Strange anomalies
Re: Strange anomalies
Post by Михаил_ » Mon Dec 02, 2013 7:39
well you can, and can be interpreted otherwise - in the sphere of social processes, there is also "swing", i.e. a sine wave. And what we are seeing - for example the neighbors = the euromaidan.... I was always out of politics, but to a hedgehog it is clear (as fond of saying our mathematician) that it's not just... obviously this turn can be mono process a, and divide the country more conventionally political. Here is the rollback of the social. the state of the first and more stable snow. I don't mean that Kiev is affected, and that swing has swung the other way and in different territories, within the framework of their processes and their current state of stability, it reflected a particular manifestation.
Well, maybe someone helped swing the hell knows, I don't want my head to go into that part of the fuss, I am interested in the help to concrete people in recovery and passive stabilization and not even at the level of knowledge in the katabasia.
Л@на
Post by Л@на » Tue Dec 03, 2013 0:28
Владер wrote:But in the evening, apparently people in the habit of beginning to worry - "it is Time for winter to begin on December 1, after", and it was snowing.
Yeah. Today at work the security guard said that they had asked the little God of snow.
Андрей С.
Been thanked: 4 times
Post by Андрей С. » Tue Dec 03, 2013 0:29
By the way, we have weather, as if to say... very clearly react to what is happening in the social sphere (I mean Kiev, Yes :))
Post by bofara » Tue Dec 03, 2013 1:06
And you put the PC in these areas? /Kiev, for example/ If Yes - it would be interesting to read the opinion.
Here we have even in the news began to observe the real state of things /I'm talking about the weather, although for a society to share something, but don't want/:
"the Storms, the snow and cold to expect in Turkey and Greece, the bad weather will pass by Bulgaria"
ВикторРусс
Post by ВикторРусс » Tue Dec 03, 2013 10:05
Yes, I also love when the top is covered by clouds, as it is calmer the feelings out :)
Has thanked: 13 times
Been thanked: 49 times
Post by ФилиНН » Tue Dec 03, 2013 10:16
ВикторРусс wrote:when covered with clouds
Not claustrophobic? :) Got a transit in N.Urengoy. Sky-clouds there on the roofs of houses, right, scratch.(At home there is a 5 FL.). So it vosche feel.
Post by Михаил_ » Tue Dec 03, 2013 11:22
by the way about the touchpad and other oddities - I've got it's the opposite effect, I'm so at all "kicking" that I had in the laptop to plug a normal mouse, can't use touchpad, it's on me from afar reacts randomly did something switches and so on... the effect is robust and does not want to get out at all (shown on a different vehicle). This despite the fact that under my feet grounding (remove tried - does not help, just the tile floor he electrovalency due to residual moisture in concrete)...
ведьмочка
Post by ведьмочка » Tue Dec 03, 2013 18:49
ahaha))) I so long ago) I hesitated even a little bit)) to stand using time in shops at the checkout, when the whole system crashes at all, for example) and the fact that I have a page opening - so this is the norm, Yes..))
Post by Михаил_ » Tue Dec 03, 2013 19:19
no, nothing freezes and cash is always fine with me technique on the contrary to listen to and repaired, but the fingers now kicking and you have to use special measures :)
Андрей С.
Post by Андрей С. » Tue Dec 03, 2013 22:05
I have a touch screen phone, too buggy, several times a day is something that involves, as if someone randomly poked a finger ten times. But I in your case, the more technical problems I think... Need to compare on other people's phones.
Малыш
Post by Малыш » Tue Dec 03, 2013 22:11
Михаил_ wrote:it is necessary to use special measures
:))) protective gloves :) with the runes:))
Нетрезвый Сурдопереводчик
Post by Нетрезвый Сурдопереводчик » Tue Dec 03, 2013 22:19
Михаил_ wrote:speaking of touch panels ...
All almost the same. from smartphone and tablet had to be abandoned in favor of push-button devices. The phones I have are "live" are simple. With constantly departing the tablet had to go for a netbook. Sometimes short out the switches in the apartment. Equipment around me it mercilessly. Home hide me away from your device :)
Post by Михаил_ » Tue Dec 03, 2013 23:49
well, in General I have everything is perfectly stable and works very well(at the same time more frightened and sometimes repaired), just before (I wrote about it), I have touch screens on the contrary is not pressed at all (had dances with a tambourine or pen to use), and suddenly became too pressed.
something that is short and technology is buggy - it's much more about something else - the uncontrolled bounce in the personal field, it is necessary over time to tame just.
but the change of polarity effects on the touch panel is ....funny...
