Disk A. Patrushev, "Journey to inner worlds"
Tell me ,and I bought it in electronic format and listen from a laptop through headphones. It's not right? Need with player etc. Thank you.
Re: Disk A. Patrushev, "Journey to inner worlds"
Michelle
it all depends on the quality of your sound card.
Andrei Patrushev, **Stimulation of theta brain wave gives us access directly into the subconscious. This way you can bypass the conscious mind, which often performs the role of "filter"**- and if, immediately after listening to the FPGA without a break to start affirmations?
AasthaYes , some time the afterglow persisted, so affirmation will be "to go" is better.
Thanks for the reply.But if supraliminal-entry "Connecting to Universal Higher Knowledge" to put after a Trip to VN.worlds..?Андрей Патрушев wrote: ↑Fri Dec 21, 2018 20:57Post by Andrey Patrushev " Fri Dec 21, 2018 20:57
Aesta, Yes, some time the afterglow persisted, so affirmation will be "to go" is better.
Aasthaeverything exactly the same.
Andrew, good day.
Greatly reduces the effect of listening to the FDA, if you listen to without glasses, only in the headphones?
Vadimstrongly (remains of interest 30%).
Not planning to do PVM without audiostrobe? And not all machine is, and want to try...(remains of interest 30%).
Vadimand what's the problem? Well, you have no decoder - listen just.
And the sense to listen just so, if the effect is 30% percent?what's the problem? Well, you have no decoder - listen just.
VadimI don't understand what You want.
At the moment the disc PVM gives 100% effect when listening with the glasses. So I ask, are there any plans to make the drive PVM without audiostrobe to get the same 100% effect, but listening to without glasses.then I don't understand what You want.
Vadimit's impossible.
The main effect always gives light (whatever the network is no chattering).
But everything is relative. Just assign 100% of the sound program and light let him go already over 100%.
Andrew, and the Journey through inner worlds and Исцеление2 combinable?
Vadimquite.
