Planned changes in the commodity row of the entire line BJ-SK, etc.
Re: proposed changes in trademark row the entire line BJ-SK
Post by Михаил_ » Thu May 23, 2013 13:57
cheated - probably early next :) - the manufacturing process is very slow.
later today will publish a number of features.
Post by Михаил_ » Thu May 23, 2013 19:56
Кулон ОЗ, версия 3
OZ, version 3, the execution of the pendant.
features:
- a vivid manifestation of forced "vpihivaniya" 3.0, 3.1 characteristic, but based on the state of OZ instead of 3.0-side view.
- the adaptation for work with PC and PC-device (This product is a rare exception, in contrast to the 3.0 can't be sewn into the dialer effectively, i.e. made to be, but because it is the setting for this world, it is less effective than many other products, the effectiveness of which when used via PC can even grow).
- working with a PC and a pendant OZ You can choose the focus within the buffer zone, will that work with the aspect of your sides of the buffer zone (personal world) or OZ (from this world), but it persists even when the focus on OZ as the "softness" of the world in the work area of the operator. Thus the operator receives the effect of increased adaptability-softness of the world under the impact, although it involves the actual exit of the buffer zone in the mode of the presence of the Creator here and now (in this world).
- actively integrates with any pendant panacea, as one of the best combinations to work with.
- can be used with any version of 3.0 with or without (no 3.0 status will still be obtained, although the load on the pendant will increase)
- actively integrates with AMB, causing the manifestation of some forgotten skills.
- has a training mode (the gradual integration of skills in a series of Vх)
- has the unit "the local anomaly of the Treaty", which allows to significantly expand the influence of the operator and its area of responsibility without the passive resistance of others (sleeping, mostly) of consciousness is communication and the lack of desire of direct control, the delegation of the right to change locally the picture of the world for the masses of people, up to the physical effects.
- actively integrates with АТ5 (as well as at the base, but with АТ5 more interesting), in the sense of translation of the active interactions with the world in the aspect of working with electronics, eliminate conflicts, and are not useful anomalies in this area, and so on.
the cost of 60t.R, welcome pre-order (determines the correct amount the first party), receipt in the office will literally piece-by-piece (long production time of each instance).<
Валор
Post by Валор » Fri May 24, 2013 8:57
A pre-order in this place can do? If there is, then I pre-order))
Ольга К
Сотрудник mindmachine.ru
Been thanked: 17 times
Post by Ольга К » Fri May 24, 2013 18:01
Валор wrote:a pre-order in this place can do? If there is, then I pre-order))
It is desirable to execute the order to our mail and contacts mindmachine@bk.ru
Post by Михаил_ » Sun May 26, 2013 18:00
Михаил_ wrote:1. glasses of glass (not plastic). The plastic charge is not so harmonious (due to the structure of the material, plastic is more bulky molecules than the glass). "your" you can charge any, but glass will work a little better.
2. the basic properties of a - "another look at the world", "look into yourself", "looking at processes" and the intensification of the upper energy centers. Side properties - in fact, it is the Subversion of AMB :) only slightly sharpened by other functions, basic it was still there, but more extended on top and look brighter.
different aspect, like the perception of subtle energetic information took place for example, or "thin places" where through the fabric of reality emerges something else are also included.
The ability to influence the process through the channel of view (in fact the aspect Agni), i.e. more treble anchor point AMB.
Given the fact that AMB we do not sell to (what is specified in a branch about them - essence is a temporary phenomenon)., this is the only way to say the way... although of course works slightly differently (one bracelets, and glasses - other).
Generally it is a "glitch", trim events. In the sense that I almost bumped up a pilot version of the show and give the Lilies... and also accidentally went agreed to make them still for sale. Initially, all planirovalos otherwise.
in this regard, I do not take on commitments that this action (their presence in the sale and the ability to "charge" your own) will be constant and the more long - term.
But while will. Indefinitely (depends on a million factors). It is highly likely and long-term, but I can't guarantee this.
sent me there is an interesting opinion - say in humans, glaucoma in one eye largely retreated after a month of continuous wear data points. I don't know how is because the direct causes of the theory seems to be not quite there, but apparently something to do :) that does not mean that same someone... but fun.<
Багвати
Post by Багвати » Tue May 28, 2013 22:50
Use points from the second day, as they appeared in the office. First wore them periodically, then, when out on the street, and are now them almost constantly! if not started whining, the nose would probably not removed. :) for not responded until now, what has changed and what is going on :? feel in the other) I have very good and comfortable! funny: it's like eyelashes grew a lot and bent, and lower, too)) and: in them( glasses) feel very relaxed, light, soft ( meaning motion). in General I like them much, and cannot explain in detail :roll: :wink:
Post by Михаил_ » Tue May 28, 2013 22:55
I mean the nose - you can try to choose for themselves individually the frame-shape-weight-size etc.
These average frames - normal, but of course not all can be perfect. Something easy for example to find.
Unfortunately, it turned out that the General problem is to find glasses with no lenses and with glass.
Can also be plastic, and plastic is different in materilu.
You can also process and bag diptheriae (one required)
Ie is under the charge then.
Олег27
Post by Олег27 » Wed May 29, 2013 1:07
Yes, glasses do an interesting thing.
Tried several times, at the stations, where there are turnstiles and all passengers with bags be sure to inspect, goggles, and the inspection is cancelled, and instead, almost "came to us, came to us ... dear." Interesting.
Have noticed, if you walk long glasses that people are beginning either to stumble, as if before them the invisible man, or Vice versa jump to the side a mile away.
