Advice from Andrei Patrushev
Yes, Healing is better at night, and Endorphins in the morning. At least to try to of at least 3 hours break.артем-83 wrote:Thank you Andrew,I hope vblizhayshee time will bring, and Healing when listening? Also in the evening before bedtime and in the morning the Endorphins or what?Андрей Патрушев wrote:That's just the Healing in Your case it would be the perfect solution.артем-83 wrote: Sorry Andrew that said, I have a tough schedule, prepays at 4:30, run, go to work after work, learn a foreign language, write a thesis and attend courses on networking =) I get home at 21:00,I would like to examine what remained in my head=) I addition to Conductor have trace. drives the Massage of the brain, Ultramesh, Star traveler, Endorphins... soon I hope that will bring Healing ...
No strict rules, because there are fatal consequences. Usually all do as they like more. The recommendations are given in order to, first they wereлиза wrote:Hello Andrey! Help,please to understand, I was confused,probably from Sitka information. I'm a novice and listen to on the machine the alpha session.You need to listen alpha 21(15) days ,then a break of 21(15) days. Right? If so,then in theory the break you want the machine to delay and not to use ? Or you can listen to any of Leo's other sessions? without alpha?
For some reason I first decided that such breaks have to do when listening to your CDs and not ochnyh sessions on the machine. Even during the break when rbate with disks, You write that you can listen to others. I have,unfortunately,Your drives there,listening in parallel with the machine drive Alexander Sviyash(I do not know how to persuade name
). Spatulas. so what breaks on the machine? And if they still need to do the break time to clean her out(which absolutely do not want to,because I already love her very
), What advise to do? If the disks,that too without alpha?
damn,here I write and even more confused
explain for God's SAKE
лиза
Thank you! Very glad to not have to postpone the car for a single day
I think that after 21 days the alpha will go to the Bette
In addition to E what else is it? In the instructions there are ,of course, the division into which you need to focus, but looking at the description of the sessions in life would not guess that relates to what
especially people who do the first time with this encounter. Thanks in advance for your answers and patience . Immediately see your alpha worked as it should
лиза wrote:Thank you! Very glad to not have to postpone the car for a single dayI think that after 21 days the alpha will go to the Bette
Some session level "L" can be attributed to the beta sessions (L01, L04, L05, L06 for Innerpulse).
Недоушелец
Yeah, Andrea-self spokoistvie. A good example of when words with deeds.лиза wrote:Thank you! Very glad to not have to postpone the car for a single dayI think that after 21 days the alpha will go to the Bette
лиза
Hello
this is again clear with my questions. without Concha read the forum and stumbled on your communication with the person who quizzed whether your disk contains bad hidden mischief
. here's a piece from your answer"this kind of drives for sale right now on the Internet and stores a lot. Besides me there is no author makes the author's support. Some discs I have analyzed it and found it very, shall we say, inadequate techniques of subliminal encoding, but I'm sure the author didn't want to do anything bad to your customers. Now let's go honestly in a logical chain to the end. Modern psychoacoustic technology to disguise all the suggestive material on the disk. So you can get all sorts of assurances about safety, but to obtain as a result of "a cross between a Viper and a hedgehog" at their disposal."
Andrew, I once really penetrated to You by trust and I want to ask a question. I understand that the question is not very tactful on my part, but I need to know. Alexander Sviyash. Listen to his CD "True love for yourself" You watched this DVD? He's all right? The fact that I now can't afford to make a mistake. Trying to get out of very severe depression, and cause depression continually and still occasionally adds "pleasures". End is not visible. I lost quite. Hence the disks, typewriter, Hixy,Seeland, Vanessa Mae ... Although,there is one big plus-it all appeared in my life
I am very pleased. Pardon me for asking, but is everything in order with this disk. to listen need 40 days for an hour. Affirmations are "poured" into the subconscious ,bypassing the conscious mind, what the doctor ordered. Throw on the half you do not want. The disc is licensed. Opinion heard only one from the seller. whether it is possible to put yourself in the head?
Hello.лиза wrote:Hellothis is again clear with my questions. without Concha read the forum and stumbled on your communication with the person who quizzed whether your disk contains bad hidden mischief
I can't buy and analyze all the disks.
Good luck!<
On the other hand, "clear being" appeared thanks to the book Tamara Andreas "Essential transformation". I remember for a long time trying to find an adequate translation, and then it dawned...Варя wrote:And SAUCE from the same place?Андрей Патрушев wrote:there...
лиза
Andrew... you wrote somewhere that when using a mind-machine you are viewing the cartoons - i.e. see the images... and you are tired to watch cartoons....
I am neither fighting with the theta can only see blurry images and very vague and ambiguous... how many time mm, you can see distinct images, and not a kaleidoscopic construction?
what do You see? could You write about what you see for example the tapping of a conductor or sessions on MM???
I understand that you're busy and you have little time but would like more detail...
it is better to HEAR or NOT to HEAR
Question (desirable) to Andrei Patrushev,
what drives would recommend to listen to at night
and what will advise in the morning
including what is contraindicated to listen to at night.
Just in the descriptions, it is almost nowhere mentioned.
Thanks in advance for the answer.
Идущая вперед
- Been thanked: 6 times
I really cut down in the sleep of the solar wind....
I passed out after 4 tracks specifically and sleep all night like a log...
but this current reaction to my disk....
session innerpulse sleepy I did not put.... ie to sleep in the evening I do not tend finally...
all of the theta drives at night not listening to (them then the vigor and midnight jump want)
conductor (if the fatigue after a hard working-labor day strong) is very good at helping to fall asleep...
the disc massage the brain current in the morning.... at night in any case...
each brow your biorhythms... someone like it and someone se...
in the morning - beta (power session)
try... try.... and trample you....
To theta to see bright clear images, it is necessary first to consistently work out alpha and beta (week three).Anonymous wrote:Andrew... you wrote somewhere that when using a mind-machine you are viewing the cartoons - i.e. see the images... and you are tired to watch cartoons....
The images are highly dependent on the Sauce - all from the kaleidoscope to the cinema (well, the type of operating system).
Re: what is better to HEAR or NOT to HEAR
At night by far (almost all, with rare exceptions) are good Conductor and is Healing, rest is better to listen to, not later than 3-4 hours before bedtime.Фёдор wrote:the Question (preferably) to Andrei Patrushev,
In the morning help to Wake up and energize for the whole day of the 2nd track Star Wanderer and 10-15 minutes of Endorphins. Some "drink" a Massage of the Brain, but then some disk in some cases
Павлум
