Range. A new product in the social. the line.
Волька
Has thanked: 3 times
Re: Spectrum. A new product in the social. the line.
Post by Волька » Tue Mar 29, 2016 0:27
Wrote a matrix on paper in the form of strips, many times wrote, with the two sides and wrapped around his left hand. And immediately, direct instantly was a glitch: I could clearly see some abandoned village not familiar, as if I was in space and felt the air, the smell and even a light breeze. :shock: :shock: :shock: It looked like a panorama card :roll: Strange in General, before there was such glitches... Lasted a few seconds. And in the night dreamed nonsense brodowski). Few days bring in passive mode. Today at my new job in the new team mode "I", me friendly all helped, gave advice, one staff member even offered some information that he has spent a lot of his time, although I never even asked about it. Miracles) I'll Try now to pulseinterval with egregors:)
другой
Has thanked: 2 times
Been thanked: 2 times
Post by другой » Mon Apr 11, 2016 15:28
Printed out the storyboard. cut. gathered cutlet of 12 pieces... Went with this case for work, of course nothing is included. After 2 hours returned. my wife asked what I was doing there? Like the whole day digging up the garden. Strange that I realized this only when she asked. Killed just tight. :shock: Where it is necessary to subtract visible? in General, pleasant, warm
Post by Михаил_ » Tue Apr 12, 2016 15:29
другой wrote:Printed out the storyboard. cut. gathered cutlet of 12 pieces... Went with this case for work, of course nothing is included. After 2 hours returned. my wife asked what I was doing there? Like the whole day digging up the garden. Strange that I realized this only when she asked. Killed just tight. :shock: Where it is necessary to subtract visible? in General, pleasant, warm
This tool is unlike other BJ not to "just wear" for work. If just work for do not want to assume management or other f-tsii, you do not need to wear. Well, or to switch to one of the. And by default, not even used the tool on hand gives you quite tangible for a beginner load. Or you could just train yourself to get used to.
Usually the Spectrum are those who are in need of active work with the social sphere.
(well, business for example).
Артем север
Has thanked: 141 times
Been thanked: 29 times
Post by Артем север » Tue May 03, 2016 2:04
Михаил_ wrote:(well, business for example).
Michael and with a heavy egregors type law enforcement,civil service, Broadcasting Facilities to cope? Or take a physical product? The need arose for it now.
35000 for physical product bracelet, not so much. Stream Range 50000, pendant 274000. And where to start? Stream and if everything turns out, six months later pendant?
Еленка
Been thanked: 4 times
Post by Еленка » Tue May 03, 2016 11:06
I have a homemade Range.Six months ago, was the need to work with the egregore of Islam.The result is a terrible headache,a broken link of the band,but "it went".
P. S. After the link is split,the headache was gone)
Артем север
Post by Артем север » Tue May 03, 2016 22:41
Еленка wrote:I Have a homemade Range.Six months ago, was the need to work with the egregore of Islam.The result is a terrible headache,a broken link of the band,but "it went".
Be so kind as to describe "in a nutshell" the process "work". Your pattern of interaction with the egregore. You could PM if this informacija closed.
Thanks In Advance.
Еленка
Post by Еленка » Tue May 03, 2016 23:39
Артем север wrote:Be so kind as to describe "in a nutshell" the process "work". Your pattern of interaction with the egregore. You could PM if this informacija closed.
Thanks In Advance.
Can describe.Operated intuitively.
It began with the fact that my husband works in a collective where some are Muslims,and tried also to involve in this religion.To be honest,that people are good,honest,and apparently he fell under the influence,listened to a CD where you were explaining about the Quran,its laws.And I "remembered" about the spectrum.Use it rarely,as needed,mostly for small things.
And then the classics :I'm your Operator,mutual.Said that we should not interfere in my family,something else I can't remember.....She wore the bracelet for three days,of which nearly two days, had a headache,but after a night split link,the pain is gone,and somehow I wanted already to remove the bracelet.He felt that "before the addressee reached my request,"and "noted")))))
Oh,and wrote a colourless marker matrix spectrum on CD,just in case.
While "normal flight".I feel that between me and this egregore established diplomatic relations.)))))
Артем север
Post by Артем север » Wed May 04, 2016 0:09
Thanks In Advance.
And you're done!
Thank you for the experience!
Еленка
Post by Еленка » Wed May 04, 2016 0:14
I hope my experience will be useful to someone :oops:
Post by Михаил_ » Wed May 04, 2016 6:06
The pendant in its current form, will require some time for manufacture. And I very carefully relate to its sales.Sold it after the interview. Too cart-power product.
Stream range is clearly not worse than physical products, although in fact they can domonate each other. A higher value just is its greater efficiency. Homemade of course is also in the bill and quite applicable.