For long meetings, simpoziuma and so on. threw glasses and sleep (or solve their issues), the people itself, and You're on your own, anyone until You do not care, rest, glasses remove, say their "good" word, the meeting is over. That's how it is.
Post by Михаил_ » Wed May 29, 2013 5:17
yeah, it is very likely points would be interesting to add insoles with similar properties, that is to say for the symmetry (the channels of the legs are connected to ground and typically do not work well due to the use of shoes and asphalt-floor buildings instead of raw earth).
Олег27
Post by Олег27 » Wed May 29, 2013 11:20
Михаил_ wrote:it is very likely points would be interesting to add insoles with similar properties, that is to say for the symmetry (the channels of the legs are connected to ground and typically do not work well due to the use of shoes and asphalt-floor buildings instead of raw earth).
Great idea, thought about it. The subjective feeling that something has to be balance, but about the insole not know if such an opportunity appeared that would be awesome :ay
Багвати
Post by Багвати » Wed May 29, 2013 11:57
And I for insoles!!!!! bi
Владимир Ш.
Has thanked: 19 times
Been thanked: 34 times
Post by Владимир Ш. » Wed May 29, 2013 12:00
Michael_, a "charge" on the glass "open-ended", as all of Your products, or you accidentally erase? To use, like a napkin, not the one in the kit? Or dirt got the alcohol wipe? Properties will remain?
Post by Михаил_ » Wed May 29, 2013 12:22
Владимир Ш. wrote:Michael_ and "charge" on the glass "open-ended", as all of Your products, or you accidentally erase? To use, like a napkin, not the one in the kit? Or dirt got the alcohol wipe? Properties will remain?
of course the charge does not damaged, neither by chance, nor especially not to erase, except that, as always, is 3.0, and not really sure how damaged and damaged if (PC based).
Владимир Ш.
Post by Владимир Ш. » Wed May 29, 2013 12:26
Great! Thank you!
Post by Михаил_ » Wed May 29, 2013 12:28
Багвати wrote:And I for insoles!!!!! bi
Yes this is all very nice, but... not to mention the fact that I was so tired to multiply entities :)
in short, this is an option under the scheme charge of the product user (cost as for the points, the program special, insoles), i.e. the sole of his size and suitable type buy. Sizes-shapes and other parameters too much will to keep a stock of charged insoles, moreover, the demand for this type of piece more than a serial, it is still not 2.0 is 2.1 something.
And the charging procedure is still too slow to charge the car, all processed piece almost.
i.e. the scheme is the same as zardai their points to transfer to the office, to wait ready to pick up.
Tomorrow will be available (I went on to do such insoles :) )
I have, incidentally, one sport Shoe insoles which fifty stickers panacea from the bottom (well I have them too lightly programmed) - also a very funny thing. But it would be better.
Багвати
Post by Багвати » Wed May 29, 2013 12:45
Yay! Yay! Hurray!! Taking the insoles in the office tomorrow!!! :ay about glasses with no lenses and light socket are still in search... But I made and "remembered" :wink: what I have :) Michael, again thanks for the speed of responses to requests :o
Post by Михаил_ » Wed May 29, 2013 12:50
yeah... the speed... I'm OZ can't finish (in fact a ready product)since last Thursday, stalled simply childish out of the blue. On the one hand a good sign that there will be moshnenko. On the other hand I got tired of it and including how it fonit personally at me (pretend that you are sick, the echoes of the seminar and the trip is still slightly going have to try to stay home and reconstruct some problems in the body).
So speed is not everywhere and not always.
With insoles that's easier....
PS pendants OZ has not yet arrived to the office the next few days....
Багвати
Post by Багвати » Wed May 29, 2013 13:04
Michael! :? :o :)
Post by Михаил_ » Thu Jun 06, 2013 20:52
The first pendants of OZ tomorrow should arrive in the office to hang on the final stage of processing.... Hard was :) very.
Attention to those who are going to the workshop PC and going to buy the pendants in the mail and not by self. You may want to pick them up at the seminar by paying in advance. In order not to have reached the situation that they are going, and do not have time (knowing how the mail of the Russian Federation).
They came, however, just pretty.
Later will be photos and 3D render(its better you can see).
Along the way they added some f-tsii from the personal security of the operator. It is to carried away in one direction not to get in the right story in the other. Address issues of protection (including reflex) and rapid regeneration (including after the energy overload).
Moreover, these f-tsii is not tied to the here and now.
Post by Михаил_ » Thu Jun 06, 2013 20:57
I temporarily removed from production all kinds of amplifiers. There will be changes in their lineup.
For sale is two pieces U1 (one is in the office MM, the other in St. Petersburg, in the store of artifacts, but may be withdrawn either in their shop in the MSC or to the office of the MM).
About the appearance of modified versions of the alert separately.
Багвати
Post by Багвати » Thu Jun 06, 2013 21:28
Writing, for all to see!) 1 from the office in Moscow, buy!) just ordered)
Has thanked: 24 times
Been thanked: 142 times
Post by Маг.нет » Thu Jun 06, 2013 21:30
:) it is high time, it is a wonderful THING!
Sincerely, MAG.no 〠
Has thanked: 478 times
Been thanked: 264 times
Post by ЛИЛИЯ-Р » Thu Jun 06, 2013 21:39
So I have bracelets on legs, also an option.Now I just wear under pants. Summer however. Well, it is insoles no.)))
Post by Михаил_ » Thu Jun 06, 2013 22:10
from anklets and insoles the effect is different.
Post by ЛИЛИЯ-Р » Thu Jun 06, 2013 22:11
Well, it is no insoles. And so I have instead of the insoles of the card, the Panacea for youth))))
