases does not work.
In General, you can write a lot about food,this is a huge topic,as well as about each individual product,starting to collect information on the subject than harmful product,such as sunflower oil,the sunflower seeds are safe for health,the technology of production of sunflower oil,makes the product harmful to health,the seeds are pressed,and in order to extract the oil,dissolve the crushed mass with an oil solvent,obtained after the liquid is evaporated,oil remains which already contains the atoms and chemicals oil in a concentrated form in the oil.
Гуфест
Post by Гуфест » Mon Dec 18, 2017 23:40
When we talk about weight involves a natural weight,tissues,muscles,fat layer.A lot of fluid intake,water,food, waste products will not take into account.
Гуфест
Post by Гуфест » Mon Dec 18, 2017 23:54
Yes, and Council for exception fat this not ice. Sugar should be excluded, and it is very difficult, because it is in all prepared foods and cook everything inside and to himself.
To unsubscribe from fat is very difficult,more difficult than from sugars,such as sugar,you can replace the consumption of sweet fruit,there are some kinds of fruit,where the sweetness as granulated sugar,such as apples,he jumped off the sugar consumption,to buy food, the most,most sweet fruit.
To abandon the oils and fats will be more difficult as many of the dishes will be impossible,such as salads,fried,baked,I'll have to think on the subject,but what is?
Цигун
Post by Цигун » Tue Dec 19, 2017 10:07
Гуфест wrote: When we talk about weight involves a natural weight,tissues,muscles,fat layer.A lot of fluid intake,water,food, waste products will not take into account.
I have not seen people talking about themselves in the plural. Well, okay. I see you have a little knowledge of the subject, this will have to explain a bit. One famous singer with a lot of extra pounds, she's a vegetarian and lose for her performance in my to 10 of these pounds. I am sure everyone understands that this is not waste products otherwise who would go to these concerts. Why?... The Mat looks like the following: there are 3 types of build. Ectomorph to discuss in this topic does not make sense, they usually want to get better, and so is a Mesomorph and Endomorph. They tend to be overweight. The difference between these constitutions is not so much external signs, but in the ability of organisms to process, conserve and expend energy. If Mesomorph not enough strict diet and a couple of hourly visits to the gym a week to look like Apollo, it Endomorph must comply with strict rules only diet and do not get out of the gym in General. Mesomorph training ends after 40 minutes and he runs a tired in the bath, and Endomorph in an hour understands that everything is just beginning, he can go to the third hour if in advance to prepare yourself a quick protein and carbohydrate shakes. From all this it becomes clear that Endomorph has "some" plug-in energy reserves, his body stores and consumes energy differently, not so in others. To adopt diet Ectomorph just silly, because there are usually no, if a Mesomorph leads an active lifestyle, also scored on the diet. All fat people usually Endomorphy usually weight away from them with difficulty, and easy returns, because the way his body is, he needs the reserves to a long and productive work. Can cite a good example blogger Dennis Seminihina, there is just Endomorph that looks like it should, but it takes all his time and meet strict diet.<
Цигун
Post by Цигун » Tue Dec 19, 2017 10:22
1. I don't even know how you can give up sugar and/or starch (starch is similar), if it is in all the products in the store. All baked, all fat-free milk (and regular too), and cheese, all banks, flasks, sauces, ketchups, pickles, marinades, juices not to mention processed foods and cooking with alcohol.
2. There is no need to abandon useful vegetable fats. All this can be advised? Fats just necessary for the proper functioning of the body, and vegetable fats also contain the essential acids, they are synthesized. If we talk about the exclusion of such products, it is necessary to replace them by others - salmon, flax seeds. Sewed on soap it turns out.
3. If the temperature is below zero, it is necessary continuously to hammer on diet. Can't the North people like the Japanese eat hundred calories a day, it will freeze and die.
