Orgone generator with their hands (SP). The FLAME
Has thanked: 125 times
Been thanked: 263 times
Post by Шалтай Балтай » Tue Aug 10, 2010 11:23
Anybody know restauratori?
Who is well versed in paints, adhesives, enamels
as Morgana, gummiarabik, Shallaki.... and so on.
I'm willing to pay for the consultation - by the hour.
PS
Please - do not say that you can search in the net
Post by Guest » Tue Aug 10, 2010 21:04
Post by Шалтай Балтай » Wed Aug 11, 2010 11:28
IMHO, this is off.
honestly - I did not read, of course.... :?
the Wasps easier to train.... IMHO.
the fact that SP can help - who can argue
but to guarantee, at unlikely. :)
Экко
Has thanked: 2 times
Been thanked: 4 times
Post by Экко » Thu Aug 12, 2010 13:45
it is not clear how can such a weak electromagnetic field from the coil with a small number of turns, and even powered by low voltage in addition through a resistor to give the effect?
Post by Шалтай Балтай » Thu Aug 12, 2010 13:55
yeah....
I have found a 12-watt amp.... and also .... think about it 8)
Экко
Post by Экко » Thu Aug 12, 2010 16:31
Humpty Baltay
just wrap the coil pair. 8 Ohms and a cross section of 0.2 mm otherwise effort will burn and/or the effect will not be
MM
Post by MM » Mon Aug 16, 2010 1:09
I read on the Internet a lot of interesting information about carnelian. In ancient times it was valued above gold. Helps a person to attract the right events, but it does so slowly. Absolutely not an expensive stone. The question for Humpty. How about to add a few cornelian in SP?
Unfortunately I have no way to cook SP. If you do, pliz, write a review. :aa
Зохраб.
Post by Зохраб. » Mon Aug 16, 2010 14:34
Zdrastvui.
Please answer this really works
homemade orgone generator,itself checked and what
results.
My email daqaz@yandex.ru
Thank you
ММ
Post by ММ » Mon Aug 16, 2010 17:50
Zohrab, that you turn to me?
Зохраб.
Post by Зохраб. » Tue Aug 17, 2010 9:35
Hello.
I to all forum users are treated.
Has anyone tried themselves datvie Radionics.
Respond of pojalusta I'm a beginner,it will make for
yourself.
Thank you all for this site.
Зохраб
Post by Зохраб » Tue Aug 17, 2010 9:38
Good site but only in English.
http://www.mysticalwonders.org/
Post by Шалтай Балтай » Tue Aug 17, 2010 10:39
MM wrote:How about to add a few cornelian in SP?
Yes, anything you can add :-)
Carnelian keeps fear and anger away and keeps the unit clear
You can put the crystal on top of SP, or the same orgone generator.
Of course it will work.
голован
Post by голован » Sat Aug 21, 2010 13:13
The French use caramel instead of epoxy.
МерКаБа
Has thanked: 7 times
Been thanked: 25 times
Post by МерКаБа » Sat Aug 21, 2010 13:46
Well done girls :) All-female approach. :)
Свами Доупаду
Post by Свами Доупаду » Mon Aug 23, 2010 21:06
Маг.нет wrote:Tourmaline, green this stone, we have in Buryatia is extracted, the Chinese are very much appreciated. Know a property treatment - when heated (light) emits vibration warms the body deep (9 mm upper layers of the skin). Used in "the massage beds and chairs" as made "healing mats" made of stones of tourmaline. Tried - useful (compare with "Mat Grace" the FACE, of course the other principles, the results seemed similar).
Currently (from China) imported a lot of "fakes" of Tourmaline, made of shredded waste processing of natural Tourmaline associated polymer mass - it does not have Tourmaline (part of the properties of course could be preserved, but the structure is broken). To distinguish "fake" from natural often "by eye", in pattern of the veins of the stone.
Sincerely, MAG.no
Thank you for the interesting information. az
Смелый
Been thanked: 79 times
Post by Смелый » Wed Sep 01, 2010 11:38
Here is the website of the Moscow school "light bearer": http://putsveta.ru/goods.php?cat_id=3
Карапуз
Post by Карапуз » Thu Sep 02, 2010 21:26
Guys, no one wants to try to twist using orgone generator drives Arcana? If the course is not afraid of the "magic kick" :)
've found one in Runet http://depositfiles.com/files/ndl13hb3c
However, there is some ambiguous information about their effects on humans
http://esoteric4u.com/ru/index.php?opti ... itstart=40
And the first 2 tracks better to remove, if affirmations through the generator work well...and then...))
What Michael thinks about the use of these discs with the generator?
Эдэм
Post by Эдэм » Tue Sep 07, 2010 2:38
You can listen , and here to copy... you can ,but only to those who wants their skin to feel the magic.
Карапуз
Post by Карапуз » Tue Sep 07, 2010 9:23
Or the power of "suggestion" :wiz .
Эдэм
Post by Эдэм » Tue Sep 07, 2010 16:28
Well,try it ,because this is only a warning. I hope the participants of this forum of suggestion do not work. Everything and everyone here is experiencing. So dear Baby GO!
+ангел
Post by +ангел » Sat Sep 11, 2010 15:16
how to make Orgone accumulator who will be able to translate into Russian?
thank you
http://web.archive.org/web/200605251013 ... ulator.htm
Has thanked: 31 times
Been thanked: 129 times
Post by к-13 » Sat Sep 11, 2010 17:21
And what is to translate? There's also an analogue of the first chamber of the Reich, surely someone with her going to the Chukchi to go, so in modern conditions to collect a bunch of "dead" orgone? Reich was talking about lethal doses. Cake(even passive) has the same effect, but in addition of negative and positive orgone else does. It's kind of like the model of modernization was the box, was the Bank...
Карапуз
Post by Карапуз » Sat Sep 11, 2010 19:19
Continuing the theme of audio - 12th lasso.
http://depositfiles.com/files/hyf8tv6fi
Guys, can someone help Ukraine with crystals? I will be grateful!
МерКаБа
Post by МерКаБа » Sat Sep 11, 2010 19:43
Tot
Refer to Logic, or wait for the exhibition the World of gems, it's all over the CIS rolls around. In October we in Belarus should be.
+ангел
Post by +ангел » Fri Sep 24, 2010 13:51
Humpty Baltay hi and give the link us where the gold leaf bought
you have such a release form? http://woodperfect.ru/internetmagazin_d ... _id=453246
to make Gold inside cannot be :shock:
it is also well accumulates in the tissues of the body and withdraw it very difficult
in Ayurveda preparations of gold but there is a small excess concentration they are seeking numerous perejivaniyami gold with cow manure
all of his impurities go into the ashes but this art on land owned by just a few people
the pharmaceutical industry produces drugs long gold and even they can be serious side effects
here for example are http://www.ill.ru/drugs/drug1584.shtml
http://dic.academic.ru/dic.nsf/meditem/182