Post by Михаил_ » Tue Dec 03, 2013 23:50
Andrew apparently about the same crap that I have a phone by the way, Yes, too, was myself to press ...
we need to think carefully nibudi :) why is it.
Post by Нетрезвый Сурдопереводчик » Wed Dec 04, 2013 2:11
Михаил_ wrote:Andrew apparently about the same crap that I have a phone by the way, Yes, too, was myself to press ...
my phone sometimes calls himself. determined by my number.
Has thanked: 24 times
Been thanked: 142 times
Post by Маг.нет » Wed Dec 04, 2013 12:00
Михаил_ wrote:to use special measures :)
helps me to deal with it (not 100%, but very significantly) the Product of N1, not 100% mean that this occasionally still continues to happen, but at times, even perhaps more accurately ten times less frequently, while the Product of N1 with conscious mental inclusion (inclusion structure of the Product as a modulator of the medium to the desired process), it allows to remove already manifested similar glitches (have not yet found this way remained largely similar when only wait until the "self-other" razrulitsya and hope that "attack of the bugs" will not lead to irreparable consequences - for example))))))) transfer money to who knows where, etc. jokes), simultaneously turning them off or smoothing out smoothly, and I observed the "list of glitches" is much broader than described here. Oh yeah, we should have to add such observations, the emotional background of the Operator, rather it bursts, can significantly strengthen the extent of such "buggy" electronics, and to contribute to its new manifestations "sort of nothing" (in post research this is often close, sometimes very weak, almost imperceptible emotional outburst of the Operator, and then "the Butterfly Effect" does the job).
Sincerely, MAG.no 〠
Gelios
Has thanked: 3 times
Been thanked: 7 times
Post by Gelios » Sun Dec 08, 2013 12:05
Another joke over time, but this time the other way :)
Something which was going to go, look at the time on the phone 11 hours. Almost drank a mug of cold espresso, took the clothes, take the phone to see the weather, and there are 12 hours and 3 minutes. Well 3 minutes that actually passed... But has nowhere to go is not required, as it was late to complete. Here and drank coffee called :oops:
Post by Михаил_ » Sun Dec 08, 2013 20:32
:) well, that's normal at all.... just before rarely occurred :)
Давзер
Post by Давзер » Thu Dec 12, 2013 14:44
I have e.g. on the body,take the courage to say,appear what type of stigmata, usually two parallel strips,can't figure out how,once in the center of the spine,upon waking,I thought that he may put and do not remember,but there is an even more shocking fact that there was a day,looked in the mirror and saw,when he felt that hurts,and another energomarket went missing after a night out,woke up and looked stunned :shock:
Here is how it to explain a magical effect,then such sort of enemies is not much,or astral adventures that are forgotten like dreams...?
Post by Михаил_ » Thu Dec 12, 2013 14:55
I do not understand what the bracelet was missing?
Владмосква
Post by Владмосква » Thu Dec 12, 2013 22:48
under the "one energomarket lost" Dowser apparently meant trail.
Post by Михаил_ » Fri Dec 13, 2013 13:51
probably, but not guaranteed, and therefore asked for clarification. I am not aware of cases before so the trail was lost without the desire of the operator to the fact (conscious or not conscious)
Post by ФилиНН » Wed Dec 18, 2013 11:47
Мариомар wrote:I am one last time dream of Putin, in the way wonderful, such a friendly guy and talk to him and Council to ask
ФилиНН wrote:Holy, Holy... Shaw, "put" fresh punch "movie"?
But why suddenly Vedmed in the "image"?! :shock:
We sat together in the office of the former GL.engineering, pogoreli its reserves in the refrigerator, and then dropped the mower on its completion!
They have that whole old "the deck" in the range is charged on a variety(in their opinion) tastes?
Better porn... :oops:
PS Kerf. It was a "bookmark" for 2018 :)
ВикторРусс
Post by ВикторРусс » Wed Dec 18, 2013 19:28
perhaps you will laugh, today, to find external signs that the Muscovites and not only , most, the increased concentration of co in the blood
Post by ФилиНН » Wed Dec 18, 2013 19:39
This is what these external signs? Carbon monoxide in the "exhaust" :)
I do not regard 8) Right now, only with accurate spectral diagnostics in the presence of only heavy metals(tomatoes? zucchini? pear, persimmon?) :roll:
