Stabilizer.
Has thanked: 2 times
Been thanked: 21 times
Post by Логик » Fri Jun 24, 2011 13:31
Michael_
Thank you very much!
Post by Михаил_ » Sat Jun 25, 2011 15:33
I Russian told me to stop arguing on this thread. And advise going elsewhere.
Post by Михаил_ » Sat Jun 25, 2011 20:08
1.
Announce a change in the configuration of the stabilizers.
Regardless of the version with the stabilizer will go:
12 anchors
1 eraser
12 programs on the choice of the buyer from the range
To purchase the program and the anchor, it is always possible (if any, specify). In some cases there may be a slight delay in their manufacture, but usually they are in stock.
2. we are preparing for release 2 of the product "Brake magic" in a wearable version. Approximate time of appearance in the sale is the end of next week. (1 number).
Design - 3-dimensional engraving in the glass.
Size: standard keyring (like in the product Ah series)
and drive glass (as a stand under the water KV, only 60mm in diameter, ie smaller).
Keychain - pocket-sized version.
Drive - wearable or table. (on these disks, blanks for which are for engraving Souvenirs, there is a flat cut on one side, it is possible for example to put on the table vertically). In wearable form, it is quite a "pocket" or "bag", but much larger than a keychain.
Both products will enter a "hodgepodge" of programs of the stabilizer:
-stop magic 1-2
protection
stabilizer additional
I think many people know these programs can be used regardless of the presence of the stabilizer from using them.
Price per keychain 2900
the CD 3900
Димонъ
Post by Димонъ » Tue Jun 28, 2011 4:10
Manufactured stabilizer. put the top of the sticker, coated with glue on top of them. put it in the closet. I think let dry. A day caught the virus on the PC-the urgent call of the master, time, money... the Situation is not deadly, but good enough. Bounce? Coincidence? With the stabilizer not working yet.
Post by Логик » Tue Jun 28, 2011 10:52
Димонъ wrote:the Situation is not deadly, but good enough. Bounce? Coincidence? With the stabilizer not working yet.
This is what...
I before the production of the stabilizer when all the components were ready, twice badly cut index finger of the left hand almost in the same place. It all happened in one week.
Came to see a friend in a darkroom for one specific thing. During the demonstration got included MP3 player and put it on photomachine. I never noticed how the player fell. Well, you never know where it fell, all was nothing to him. But this time, he fell into the lake with water which stood near photomachine... Player stopped working. Repair cost 500r
Well, the little things all sorts of unpleasant stuff happened a lot...
Алексc3000
Post by Алексc3000 » Tue Jun 28, 2011 12:08
Good day, the questions still arise, and better still to ask again:
1 - if the diameter of the tray is greater than 60 cm whether to increase the size of the Mandal (in proportion to the inch of course) or leave them an inch (on a big tray everything is as it razmazana and very much miniature work)
2 - if the wax or the wax from normal candles from the store and what color it should be in the device ( white, red, green, etc. and if the wax from Church candles)
3 - if understood correctly before filling with oil to impregnate the sawdust of the tree the resin is completely frozen, what tree is most suitable for this purpose (birch, spruce, poplar, etc.)
4 - is it enough to be the size of the druses of amethyst 5 cm in diameter when using the tray 60 cm in diameter
5 - if the solidification of the resin shrinkage will occur and the field stabilizer for example will not be hard to stay in the tray will the device function correctly
And last, probably the most interesting question (discussed it on the forum or not found), the file that was posted for the independent production of the stabilizer, there are four pdf file (the source in my understanding), if you look at the scans posted them there under each graphic matrix written letter matrix of nine letters and other letter files, this matrix is just cut off. Some images of mandalas, it would be PREFERABLE to use the stabilizer or trimmed the source.
PS we put the letter matrix in the manufacture of products and light products already work, but here is that most of the cut, it turns out part of the power is lost
Has thanked: 24 times
Been thanked: 142 times
Post by Маг.нет » Tue Jun 28, 2011 12:36
Алексc3000 wrote:PS we apply the alphabetic matrix in the manufacture of products and light products already work, but here is that most of the cut, it turns out part of the power is lost
The matrix is not described by the rules, and the link to the source where these rules are shown, only the sign (label) and what is written there, sometimes it does not matter. Therefore, if repeat this signthis link , then nothing is lost.
1. The matrix can be increased in multiples, but their power and potential will not change much, the only - charging time quality may be reduced (by increasing the initial area of the charging), but power device is not much to add.
2. With the color not bother much, the main thing that the material was of high quality and meets the conditions in the description.
3. As in section 2 mono material properties of the secondary they can add a little here, but I think is not affected much. Well, if you want understanding, take it for sawdust easier (because it is for the HF range closer) wood or those rose petals to impregnate any essential oil of Your choice, but it is only as one of the options.
4. Should be enough, there is much more that it was "clean" (charged 1.0 "in the wet") and on the place.
5. My Stabilizer from the edges of some composition moved away from the tray - did not notice a difference, probably not significantly.
How to choose from the list, voicing their opinions, Michael_ will correct inaccuracies. In my opinion the earth/clay/rose petals, as well as other components of a priority to take seats that close, and even better if You were there, and even better if the source that You linked (around the house, garden, alley frequented, etc.).
Will explain why. Elements taken from the places that You familiar already with You structurally aligned (You keep the experience of their "structural fingerprint") and, therefore, the final Product may be much better aligned with You. And there is another upside to this, as processes are usually low-sided, and multi-faceted, the Stabilizer is such as to cling to its structure and the place from which the seized materials, so you get a double benefit and Operator and "places of origin" materials.
Think enough to answer Your question, if necessary, can make corrections.
Sincerely, MAG.no<
Алексc3000
Post by Алексc3000 » Tue Jun 28, 2011 13:18
MAG.no and thank you for the quick reply, I have the impression that You're just living (no offense of course), at the expense of the wax, I understand it is better to take neutral color milky or yellowish be sure to melt it down, cool, grate and then it will be possible to use, mandala has become the same all clear (all night spent preparing files for printing in Corele shame it would be if not approached) will go to the spring will attempt to extract clay where to see what it should be
Post by Маг.нет » Tue Jun 28, 2011 13:41
Nah, I just have the feedback channels work well, and V-kit (incl. lessons) helps the eye to see not only the investigation, but the reasons (as a manifestation of the structures). On account of the wax, it is better to take a natural (no matter what color) can be further purified from the distorting structures, melting, then running water (20 minutes would probably be enough, and in the spring, just class!) although not required, after you grate it and you can use. If the source is to use wax Church candle wax, the melting and flushing more desirable than in the previous case (in order not to cling to the structure of Orthodoxy), if you take with a friend of the apiary, it may be more efficient (in a previous post pointed out the reason) and then you can without cleaning.
The main mandala (also zoom) is not to rule at all - the link will be clearer.
Sincerely, MAG.no
Post by Михаил_ » Tue Jun 28, 2011 13:53
MAG. not all questions are in principle answered.
Matrices can also be.... But the difference will not be. I.e. it makes no sense, matrix is good for superposing hard copy or drawing of the stabilizer on the something (sand, earth, asphalt, rock, etc.).
I use wax jewelry in the crumb. Not because it's necessary, and not to RUB - it mangled plates of the bizarre - well chaos is a. And then grated the chips are still all similar.
Петрос
Has thanked: 45 times
Been thanked: 9 times
Post by Петрос » Tue Jun 28, 2011 16:33
Алексc3000 wrote:go to the spring will attempt to extract clay where to see what it should be
near the springs is not found, found in a forest pond, the place where water meets land )) Grey, greasy, solid mass without lumps, do not be confused.
Post by Михаил_ » Tue Jun 28, 2011 18:25
exactly, that's what. there..... she can always be found where there are natural water bodies - it is a unique thing. I recommend....
Димонъ
Post by Димонъ » Fri Jul 01, 2011 3:31
Didn't know where to get clay and decided to use the BJ for this purpose. Wore bracelets, and requested to help in the search. After I got in the car and went in....the center of Moscow. Within a few moments I recalled a childhood memory with the forest spring. Came back and again use the BZ, in 5 minutes found. The legs themselves led to the right place. This is our experience. Rule out coincidence, because I tried to find in other places of the same stream, the result is zero.
Even a small report about the stabilizer. Anchors and prog were not yet working. Decided to get used to and survive a small "bounce". But there are some changes and so.
1) there was a desire to play sports( before it sometimes had to force myself,
and in other cases simply because it is necessary)
2) Decreased, or so it seems to me pain in the knees and ankles(injuries),which hated squats.
3)Recent(a year old) scars have become to ache and to "move". Hope to recovery :)
4)Several times a day catch a state of weightlessness. On the other does not know how to say. The feeling of videotest or something. Condition is not bad, even like.
In General, the stabilizer was cool :ay . I like feel and appearance :) .
Michael, thanks for the device bi .
Well, as always questions.
a) Improvised prog(for stabilizer) less than nominal. What? At the time of the manifestation of the properties or in the power of manifestation? For example, to achieve the result required 1 day and 10 respectively. Or will appear simultaneously, but the power of manifestation will be different. In other words, a makeshift shovel to dig a hole like an excavator, only "a bit" longer work :) or simply will not work.
b) does it make sense to use the standard bend with a homemade stabilizer?.
C) Well, and work with the stabilizer. The goal is recruitment for the company-anchor on creativity. The incumbency, on the development. Stop staff rotation-braking. In principle, one goal of forming a stable , professional workforce. Is it possible to break it into three or better concatenate into one and to anchor the development?
d) To initialize the OS where would you recommend to anchor itself, provided that the Wasps was not stable?
D) Michael, (Sori that is not the topic) you wrote about a simple way of getting rid of scars. You mean plucking or something else?
Thank you.<
Post by Михаил_ » Fri Jul 01, 2011 12:39
a) and so and so.... there is no definite answer, because in one case it is longer longer longer and the other may not cross a certain threshold at which the General effect can be obtained.
b) quite possible is one of the options.
C) you can leave one, but sometimes the anchor and I want to put here and there - then it is appropriate and a couple of anchors.
d)... well, for example in the area of development
d) sure it was me? sure didn't mean no plucking, and no longer remember. I do much prefer useless once the heads off. So maybe when he said, then remembered what :) for example, the scars are easily removed, many appropriate exercise gorbachevskogo course that is specifically designed for scars.... many, but not all of course. Some of them will akorat very efficiently... but this shop (INM norbekova) as something well degraded in recent years and I have no idea whether there are other people efficiently courses.
Димонъ
Post by Димонъ » Fri Jul 01, 2011 16:09
Michael, thank you.
Алексc3000
Post by Алексc3000 » Fri Jul 01, 2011 16:54
Good day, opened today at the photography shop Kodak photo mandalas, come home watching and they are branded photo paper to use with the logo on the back (the entire leaf infection in the logo) as you think you are suitable for the stabilizer of such a mandala on the paper or will have to remodel.
Post by Михаил_ » Fri Jul 01, 2011 17:04
suitable
Димонъ
Post by Димонъ » Mon Jul 04, 2011 16:47
Night placed the first anchor on the stabilizer. Yourself put on druso. In a few minutes felt a push in the chest. The state, like the beginning of loss of consciousness ringing in the ears, and as if out of the body. After a few seconds everything went. Slept like a deck. He lay down immediately fell asleep. Woke up very weak recollection of the last dream, which immediately disappeared. Slept very well. Put 2.5 and 2.7. Moved itself to the development, an unexpected result. All things that were planned, decided not to do, and to do completely different. :?
Ольга К
Сотрудник mindmachine.ru
Been thanked: 17 times
Post by Ольга К » Thu Jul 07, 2011 15:53
Appeared in the office Disk glass stop magic. Photos will be later.
The price of 3900 rubles.
Петрос
Post by Петрос » Thu Jul 07, 2011 19:56
Ольга_С wrote:appeared In the office Disk glass stop magic. Photos will be later.
well opielka... also in the Studio :)
Post by Михаил_ » Thu Jul 07, 2011 20:03
what kind of Apizaco? Like I described her......
Петрос
Post by Петрос » Thu Jul 07, 2011 20:10
hmm, in this topic?
Петрос
Post by Петрос » Thu Jul 07, 2011 20:11
Михаил_ wrote:what kind of Apizaco? Like I described her......
and I found :)
Петрос
Post by Петрос » Thu Jul 07, 2011 20:14
-stop magic 1-2
protection
why in this set?
Post by Маг.нет » Thu Jul 07, 2011 20:30
.Buy FOB StopMagicissue is - this "set of software" would like something to interact with my Stabilizer, will my Stabilizer to strengthen the capacity of key FOB?
Would it be possible to place the "eye" of the keychain as "stack programs" directly on "one of..." anchors of my Stabilizer, does it increase the capacity or manifestation of the programs in this adjustment of the processes/objects?
Sincerely, MAG.no
