CD "healing: the magic river"
Post by Андрей Патрушев » Sun Jan 04, 2009 18:53
Ангелина wrote:And tell patients with epilepsy you can listen to this disc?
One of my colleagues in Ukraine uses a similar (not mine) disks for the treatment of epilepsy (significantly reduced the number of attacks and Dlinnaya gap between them).
I think that definitely anything to say. Everyone should responsibly take on the decision. My CDs are not intended to cure anything...
Ростислав
Has thanked: 35 times
Been thanked: 28 times
Post by Ростислав » Sun Jan 04, 2009 18:58
I also want to add that the cicadas are heard only good headphones with a large frequency range (I have 4до22кгц) and photosonics that came with innerpulse cicadas almost unheard of! So grab your headphones and 20гц20кгц bidet you happiness?
Марго
Post by Марго » Sun Jan 04, 2009 22:53
Hi! It was above told about 2 cups of water and high blood pressure. Can someone come in handy: my mother suffers high blood pressure + diabetes of the 2nd type, respectively, drink a lot of drugs that perform their role - pressure falls. But you can not constantly on drugs. I don't remember how I learned, but here are a few extra ways to help oneself.
1) Clove: take a deep breath with the palm of where some - the pressure drops (cloves should be aromatnaya, i.e. fresh, not stale). All of its flavor – in a hat. The pungency and bitterness in the leg. If the broken stud – then stored for a long time. The most fragrant and young, valuable. No breaks, only bends. In water sinks or floats hat up.
2) Pomegranate juice - if the mouth dries, leg cramps, head aches, then maybe the pressure jumped and sugar too. Now sell pomegranate juice good quality or from the fetus itself can do. So: I'm doing a full coffee Cup of pomegranate juice + topped up to a full glass of 250 ml of pure water. State stabiliziruemost for 15-20 minutes.
3) MEDICINAL PERSIMMON JUICE – Thanks to my wife, she's my medicine instantly found. Brought from the market persimmon, ran it through a juicer and made me two glass of juice to drink. At first I did not believe that this fruit could cure me, but by the evening my blood pressure returned to normal. Afterwards, I every day for a month drank 2 cups of juice from the persimmon. Since then, the disease doesn't bother me anymore, but every fall I am a wife to the market for sweet "medicine" to send. - this recipe is from the network.
4) IF PRESSURE PRESSURE: There is a very simple but nevertheless effective way of dealing with hypertension. Grasp the earlobes vigorously 20 times and pull them down. Do the same with the upper part of the ear, but making the move up. 20 times then pull yourself over the middle part of the ear back. Finally, RUB the ears with his knuckles 20 times clockwise and counterclockwise. Although this recipe and is perceived with irony, I can assure it works.
5) ...to lower the pressure, you need to prepare a tincture. 4 tablespoons powdered leaves of plantain pour 1 Cup of vodka and insist 2 weeks in a dark place. Then strain. Take tincture need 30 drops 3 times a day. Relieves pressure like a hand. Can not believe it, but I use this tool for the past ten or two-twelve, and need no pills. This recipe found in the newspaper.
6) Fresh red beet juice drink with diabetes on 1/4 glasses 4 times a day. In folk BPA-chevyii beet juice has long been known as the means to treat hypertension. The juice of the fresh root-fruit mix mixed with bee honey and take 1 tbsp 4-5 times a day. Course of treatment 2-3 weeks. But do not hurry to drink freshly prepared beetroot juice is bad for blood vessels. Let it rest for 2-3 hours.
+ of course the disc healing - I use it with happy. Somewhere from 10 minutes to fall asleep all the time. In all there have been 2-3 times when not at all (don't know why). The disk is tapped at night - put about 24.00. Get up in the morning during 7.00 - a sense of energy, clarity, sleep 100 %, work several different cases at the same time perform better than before. From frequent colds go without pills, the main time to catch a cold "tail" (as nasal passages begin "scratching" once the nose with salt water washed oksolinova ointment, something like "Septolete+" and must drive at night is always helpful. In the last month of the colds become much less frequent. Tried to take breaks in 15 days, but apparently health problems were quite deep and as they say "moved the problem" - be patient until the condition stabilizes the body using the disk. So since September I take the drive without a break, no addiction is not noticed and the benefit is tangible. Since I go late enough, you are too lazy to get up after listening to the disk and drink water, so before the drive I immediately drink 2 glasses of water and the sound in the headphones make the minimum-a comfortable and negative feelings were not. Health problems there are a lot, but I do not think that treatment with this disc, but feel that drive as it helps you to be stronger, my feeling is a kind of restructuring overall, the body looks for the path of self-healing. In a nutshell, if it good and deep relaxation.<
Олег Викторовсын
Post by Олег Викторовсын » Mon Jan 05, 2009 17:56
Dear Andrei Patrushev!
Thank you for your answer. "If you have chronic dehydration..." - will have to dig a little deeper this topic.
Cicadas... remember Quite well how they sound in the Crimea. Their sound is soft, alive. In the program it is somewhat mechanical. It's one thing to perceive this sound as the sound of a species of cicadas. In any case, it's better than just an alarm clock.
I wish you success and good luck.
Ив@н
Post by Ив@н » Sun Jan 18, 2009 18:05
Hello, Andrey.
Please tell me how your drive affects patients with leukemia in remisio and people suffering from cranial pressure. Thanks in advance.
Маргарита
Post by Маргарита » Sun Jan 18, 2009 21:26
Dear Andrew! My client listens to the disc Healing (with audiostrobe signal, the blue glasses) in order to remove the effects of stress and to restore forces. He's got 8 years ago had surgery to remove dobrokachestvenno brain tumor, and the result was the auditory nerve is damaged and one ear does not hear, there is only bone conduction. I know that the disc has binaural beats, they are designed for both ears. Please tell me whether it makes sense to continue the course, if one ear does not hear? The condition of man after listening to beautiful, refreshed.