From the point of view of what work is important not only last, but also the approach and the operator's experience. Recommend to use with the Activator and ALFAVIT/ALFAVIT/VIP.
Post by Михаил_ » Wed May 04, 2016 6:09
The above described experience is not the only option for such rassada. You could go another dozen routes, but I wouldn't want to discuss too much detail here. For a number of reasons. Can read everything, but some things - the essence of things trebuie experience, understanding of what is happening, not just up-done-gone.
PS most religions this is not only the egregore but the spectrum applies here.
Post by Михаил_ » Wed May 04, 2016 6:13
By the way, since I still "lit" in the subject for the exchange of experience on my forum for similar transactions also applies designer ties VIP version. (COP common in this scenario is NOT APPLICABLE, it completely different algorithm!) It is possible to work with the egregore itself, but with a lot of people (not one person) as the target. Organization/Department/service/located in one place people, and so on - is quite suitable. Of course we must understand that the scum of the media will not force these people to go beyond the boundaries of what they should and used to do, but the same aspects of "I", desire to assist You, light anomalies in your favor, and other utility - it works well even on the run and with unknown structures.
Артем север
Post by Артем север » Fri Jul 08, 2016 19:07
Bought a bracelet physical, range-4, as it turns out only to quickly get through traffic and be in time everywhere. In societies pose mode I your. In General, I want to grow to the pendant Range... Thing is cool if the bracelet is doing (father-in-law 4 days). And I think he does something with time(bracelet), or whether slow stretches.
Also a couple of bursts turned out to disperse.
Джейсон
Been thanked: 27 times
Post by Джейсон » Mon Jul 11, 2016 23:29
I have to be honest, of strong emotions has not received after migrating from homemade. It turns out she's amazing, my friend recently good social. the effect has got to do with it abnormal, fast, it is not the stars aligned. He himself direct the hero felt. Looking back, I probably would have paid extra and took the stream. Do you think it's the sweetest.
Post by Михаил_ » Tue Jul 12, 2016 11:08
Yes, stream is a good thing.... I think so too. Actually in the current line only the product with Pandora and some others including the actor/activator/I2 deserve to be physically purchased, almost all the main rest of a stream is taken.
Агент Смит
Post by Агент Смит » Thu Jul 14, 2016 1:37
Good day!
I have a question: do we need the physical contact of the recording wristband with printing? The fact that I printed the storyboard of the Spectrum on photographic paper, and it is hard and the whole chip under a tight wrap, and I had a thought: what if you turn the sheet in the form of a cylinder inside of it and hang the bracelet on a string so he was right in the center, but not to touch the paper. Then the storyboard goes like the cycle and all shots will impact at the same time, well, in all this foil to wrap. What do you say people in the know?
Post by Михаил_ » Thu Jul 14, 2016 13:27
Well, and so :)
Агент Смит
Post by Агент Смит » Thu Jul 14, 2016 13:36
What time is it there to sustain, given the fact that the bracelet has "watched" the video Spectrum on iPad 12 hours?
Post by Михаил_ » Thu Jul 14, 2016 13:45
But feel - look at him (put) may already be enough :)
Агент Смит
Post by Агент Смит » Thu Jul 14, 2016 13:58
Yes I then Keane ;) two days it was worn - no sensations. However, I have not tried anything there to enable it, because I read that they need to get used to each other ;) So decided to improve and printing. By the way, on the contrary, wrote the matrix (links are hexagonal, with three letters on one face), so somehow it needs to show itself.
Post by Михаил_ » Mon Jul 18, 2016 16:26
Well, range - clearly the operator product, (not counting its mode, and of other car-washes). Many it satisfies a simple matrix as an aid in social work, so to speak. Although I know and those who pendant clothes sometimes. And it's tough stuff (a locket).
However, for those who understand where he wants to steer and that it is a lot healthier and clearer in manifestations than in the option "wait until he show himself", the spectrum is a support product, social oriented, not basic BJ. Can "sit quietly" and not be seen for a long time.....
Джейсон
Post by Джейсон » Mon Jul 18, 2016 16:52
Михаил_ wrote:Can "sit quietly" and not be seen for a long time.....
I had one unpleasant situation a long time ago. With the "stupid" range were operamail. There was no result, I even got upset because joined well. And 4 years later he shot straight at the scenario. With it, I really don't need it because the route was just found then better, and I did not understand, and clutching claws. Inclusion in the word, and give you useful information and Dating from there, always instantly.
Агент Смит
Post by Агент Смит » Mon Jul 18, 2016 16:58
When working with the spectrum of BZ must be worn? And what is the minimum version of the BZ is enough to range of work?
Джейсон
Post by Джейсон » Mon Jul 18, 2016 17:00
It works and without special stages. The more bracelets, the more energy. The more energy the higher the efficiency. About the version, probably the best Panacea.