And also, please tell me which of your disks, you can listen with one ear?
Алакей
Post by Алакей » Wed Jan 28, 2009 20:58
Andrew, please tell me why when listening to Healing the feeling of anxiety and sometimes fear and then float some not very biased images? And what to do about it?!
Post by Андрей Патрушев » Wed Jan 28, 2009 21:02
Ив@н wrote:Hello, Andrew.
I do not know. :cry:
Post by Андрей Патрушев » Wed Jan 28, 2009 21:07
Маргарита wrote:Dear Andrew! My client listens to the disc Healing (with audiostrobe signal, the blue glasses) in order to remove the effects of stress and to restore forces. He's got 8 years ago had surgery to remove dobrokachestvenno brain tumor, and the result was the auditory nerve is damaged and one ear does not hear, there is only bone conduction. I know that the disc has binaural beats, they are designed for both ears. Please tell me whether it makes sense to continue the course, if one ear does not hear? The condition of man after listening to beautiful, refreshed.
Headphones pressed to the head, so the bone conduction somehow works. It is even possible that the hearing barely survived because binaural beats work even when carrying served on a subliminal level. Criterion one - the feeling after listening. :)
All drives designed for binaural hearing.
Post by Андрей Патрушев » Wed Jan 28, 2009 21:10
Алакей wrote:Andrew, please tell me why when listening to Healing the feeling of anxiety and sometimes fear and then float some not very biased images? And what to do about it?!
In the beginning (three times) it happens, if it happens, then perhaps it is due to some other components of the sound pattern (the roots usually lie in the deep childhood) - listen carefully and analyze when the feeling is amplified when attenuated and that You are at this moment hear.
Алакей
Post by Алакей » Wed Jan 28, 2009 21:30
That is to rationalize and try to remember where it is, from what experiences?
Post by Андрей Патрушев » Wed Jan 28, 2009 21:35
Алакей wrote:That is to rationalize and try to remember where it is, from what experiences?
Yes.
Дмитрий В.
Been thanked: 2 times
Post by Дмитрий В. » Mon Feb 09, 2009 18:31
Hello, Andrey.
My father, after a stroke (last 2 years) started listening to the CDs.
Started with the 1st course - the Healing, 21 days, 1 times a day.
As stopped listening, increased blood pressure.
Took an EKG, it was normal.
Pills something not help.
Scary ...
Post by Андрей Патрушев » Mon Feb 09, 2009 18:57
Паскаль wrote:Hello, Andrew.
Scary ...
And the disk pressure was stable?
Time can be pure pskhologicheskoe - used to listen to (probably more at certain times), and now lacks something - hence trevozhnosti. Even without disk lies and lies as much as the drive was (you can headphones to wear).
Дмитрий В.
Post by Дмитрий В. » Mon Feb 09, 2009 22:02
And disk pressure was stable?
not stable, all life on tablets. The diagnosis of angina.
will try, thanks!
Post by Guest » Fri Feb 20, 2009 0:48
ЛИЛИЯ-Р wrote:Yes, you can boast of a body has become much younger looking and the face too. And the figure became like 18 years. Hair became thicker. A lot of energy
How did you achieved such results? Just listened or gave any instructions before the hearing.
Post by Guest » Fri Feb 20, 2009 1:04
Hello! Tell me, when listening to the course of Healing to occur exacerbation of chronic diseases. Can they somehow be treated with medication, or to refrain from taking any drugs. What do you think, Andrew? Or perhaps the forum will tell you who to date. :)
Another question - I listen to healing 8 days. First day listened to at night - slept very badly, tossing and turning. Then start to listen for a couple of hours before bedtime. Still can not sleep (two hours). What is it? Guess sleep should return to normal.
Post by Андрей Патрушев » Fri Feb 20, 2009 17:16
Anonymous wrote:Hello! Tell me, when listening to the course of Healing to occur exacerbation of chronic diseases. Can they somehow be treated with medication, or to refrain from taking any drugs. What do you think, Andrew? Or perhaps the forum will tell you who to date. :)
Yes - you need to treat what is usually treat.
And before sleep?
Post by Guest » Fri Feb 20, 2009 22:11
:shock:
Has thanked: 478 times
Been thanked: 264 times
Post by ЛИЛИЯ-Р » Sat Feb 21, 2009 2:30
Гость wrote:LILIYA-R wrote(a):
I've done this before without discs. Drives helped accelerate the effect.
But like any agreement reached should be supported.
But now less concerned.
Василий_V
Post by Василий_V » Sat Feb 21, 2009 2:54
ЛИЛИЯ-Р wrote: Posted: Sat Feb 21, 2009 12:30 am
Guest wrote(a):
LILY-P wrote(a):
So what is the principle of rejuvenation? :wink:
ыыыы
Post by ыыыы » Sat Feb 21, 2009 15:48
It seems that the disk should reduce the time of sleep, and when I listen before sleep sleep 12-16 hours nebrasa attention to the alarms. And Wake up as though did not sleep till evening are polyphase condition. :(
Because of what such an effect at all ?
андрейtver
Post by андрейtver » Sat Feb 21, 2009 19:43
I also noticed that the skin became Pinker and softer hair,here and from water much depends I guess.
Post by Андрей Патрушев » Sat Feb 21, 2009 21:44
ыыыы wrote:it Seems that the disk should reduce the time of sleep, and when I listen before sleep sleep 12-16 hours nebrasa attention to the alarms. And Wake up as though did not sleep till evening are polyphase condition. :(
May collection dream big... :) Or inertia of the nervous system...
Post by Guest » Sun Feb 22, 2009 1:06
:roll:
